00-Preface | 103.01 KB |
Preface
This configuration guide describes the virtualization technologies including Intelligent Resilient Framework (IRF) and Multitenant Device Context (MDC). IRF virtualizes multiple physical devices into one logical device, enabling simplified network topology, node-level high availability, and efficient and easy management. MDC partitions one physical device into multiple logical devices that run independently to forward traffic with dedicated software and hardware resources that are inaccessible to each other.
· Audience
Audience
· Network planners.
· Network administrators working with the S12500-X & S12500X-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
