11-High Availability Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release758X-6W10011-High Availability Configuration Guide
02-CFD configuration
02-CFD configuration 203.90 KB
Configuring CFD
Overview
Connectivity Fault Detection (CFD), which conforms to IEEE 802.1ag Connectivity Fault Management (CFM) and ITU-T Y.1731, is an end-to-end per-VLAN link layer OAM mechanism. CFD is used for link connectivity detection, fault verification, and fault location.
Basic CFD concepts
Maintenance domain
A maintenance domain (MD) defines the network or part of the network where CFD plays its role. An MD is identified by its MD name.
To accurately locate faults, CFD introduces eight levels (from 0 to 7) to MDs. The bigger the number, the higher the level and the larger the area covered. Domains can touch or nest (if the outer domain has a higher level than the nested one) but cannot intersect or overlap.
MD levels facilitate fault location and make fault location more accurate. As shown in Figure 1, MD_A in light blue nests MD_B in dark blue. If a connectivity fault is detected at the boundary of MD_A, any of the devices in MD_A, including Device A through Device E, might fail. If a connectivity fault is also detected at the boundary of MD_B, the failure points can be any of Device B through Device D. If the devices in MD_B can operate correctly, at least Device C is operational.
Figure 1 Two nested MDs
CFD exchanges messages and performs operations on a per-domain basis. By planning MDs correctly in a network, you can use CFD to rapidly locate failure points.
Maintenance association
A maintenance association (MA) is a part of an MD. You can configure multiple MAs in an MD as needed. An MA is identified by the MD name + MA name.
An MA serves the specified VLAN or no VLAN. An MA that serves a VLAN is considered to be carrying VLAN attribute. An MA that serves no VLAN is considered to be carrying no VLAN attribute. An MP can receive packets sent by other MPs in the same MA. The level of an MA equals the level of the MD that the MA belongs to.
Maintenance point
An MP is configured on a port and belongs to an MA. MPs include the following types: maintenance association end points (MEPs) and maintenance association intermediate points (MIPs).
·     MEP
MEPs define the boundary of the MA. Each MEP is identified by a MEP ID.
The MA to which a MEP belongs defines the VLAN of packets sent by the MEP. The level of a MEP equals the level of the MD to which the MEP belongs. The level of packets sent by a MEP equals the level of the MEP.
The level of a MEP determines the levels of packets that the MEP can process. A MEP forwards packets at a higher level and processes packet of its level or lower. The processing procedure is specific to packets in the same VLAN. Packets of different VLANs are independent.
MEPs include inward-facing MEPs and outward-facing MEPs:
¡     An outward-facing MEP sends packets to its host port.
¡     An inward-facing MEP does not send packets to its host port. Rather, it sends packets to other ports on the device.
·     MIP
A MIP is internal to an MA. It cannot send CFD packets actively, but it can handle and respond to CFD packets. By cooperating with MEPs, a MIP can perform a function similar to ping and traceroute. A MIP forwards packets of a different level without any processing and only processes packet of its level.
The MA to which a MIP belongs defines the VLAN of packets that the MIP can receive. The level of a MIP is defined by its generation rule and the MD to which the MIP belongs. MIPs are generated on each port automatically according to the following MIP generation rules:
¡     Default rule—If no lower-level MIP exists on an interface, a MIP is created on the current level. A MIP can be created even if no MEP is configured on the interface.
¡     Explicit rule—If no lower-level MIP exists and a lower-level MEP exists on an interface, a MIP is created on the current level. A MIP can be created only when a lower-level MEP is created on the interface.
If a port has no MIP, the system will check the MAs in each MD (from low to high levels), and follow the procedure as described in Figure 2 to create or not to create MIPs at the current level.
Figure 2 Procedure of creating MIPs
Figure 3 demonstrates a grading example of the CFD module. Four levels of MDs (0, 2, 3, and 5) are designed. The bigger the number, the higher the level and the larger the area covered. MPs are configured on the ports of Device A through Device F. Port 1 of Device B is configured with the following MPs:
·     A level 5 MIP.
·     A level 3 inward-facing MEP.
·     A level 2 inward-facing MEP.
·     A level 0 outward-facing MEP.
Figure 3 CFD grading example
MEP list
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA. It lists all the MEPs configured on different devices in the same MA. The MEPs all have unique MEP IDs. When a MEP receives from a remote device a continuity check message (CCM) carrying a MEP ID not in the MEP list of the MA, it drops the message.
The local device must send CCM messages carrying the Remote Defect Indication (RDI) flag bits. Otherwise, the peer device cannot sense certain failures.
CFD functions
CFD functions, which are implemented through the MPs, include:
·     Continuity check (CC).
·     Loopback (LB).
·     Linktrace (LT).
·     Alarm indication signal (AIS).
·     Loss measurement (LM).
·     Delay measurement (DM).
·     Test (TST).
Continuity check
Connectivity faults are usually caused by device faults or configuration errors. Continuity check examines the connectivity between MEPs. This function is implemented through periodic sending of CCMs by the MEPs. A CCM sent by one MEP is intended to be received by all the other MEPs in the same MA. If a MEP fails to receive the CCMs within 3.5 times the sending interval, the link is considered as faulty and a log is generated. When multiple MEPs send CCMs at the same time, the multipoint-to-multipoint link check is achieved. CCM frames are multicast frames.
Loopback
Similar to ping at the IP layer, loopback verifies the connectivity between a source device and a target device. To implement this function, the source MEP sends loopback messages (LBMs) to the target MEP. Depending on whether the source MEP can receive a loopback reply message (LBR) from the target MEP, the link state between the two can be verified.
LBM frames are multicast and unicast frames. The switch can send and receive unicast LBM frames, and can receive multicast LBM frames but cannot send multicast LBM frames. LBR frames are unicast frames.
Linktrace
Linktrace is similar to traceroute. It identifies the path between the source MEP and the target MP. The source MEP sends the linktrace messages (LTMs) to the target MP. After receiving the messages, the target MP and the MIPs that the LTM frames pass send back linktrace reply messages (LTRs) to the source MEP. Based on the reply messages, the source MEP can identify the path to the target MP. LTM frames are multicast frames and LTRs are unicast frames.
AIS
The AIS function suppresses the number of error alarms reported by MEPs. If a local MEP does not receive any CCM frames from its peer MEP within 3.5 times the CCM transmission interval, it immediately starts sending AIS frames. The AIS frames are sent periodically in the opposite direction of CCM frames. When the peer MEP receives the AIS frames, it suppresses the error alarms locally, and continues to send the AIS frames. If the local MEP receives CCM frames within 3.5 times the CCM transmission interval, it stops sending AIS frames and restores the error alarm function. AIS frames are multicast frames.
LM
The LM function measures the frame loss in a certain direction between a pair of MEPs. The source MEP sends loss measurement messages (LMMs) to the target MEP. The target MEP responds with loss measurement replies (LMRs). The source MEP calculates the number of lost frames according to the counter values of the two consecutive LMRs (the current LMR and the previous LMR). LMMs and LMRs are unicast frames.
DM
The DM function measures frame delays between two MEPs, including the following types:
·     One-way frame delay measurement
The source MEP sends a one-way delay measurement (1DM) frame, which carries the transmission time, to the target MEP. When the target MEP receives the 1DM frame, it does the following:
¡     Records the reception time.
¡     Calculates and records the link transmission delay and jitter (delay variation) according to the transmission time and reception time.
1DM frames are unicast frames.
·     Two-way frame delay measurement
The source MEP sends a delay measurement message (DMM), which carries the transmission time, to the target MEP. When the target MEP receives the DMM, it responds with a delay measurement reply (DMR). The DMR carries the reception time and transmission time of the DMM and the transmission time of the DMR. When the source MEP receives the DMR, it does the following:
¡     Records the DMR reception time.
¡     Calculates the link transmission delay and jitter according to the DMR reception time and DMM transmission time.
DMM frames and DMR frames are unicast frames.
TST
The TST function tests the bit errors between two MEPs. The source MEP sends a TST frame, which carries the test pattern, such as pseudo random bit sequence (PRBS) or all-zero, to the target MEP. When the target MEP receives the TST frame, it determines the bit errors by calculating and comparing the content of the TST frame. TST frames are unicast frames.
EAIS
Ethernet Alarm Indication Signal (EAIS) enables collaboration between the Ethernet port status and the AIS function. When a port on the device (not necessarily an MP) goes down, it immediately starts to send EAIS frames periodically to suppress the error alarms. When the port goes up again, it immediately stops sending EAIS frames. When the MEP receives the EAIS frames, it suppresses the error alarms locally, and continues to send the EAIS frames. If a MEP receives no EAIS frames within 3.5 times the EAIS frame transmission interval, the fault is considered cleared. The port stops sending EAIS frames and restores the error alarm function. EAIS frames are multicast frames.
Protocols and standards
·     IEEE 802.1ag, Virtual Bridged Local Area Networks Amendment 5: Connectivity Fault Management
·     ITU-T Y.1731, OAM functions and mechanisms for Ethernet based networks
·     CFD is not supported on OAP modules. For more information about OAP modules, see OAA Configuration Guide.
·     Do not configure a Layer 2 aggregate interface as an IPP if the following conditions exist:
¡     The Layer 2 aggregate interface exists between an inward-facing MEP and a remote MEP.
¡     The MAC address of the remote MEP is used for CFD functions.
For information about IPPs, see DRNI configuration in Layer 2—LAN Switching Configuration Guide.
CFD configuration task list
For CFD to work correctly, design the network by performing the following tasks:
·     Grade the MDs in the entire network, and define the boundary of each MD.
·     Assign a name for each MD. Make sure that the devices in the same MD use the same MD name.
·     Define the MA in each MD according to the VLAN you want to monitor.
·     Assign a name for each MA. Make sure that the devices in the same MA in the same MD use the same MA name.
·     Determine the MEP list of each MA in each MD. Make sure that devices in the same MA maintain the same MEP list.
·     At the edges of MD and MA, MEPs must be designed at the device port. MIPs can be designed on devices or ports that are not at the edges.
To configure CFD, perform the following tasks:
Tasks at a glance
Configuring basic CFD settings:
·     (Required.) Enabling CFD
·     (Required.) Configuring Ethernet service instances
·     (Required.) Configuring MEPs
·     (Required.) Configuring MIP auto-generation rules
Configuring CFD functions:
·     (Required.) Configuring CC
·     (Optional.) Configuring LB
·     (Optional.) Configuring LT
·     (Optional.) Configuring AIS
·     (Optional.) Configuring LM
·     (Optional.) Configuring one-way DM
·     (Optional.) Configuring two-way DM
·     (Optional.) Configuring TST
(Optional.) Configuring EAIS
Typically, a port blocked by the spanning tree feature cannot receive or send CFD messages except in the following cases:
·     The port is configured as an outward-facing MEP.
·     The port is configured as a MIP or inward-facing MEP, which can still receive and send CFD messages except CCM messages.
For more information about the spanning tree feature, see Layer 2—LAN Switching Configuration Guide.
Enabling CFD
Step
Remarks
N/A
2.     Enable CFD.
cfd enable
By default, CFD is disabled.
Before configuring the MEPs and MIPs, you must first configure Ethernet service instances. An Ethernet service instance is a set of service access points (SAPs), and belongs to an MA in an MD.
The MD and MA define the level attribute and VLAN attribute of the messages handled by the MPs in an Ethernet service instance. The MPs of the MA that carries no VLAN attribute do not belong to any VLAN.
To configure an Ethernet service instance with the MD name:
Step
Remarks
N/A
2.     Create an MD.
cfd md md-name [ index index-value ] level level-value
By default, no MDs exist.
3.     Create an Ethernet service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name | vlan-based [ vlan-id ] } [ ma-index index-value ] md md-name [ vlan vlan-id ]
By default, no Ethernet service instance exists.
Configuring MEPs
CFD is implemented through various operations on MEPs. As a MEP is configured on an Ethernet service instance, the MD level and VLAN attribute of the Ethernet service instance become the attribute of the MEP.
Before creating MEPs, configure the MEP list. A MEP list is a collection of local MEPs that can be configured in an MA and the remote MEPs to be monitored. You cannot create a MEP if the MEP ID is not included in the MEP list of the Ethernet service instance.
You can specify an interface as the MEP for only one of the non-VLAN-specific MAs at the same level. In addition, the MEP must be outward facing.
CFD sets the link state for an interface to down if the following conditions exist:
·     The MEP configured on the interface is in an MA carrying no VLAN attribute.
·     The MEP does not receive any CCM messages from its peer MEP within 3.5 times the CCM transmission interval.
To configure a MEP:
Step
Remarks
N/A
2.     Configure a MEP list.
cfd meplist mep-list service-instance instance-id
By default, no MEP list is configured.
3.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
4.     Create a MEP.
cfd mep mep-id service-instance instance-id { inbound | outbound }
By default, no MEPs are configured.
As functional entities in an Ethernet service instance, MIPs respond to various CFD frames, such as LTM and LBM frames. You can configure MIP auto-generation rules for the system to automatically create MIPs.
Any of the following events can cause MIPs to be created or deleted after you have configured the cfd mip-rule command:
·     Enabling or disabling CFD.
·     Creating or deleting MEPs on a port.
·     Changes occur to the VLAN attribute of a port.
·     The rule specified in the cfd mip-rule command changes.
An MA carrying no VLAN attribute is typically used to detect direct link status. The system cannot generate MIPs for such MAs.
For an MA carrying VLAN attribute, the system does not generate MIPs if the same or a higher level MEP exists on the interface.
To configure the rules for generating MIPs:
Step
Remarks
N/A
2.     Configure MIP auto-generation rules.
cfd mip-rule { default | explicit } service-instance instance-id
By default, no rules for generating MIPs are configured, and the system does not automatically create any MIP.
Configuration prerequisites
Complete basic CFD settings.
Configuring CC
Configure CC before you use the MEP ID of the remote MEP to configure other CFD functions. This restriction does not apply when you use the MAC address of the remote MEP to configure other CFD functions.
After the CC function is configured, MEPs in an MA can periodically send CCM frames to maintain connectivity. When the lifetime of a CCM frame expires, the link to the sending MEP is considered disconnected. When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field
Transmission interval
Maximum CCM lifetime
3
100 milliseconds
350 milliseconds
4
1 second
3.5 seconds
5
10 seconds
35 seconds
6
60 seconds
210 seconds
7
600 seconds
2100 seconds
·     The value range for the interval field value is 3 to 7.
·     The CCM messages with an interval field value of 1 to 3 are short-interval CCM messages. The CCM messages with an interval field value of 4 to 7 are long-interval CCM messages.
Follow these guidelines when you configure CC on a MEP:
·     Configure the same CCM interval field value for all MEPs in the same MA.
·     After the CCM interval field is modified, the MEP must wait for another CCM interval before sending CCMs.
·     Setting the CCM interval field value to smaller than 4 might cause the CC function to operate unsteadily.
·     If the device has multiple cards with auxiliary CPUs, all MEPs on the device send CCM frames through one of these cards. If the sending card is removed, another card takes over to send CCM frames. If all these cards are removed, MEPs with a short CCM interval immediately stop sending CCM frames. MEPs with a long CCM interval send CCM frames through the cards where the MEPs are created.
·     The cards without auxiliary CPUs discard short-interval CCM messages to reduce impact on CPU performance. If your device does not have an auxiliary CPU, configure a long CCM interval for all MEPs.
To configure CC on a MEP:
Step
Remarks
N/A
2.     (Optional.) Set the CCM interval field.
cfd cc interval interval-value service-instance instance-id
By default, the interval field value is 4.
N/A
4.     Enable CCM sending on a MEP.
cfd cc service-instance instance-id mep mep-id enable
By default, CCM sending is disabled on a MEP.
Configuring LB
The LB function can verify the link state between the local MEP and the remote MEP or MIP.
To configure LB on a MEP:
Remarks
Enable LB.
cfd loopback service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
Available in any view.
Configuring LT
LT can trace the path between source and target MEPs, and can locate link faults by automatically sending LT messages. The two functions are implemented in the following way:
·     Tracing path—The source MEP first sends LTM messages to the target MEP. Based on the LTR messages in response to the LTM messages, the path between the two MEPs is identified.
·     LT messages automatic sending—If the source MEP fails to receive CCM frames from the target MEP within 3.5 times the transmission interval, it considers the link faulty. The source MEP then sends LTM frames, with the TTL field set to the maximum value 255, to the target MEP. Based on the returned LTRs, the fault source is located.
IMPORTANT
IMPORTANT:
Before you configure LT on a MEP in an MA carrying VLAN attribute, create the VLAN to which the MA belongs.
To configure LT on MEPs:
Step
Remarks
1.     Identify the path between a source MEP and a target MEP.
cfd linktrace service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ ttl ttl-value ] [ hw-only ]
2.     Enter system view.
N/A
3.     Enable LT messages automatic sending.
cfd linktrace auto-detection [ size size-value ]
By default, LT messages automatic sending is disabled.
Configuring AIS
To make a MEP in the Ethernet service instance send AIS frames, set the AIS frame transmission level to be higher than the MD level of the MEP.
If you enable AIS, the MEPs in an Ethernet service instance cannot send AIS frames in the following conditions:
·     No AIS frame transmission level is configured.
·     The AIS frame transmission level is lower than the MD level of the Ethernet service instance.
If you enable AIS and configure an AIS frame transmission level equal to the MD level of an Ethernet service instance, the MEPs in the Ethernet service instance:
·     Can suppress error alarms.
·     Cannot send AIS frames to MDs with higher level.
To configure AIS:
Step
Remarks
N/A
2.     Enable AIS.
cfd ais enable
By default, AIS is disabled.
3.     Configure the AIS frame transmission level.
cfd ais level level-value service-instance instance-id
By default, the AIS frame transmission level is not configured.
The AIS frame transmission level must be higher than the MD level of the Ethernet service instance.
4.     Configure the AIS frame transmission interval.
cfd ais period period-value service-instance instance-id
By default, the AIS frame transmission interval is 1 second.
Configuring LM
The LM function measures frame loss between MEPs. Frame loss statistics include the number of lost frames, the frame loss ratio, and the average number of lost frames for the source and target MEPs.
To configure LM:
Remarks
Configure LM.
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ dot1p dot1p-value ] [ number number ] [ interval interval ]
The one-way DM function measures the one-way frame delay between two MEPs, and monitors and manages the link transmission performance.
One-way DM requires that the time setting at the transmitting MEP and the receiving MEP be the same. For the purpose of frame delay variation measurement, the requirement can be relaxed.
To view the test result, use the display cfd dm one-way history command on the target MEP.
To configure one-way DM:
Remarks
Configure one-way DM.
cfd dm one-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
The two-way DM function measures the two-way frame delay, average two-way frame delay, and two-way frame delay variation between two MEPs. It also monitors and manages the link transmission performance.
To configure two-way DM:
Remarks
Configure two-way DM.
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } dot1p dot1p-value ] [ number number ] [ interval interval ]
Configuring TST
The TST function detects bit errors on a link, and monitors and manages the link transmission performance.
To view the test result, use the display cfd tst command on the target MEP.
To configure TST:
Remarks
Configure TST.
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
Configuring EAIS
You can configure EAIS on a device that does not support or is not configured with CFD. However, EAIS must collaborate with the CFD function in the network, so you must configure CFD in the network.
To make a port send the EAIS frames, configure port status-AIS collaboration, and configure the correct EAIS frame transmission level and interval. If you only enable port status-EAIS collaboration, but do not configure the EAIS frame transmission level and interval, the port cannot send EAIS frames.
If you do not specify the VLANs where the EAIS frames can be transmitted, the EAIS frames will be transmitted in the default VLAN of the current port. Otherwise, the EAIS frames will be transmitted in the intersection of the following VLANs:
·     Specified VLANs where the EAIS frames can be transmitted.
·     VLANs to which the port belongs.
If you configure EAIS on the member port of an aggregation group, the EAIS configuration does not take effect until the port leaves the aggregation group.
If the intersection of the configured VLANs where the EAIS frames can be transmitted and the VLANs to which the port belongs is empty, no EAIS frame is sent. If the intersection contains more than 70 VLANs and the EAIS frame transmission interval is 1 second, the CPU usage will be too high. As a best practice, set the EAIS frame transmission interval to 60 seconds in this case.
To configure EAIS:
Step
Remarks
N/A
2.     Enable port status-AIS collaboration.
cfd ais-track link-status global
By default, port status-AIS collaboration is disabled.
N/A
4.     Configure the EAIS frame transmission level.
cfd ais-track link-status level level-value
By default, the EAIS frame transmission level is not configured.
5.     Configure the EAIS frame transmission interval.
cfd ais-track link-status period period-value
By default, the EAIS frame transmission interval is not configured.
6.     Specify the VLANs where the EAIS frames can be transmitted.
cfd ais-track link-status vlan vlan-list
By default, the EAIS frames can only be transmitted within the default VLAN of the port.
Displaying and maintaining CFD
Display the AIS configuration and information on the specified MEP.
display cfd ais [ service-instance instance-id [ mep mep-id ] ]
Display the AIS configuration and information associated with the status of the specified port.
display cfd ais-track link-status [ interface interface-type interface-number ]
Display the one-way DM result on the specified MEP.
display cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
Display LTR information received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
Display the content of the LTR messages received as responses to the automatically sent LTMs.
display cfd linktrace-reply auto-detection [ size size-value ]
Display MD configuration information.
display cfd md
Display the attribute and running information of the MEPs.
display cfd mep mep-id service-instance instance-id
Display MEP list in an Ethernet service instance.
display cfd meplist [ service-instance instance-id
Display MP information.
display cfd mp [ interface interface-type interface-number ]
Display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
Display Ethernet service instance configuration information.
display cfd service-instance [ instance-id ]
Display CFD status.
display cfd status
Display the TST result on the specified MEP.
display cfd tst [ service-instance instance-id [ mep mep-id ] ]
Clear the one-way DM result on the specified MEP.
reset cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
Clear the TST result on the specified MEP.
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
CFD configuration example
Network requirements
As shown in Figure 4:
·     The network comprises five devices and is divided into two MDs: MD_A (level 5) and MD_B (level 3). All ports belong to VLAN 100, and the MAs in the two MDs all serve VLAN 100. Assume that the MAC addresses of Device A through Device E are 0010-FC01-6511, 0010-FC02-6512, 0010-FC03-6513, 0010-FC04-6514, and 0010-FC05-6515, respectively.
·     MD_A has three edge ports: GigabitEthernet 1/0/1 on Device A, GigabitEthernet 1/0/3 on Device D, and GigabitEthernet 1/0/4 on Device E. They are all inward-facing MEPs. MD_B has two edge ports: GigabitEthernet 1/0/3 on Device B and GigabitEthernet 1/0/1 on Device D. They are both outward-facing MEPs.
·     In MD_A, Device B is designed to have MIPs when its port is configured with low level MEPs. Port GigabitEthernet 1/0/3 is configured with MEPs of MD_B, and the MIPs of MD_A can be configured on this port. You must configure the MIP generation rule of MD_A as explicit.
·     The MIPs of MD_B are designed on Device C, and are configured on all ports. You must configure the MIP generation rule as default.
·     Configure CC to monitor the connectivity among all the MEPs in MD_A and MD_B. Configure LB to locate link faults, and use the AIS and EAIS functions to suppress the error alarms that are reported.
·     After the status information of the entire network is obtained, use LT, LM, one-way DM, two-way DM, and TST to detect link faults.
Figure 4 Network diagram
Configuration procedure
1.     Configure a VLAN and assign ports to it:
On each device shown in Figure 4, create VLAN 100 and assign ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to VLAN 100.
2.     Enable CFD:
# Enable CFD on Device A.
[DeviceA] cfd enable
# Configure Device B through Device E in the same way Device A is configured. (Details not shown.)
3.     Configure Ethernet service instances:
# Create MD_A (level 5) on Device A, and create Ethernet service instance 1 (in which the MA is identified by a VLAN and serves VLAN 100).
[DeviceA] cfd md MD_A level 5
[DeviceA] cfd service-instance 1 ma-id vlan-based md MD_A vlan 100
# Configure Device E in the same way Device A is configured. (Details not shown.)
# Create MD_A (level 5) on Device B, and create Ethernet service instance 1 (in which the MA is identified by a VLAN and serves VLAN 100).
[DeviceB] cfd md MD_A level 5
[DeviceB] cfd service-instance 1 ma-id vlan-based md MD_A vlan 100
# Create MD_B (level 3), and create Ethernet service instance 2 (in which the MA is identified by a VLAN and serves VLAN 100).
[DeviceB] cfd md MD_B level 3
[DeviceB] cfd service-instance 2 ma-id vlan-based md MD_B vlan 100
# Configure Device D in the same way Device B is configured. (Details not shown.)
# Create MD_B (level 3) on Device C, and create Ethernet service instance 2 (in which the MA is identified by a VLAN and serves VLAN 100).
[DeviceC] cfd md MD_B level 3
[DeviceC] cfd service-instance 2 ma-id vlan-based md MD_B vlan 100
4.     Configure MEPs:
# On Device A, configure a MEP list in Ethernet service instance 1, and create inward-facing MEP 1001 in Ethernet service instance 1 on GigabitEthernet 1/0/1.
[DeviceA] cfd meplist 1001 4002 5001 service-instance 1
[DeviceA-GigabitEthernet1/0/1] cfd mep 1001 service-instance 1 inbound
# On Device B, configure a MEP list in Ethernet service instances 1 and 2.
[DeviceB] cfd meplist 1001 4002 5001 service-instance 1
[DeviceB] cfd meplist 2001 4001 service-instance 2
# Create outward-facing MEP 2001 in Ethernet service instance 2 on GigabitEthernet 1/0/3.
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] cfd mep 2001 service-instance 2 outbound
# On Device D, configure a MEP list in Ethernet service instances 1 and 2.
[DeviceD] cfd meplist 1001 4002 5001 service-instance 1
[DeviceD] cfd meplist 2001 4001 service-instance 2
# Create outward-facing MEP 4001 in Ethernet service instance 2 on GigabitEthernet 1/0/1.
[DeviceD] interface gigabitethernet 1/0/1
[DeviceD-GigabitEthernet1/0/1] cfd mep 4001 service-instance 2 outbound
[DeviceD-GigabitEthernet1/0/1] quit
# Create inward-facing MEP 4002 in Ethernet service instance 1 on GigabitEthernet 1/0/3.
[DeviceD] interface gigabitethernet 1/0/3
[DeviceD-GigabitEthernet1/0/3] cfd mep 4002 service-instance 1 inbound
[DeviceD-GigabitEthernet1/0/3] quit
# On Device E, configure a MEP list in Ethernet service instance 1.
[DeviceE] cfd meplist 1001 4002 5001 service-instance 1
# Create inward-facing MEP 5001 in Ethernet service instance 1 on GigabitEthernet 1/0/4.
[DeviceE] interface gigabitethernet 1/0/4
[DeviceE-GigabitEthernet1/0/4] cfd mep 5001 service-instance 1 inbound
[DeviceE-GigabitEthernet1/0/4] quit
5.     Configure MIPs:
# Configure the MIP generation rule in Ethernet service instance 1 on Device B as explicit.
[DeviceB] cfd mip-rule explicit service-instance 1
# Configure the MIP generation rule in Ethernet service instance 2 on Device C as default.
[DeviceC] cfd mip-rule default service-instance 2
6.     Configure CC:
# On Device A, enable the sending of CCM frames for MEP 1001 in Ethernet service instance 1 on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] cfd cc service-instance 1 mep 1001 enable
# On Device B, enable the sending of CCM frames for MEP 2001 in Ethernet service instance 2 on GigabitEthernet 1/0/3.
[DeviceB-GigabitEthernet1/0/3] cfd cc service-instance 2 mep 2001 enable
# On Device D, enable the sending of CCM frames for MEP 4001 in Ethernet service instance 2 on GigabitEthernet 1/0/1.
[DeviceD-GigabitEthernet1/0/1] cfd cc service-instance 2 mep 4001 enable
# Enable the sending of CCM frames for MEP 4002 in Ethernet service instance 1 on GigabitEthernet 1/0/3.
[DeviceD-GigabitEthernet1/0/3] cfd cc service-instance 1 mep 4002 enable
# On Device E, enable the sending of CCM frames for MEP 5001 in Ethernet service instance 1 on GigabitEthernet 1/0/4.
[DeviceE-GigabitEthernet1/0/4] cfd cc service-instance 1 mep 5001 enable
7.     Configure AIS:
# Enable AIS on Device B. Configure the AIS frame transmission level as 5 and AIS frame transmission interval as 1 second in Ethernet service instance 2.
[DeviceB] cfd ais enable
[DeviceB] cfd ais level 5 service-instance 2
[DeviceB] cfd ais period 1 service-instance 2
8.     Configure EAIS:
# Enable port status-AIS collaboration on Device B.
[DeviceB] cfd ais-track link-status global
# On GigabitEthernet 1/0/3 of Device B, configure the EAIS frame transmission level as 5 and the EAIS frame transmission interval as 60 seconds. Specify the VLANs where the EAIS frames can be transmitted as VLAN 100.
[DeviceB-GigabitEthernet1/0/3] cfd ais-track link-status level 5
[DeviceB-GigabitEthernet1/0/3] cfd ais-track link-status period 60
[DeviceB-GigabitEthernet1/0/3] cfd ais-track link-status vlan 100
1.     Verify the LB function when the CC function detects a link fault:
# Enable LB on Device A to check the status of the link between MEP 1001 and MEP 5001 in Ethernet service instance 1.
[DeviceA] cfd loopback service-instance 1 mep 1001 target-mep 5001
Loopback to MEP 5001 with the sequence number start from 1001-43404:
Reply from 0010-fc05-6515: sequence number=1001-43404 time=5ms
Reply from 0010-fc05-6515: sequence number=1001-43405 time=5ms
Reply from 0010-fc05-6515: sequence number=1001-43406 time=5ms
Reply from 0010-fc05-6515: sequence number=1001-43407 time=5ms
Reply from 0010-fc05-6515: sequence number=1001-43408 time=5ms
Sent: 5        Received: 5        Lost: 0
2.     Verify the LT function after the CC function obtains the status information of the entire network:
# Identify the path between MEP 1001 and MEP 5001 in Ethernet service instance 1 on Device A.
[DeviceA] cfd linktrace service-instance 1 mep 1001 target-mep 5001
Linktrace to MEP 5001 with the sequence number 1001-43462:
MAC address               TTL     Last MAC         Relay action
0010-fc05-6515            63      0010-fc02-6512   Hit
3.     Verify the LM function after the CC function obtains the status information of the entire network:
# Test the frame loss from MEP 1001 to MEP 4002 in Ethernet service instance 1 on Device A.
[DeviceA] cfd slm service-instance 1 mep 1001 target-mep 4002
Reply from 0010-fc04-6514
Far-end frame loss: 10    Near-end frame loss: 20
Far-end frame loss: 40    Near-end frame loss: 40
Far-end frame loss: 0     Near-end frame loss: 10
Far-end frame loss: 30    Near-end frame loss: 30
Average
Far-end frame loss: 20    Near-end frame loss: 25
Far-end frame loss rate: 25.00%    Near-end frame loss rate: 32.00%
Send LMMs: 5        Received: 5        Lost: 0
4.     Verify the one-way DM function after the CC function obtains the status information of the entire network:
# Test the one-way frame delay from MEP 1001 to MEP 4002 in Ethernet service instance 1 on Device A.
[DeviceA] cfd dm one-way service-instance 1 mep 1001 target-mep 4002
5 1DMs have been sent. Please check the result on the remote device.
# Display the one-way DM result on MEP 4002 in Ethernet service instance 1 on Device D.
[DeviceD] display cfd dm one-way history service-instance 1 mep 4002
Service instance: 1
MEP ID: 4002
Sent 1DM total number: 0
Received 1DM total number: 5
Frame delay: 10ms 9ms 11ms 5ms 5ms
Delay average: 8ms
Delay variation: 5ms 4ms 6ms 0ms 0ms
Variation average: 3ms
5.     Verify the two-way DM function after the CC function obtains the status information of the entire network:
# Test the two-way frame delay from MEP 1001 to MEP 4002 in Ethernet service instance 1 on Device A.
[DeviceA] cfd dm two-way service-instance 1 mep 1001 target-mep 4002
Frame delay:
Reply from 0010-fc04-6514: 2406us
Reply from 0010-fc04-6514: 2215us
Reply from 0010-fc04-6514: 2112us
Reply from 0010-fc04-6514: 1812us
Reply from 0010-fc04-6514: 2249us
Average: 2158us
Sent DMMs: 5        Received: 5        Lost: 0
Frame delay variation: 191us 103us 300us 437us
Average: 257us
6.     Verify the TST function after the CC function obtains the status information of the entire network:
# Test the bit errors on the link from MEP 1001 to MEP 4002 in Ethernet service instance 1 on Device A.
[DeviceA] cfd tst service-instance 1 mep 1001 target-mep 4002
5 TSTs have been sent. Please check the result on the remote device.
# Display the TST result on MEP 4002 in Ethernet service instance 1 on Device D.
[DeviceD] display cfd tst service-instance 1 mep 4002
Service instance: 1
MEP ID: 4002
Sent TST total number: 0
Received TST total number: 5
Received from 0010-fc01-6511, Bit True,  sequence number 0
Received from 0010-fc01-6511, Bit True,  sequence number 1
Received from 0010-fc01-6511, Bit True,  sequence number 2
Received from 0010-fc01-6511, Bit True,  sequence number 3
Received from 0010-fc01-6511, Bit True,  sequence number 4
