09-High Availability Configuration Guide
HomeSupportSwitchesH3C S5130 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5130-HI Switch Series Configuration Guides-Release 1312-6W10109-High Availability Configuration Guide
09-BFD configuration
09-BFD configuration 75.69 KB
Configuring BFD
Overview
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of links in IP to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
BFD can be used for single-hop and multihop detections.
·          Single-hop detection—Detects the IP connectivity between two directly connected systems.
·          Multihop detection—Detects any of the paths between two systems. These paths have multiple hops, and might overlap.
BFD session establishment and termination
Establishing a BFD session
BFD does not provide any neighbor discovery mechanisms. The upper protocol notifies BFD of the routers to which it needs to establish sessions.
A BFD session is established as follows:
1.        A protocol sends Hello messages to discover neighbors and establish neighborships.
2.        After establishing a neighborship, the protocol notifies BFD of the neighbor information, including destination and source addresses.
3.        BFD uses the information to establish a BFD session.
Terminating a BFD session
When BFD detects a link failure, it performs the following tasks:
1.        BFD clears the neighbor session.
2.        BFD notifies the protocol of the failure.
3.        The protocol terminates the neighborship on the link.
4.        If a backup link is available, the protocol will use it for communication.
BFD session modes and operating modes
BFD sessions use the following types of packets:
·          Echo packets—Encapsulated into UDP packets with port number 3785.
·          Control packets—Encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
Echo packet mode
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end.
In echo packet mode, BFD supports only single-hop detection and the BFD session is independent of the operating mode.
Control packet mode
Both ends of the link exchange BFD control packets to monitor link status.
Before a BFD session is established, BFD has two operating modes—active and passive.
·          Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·          Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
After a BFD session is established, the two ends can operate in the following BFD operating modes:
·          Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
·          Demand mode—The device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
In addition, both ends of the link can exchange BFD control packets to establish and maintain BFD sessions, and one end of the link sends echo packets to monitor link status.
Supported features
·          Static routing. For more information, see Layer 3—IP Routing Configuration Guide.
·          IPv6 static routing. For more information, see Layer 3—IP Routing Configuration Guide.
·          RIP. For more information, see Layer 3—IP Routing Configuration Guide.
·          OSPF. For more information, see Layer 3—IP Routing Configuration Guide.
·          OSPFv3. For more information, see Layer 3—IP Routing Configuration Guide.
·          IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
·          IPv6 IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
·          BGP. For more information, see Layer 3—IP Routing Configuration Guide.
·          IPv6 BGP. For more information, see Layer 3—IP Routing Configuration Guide.
·          PIM. For more information, see IP Multicast Configuration Guide.
·          IPv6 PIM. For more information, see IP Multicast Configuration Guide.
·          Track. For more information, see "Configuring Track."
·          IP fast reroute (FRR). IP FRR is supported by BGP, OSPF, RIP, IS-IS, and static routing. For more information, see Layer 3—IP Routing Configuration Guide.
·          Ethernet link aggregation. For more information, see Layer 2—LAN Switching Configuration Guide.
Protocols and standards
·          RFC 5880, Bidirectional Forwarding Detection (BFD)
·          RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·          RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·          RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·          RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
Configuring BFD basic functions
Before configuring BFD basic functions, configure the network layer addresses of the interfaces so that adjacent nodes are reachable to each other at the network layer.
After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
BFD session flapping might occur on an aggregate interface with member ports on different IRF member devices. When the master device, which receives and sends BFD packets, is removed or restarted, a subordinate device might not immediately take over. For example, a subordinate device will not take over when the subordinate device has a short detection time or a large number of BFD sessions.
By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
Configuring echo packet mode
CAUTION
CAUTION:
To avoid echo packet loss, do not configure the echo packet mode on a device with uRPF enabled. For more information about uRPF, see Security Configuration Guide.
To configure echo packet mode:
Step
Remarks
1.       Enter system view.
N/A
2.       Configure the source IP address of echo packets.
·         Configure the source IP address of echo packets:
bfd echo-source-ip ip-address
·         Configure the source IPv6 address of echo packets:
By default, no source IP address is configured for echo packets.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
The source IPv6 address of echo packets can only be a global unicast address.
3.       Enter interface view.
N/A
4.       (Optional.) Set the minimum interval for receiving BFD echo packets.
By default, the minimum interval for receiving BFD echo packets is 400 milliseconds.
5.       (Optional.) Set the single-hop detection time multiplier.
bfd detect-multiplier value
The default setting is 5.
Configuring control packet mode
To configure control packet mode for single-hop detection:
Step
Remarks
N/A
2.       Specify the mode for establishing a BFD session.
By default, active is specified.
BFD version 0 does not support this command. The configuration does not take effect.
N/A
4.       Configure the authentication mode for single-hop control packets.
bfd authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, single-hop BFD packets are not authenticated.
5.       Enable the Demand BFD session mode.
bfd demand enable
By default, the BFD session is in Asynchronous mode.
6.       Enable the echo packet mode.
By default, the echo packet mode is disabled.
Configure this command for BFD sessions in which control packets are sent. When you enable the echo packet mode for such a session in up state, BFD periodically sends echo packets to detect link connectivity and decrease control packet receive rate.
7.       Set the minimum interval for transmitting single-hop BFD control packets.
By default, the minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
8.       Set the minimum interval for receiving single-hop BFD control packets.
By default, the minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
9.       Set the single-hop detection time multiplier.
10.     Create a BFD session for detecting the local interface state.
bfd detect-interface source-ip ip-address
By default, no BFD session is created for detecting the local interface state.
To configure control packet mode for multihop detection:
Step
Remarks
N/A
3.       Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication is performed.
4.       Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
5.       Set the multihop detection time multiplier.
6.       Set the minimum interval for receiving multihop BFD control packets.
By default, the minimum interval for receiving multihop BFD control packets is 400 milliseconds.
7.       Set the minimum interval for transmitting multihop BFD control packets.
By default, the minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
Configuring a BFD template
Perform this task to specify BFD parameters in a template for sessions without next hops. You can configure BFD parameters for LSPs and PWs through a BFD template.
To configure a BFD template:
Step
Remarks
N/A
2.       Create a BFD template and enter BFD template view.
bfd template template-name
By default, no BFD templates exist.
3.       Configure the authentication mode for BFD control packets.
4.       Set the detection time multiplier.
5.       Set the minimum interval for receiving BFD control packets.
By default, the minimum interval for receiving BFD control packets is 400 milliseconds.
6.       Set the minimum interval for transmitting BFD control packets.
By default, the minimum interval for transmitting BFD control packets is 400 milliseconds.
Enabling SNMP notifications for BFD
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
To enable SNMP notifications for BFD:
Step
Remarks
N/A
2.       Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
Displaying and maintaining BFD
Execute the display command in any view and the reset command in user view.
Display BFD session information.
display bfd session [ discriminator value | verbose ]
Clear BFD session statistics.
reset bfd session statistics
