- 05-Layer 3 - IP Routing Configuration Examples
- 01-H3C_BGP_Configuration_Examples
- 02-H3C_BGP_Route_Selection_Configuration_Examples
- 03-H3C_IPv6_IS-IS_Configuration_Examples
- 04-H3C_IS-IS_Configuration_Examples
- 05-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 06-H3C_OSPFv3_Configuration_Examples
- 07-H3C_OSPF_Configuration_Examples
- 08-H3C_Policy-Based_Routing_Configuration_Examples
- 09-H3C_Routing_Policy_Configuration_Examples
| 05-H3C_IS-IS_Route_Summarization_Configuration_Examples | 93.25 KB |
H3C IS-IS Route Summarization Configuration Examples
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Example: Configuring IS-IS route summarization
Configuring IP addresses for interfaces
Introduction
This document provides IS-IS route summarization configuration examples.
This document assumes that you have basic knowledge of IS-IS route summarization.
As shown in Figure 1, the five departments of a company use IS-IS to connect to the backbone network. The five departments are assigned the networks 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24, 192.168.4.0/24, and 192.168.5.0/24. Configure IS-IS route summarization to reduce routing entries and save system resources for Device B.
Analysis
Configure route summarization on Device A because route summarization applies only to locally generated LSPs.
To avoid blackhole routes, set the summary route to 192.168.0.0/21.
Software versions used
This configuration example was created and verified on S10500X-CMW710-R7557.
Procedures
# Configure an IP address for the interface VLAN-interface 10 on Device A.
[DeviceA-Vlan-interface10] ip address 172.16.1.2 24
# Configure IP addresses for other interfaces as shown in Figure 1 in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring basic IS-IS
Configuring Device A
# Enable IS-IS on Device A and configure Device A as a Level-1-2 router.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] is-level level-1-2
[DeviceA-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 10.
[DeviceA–Vlan-interface10] isis enable 1
[DeviceA–Vlan-interface10] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring Device B
# Enable IS-IS on Device B and configure Device B as a Level-2 router.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 10.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 10
[DeviceB–Vlan-interface10] isis enable 1
[DeviceB–Vlan-interface10] quit
Configuring the gateways
# Enable IS-IS on GW 1 and configure GW 1 as a Level-1 router.
[GW1] isis 1
[GW1-isis-1] network-entity 10.0001.0001.0001.00
[GW1-isis-1] is-level level-1
[GW1-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 11.
[GW1] interface vlan-interface 11
[GW1–Vlan-interface11] isis enable 1
[GW1–Vlan-interface11] quit
# Configure other gateways in the same way GW 1 is configured. (Details not shown.)
Displaying IS-IS routing information on Device B
# Display IS-IS routing information on Device B to view the network address of each department.
[DeviceB] display isis route
Level-2 IPv4 Forwarding Table
IPv4 Destination IntCost ExtCost ExitInterface NextHop Flags
192.168.1.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.1.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.2.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.2.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.3.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.3.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.4.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.4.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.5.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.5.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
172.16.1.0/24 10 NULL GE3/0/1 Direct D/L/-
# Configure IS-IS route summarization on Device A.
[DeviceA] isis 1
[DeviceA-isis-1]address-family ipv4
[DeviceA-isis-1-ipv4]summary 192.168.0.0 21
# Display IS-IS routing information on Device B.
192.168.0.0/21 30 NULL GE3/0/1 172.16.1.1 R/-/-
The output shows that the networks have been summarized into a single network 192.168.0.0/21.
Configuration files
· Device A:
isis 1
address-family ipv4 unicast
summary 192.168.0.0 255.255.248.0
vlan 10
vlan 101 to 105
interface vlan-interface10
ip address 172.16.1.1 255.255.255.0
isis enable 1
interface vlan-interface101
isis enable 1
interface vlan-interface102
ip address 10.1.2.1 255.255.255.0
isis enable 1
interface vlan-interface103
ip address 10.1.3.1 255.255.255.0
isis enable 1
interface vlan-interface104
ip address 10.1.4.1 255.255.255.0
isis enable 1
interface vlan-interface105
ip address 10.1.5.1 255.255.255.0
isis enable 1
· Device B:
isis 1
is-level level-2
vlan 10
ip address 172.16.1.2 255.255.255.0
isis enable 1
· GW 1:
isis 1
is-level level-1
vlan 11
vlan 101
isis enable 1
interface vlan-interface11
isis enable 1
· The configuration files for other gateways are similar to the configuration file for GW 1. (Details not shown.)
Related documentation
· H3C S10500X Switch Series Layer 3—IP Routing Command Reference-R7557
· H3C S10500X Switch Series Layer 3—IP Routing Configuration Guide-R7557
