05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release758X-6W10005-Layer 3 - IP Services Command Reference
10-IP performance optimization commands
10-IP performance optimization commands 172.60 KB
display icmp statistics
Use display icmp statistics to display ICMP statistics.
In standalone mode:
In IRF mode:
display icmp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ICMP statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ICMP statistics for all cards. (In IRF mode.)
ICMP statistics include information about received and sent ICMP packets.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          175                 destination unreachable 0
         source quench 0                   redirects               0
         echo replies  201                 parameter problem       0
         timestamp     0                   information requests    0
         mask requests 0                   mask replies            0
         time exceeded 0                   invalid type            0
         router advert 0                   router solicit          0
         broadcast/multicast echo requests ignored            0
         broadcast/multicast timestamp requests ignored       0
 Output: echo          0                   destination unreachable 0
         echo replies  175                 parameter problem       0
         timestamp     0                   information replies     0
         time exceeded 0                   bad address             0
         packet error  1442                router advert           3
display ip statistics
Use display ip statistics to display IP packet statistics.
In standalone mode:
In IRF mode:
display ip statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IP packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IP packet statistics for all cards. (In IRF mode.)
IP statistics include information about received and sent packets, fragments, and reassembly.
# Display IP packet statistics.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Input
Statistics about received packets:
·     sum—Total number of packets received.
·     local—Total number of packets destined for the device.
·     bad protocol—Total number of unknown protocol packets.
·     bad format—Total number of packets with incorrect format.
·     bad checksum—Total number of packets with incorrect checksum.
·     bad options—Total number of packets with incorrect option.
Output
Statistics about sent packets:
·     forwarding—Total number of packets forwarded.
·     local—Total number of packets locally sent.
·     dropped—Total number of packets discarded.
·     no route—Total number of packets for which no route is available.
·     compress fails—Total number of packets failed to be compressed.
Fragment
Statistics about fragments:
·     input—Total number of fragments received.
·     output—Total number of fragments sent.
·     dropped—Total number of fragments dropped.
·     fragmented—Total number of packets successfully fragmented.
·     couldn't fragment—Total number of packets failed to be fragmented.
Reassembling
Statistics about reassembly:
·     sum—Total number of packets reassembled.
·     timeouts—Total number of reassembly timeouts.
display ip interface
reset ip statistics
display rawip
Use display rawip to display brief information about RawIP connections.
In standalone mode:
In IRF mode:
display rawip [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about RawIP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about RawIP connections for all cards. (In IRF mode.)
Brief RawIP connection information includes local and peer addresses, protocol, and PCB.
# (In standalone mode.) Display brief information about RawIP connections.
<Sysname> display rawip
 Local Addr       Foreign Addr     Protocol  Slot  Cpu PCB
 0.0.0.0          0.0.0.0          1         1     0   0x0000000000000009
 0.0.0.0          0.0.0.0          1         1     0   0x0000000000000008
 0.0.0.0          0.0.0.0          1         5     0   0x0000000000000002
Local Addr
Local IP address.
Foreign Addr
Peer IP address.
Protocol
Protocol number.
PCB
Protocol control block.
display rawip verbose
Use display rawip verbose to display detailed information about RawIP connections.
In standalone mode:
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
In IRF mode:
display rawip verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed RawIP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB. The index is a hexadecimal string in the range of 1 to ffffffffffffffff.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about RawIP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed RawIP connection information for all cards. (In IRF mode.)
The detailed information includes socket creator, state, option, type, protocol number, and the source and destination IP addresses of RawIP connections.
# (In standalone mode.) Display detailed information about RawIP connections.
<Sysname> display rawip verbose
Total RawIP socket number: 1
 Connection info: src = 0.0.0.0, dst = 0.0.0.0
 Creator: ping[320]
 State: N/A
 Options: N/A
 Error: 0
 Type: 3
 Protocol: 1
 Inpcb flags: N/A
 Inpcb extflag: INP_EXTRCVICMPERR INP_EXTFILTER
 Inpcb vflag: INP_IPV4
 TTL: 255(minimum TTL: 0)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Total number of RawIP sockets.
Connection info
Connection information, including source IP address and destination IP address.
Creator
Name of the operation that created the socket. The number in brackets is the process number of the creator.
State of the socket.
Options
Socket options.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/drop/state)
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     drop—Number of dropped packets.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     RCVATMARK—Receiving tag.
¡     N/A—None of the above states.
Sending buffer (cc/hiwat/lowat/state)
Displays send buffer information in the following order:
·     cc—Used space.
Socket type:
·     1SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of the protocol using the socket.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IP options.
·     INP_RECVRETOPTS—Receives replied IP options.
·     INP_RECVDSTADDR—Receives destination IP address.
·     INP_HDRINCL—Provides the entire IP header.
·     INP_REUSEADDR—Reuses the IP address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_RECVIF—Records the input interface of the packet.
·     INP_RECVTTL—Receives TTL of the packet. Only UDP and RawIP support this flag.
·     INP_DONTFRAG—Sets the Don't Fragment flag.
·     INP_ROUTER_ALERT—Receives packets with the router alert option. Only RawIP supports this flag.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_SNDBYLSPV—Sends through MPLS.
·     INP_RECVTOS—Receives TOS of the packet. Only UDP and RawIP support this flag.
·     INP_USEICMPSRC—Uses the specified IP address as the source IP address for outgoing ICMP packets.
·     INP_SYNCPCB—Waits until Internet PCB is synchronized.
·     N/A—None of the above flags.
Inpcb extflag
Extension flags in the Internet PCB:
·     INP_EXTRCVPVCIDX—Records the PVC index of the received packet.
·     INP_RCVPWID—Records the PW ID of the received packet.
·     INP_EXTRCVICMPERR—Receives an ICMP error packet.
·     INP_EXTFILTER—Filters the contents in the received packet.
Inpcb vflag
IP version flags in the Internet PCB:
·     INP_IPV4—IPv4 protocol.
·     INP_TIMEWAIT—In TIMEWAIT state.
·     INP_ONESBCAST—Sends broadcast packets.
·     INP_DROPPED—Protocol dropped flag.
·     INP_SOCKREF—Strong socket reference.
·     INP_DONTBLOCK—Do not block synchronization of the Internet PCB.
TTL
TTL value in the Internet PCB.
Send VRF
VRF from which packets are sent.
Receive VRF
VRF from which packets are received.
display tcp
Use display tcp to display brief information about TCP connections.
In standalone mode:
In IRF mode:
display tcp [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about TCP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about TCP connections for all cards. (In IRF mode.)
Brief TCP connection information includes local IP address, local port number, peer IP address, peer port number, and TCP connection state.
# (In standalone mode.) Display brief information about TCP connections.
<Sysname> display tcp
 *: TCP connection with authentication
 Local Addr:port       Foreign Addr:port     State       Slot  Cpu PCB
*0.0.0.0:21            0.0.0.0:0             LISTEN      1     0   0x000000000000c387
 192.168.20.200:23     192.168.20.14:1284    ESTABLISHED 1     0   0x0000000000000009
 192.168.20.200:23     192.168.20.14:1283    ESTABLISHED 1     0   0x0000000000000002
Indicates that the TCP connection uses authentication.
Local Addr:port
Local IP address and port number.
Foreign Addr:port
Peer IP address and port number.
PCB
PCB index.
display tcp statistics
Use display tcp statistics to display TCP traffic statistics.
In standalone mode:
In IRF mode:
display tcp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays TCP traffic statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays TCP traffic statistics for all cards. (In IRF mode.)
TCP traffic statistics include information about received and sent TCP packets and Syncache/syncookie.
# Display TCP traffic statistics.
<Sysname> display tcp statistics
Received packets:
    Total: 4150
    packets in sequence: 1366 (134675 bytes)
    window probe packets: 0, window update packets: 0
    checksum error: 0, offset error: 0, short error: 0
    packets dropped for lack of memory: 0
    packets dropped due to PAWS: 0
    duplicate packets: 12 (36 bytes), partially duplicate packets: 0 (0 bytes)
    out-of-order packets: 0 (0 bytes)
    packets with data after window: 0 (0 bytes)
    packets after close: 0
    ACK packets: 3531 (795048 bytes)
    duplicate ACK packets: 33, ACK packets for unsent data: 0
Sent packets:
    Total: 4058
    urgent packets: 0
    control packets: 50
    window probe packets: 3, window update packets: 11
    data packets: 3862 (795012 bytes), data packets retransmitted: 0 (0 bytes)
    ACK-only packets: 150 (52 delayed)
    unnecessary packet retransmissions: 0
Syncache/syncookie related statistics:
    entries added to syncache: 12
    syncache entries retransmitted: 0
    duplicate SYN packets: 0
    reply failures: 0
    successfully build new socket: 12
    bucket overflows: 0
    zone failures: 0
    syncache entries removed due to RST: 0
    syncache entries removed due to timed out: 0
    ACK checked by syncache or syncookie failures: 0
    syncache entries aborted: 0
    syncache entries removed due to bad ACK: 0
    syncache entries removed due to ICMP unreachable: 0
    SYN cookies sent: 0
    SYN cookies received: 0
SACK related statistics:
    SACK recoveries: 1
    SACK retransmitted segments: 0 (0 bytes)
    SACK blocks (options) received: 0
    SACK blocks (options) sent: 0
    SACK scoreboard overflows: 0
Other statistics:
    retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
    persist timeout: 0
    keepalive timeout: 21, keepalive probe: 0
    keepalive timeout, so connections disconnected: 0
    fin_wait_2 timeout, so connections disconnected: 0
    initiated connections: 29, accepted connections: 12, established connections:
23
    closed connections: 50051 (dropped: 0, initiated dropped: 0)
    bad connection attempt: 0
    ignored RSTs in the window: 0
    listen queue overflows: 0
    RTT updates: 3518(attempt segment: 3537)
    correct ACK header predictions: 0
    correct data packet header predictions: 568
    resends due to MTU discovery: 0
    packets dropped due to MD5 authentication failure: 0
    packets that passed MD5 authentication: 0
    sent Keychain-encrypted packets: 0
    packets that passed Keychain authentication: 0
    packets dropped due to Keychain authentication failure: 0
reset tcp statistics
display tcp verbose
Use display tcp verbose to display detailed information about TCP connections.
In standalone mode:
In IRF mode:
display tcp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed TCP connection information for the specified PCB. The index is a hexadecimal string in the range of 1 to ffffffffffffffff.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about TCP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed information about TCP connections for all cards. (In IRF mode.)
The detailed TCP connection information includes socket creator, state, option, type, protocol number, source IP address and port number, destination IP address and port number, and connection state.
# (In standalone mode.) Display detailed information about TCP connections.
<Sysname> display tcp verbose
 Connection info: src = 192.168.20.200:179 ,  dst = 192.168.20.14:4181
 NSR standby: N/A
 Creator: bgpd[199]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/state): 0 / 65700 / 1 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65700 / 512 / N/A
 Type: 1
 Protocol: 6
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Send VRF: 0x0
 Receive VRF: 0x0
Table 5 Command output
TCP inpcb number
Number of TCP IP PCBs.
Connection info
Connection information, including source IP address, source port number, destination IP address, and destination port number.
tcpcb number
Number of TCP PCBs. This field is not displayed if the state of the TCP connection is TIME_WAIT.
Creator
Options
Socket options.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/state)
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb extflag
·     INP_EXTDONTDROP—Does not drop the received packet.
Inpcb vflag
TTL
TCP options
TCP options:
·     TF_MD5SIG—Enables MD5 signature.
·     TF_NODELAY—Disables the Nagle algorithm that buffers the sent data inside the TCP.
·     TF_NOOPT—No TCP options.
·     TF_NOPUSH—Forces TCP to delay sending any TCP data until a full sized segment is buffered in the TCP buffers.
·     TF_BINDFOREIGNADDR—Binds the peer IP address.
·     TF_NSR—Enables TCP NSR.
·     TF_REQ_SCALE—Enables the TCP window scale option.
·     TF_REQ_TSTMP—Enables the time stamp option.
·     TF_SACK_PERMIT—Enables the TCP selective acknowledgement option.
·     TF_ENHANCED_AUTH—Enables the enhanced authentication option.
NSR state
State of the TCP connections.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
Send VRF
Receive VRF
display udp
Use display udp to display brief information about UDP connections.
In standalone mode:
In IRF mode:
display udp [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about UDP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about UDP connections for all cards. (In IRF mode.)
Brief UDP connection information includes local IP address and port number, and peer IP address and port number.
# (In standalone mode.) Display brief information about UDP connections.
<Sysname> display udp
 Local Addr:port        Foreign Addr:port     Slot  Cpu PCB
 0.0.0.0:69             0.0.0.0:0             1     0   0x0000000000000003
 192.168.20.200:1024    192.168.20.14:69      5     0   0x0000000000000002
Table 6 Command output
Local Addr:port
Foreign Addr:port
PCB
PCB index.
display udp statistics
Use display udp statistics to display UDP traffic statistics.
In standalone mode:
In IRF mode:
display udp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays UDP traffic statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays UDP traffic statistics for all cards. (In IRF mode.)
UDP traffic statistics include information about received and sent UDP packets.
# Display UDP traffic statistics.
<Sysname> display udp statistics
Received packets:
     Total: 240
     checksum error: 0, no checksum: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port(unicast): 0
     no socket on port(broadcast/multicast): 240
     not delivered, input socket full: 0
Sent packets:
     Total: 0
reset udp statistics
display udp verbose
Use display udp verbose to display detailed information about UDP connections.
In standalone mode:
In IRF mode:
display udp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed UDP connection information for the specified PCB. The index is a hexadecimal string in the range of 1 to ffffffffffffffff.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about UDP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed information about UDP connections for all cards. (In IRF mode.)
The detailed information includes socket creator, status, option, type, protocol number, source IP address and port number, and destination IP address and port number for UDP connections.
# (In standalone mode.) Display detailed UDP connection information.
<Sysname> display udp verbose
Total UDP socket number: 1
 Connection info: src = 0.0.0.0:69, dst = 0.0.0.0:0
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Type: 2
 Protocol: 17
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 7 Command output
Total number of UDP sockets.
Connection info
Creator
Socket state.
Options
Socket option.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb extflag
Inpcb vflag
TTL
Send VRF
Receive VRF
ip forward-broadcast
Use ip forward-broadcast to enable an interface to forward directed broadcast packets destined for the directly connected network.
Use undo ip forward-broadcast to disable an interface from forwarding directed broadcast packets destined for the directly connected network.
ip forward-broadcast [ acl acl-number ]
An interface cannot forward directed broadcasts destined for the directly connected network.
Interface view
acl acl-number: Specifies an ACL by its number. The interface forwards only the directed broadcasts permitted by the ACL. The value range for basic ACLs is 2000 to 2999. The value range for advanced ACLs is 3000 to 3999.
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
If an interface is allowed to forward directed broadcasts destined for the directly connected network, hackers can exploit this vulnerability to attack the target network. In some scenarios, however, an interface must send such directed broadcast packets to support UDP helper and Wake on LAN.
The command enables the interface to forward directed broadcast packets that are destined for the directly connected network and are received from another subnet to support Wake on LAN. Wake on LAN sends the directed broadcasts to wake up the hosts on the target network.
# Enable VLAN-interface 2 to forward directed broadcast packets destined for the directly connected network.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp error-interval
Use ip icmp error-interval to set the interval for tokens to arrive in the bucket and the bucket size for ICMP error messages.
Use undo ip icmp error-interval to restore the default.
A token is placed in the bucket every 100 milliseconds, and the bucket allows a maximum of 10 tokens.
interval: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds. To disable the ICMP rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200.
This command limits the rate at which ICMP error messages are sent. Use this command to avoid sending excessive ICMP error messages within a short period that might cause network congestion. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
# Set the interval to 200 milliseconds for tokens to arrive in the bucket and the bucket size to 40 tokens for ICMP error messages.
[Sysname] ip icmp error-interval 200 40
ip icmp fragment discarding
Use ip icmp fragment discarding to disable forwarding of ICMP fragments.
Use undo ip icmp fragment discarding to enable forwarding of ICMP fragments.
Forwarding of ICMP fragments is enabled.
Disabling forwarding of ICMP fragments can prevent ICMP fragment attacks.
# Disable forwarding of ICMP fragments.
[Sysname] ip icmp fragment discarding
ip icmp source
Use ip icmp source to specify the source address for outgoing ICMP packets.
Use undo ip icmp source to remove the specified source address for outgoing ICMP packets.
undo ip icmp source [ vpn-instance vpn-instance-name ]
No source address is specified for outgoing ICMP packets. The device uses the IP address of the sending interface as the source IP address for outgoing ICMP packets.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the specified address belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If you do not specify a VPN instance, the ip-address argument specifies an IP address on the public network.
ip-address: Specifies an IP address.
It is a good practice to specify the IP address of the loopback interface as the source IP address for outgoing ping echo request and ICMP error messages. This feature helps users to locate the sending device easily.
# Specify 1.1.1.1 as the source address for outgoing ICMP packets.
[Sysname] ip icmp source 1.1.1.1
ip mtu
Use ip mtu to set the interface MTU for IPv4 packets. The setting defines the largest size of an IPv4 packet that an interface can transmit without fragmentation.
Use undo ip mtu to restore the default.
ip mtu mtu-size
undo ip mtu
The interface MTU is not set.
Interface view
mtu-size: Specifies the MTU in bytes. The value range for the mtu-size argument varies by card type.
When a packet exceeds the MTU of the sending interface, the device processes the packet in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set an appropriate MTU to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments a packet based on the MTU set by the ip mtu command.
# Set the interface MTU for IPv4 packets to 1280 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] ip mtu 1280
ip reassemble local enable
Use ip reassemble local enable to enable IPv4 local fragment reassembly.
Use undo ip reassemble local enable to disable local fragment reassembly.
IPv4 local fragment reassembly is disabled.
Use this feature on a device to improve fragment reassembly efficiency. This feature enables the LPU to reassemble the IPv4 fragments of a packet if all the fragments arrive at it. If this feature is disabled, all IPv4 fragments are delivered to the active MPU for reassembly. The feature applies only to fragments received by the same LPU.
# Enable IPv4 local fragment reassembly.
[Sysname] ip reassemble local enable
ip redirects enable
Use ip redirects enable to enable sending ICMP redirect messages.
Use undo ip redirects enable to disable sending ICMP redirect messages.
ip redirects enable
Sending ICMP redirect messages is disabled.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing tables.
A host that has only one route destined for the default gateway sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop by following these rules:
·     The receiving and sending interfaces are the same.
·     The selected route is not created or modified by any ICMP redirect messages.
·     The selected route is not destined for 0.0.0.0.
·     There is no source route option in the received packet.
# Enable sending ICMP redirect messages.
[Sysname] ip redirects enable
ip ttl-expires enable
Use ip ttl-expires enable to enable sending ICMP time exceeded messages.
Use undo ip ttl-expires enable to disable sending ICMP time exceeded messages.
Sending ICMP time exceeded messages is disabled.
A device sends ICMP time exceeded messages by following these rules:
·     The device sends an ICMP TTL exceeded in transit message to the source when the following conditions are met:
¡     The received packet is not destined for the device.
¡     The TTL field of the packet is 1.
·     When the device receives the first fragment of an IP datagram destined for the device itself, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
A device disabled from sending ICMP time exceeded messages does not send ICMP TTL exceeded in transit messages but can still send ICMP fragment reassembly time exceeded messages.
# Enable sending ICMP time exceeded messages.
[Sysname] ip ttl-expires enable
ip unreachables enable
Use ip unreachables enable to enable sending ICMP destination unreachable messages.
Use undo ip unreachables enable to disable sending ICMP destination unreachable messages.
Sending ICMP destination unreachable messages is disabled.
A device sends ICMP destination unreachable messages by following these rules:
·     The device sends the source an ICMP network unreachable message when the following conditions are met:
¡     The received packet does not match any route.
¡     No default route exists in the routing table.
·     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡     The received packet is destined for the device.
¡     The transport layer protocol of the packet is not supported by the device.
·     The device sends the source an ICMP port unreachable message when the following conditions are met:
¡     The received UDP packet is destined for the device.
¡     The packet's port number does not match the running process.
·     The device sends the source an ICMP source route failed message when the following conditions are met:
¡     The source uses Strict Source Routing to send packets.
¡     The intermediate device finds that the next hop specified by the source is not directly connected.
·     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡     The MTU of the sending interface is smaller than the packet.
¡     The packet has Don't Fragment set.
# Enable sending ICMP destination unreachable messages.
[Sysname] ip unreachables enable
reset ip statistics
Use reset ip statistics to clear IP traffic statistics.
In standalone mode:
In IRF mode:
reset ip statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears IP traffic statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears IP traffic statistics for all cards. (In IRF mode.)
Use this command to clear history IP traffic statistics before you collect IP traffic statistics for a time period.
# Clear IP traffic statistics.
<Sysname> reset ip statistics
Use reset tcp statistics to clear TCP traffic statistics.
# Clear TCP traffic statistics.
<Sysname> reset tcp statistics
Use reset udp statistics to clear UDP traffic statistics.
# Clear UDP traffic statistics.
<Sysname> reset udp statistics
tcp mss
Use tcp mss to set the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The TCP MSS is not set.
Interface view
value: Specifies the TCP MSS in bytes. The minimum value is 128 bytes. The maximum value equals the maximum MTU that the interface supports minus 40.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, TCP fragments the segment according to the receiver's MSS.
If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
This configuration is effective only on IP packets. If MPLS is enabled on the interface, do not set the TCP MSS on the interface.
# Set the TCP MSS to 300 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] tcp mss 300
tcp path-mtu-discovery
Use tcp path-mtu-discovery to enable TCP path MTU discovery.
Use undo tcp path-mtu-discovery to disable TCP path MTU discovery.
TCP path MTU discovery is disabled.
aging age-time: Specifies the aging time for the path MTU, in the range of 10 to 30 minutes. The default aging time is 10 minutes.
no-aging: Does not age out the path MTU.
After you enable TCP path MTU discovery, all new TCP connections detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
After you disable TCP path MTU discovery, the system stops all path MTU timers. The TCP connections established later do not detect the path MTU, but the TCP connections previously established still can detect the path MTU.
# Enable TCP path MTU discovery and set the path MTU aging time to 20 minutes.
[Sysname] tcp path-mtu-discovery aging 20
tcp syn-cookie enable
Use tcp syn-cookie enable to enable SYN Cookie to protect the device from SYN flood attacks.
Use undo tcp syn-cookie enable to disable SYN Cookie.
SYN Cookie is disabled.
A TCP connection is established through a three-way handshake:
1.     The sender sends a SYN packet to the server.
2.     The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3.     The sender receives the SYN ACK packet and replies with an ACK packet. Then, a TCP connection is established.
An attacker can exploit this mechanism to mount SYN flood attacks. The attacker sends a large number of SYN packets, but they do not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and cannot handle normal services.
SYN Cookie can protect the server from SYN flood attacks. When the server receives a SYN packet, it responds to the request with a SYN ACK packet without establishing a TCP semi-connection.
The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the sender.
# Enable SYN Cookie.
[Sysname] tcp syn-cookie enable
tcp timer fin-timeout
Use tcp timer fin-timeout to set the TCP FIN wait timer.
Use undo tcp timer fin-timeout to restore the default.
The TCP FIN wait timer is 675 seconds.
time-value: Specifies the TCP FIN wait timer in the range of 76 to 3600 seconds.
TCP starts the FIN wait timer when the state of a TCP connection changes to FIN_WAIT_2. If no FIN packet is received within the timer interval, the TCP connection is terminated.
If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer and tears down the connection when the timer expires.
# Set the TCP FIN wait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
tcp timer syn-timeout
Use tcp timer syn-timeout to set the TCP SYN wait timer.
Use undo tcp timer syn-timeout to restore the default.
The TCP SYN wait timer is 75 seconds.
time-value: Specifies the TCP SYN wait timer in the range of 2 to 600 seconds.
TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
# Set the TCP SYN wait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp timestamps enable
Use tcp timestamps enable to enable the device to encapsulate the TCP Timestamps option in outgoing TCP packets.
Use undo tcp timestamps enable to disable the device from encapsulating the TCP Timestamps option in outgoing TCP packets.
The TCP Timestamps option is encapsulated in outgoing TCP packets.
Devices at each end of the TCP connection can calculate the RTT value by using the TCP Timestamps option carried in TCP packets. For security purpose in some networks, you can disable the TCP Timestamps option encapsulation at one end of the TCP connection to prevent intermediate devices from obtaining the option information.
This command takes effect only on new connections that are established after you execute the command. Existing TCP connections are not affected.
# Enable the device to encapsulate the TCP Timestamps option in outgoing TCP packets.
[Sysname] undo tcp timestamps enable
tcp window
Use tcp window to set the size of the TCP receive/send buffer.
Use undo tcp window to restore the default.
tcp window window-size
undo tcp window
The size of the TCP receive/send buffer is 63 KB.
window-size: Specifies the size of the TCP receive/send buffer, in the range of 1 to 64 KB.
# Set the size of the TCP receive/send buffer to 3 KB.
[Sysname] tcp window 3
