12-OpenFlow Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5560S-EI&S5560S-SI&S5500V3-SI Switch Series Command References-R612x-6W10212-OpenFlow Command Reference
Table of Contents
Related Documents
00-Preface
00-Preface 80.85 KB
Preface
This command reference describes the OpenFlow configuration commands.
·          Audience
·          Conventions
·          Documentation feedback
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
