06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration GuidesH3C S10500X Switch Series Configuration Guides-Release758X-6W10006-Layer 3 - IP Routing Configuration Guide
11-IPv6 policy-based routing configuration
11-IPv6 policy-based routing configuration 132.53 KB
Configuring IPv6 PBR
Overview
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify the next hop for packets that match specific criteria such as ACLs.
A device forwards received packets using the following process:
1.     The device uses PBR to forward matching packets.
2.     If the packets do not match the PBR policy or the PBR-based forwarding fails, the device uses the routing table, excluding the default route, to forward the packets.
3.     If the routing table-based forwarding fails, the device uses the default route to forward packets.
PBR includes local PBR and interface PBR.
·     Local PBR guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
·     Interface PBR guides the forwarding of packets received on an interface only.
Policy
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
An IPv6 policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, it is forwarded according to the routing table.
if-match clause
IPv6 PBR supports the if-match acl clause, which sets an ACL match criterion.
You can specify only one if-match clause for each node.
apply clause
IPv6 PBR supports the types of apply clauses shown in Table 1. You can specify multiple apply clauses for a node, but some of them might not be executed. The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
Table 1 Priorities and meanings of apply clauses
Clause
Meaning
Priority
apply precedence
Sets an IP precedence.
This clause is always executed.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
Only the apply next-hop clause is executed when both are configured.
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
In permit mode
In deny mode
Yes
·     If the node contains apply clauses, IPv6 PBR executes the apply clauses on the node.
¡     If IPv6 PBR-based forwarding succeeds, IPv6 PBR does not compare the packet with the next node.
¡     If IPv6 PBR-based forwarding fails, IPv6 PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the packet is forwarded according to the routing table.
The packet is forwarded according to the routing table.
No
IPv6 PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
IPv6 PBR and Track
IPv6 PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and IPv6 PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: IPv6 PBR configuration
If a packet destined for the local device matches an IPv6 PBR policy, IPv6 PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure an IPv6 PBR policy, be careful to avoid this situation.
IPv6 PBR configuration task list
Tasks at a glance
(Required.) Configuring an IPv6 policy:
·     Creating an IPv6 node
·     Setting match criteria for an IPv6 node
·     Configuring actions for an IPv6 node
(Required.) Configuring IPv6 PBR:
·     Configuring IPv6 local PBR
·     Configuring IPv6 interface PBR
Step
Remarks
N/A
2.     Create an IPv6 policy or policy node, and enter IPv6 policy node view.
By default, no IPv6 policy node is created.
3.     (Optional.) Configure a description for the IPv6 policy node.
By default, no description is configured for the IPv6 policy node.
Step
Remarks
N/A
2.     Enter IPv6 policy node view.
N/A
3.     Set an ACL match criterion.
By default, no ACL match criterion is set.
If an ACL match criterion is defined, packets are compared with the ACL rules, and the permit or deny action and the time range of the specified ACL are ignored. If the specified ACL does not exist, no packet is matched.
Step
Remarks
N/A
N/A
3.     Set an IP precedence.
By default, no IP precedence is specified.
4.     Set next hops for permitted IPv6 packets.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no next hop is specified.
You can specify two next hops for backup by executing this command twice.
5.     Set output interfaces.
apply output-interface { interface-type interface-number  [ track track-entry-number ] }
By default, no output interface is specified.
Configure IPv6 PBR by applying a policy locally. IPv6 PBR uses the policy to guide the forwarding of locally generated packets. The specified policy must already exist. If the policy does not exist, the IPv6 local PBR configuration fails.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. Do not configure IPv6 local PBR unless doing so is required.
To configure IPv6 local PBR:
Step
Remarks
N/A
2.     Apply a policy locally.
By default, no policy is locally applied.
Configure IPv6 PBR by applying an IPv6 policy to an interface. IPv6 PBR uses the policy to guide the forwarding of IPv6 packets received on the interface. The specified policy must already exist. If the policy does not exist, the IPv6 interface PBR configuration fails.
You can apply only one policy to an interface. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
To configure IPv6 interface PBR:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Apply an IPv6 policy to the interface.
By default, no IPv6 policy is applied to the interface.
Displaying and maintaining IPv6 PBR
Display IPv6 PBR policy information.
Display IPv6 PBR configuration.
display ipv6 policy-based-route setup
(In standalone mode.) Display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
(In IRF mode.) Display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
(In standalone mode.) Display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
(In IRF mode.) Display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
Clear IPv6 PBR statistics.
IPv6 PBR configuration examples
Packet type-based IPv6 local PBR configuration example
Network requirements
As shown in Figure 1, configure IPv6 PBR on Switch A to forward all TCP packets to the next hop 1::2. Switch A forwards other packets according to the routing table.
Figure 1 Network diagram
Configuration procedure
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IPv6 addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ipv6 address 1::1 64
[SwitchA-Vlan-interface20] ipv6 address 2::1 64
# Configure ACL 3001 to match TCP packets.
[SwitchA] acl ipv6 advanced 3001
[SwitchA-acl-ipv6-adv-3001] rule permit tcp
[SwitchA-acl-ipv6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[SwitchA] ipv6 policy-based-route aaa permit node 5
[SwitchA-pbr6-aaa-5] if-match acl 3001
[SwitchA-pbr6-aaa-5] apply next-hop 1::2
[SwitchA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Switch A.
[SwitchA] ipv6 local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IPv6 address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ipv6 address 1::2 64
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IPv6 address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ipv6 address 2::2 64
1.     Perform telnet operations to verify that IPv6 local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20.For example, verify that you can ping Switch C from Switch A. (Details not shown.)
Packet type-based IPv6 interface PBR configuration example
As shown in Figure 2, configure IPv6 PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1::2. Switch A forwards other IPv6 packets according to the routing table.
Figure 2 Network diagram
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure RIPng.
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface10] ripng 1 enable
[SwitchA-Vlan-interface20] ripng 1 enable
# Configure IPv6 interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 10::2 64
[SwitchA-Vlan-interface11] undo ipv6 nd ra halt
[SwitchA-Vlan-interface11] ripng 1 enable
[SwitchA-Vlan-interface11] ipv6 policy-based-route aaa
# Create VLAN 10.
[SwitchB] vlan 10
# Configure RIPng.
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface10] ripng 1 enable
# Create VLAN 20.
[SwitchC] vlan 20
# Configure RIPng.
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface20] ripng 1 enable
[SwitchC-Vlan-interface20] quit
1.     Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
2.     Perform telnet operations to verify that IPv6 interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
3.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
