11-Security Configuration Guide
HomeSupportNFVH3C VSRConfigure & DeployConfiguration GuidesH3C VSR Series Virtual Services Routers Configuration Guides(V7)-R0618-5W20011-Security Configuration Guide
11-SSH configuration
11-SSH configuration 596.19 KB
Configuring SSH·· 1
About SSH· 1
SSH applications· 1
How SSH works· 1
SSH authentication methods· 2
SSH support for Suite B· 3
FIPS compliance· 3
Configuring the device as an SSH server 4
SSH server tasks at a glance· 4
Generating local key pairs· 4
Specifying the SSH service port 5
Enabling the Stelnet server 5
Enabling the SFTP server 6
Enabling the SCP server 6
Enabling NETCONF over SSH· 6
Configuring the user lines for SSH login· 7
Configuring a client's host public key· 7
Configuring an SSH user 8
Configuring the SSH management parameters· 9
Specifying a PKI domain for the SSH server 11
Configuring the device as an Stelnet client 12
Stelnet client tasks at a glance· 12
Generating local key pairs· 12
Specifying the source IP address for outgoing SSH packets· 12
Establishing a connection to an Stelnet server 13
Establishing a connection to an Stelnet server based on Suite B· 15
Configuring the device as an SFTP client 15
SFTP client tasks at a glance· 15
Generating local key pairs· 15
Specifying the source IP address for outgoing SFTP packets· 16
Establishing a connection to an SFTP server 16
Establishing a connection to an SFTP server based on Suite B· 18
Working with SFTP directories· 18
Working with SFTP files· 19
Displaying help information· 20
Terminating the connection with the SFTP server 20
Configuring the device as an SCP client 20
SCP client tasks at a glance· 20
Generating local key pairs· 21
Establishing a connection to an SCP server 21
Establishing a connection to an SCP server based on Suite B· 23
Specifying algorithms for SSH2· 23
About algorithms for SSH2· 23
Specifying key exchange algorithms for SSH2· 23
Specifying public key algorithms for SSH2· 24
Specifying encryption algorithms for SSH2· 24
Specifying MAC algorithms for SSH2· 25
Display and maintenance commands for SSH· 25
Stelnet configuration examples· 25
Example: Configuring the device as an Stelnet server (password authentication) 26
Example: Configuring the device as an Stelnet server (publickey authentication) 28
Example: Configuring the device as an Stelnet client (password authentication) 34
Example: Configuring the device as an Stelnet client (publickey authentication) 37
Example: Configuring Stelnet based on 128-bit Suite B algorithms· 40
SFTP configuration examples· 44
Example: Configuring the device as an SFTP server (password authentication) 44
Example: Configuring the device as an SFTP client (publickey authentication) 46
Example: Configuring SFTP based on 192-bit Suite B algorithms· 49
SCP configuration examples· 53
Example: Configuring SCP with password authentication· 53
Example: Configuring SCP based on Suite B algorithms· 55
NETCONF over SSH configuration examples· 62
Example: Configuring NETCONF over SSH with password authentication· 62
Configuring SSH
About SSH
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
SSH applications
The device supports the following SSH applications:
·           Secure Telnet—Stelnet provides secure and reliable network terminal access services. Through Stelnet, a user can securely log in to a remote server. Stelnet can protect devices against attacks, such as IP spoofing and plain text password interception. The device can act as an Stelnet server or an Stelnet client.
·           Secure File Transfer Protocol—Based on SSH2, SFTP uses SSH connections to provide secure file transfer. The device can act as an SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also act as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
·           Secure Copy—Based on SSH2, SCP offers a secure method to copy files. The device can act as an SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote device for secure file transfer.
·           NETCONF over SSH—Based on SSH2, it enables users to securely log in to the device through SSH and perform NETCONF operations on the device through the NETCONF-over-SSH connections. The device can act only as a NETCONF-over-SSH server. For more information about NETCONF, see Network Management and Monitoring Configuration Guide.
When acting as an SSH server or client, the device supports the following SSH versions:
·           When acting as an Stelnet, SFTP, or SCP server, the device supports both SSH2 and SSH1 in non-FIPS mode and only SSH2 in FIPS mode.
·           When acting as an SSH client, the device supports only SSH2.
·           When acting as a NETCONF-over-SSH server, the device supports only SSH2.
How SSH works
This section uses SSH2 as an example to describe the stages to establish an SSH session.
Table 1 Stages to establish an SSH session
Stages
Connection establishment
The SSH server listens to connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection.
Version negotiation
The two parties determine a version to use.
Algorithm negotiation
SSH supports multiple algorithms. Based on the local algorithms, the two parties negotiate the following algorithms:
·          Key exchange algorithm for generating session keys.
·          Encryption algorithm for encrypting data.
·          Public key algorithm for the digital signature and authentication.
·          HMAC algorithm for protecting data integrity.
Key exchange
The two parties use the DH exchange algorithm to dynamically generate the session keys and session ID.
·          The session keys are used for protecting data transfer.
·          The session ID is used for identifying the SSH connection.
In this stage, the client also authenticates the server.
Authentication
The SSH server authenticates the client in response to the client's authentication request.
Session request
After passing the authentication, the client sends a session request to the server to request the establishment of a session (or request the Stelnet, SFTP, SCP, or NETCONF service).
Interaction
After the server grants the request, the client and the server start to communicate with each other in the session.
In this stage, you can paste commands in text format and execute them at the CLI. The text pasted at one time must be no more than 2000 bytes. As a best practice to ensure the correct execution of commands, paste commands that are in the same view.
To execute commands of more than 2000 bytes, save the commands in a configuration file, upload the file to the server through SFTP, and use it to restart the server.
This section describes authentication methods that are supported by the device when it acts as an SSH server.
Password authentication
The SSH server authenticates a client through the AAA mechanism. The password authentication process is as follows:
1.      The client sends the server an authentication request that includes the encrypted username and password.
2.      The server performs the following operations:
a.    Decrypts the request to get the username and password in plain text.
b.    Verifies the username and password locally or through remote AAA authentication.
c.    Informs the client of the authentication result.
If the remote AAA server requires the user to enter a password for secondary authentication, it send the SSH server an authentication response carrying a prompt. The prompt is transparently transmitted to the client to notify the user to enter a specific password. When the user enters the correct password, the AAA sever examines the password validity. If the password is valid, the SSH server returns an authentication success message to the client.
SSH1 clients do not support secondary password authentication initiated by the AAA server.
For more information about AAA, see "Configuring AAA."
Publickey authentication
The server authenticates a client by verifying the digital signature of the client. The publickey authentication process is as follows:
1.      The client sends the server a publickey authentication request that includes the username, public key, and public key algorithm name.
If the digital certificate of the client is required in authentication, the client also encapsulates the digital certificate in the authentication request. The digital certificate carries the public key information of the client.
2.      The server verifies the client's public key.
¡  If the public key is invalid, the server informs the client of the authentication failure.
¡  If the public key is valid, the server requests the digital signature of the client. After receiving the signature, the server uses the public key to verify the signature and informs the client of the authentication result.
When acting as an SSH server, the device supports using the public key algorithms DSA, ECDSA, and RSA to verify digital signatures.
When acting as an SSH client, the device supports using the public key algorithms DSA, ECDSA, and RSA to generate digital signatures.
For more information about public key configuration, see "Managing public keys."
Password-publickey authentication
The server requires SSH2 clients to pass both password authentication and publickey authentication. However, an SSH1 client only needs to pass either authentication.
Any authentication
The server requires clients to pass password authentication or publickey authentication.
Suite B contains a set of encryption and authentication algorithms that meet high security requirements. Table 2 lists all algorithms in Suite B.
The SSH server and client support using the X.509v3 certificate for identity authentication in compliance with the algorithm, negotiation, and authentication specifications defined in RFC 6239.
Table 2 Suite B algorithms
Security level
Encryption algorithm and HMAC algorithm
128-bit
ecdh-sha2-nistp256
AES128-GCM
x509v3-ecdsa-sha2-nistp256
192-bit
ecdh-sha2-nistp384
AES256-GCM
x509v3-ecdsa-sha2-nistp384
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode and non-FIPS mode. For more information about FIPS mode, see "Configuring FIPS."
To configure an SSH server, perform the following tasks:
1.      Generating local key pairs
2.      (Optional.) Specifying the SSH service port
3.      Enabling the SSH server
¡  Enabling the Stelnet server
¡  Enabling the SFTP server
¡  Enabling the SCP server
¡  Enabling NETCONF over SSH
4.      Configuring the user lines for SSH login
Required only for Stelnet and NETCONF-over-SSH servers.
5.      Configuring a client's host public key
Required for authentication method publickey, password-publickey, or any.
6.      Configuring an SSH user
¡  Required for authentication method publickey, password-publickey, or any.
¡  Optional for the password authentication method.
7.      (Optional.) Configuring the SSH management parameters
SSH management settings, such as authentication and connection control settings, help improve security of SSH connections.
8.      (Optional.) Specifying a PKI domain for the SSH server
About local key pairs
The DSA, ECDSA, or RSA key pairs on the SSH server are required for generating the session keys and session ID in the key exchange stage. They can also be used by a client to authenticate the server. When a client authenticates the server, it compares the public key received from the server with the server's public key that the client saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
To support SSH clients that use different types of key pairs, generate DSA, ECDSA, and RSA key pairs on the SSH server.
·           RSA key pairs—The SSH server generates a server key pair and a host key pair for RSA. The RSA server key pair is only used in SSH1 to encrypt the session key for secure transmission of the session key. It is not used in SSH2, because no session key transmission is required in SSH2.
·           DSA key pair—The SSH server generates only one DSA host key pair. SSH1 does not support the DSA algorithm.
·           ECDSA key pair—The SSH server generates only one ECDSA host key pair.
Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
If the device does not have RSA key pairs with default names, it automatically generates one RSA server key pair and one RSA host key pair when SSH starts. Both key pairs use their default names. The SSH application starts when you execute an SSH server command on the device.
The key modulus length must be less than 2048 bits when you generate the DSA key pair on the SSH server.
When you generate an ECDSA key pair, you can generate only a secp256r1 or secp384r1 ECDSA key pair.
The SSH server operating in FIPS mode supports only ECDSA and RSA key pairs. Do not generate a DSA key pair on the SSH server in FIPS mode.
1.      Enter system view.
2.      Generate local key pairs.
public-key local create { dsa | ecdsa { secp256r1 | secp384r1 } | rsa }
About the SSH service port
The default port of the SSH service is 22. You can specify another port for the SSH service to improve security of SSH connections.
If you modify the SSH port number when the SSH server is enabled, the SSH service is restarted and all SSH connections are terminated after the modification. SSH users must reconnect to the SSH server to access the server.
If you set the SSH port to a well-known port number, the service that uses the well-known port number might fail to start. Well-known port numbers are in the range of 1 to 1024.
2.      Specify the SSH service port.
ssh server port port-number
By default, the SSH service port is 22.
About enabling the Stelnet server
After you enable the Stelnet server on the device, a client can log in to the device through Stelnet.
2.      Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
About enabling the SFTP server
After you enable the SFTP server on the device, a client can log in to the device through SFTP.
When acting as an SFTP server, the device does not support SFTP connections initiated by SSH1 clients.
2.      Enable the SFTP server.
sftp server enable
By default, the SFTP server is disabled.
About enabling the SCP server
After you enable the SCP server on the device, a client can log in to the device through SCP.
When acting as an SCP server, the device does not support SCP connections initiated by SSH1 clients.
2.      Enable the SCP server.
scp server enable
By default, the SCP server is disabled.
About enabling NETCONF over SSH
After you enable NETCONF over SSH on the device, a client can perform NETCONF operations on the device through a NETCONF-over-SSH connection.
When acting as a server in the NETCONF-over-SSH connection, the device does not support connection requests initiated by SSH1 clients.
2.      Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
For more information about NETCONF over SSH commands, see Network Management and Monitoring Command Reference.
About user line configuration for SSH login
Depending on the SSH application, an SSH client can be an Stelnet client, SFTP client, SCP client, or NETCONF-over-SSH client.
Only Stelnet and NETCONF-over-SSH clients require the user line configuration. The user line configuration takes effect on the clients at the next login.
2.      Enter VTY user line view.
line vty number [ ending-number ]
3.      Set the login authentication mode to scheme.
authentication-mode scheme
By default, the authentication mode is password.
For more information about this command, see Fundamentals Command Reference.
About the client's host public key
In publickey authentication, the server compares the SSH username and the client's host public key received from the client with the locally saved SSH username and the client's host public key. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is paired with the client's host public key.
For publickey authentication, password-publickey authentication, or any authentication, you must perform the following tasks:
1.      Configure the client's DSA, ECDSA, or RSA host public key on the server.
2.      Specify the associated host private key on the client to generate the digital signature.
If the device acts as an SSH client, specify the public key algorithm on the client. The algorithm determines the associated host private key for generating the digital signature.
Client public key configuration methods
You can configure the client host public key by using the following methods:
·           Manually enter the content of a client's host public key on the server.
a.    Display the host public key on the client and record the key.
b.    Type the client's host public key character by character on the server, or use the copy and paste method.
The manually entered key must be in DER format without being converted. For the displayed key to meet the requirement when the client is an H3C device,  use the display public-key local public command. The format of the public key displayed in any other way (for example, by using the public-key local export command) might be incorrect. If the key is not in correct format, the system discards the key.
·           Import the client host public key from a public key file.
a.    Save the client public key file to the server. For example, transfer the client public key file to the server in binary mode through FTP or TFTP.
b.    Import the client public key from the locally saved public key file.
During the import process, the server automatically converts the host public key to a string in PKCS format.
As a best practice, configure no more than 20 SSH client's host public keys on an SSH server.
Import the client's host public key as a best practice.
Entering a client's host public key
2.      Enter public key view.
public-key peer keyname
3.      Configure a client's host public key.
Enter the content of the client's host public key character by character, or use the copy and paste method.
When you enter the content of a client's host public key, you can use spaces and carriage returns between characters but the system does not save them. For more information, see "Managing public keys."
4.      Exit public key view and save the key.
peer-public-key end
Importing a client's host public key from the public key file
2.      Import a client's public key from the public key file.
public-key peer keyname import sshkey filename
About the SSH user
Configure an SSH user and a local user depending on the authentication method.
·           If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
·           If the authentication method is password, you must perform one of the following tasks:
¡  For local authentication, configure a local user on the SSH server.
¡  For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
·           If the authentication method is password-publickey or any, you must create an SSH user on the SSH server and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
If you change the authentication parameters for a logged-in SSH user, the change takes effect on the user at the next login.
When the device operates as an SSH server in FIPS mode, the device does not support authentication method any or publickey.
For an SFTP or SCP user, the working directory depends on the authentication method.
·           If the authentication method is password, the working directory is authorized by AAA.
·           If the authentication method is publickey or password-publickey, the working folder is specified by the authorization-attribute command in the associated local user view.
For an SSH user, the user role also depends on the authentication method.
·           If the authentication method is password, the user role is authorized by AAA.
·           If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
For all authentication methods except password authentication, you must specify a client's host public key or digital certificate.
·           For a client that sends the user's public key information directly to the server, specify the client's host public key on the server. The specified public key must already exist. For more information about public keys, see "Configuring a client's host public key."
·           For a client that sends the user's public key information to the server through a digital certificate, specify the PKI domain on the server. This PKI domain verifies the client's digital certificate. For successful verification, the specified PKI domain must have the correct CA certificate. To specify the PKI domain, use the ssh user or ssh server pki-domain command. For more information about configuring a PKI domain, see "Configuring PKI."
For information about configuring local users and remote authentication, see "Configuring AAA."
2.      Create an SSH user, and specify the service type and authentication method.
In non-FIPS mode:
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } [ assign { pki-domain domain-name | publickey keyname } ] }
In FIPS mode:
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | password-publickey [ assign { pki-domain domain-name | publickey keyname } ] }
An SSH server supports up to 1024 SSH users.
Enabling the SSH server to support SSH1 clients
2.      Enable the SSH server to support SSH1 clients.
ssh server compatible-ssh1x enable
By default, the SSH server does not support SSH1 clients.
This command is not available in FIPS mode.
Setting the minimum interval for updating the RSA server key pair
2.      Set the minimum interval for updating the RSA server key pair.
ssh server rekey-interval interval
By default, the device does not update the RSA server key pair.
This configuration takes effect only on SSH1 clients.
Setting the SSH user authentication timeout timer
2.      Set the SSH user authentication timeout timer.
The default setting is 60 seconds.
Perform this task to prevent malicious occupation of TCP connections. If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
Setting the maximum number of SSH authentication attempts
2.      Set the maximum number of SSH authentication attempts.
ssh server authentication-retries retries
The default setting is 3.
Perform this task to prevent malicious hacking of usernames and passwords. If the authentication method is any, the total number of publickey authentication attempts and password authentication attempts cannot exceed the upper limit.
Specifying an SSH login control ACL
2.      Specify an SSH login control ACL.
IPv4:
IPv6:
This feature uses an ACL to filter SSH clients that initiate SSH connections to the server. By default, no ACLs are specified and all SSH users can initiate SSH connections to the server.
Enabling logging for SSH login attempts that are denied by the SSH login control ACL
2.      Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for login attempts that are denied by the SSH login control ACL.
This command enables SSH to generate log messages for SSH login attempts that are denied by the SSH login control ACL and send the messages to the information center.
Setting the DSCP value in the packets that the SSH server sends to SSH clients
2.      Set the DSCP value in the packets that the SSH server sends to the SSH clients.
IPv4:
ssh server dscp dscp-value
IPv6:
By default, the DSCP value of SSH packets is 48.
The DSCP value of a packet defines the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
Setting the SFTP connection idle timeout timer
2.      Set the SFTP connection idle timeout timer.
By default, the SFTP connection idle timeout is 10 minutes.
When the SFTP connection idle timeout timer expires, the system automatically tears the connection down and releases the connection resources.
Setting the maximum number of online SSH users
2.      Set the maximum number of online SSH users.
The default setting is 32.
When the number of online SSH users reaches the upper limit, the system denies new SSH connection requests. Changing the upper limit does not affect online SSH users.
For more information about this command, see AAA commands in Security Command Reference.
About specifying a PKI domain for the SSH server
The PKI domain specified for the SSH server has the following functions:
·           The SSH server uses the PKI domain to send its certificate to the client in the key exchange stage.
·           The SSH server uses the PKI domain to authenticate the client's certificate if no PKI domain is specified for the client authentication by using the ssh user command.
2.      Specify a PKI domain for the SSH server.
ssh server pki-domain domain-name
By default, no PKI domain is specified for the SSH server.
To configure an Stelnet client, perform the following tasks:
Only required for authentication method publickey, password-publickey, or any.
2.      (Optional.) Specifying the source IP address for outgoing SSH packets
3.      Establishing a connection to an Stelnet server
4.      (Optional.) Establishing a connection to an Stelnet server based on Suite B
About generating local key pairs
You must generate local key pairs on Stelnet clients when the Stelnet server uses the publickey, password-publickey, or any authentication method.
The key modulus length must be less than 2048 bits when you generate a DSA key pair.
The Stelnet client operating in FIPS mode supports only ECDSA and RSA key pairs.
About specifying the source IP address for outgoing SSH packets
After you specify the source IP address for outgoing SSH packets on an Stelnet client, the client uses the specified IP address to communicate with the Stelnet server.
As a best practice, specify a loopback interface as the source interface or specify the IP address of a loopback or dialer interface as the source address of outgoing SSH packets for the following purposes:
·           Ensuring the communication between the Stelnet client and the Stelnet server.
·           Improving the manageability of Stelnet clients in authentication service.
2.      Specify the source address for outgoing SSH packets.
IPv4:
By default, an IPv4 Stelnet client uses the primary IPv4 address of the output interface in the matching route as the source address of the outgoing SSH packets.
IPv6:
By default, an IPv6 Stelnet client automatically selects a source IPv6 address for outgoing SSH packets in compliance with RFC 3484.
About establishing a connection to an Stelnet server
Perform this task to enable the Stelnet client feature on the device and establish a connection to the Stelnet server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
To access the server, a client must use the server's host public key to authenticate the server. As a best practice, configure the server's host public key on the device in an insecure network. If the server's host public key is not configured on the client, the client will notify you to confirm whether to continue with the access.
·           If you choose to continue, the client accesses the server and downloads the server's host public key. The downloaded public key will be used to authenticate the server in subsequent accesses.
·           If you choose to not continue, the connection cannot be established.
Restrictions and guidelines for establishing a connection to an Stelnet server
An Stelnet client cannot establish connections to both IPv4 and IPv6 Stelnet servers.
Establishing a connection to an IPv4 Stelnet server
Execute the following command in user view to establish a connection with an IPv4 Stelnet server:
In non-FIPS mode:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 Stelnet server
Execute the following command in user view to establish a connection to an IPv6 Stelnet server:
In non-FIPS mode:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Execute the following command in user view to establish a connection to an Stelnet server based on Suite B:
IPv4:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ip ip-address } ] *
IPv6:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
To configure an SFTP client, perform the following tasks:
2.      (Optional.) Specifying the source IP address for outgoing SFTP packets
3.      Establishing a connection to an SFTP server
4.      (Optional.) Establishing a connection to an SFTP server based on Suite B
5.      (Optional.) Working with SFTP directories
6.      (Optional.) Working with SFTP files
7.      (Optional.) Displaying help information
8.      (Optional.) Terminating the connection with the SFTP server
You must generate local key pairs on SFTP clients when the SFTP server uses the publickey, password-publickey, or any authentication method.
The SFTP client operating in FIPS mode supports only ECDSA and RSA key pairs.
About specifying the source IP address for outgoing SFTP packets
After you specify the source IP address for outgoing SFTP packets on an SFTP client, the client uses the specified IP address to communicate with the SFTP server.
As a best practice, specify a loopback interface as the source interface or specify the IP address of a loopback or dialer interface as the source address of outgoing SFTP packets for the following purposes:
·           Ensuring the communication between the SFTP client and the SFTP server.
·           Improving the manageability of SFTP clients in authentication service.
2.      Specify the source address for outgoing SFTP packets.
IPv4:
sftp client source { ip ip-address | interface interface-type interface-number }
By default, an SFTP client uses the primary IPv4 address of the output interface in the matching route as the source address of the outgoing SFTP packets.
IPv6:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
By default, an IPv6 SFTP client automatically selects a source IPv6 address for the outgoing SFTP packets in compliance with RFC 3484.
About establishing a connection to an SFTP server
Perform this task to enable the SFTP client feature on the device and establish a connection to the SFTP server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
Restrictions and guidelines for establishing a connection to an SFTP server
An SFTP client cannot establish connections to both IPv4 and IPv6 SFTP servers.
Establishing a connection to an IPv4 SFTP server
Execute the following command in user view to establish a connection to an IPv4 SFTP server:
In non-FIPS mode:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SFTP server
Execute the following command in user view to establish a connection to an IPv6 SFTP server:
In non-FIPS mode:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Execute the following command in user view to establish a connection to an SFTP server based on Suite B:
IPv4:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ip ip-address } ] *
IPv6:
About SFTP directory operations
After you establish a connection to an SFTP server, you can operate directories of the SFTP server.
Changing the working directory on the SFTP server
1.      Enter SFTP client view.
For more information, see "Establishing a connection to an SFTP server."
2.      Change the working directory on the SFTP server.
cd [ remote-path ]
3.      (Optional.) Return to the upper-level directory.
cdup
Displaying the current working directory on the SFTP server
2.      Display the current working directory on the SFTP server.
pwd
Displaying files under a directory
2.      Display files under a directory.
¡  dir [ -a | -l ] [ remote-path ]
¡  ls [ -a | -l ] [ remote-path ]
The dir command has the same function as the ls command.
Changing the name of a directory on the SFTP server
2.      Change the name of a directory on the SFTP server.
rename oldname newname
Creating a new directory on the SFTP server
2.      Create a new directory on the SFTP server.
mkdir remote-path
Deleting directories on the SFTP server
2.      Delete one or more directories from the SFTP server.
rmdir remote-path
About SFTP file operations
After you establish a connection to an SFTP server, you can operate files on the SFTP server.
Changing the name of a file on the SFTP server
2.      Change the name of a file on the SFTP server.
rename old-name new-name
Downloading a file from the SFTP server and save it locally
2.      Download a file from the SFTP server and save it locally.
Uploading a local file to the SFTP server
2.      Upload a local file to the SFTP server.
Deleting a file from the SFTP server
2.      Delete a file from the SFTP server.
¡  delete remote-file
¡  remove remote-file
The delete command has the same function as the remove command.
About displaying help information
After you establish a connection to the SFTP server, you can display the help information of SFTP client commands, including the command syntax and parameter configuration.
2.      Display SFTP client command help information.
¡  help
The help command has the same function as the ? command.
2.      Terminate the connection with the SFTP server and return to user view.
¡  bye
¡  exit
¡  quit
The three commands have the same function.
To configure an SCP client, perform the following tasks:
Only required for the publickey, password-publickey, or any authentication method.
2.      Establishing a connection to an SCP server
3.      (Optional.) Establishing a connection to an SCP server based on Suite B
You must generate local key pairs on SCP clients when the SCP server uses the publickey, password-publickey, or any authentication method.
The SCP client operating in FIPS mode supports only ECDSA and RSA key pairs.
About establishing a connection to an SCP server
Perform this task to enable the SCP client feature on the device, establish a connection to the SCP server, and transfer files with the server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
Restrictions and guidelines for establishing a connection to an SCP server
An SCP client cannot establish connections to both IPv4 and IPv6 SCP servers.
Establishing a connection to an IPv4 SCP server
Execute the following command in user view to connect to an IPv4 SCP server, and transfer files with the server:
In non-FIPS mode:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { get | put } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
In FIPS mode:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { get | put } source-file-name [ destination-file-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SCP server
Execute the following command in user view to connect to an IPv6 SCP server, and transfer files with the server.
In non-FIPS mode:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { get | put } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
In FIPS mode:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number  ] { get | put } source-file-name [ destination-file-name ] [ identity-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-ctos-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group14-sha1  | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } | prefer-stoc-hmac { sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Execute the following command in user view to establish a connection to an SCP server based on Suite B:
IPv4:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { get | put } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ip ip-address } ] *
IPv6:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { get | put } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] *
The SSH2 client and server use the following types of algorithms for algorithm negotiation during the Stelnet, SFTP, or SCP session establishment:
·           Key exchange algorithms.
·           Public key algorithms.
·           Encryption algorithms.
·           MAC algorithms.
If you specify algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The client uses the specified algorithms to initiate the negotiation, and the server uses the matching algorithms to negotiate with the client. If multiple algorithms of the same type are specified, the algorithm specified earlier has a higher priority during negotiation.
2.      Specify key exchange algorithms for SSH2.
In non-FIPS mode:
ssh2 algorithm key-exchange { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
By default, SSH2 uses the ecdh-sha2-nistp256, ecdh-sha2-nistp384, dh-group-exchange-sha1, dh-group14-sha1, and dh-group1-sha1 key exchange algorithms in descending order of priority for algorithm negotiation.
In FIPS mode:
ssh2 algorithm key-exchange { dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
By default, SSH2 uses the ecdh-sha2-nistp256, ecdh-sha2-nistp384, and dh-group14-sha1 key exchange algorithms in descending order of priority for algorithm negotiation.
2.      Specify public key algorithms for SSH2.
In non-FIPS mode:
ssh2 algorithm public-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
By default, SSH2 uses the x509v3-ecdsa-sha2-nistp256, x509v3-ecdsa-sha2-nistp384, ecdsa-sha2-nistp256, ecdsa-sha2-nistp384, rsa, and dsa public key algorithms in descending order of priority for algorithm negotiation.
In FIPS mode:
ssh2 algorithm public-key { ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
By default, SSH2 uses the x509v3-ecdsa-sha2-nistp256, x509v3-ecdsa-sha2-nistp384, ecdsa-sha2-nistp256, ecdsa-sha2-nistp384, and rsa public key algorithms in descending order of priority for algorithm negotiation.
2.      Specify encryption algorithms for SSH2.
In non-FIPS mode:
ssh2 algorithm cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } *
By default, SSH2 uses the aes128-ctr, aes192-ctr, aes256-ctr, aes128-gcm, aes256-gcm, aes128-cbc, 3des-cbc, aes256-cbc, and des-cbc encryption algorithms in descending order of priority for algorithm negotiation.
In FIPS mode:
ssh2 algorithm cipher { aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm } *
By default, SSH2 uses the aes128-ctr, aes192-ctr, aes256-ctr, aes128-gcm, aes256-gcm, aes128-cbc, and aes256-cbc encryption algorithms in descending order of priority for algorithm negotiation.
2.      Specify MAC algorithms for SSH2.
In non-FIPS mode:
ssh2 algorithm mac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } *
By default, SSH2 uses the sha2-256, sha2-512, sha1, md5, sha1-96, and md5-96 MAC algorithms in descending order of priority for algorithm negotiation.
In FIPS mode:
ssh2 algorithm mac { sha1 | sha1-96 | sha2-256 | sha2-512 } *
By default, SSH2 uses the sha2-256, sha2-512, sha1, and sha1-96 MAC algorithms in descending order of priority for algorithm negotiation.
Display the public keys of the local key pairs.
display public-key local { dsa | ecdsa | rsa } public [ name publickey-name ]
Display information about peer public keys.
display public-key peer [ brief | name publickey-name ]
Display the source IP address configuration of the SFTP client.
display sftp client source
Display the source IP address configuration of the Stelnet client.
display ssh client source
Display SSH server status or sessions.
In standalone mode:
In IRF mode:
display ssh server { session [ slot slot-number ] | status }
Display SSH user information on the SSH server.
Display algorithms used by SSH2 in the algorithm negotiation stage.
display ssh2 algorithm
For more information about the display public-key local and display public-key peer commands, see public key management commands in Security Command Reference.
Unless otherwise noted, devices in the configuration examples operate in non-FIPS mode.
When the device acts as an Stelnet server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the Stelnet server.
As shown in Figure 1:
·           The router acts as the Stelnet server and uses password authentication to authenticate the Stelnet client. The username and password of the client are saved on the router.
·           The host acts as the Stelnet client, using Stelnet client software (SSH2). After the user on the host logs in to the router through Stelnet, the user can configure and manage the router as a network administrator.
Figure 1 Network diagram
1.      Configure the Stelnet server:
# Generate RSA key pairs.
<Router> system-view
[Router] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Router] public-key local create dsa
Generating Keys...
# Generate an ECDSA key pair.
[Router] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the Stelnet server.
[Router] ssh server enable
# Assign an IP address to GigabitEthernet 1/0. The Stelnet client uses this IP address as the destination for SSH connection.
[Router] interface gigabitethernet 1/0
[Router-GigabitEthernet1/0] ip address 192.168.1.40 255.255.255.0
[Router-GigabitEthernet1/0] quit
# Set the authentication mode to AAA for user lines.
[Router] line vty 0 63
[Router-line-vty0-63] authentication-mode scheme
[Router-line-vty0-63] quit
# Create a local device management user named client001.
[Router] local-user client001 class manage
# Set the password to aabbcc in plain text for local user client001.
[Router-luser-manage-client001] password simple aabbcc
# Authorize local user client001 to use the SSH service.
[Router-luser-manage-client001] service-type ssh
# Assign the network-admin user role to local user client001.
[Router-luser-manage-client001] authorization-attribute user-role network-admin
[Router-luser-manage-client001] quit
# Create an SSH user named client001. Specify the service type as stelnet and the authentication method as password for the user.
[Router] ssh user client001 service-type stelnet authentication-type password
2.      Establish a connection to the Stelnet server:
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
To establish a connection to the Stelnet server:
a.    Launch PuTTY.exe to enter the interface shown in Figure 2.
b.    In the Host Name (or IP address) field, enter the IP address 192.168.1.40 of the Stelnet server.
c.    Click Open.
Figure 2 Specifying the host name (or IP address)
d.    Enter username client001 and password aabbcc to log in to the Stelnet server.
As shown in Figure 3:
·           The router acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
Figure 3 Network diagram
In the server configuration, the client's host public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
The configuration procedure is as follows:
1.      Generate RSA key pairs on the Stelnet client:
a.    Run PuTTYGen.exe, select SSH-2 RSA, and click Generate.
Figure 4 Generating a key pair on the client
b.    Continue moving the mouse during the key generating process, but do not place the mouse over the green progress bar shown in Figure 5. Otherwise, the progress bar stops moving and the key pair generating process stops.
Figure 5 Generating process
c.    After the key pair is generated, click Save public key to save the public key.
A file saving window appears.
Figure 6 Saving a key pair on the client
d.    Enter a file name (key.pub in this example), and click Save.
e.    On the page as shown in Figure 6, click Save private key to save the private key.
A confirmation dialog box appears.
f.     Click Yes.
g.    Enter a file name (private.ppk in this example), and click Save.
h.    Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2.      Configure the Stelnet server:
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to GigabitEthernet 1/0. The Stelnet client uses this address as the destination for SSH connection.
# Import the peer public key from the public key file key.pub and name it clientkey.
[Router] public-key peer clientkey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user, and assign the public key clientkey to the user.
[Router] ssh user client002 service-type stelnet authentication-type publickey assign publickey clientkey
# Create a local device management user named client002.
[Router] local-user client002 class manage
# Authorize local user client002 to use the SSH service.
[Router-luser-manage-client002] service-type ssh
# Assign the network-admin user role to local user client002.
[Router-luser-manage-client002] authorization-attribute user-role network-admin
[Router-luser-manage-client002] quit
3.      Specify the private key file and establish a connection to the Stelnet server:
a.    Launch PuTTY.exe on the Stelnet client to enter the interface shown in Figure 7.
b.    In the Host Name (or IP address) field, enter IP address 192.168.1.40 of the Stelnet server.
Figure 7 Specifying the host name (or IP address)
c.    From the navigation tree, select Connection > SSH.
The window shown in Figure 8 appears.
d.    Set Preferred SSH protocol version to 2.
Figure 8 Setting the preferred SSH version
e.    From the navigation tree, select Connection > SSH > Auth.
The window shown in Figure 9 appears.
f.     Click Browse… and select the private key file (private.ppk in this example).
g.    Click Open.
Figure 9 Specifying the private key file
h.    Enter username client002 to log in to the Stelnet server.
As shown in Figure 10:
·           Router B acts as the Stelnet server and uses password authentication to authenticate the Stelnet client. The username and password of the client are saved on Router B.
·           Router A acts as the Stelnet client. After the user on Router A logs in to Router B through Stelnet, the user can configure and manage Router B as a network administrator.
Figure 10 Network diagram
<RouterB> system-view
[RouterB] public-key local create rsa
Generating Keys...
[RouterB] public-key local create dsa
Generating Keys...
[RouterB] public-key local create ecdsa secp256r1
Generating Keys...
[RouterB] ssh server enable
# Assign an IP address to GigabitEthernet 1/0. The Stelnet client uses this address as the destination address for SSH connection.
[RouterB] interface gigabitethernet 1/0
[RouterB-GigabitEthernet1/0] ip address 192.168.1.40 255.255.255.0
[RouterB-GigabitEthernet1/0] quit
[RouterB] line vty 0 63
[RouterB-line-vty0-63] authentication-mode scheme
[RouterB-line-vty0-63] quit
[RouterB] local-user client001 class manage
[RouterB-luser-manage-client001] password simple aabbcc
[RouterB-luser-manage-client001] service-type ssh
[RouterB-luser-manage-client001] authorization-attribute user-role network-admin
[RouterB-luser-manage-client001] quit
[RouterB] ssh user client001 service-type stelnet authentication-type password
<RouterA> system-views
[RouterA] interface gigabitethernet 1/0
[RouterA-GigabitEthernet1/0] ip address 192.168.1.56 255.255.255.0
[RouterA-GigabitEthernet1/0] quit
[RouterA] quit
Before establishing a connection to the server, you can configure the server's host public key on the client to authenticate the server.
¡  To configure the server's host public key on the client, perform the following tasks:
# Use the display public-key local dsa public command on the server to display the server's host public key. (Details not shown.)
# Enter public key view of the client and copy the host public key of the server to the client.
[RouterA] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[RouterA-pkey-public-key-key1] 308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[RouterA-pkey-public-key-key1]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[RouterA-pkey-public-key-key1]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[RouterA-pkey-public-key-key1]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[RouterA-pkey-public-key-key1]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[RouterA-pkey-public-key-key1]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[RouterA-pkey-public-key-key1]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[RouterA-pkey-public-key-key1]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[RouterA-pkey-public-key-key1]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[RouterA-pkey-public-key-key1]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[RouterA-pkey-public-key-key1]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[RouterA-pkey-public-key-key1]485348
[RouterA-pkey-public-key-key1] peer-public-key end
[RouterA] quit
# Establish an SSH connection to the server, and specify the host public key of the server as key1.
<RouterA> ssh2 192.168.1.40 public-key key1
Username: client001
Connecting to 192.168.1.40 port 22.
[email protected]'s password:
Enter a character ~ and a dot to abort.
<RouterB>
After you enter username client001 and password aabbcc, you can log in to Router B successfully.
¡  If the client does not have the server's host public key, enter username client001, and then enter y to access the server and download the server's host public key.
Username: client001
The server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:y
<RouterB>
After you enter password aabbcc, you can access Router B successfully. At the next connection attempt, the client authenticates the server by using the server's host public key that is locally saved on the client.
Example: Configuring the device as an Stelnet client (publickey authentication)
As shown in Figure 11:
·           Router B acts as the Stelnet server, and it uses publickey authentication and the DSA public key algorithm.
Figure 11 Network diagram
In the server configuration, the client's host public key is required. Generate a DSA key pair on the client before configuring the Stelnet server.
1.      Configure the Stelnet client:
[RouterA] public-key local create dsa
Generating Keys...
# Export the DSA host public key to a public key file named key.pub.
[RouterA] public-key local export dsa ssh2 key.pub
[RouterA] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
Generating Keys...
Generating Keys...
Generating Keys...
# Import the peer public key from the public key file key.pub, and name it clientkey.
[RouterB] public-key peer clientkey import sshkey key.pub
[RouterB] ssh user client002 service-type stelnet authentication-type publickey assign publickey clientkey
[RouterB] local-user client002 class manage
[RouterB-luser-manage-client002] service-type ssh
[RouterB-luser-manage-client002] authorization-attribute user-role network-admin
[RouterB-luser-manage-client002] quit
3.      Establish an SSH connection to the Stelnet server.
<RouterA> ssh2 192.168.1.40 identity-key dsa
Username: client002
Do you want to save the server public key? [Y/N]:n
<RouterB>
After you enter username client002 and then enter y to continue accessing the server, you can log in to the server successfully.
Example: Configuring Stelnet based on 128-bit Suite B algorithms
As shown in Figure 12:
·           Router B acts as the Stelnet Suite B server (SSH2), and it uses publickey authentication to authenticate the client.
·           Router A acts as an Stelnet Suite B client (SSH2). After the user on Router A logs in to Router B through the Stelnet Suite B client software, the user can configure and manage Router B as an administrator.
Figure 12 Network diagram
1.      Generate the client's certificate and the server's certificate. (Details not shown.)
You must first configure the certificates of the server and the client because they are required for identity authentication between the two parties.
In this example, the server's certificate file is ssh-server-ecdsa256.p12 and the client's certificate file is ssh-client-ecdsa256.p12.
2.      Configure the Stelnet client:
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an Stelnet client.
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate and enter its view.
[RouterA] pki domain server256
# Disable CRL checking.
[RouterA-pki-domain-server256] undo crl check enable
[RouterA-pki-domain-server256] quit
# Import local certificate file ssh-server-ecdsa256.p12 to PKI domain server256.
[RouterA] pki import domain server256 p12 local filename ssh-server-ecdsa256.p12
The system is going to save the key pair. You must specify a key pair name, which is a case-insensitive string of 1 to 64 characters. Valid characters include a to z, A to Z, 0 to 9, and hyphens (-).
Please enter the key pair name[default name: server256]:
# Display information about local certificates in PKI domain server256.
[RouterA] display pki certificate domain server256 local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 3 (0x3)
    Signature Algorithm: ecdsa-with-SHA256
        Issuer: C=CN, ST=Beijing, L=Beijing, O=H3C, OU=Software, CN=SuiteB CA
        Validity
            Not Before: Aug 21 08:39:51 2015 GMT
            Not After : Aug 20 08:39:51 2016 GMT
        Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Server secp256
        Subject Public Key Info:
            Public Key Algorithm: id-ecPublicKey
                Public-Key: (256 bit)
                pub:
                    04:a2:b4:b4:66:1e:3b:d5:50:50:0e:55:19:8d:52:
                    6d:47:8c:3d:3d:96:75:88:2f:9a:ba:a2:a7:f9:ef:
                    0a:a9:20:b7:b6:6a:90:0e:f8:c6:de:15:a2:23:81:
                    3c:9e:a2:b7:83:87:b9:ad:28:c8:2a:5e:58:11:8e:
                    c7:61:4a:52:51
                ASN1 OID: prime256v1
                NIST CURVE: P-256
        X509v3 extensions:
            X509v3 Basic Constraints:
                CA:FALSE
            Netscape Comment:
                OpenSSL Generated Certificate
            X509v3 Subject Key Identifier:
                08:C1:F1:AA:97:45:19:6A:DA:4A:F2:87:A1:1A:E8:30:BD:31:30:D7
            X509v3 Authority Key Identifier:
                keyid:5A:BE:85:49:16:E5:EB:33:80:25:EB:D8:91:50:B4:E6:3E:4F:B8:22
         30:65:02:31:00:a9:16:e9:c1:76:f0:32:fc:4b:f9:8f:b6:7f:
         31:a0:9f:de:a7:cc:33:29:27:2c:71:2e:f9:0d:74:cb:25:c9:
         00:d2:52:18:7f:58:3f:cc:7e:8b:d3:42:65:00:cb:63:f8:02:
         30:01:a2:f6:a1:51:04:1c:61:78:f6:6b:7e:f9:f9:42:8d:7c:
         a7:bb:47:7c:2a:85:67:0d:81:12:0b:02:98:bc:06:1f:c1:3c:
         9b:c2:1b:4c:44:38:5a:14:b2:48:63:02:2b
# Create a PKI domain named client256 for the client's certificate and enter its view.
[RouterA] pki domain client256
[RouterA-pki-domain-client256] undo crl check enable
[RouterA-pki-domain-client256] quit
# Import local certificate file ssh-client-ecdsa256.p12 to PKI domain client256.
[RouterA] pki import domain client256 p12 local filename ssh-client-ecdsa256.p12
Please enter the key pair name[default name: client256]:
# Display information about local certificates in PKI domain client256.
[RouterA] display pki certificate domain client256 local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 4 (0x4)
        Validity
            Not Before: Aug 21 08:41:09 2015 GMT
            Not After : Aug 20 08:41:09 2016 GMT
        Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Client secp256
                pub:
                    04:da:e2:26:45:87:7a:63:20:e7:ca:7f:82:19:f5:
                    96:88:3e:25:46:f8:2f:9a:4c:70:61:35:db:e4:39:
                    b8:38:c4:60:4a:65:28:49:14:32:3c:cc:6d:cd:34:
                    29:83:84:74:a7:2d:0e:75:1c:c2:52:58:1e:22:16:
                    12:d0:b4:8a:92
                NIST CURVE: P-256
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
                1A:61:60:4D:76:40:B8:BA:5D:A1:3C:60:BC:57:98:35:20:79:80:FC
         30:66:02:31:00:9a:6d:fd:7d:ab:ae:54:9a:81:71:e6:bb:ad:
         5a:2e:dc:1d:b3:8a:bf:ce:ee:71:4e:8f:d9:93:7f:a3:48:a1:
         5c:17:cb:22:fa:8f:b3:e5:76:89:06:9f:96:47:dc:34:87:02:
         31:00:e3:af:2a:8f:d6:8d:1f:3a:2b:ae:2f:97:b3:52:63:b6:
         18:67:70:2c:93:2a:41:c0:e7:fa:93:20:09:4d:f4:bf:d0:11:
         66:0f:48:56:01:1e:c3:be:37:4e:49:19:cf:c6
3.      Configure the Stelnet server:
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server256 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
# Specify Suite B algorithms for algorithm negotiation.
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp256
[RouterB] ssh2 algorithm cipher aes128-gcm
[RouterB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384
# Specify server256 as the PKI domain of the server's certificate.
[RouterB] ssh server pki-domain server256
# Create a local device management user named client001. Authorize the user to use the SSH service and assign the network-admin user role to the user.
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client256 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type stelnet authentication-type publickey assign pki-domain client256
4.      Establish an SSH connection to the Stelnet server based on the 128-bit Suite B algorithms:
# Establish an SSH connection to the server at 192.168.1.40.
<RouterA> ssh2 192.168.1.40 suite-b 128-bit pki-domain client256 server-pki-domain server256
Username: client001
<RouterB>
SFTP configuration examples
When the device acts as an SFTP server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the SFTP server.
Example: Configuring the device as an SFTP server (password authentication)
As shown in Figure 13:
·           The router acts as the SFTP server and uses password authentication to authenticate the SFTP client. The username and password of the client are saved on the router.
·           The host acts as the SFTP client. After the user on the client logs in to the router through SFTP, the user can perform file management and transfer operations on the router as a network administrator.
Figure 13 Network diagram
1.      Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SFTP server.
[Router] sftp server enable
# Assign an IP address to GigabitEthernet 1/0. The client uses this address as the destination for SSH connection.
[Router-GigabitEthernet1/0] ip address 192.168.1.45 255.255.255.0
# Set the password to aabbcc in plain text for local user client002.
[Router-luser-manage-client002] password simple aabbcc
# Assign the network-admin user role and working directory flash:/ to local user client002.
[Router-luser-manage-client002] authorization-attribute user-role network-admin work-directory flash:/
# Create an SSH user named client002. Specify the authentication method as password and service type as sftp for the user.
[Router] ssh user client002 service-type sftp authentication-type password
2.      Establish a connection to the SFTP server:
The device supports different types of SFTP client software. This example uses an SFTP client that runs PSFTP of PuTTY version 0.58.
PSFTP supports only password authentication.
To establish a connection to the SFTP server:
a.    Run the psftp.exe to launch the client interface shown in Figure 14, and enter the following command:
open 192.168.1.45
b.    Enter username client002 and password aabbcc to log in to the SFTP server.
Figure 14 SFTP client interface
Example: Configuring the device as an SFTP client (publickey authentication)
As shown in Figure 15:
·           Router B acts as the SFTP server, and it uses publickey authentication and the RSA public key algorithm.
·           Router A acts as the SFTP client. After the user on Router A logs in to Router B through SFTP, the user can perform file management and transfer operations on Router B as a network administrator.
Figure 15 Network diagram
In the server configuration, the client's host public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1.      Configure the SFTP client:
[RouterA-GigabitEthernet1/0] ip address 192.168.0.2 255.255.255.0
[RouterA] public-key local create rsa
Generating Keys...
# Export the host public key to a public key file named pubkey.
[RouterA] public-key local export rsa ssh2 pubkey
[RouterA] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2.      Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
[RouterB] sftp server enable
# Assign an IP address to GigabitEthernet 1/0. The client uses this address as the destination address for SSH connection.
[RouterB-GigabitEthernet1/0] ip address 192.168.0.1 255.255.255.0
# Import the peer public key from the public key file pubkey, and name it routerkey.
[RouterB] public-key peer routerkey import sshkey pubkey
# Create an SSH user named client001. Specify the service type as sftp and the authentication method as publickey for the user. Assign the public key routerkey to the user.
[RouterB] ssh user client001 service-type sftp authentication-type publickey assign publickey routerkey
# Assign the network-admin user role and working directory flash:/ to local user client001.
[RouterB-luser-manage-client001] authorization-attribute user-role network-admin work-directory flash:/
3.      Establish a connection between the SFTP client and the SFTP server:
# Establish a connection to the SFTP server and enter SFTP client view.
<RouterA> sftp 192.168.0.1 identity-key rsa
Username: client001
Connecting to 192.168.0.1 port 22.
sftp>
# Display files under the current directory of the server, delete file z, and verify the result.
sftp> dir -l
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
sftp> delete z
Removing /z
sftp> dir -l
# Add a directory named new1 and verify the result.
sftp> mkdir new1
sftp> dir -l
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Change the name of directory new1 to new2 and verify the result.
sftp> rename new1 new2
sftp> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download file pubkey2 from the server and save it as a local file named public.
sftp> get pubkey2 public
Fetching / pubkey2 to public
/pubkey2                                  100% 225     1.4KB/s   00:00
# Upload a local file pu to the server, save it as puk, and verify the result.
sftp> put pu puk
Uploading pu to / puk
sftp> dir
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp>
# Exit SFTP client view.
sftp> quit
<RouterA>
Example: Configuring SFTP based on 192-bit Suite B algorithms
As shown in Figure 16:
·           Router B acts as the SFTP Suite B server (SSH2), and it uses publickey authentication to authenticate the SFTP client.
·           Router A acts as an SFTP Suite B client (SSH2). After the user on Router A logs in to Router B based on the SFTP Suite B client software, the user can manage and transfer files on Router B as an administrator.
Figure 16 Network diagram
In this example, the server's certificate file is ssh-server-ecdsa384.p12 and the client's certificate file is ssh-client-ecdsa384.p12.
2.      Configure the SFTP client:
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an SFTP client.
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server384 for verifying the server's certificate and enter its view.
[RouterA] pki domain server384
[RouterA-pki-domain-server384] undo crl check enable
[RouterA-pki-domain-server384] quit
# Import local certificate file ssh-server-ecdsa384.p12 to PKI domain server384.
[RouterA] pki import domain server384 p12 local filename ssh-server-ecdsa384.p12
Please enter the key pair name[default name: server384]:
# Display information about local certificates in PKI domain server384.
[RouterA] display pki certificate domain server384 local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 1 (0x1)
    Signature Algorithm: ecdsa-with-SHA384
        Validity
            Not Before: Aug 20 10:08:41 2015 GMT
            Not After : Aug 19 10:08:41 2016 GMT
        Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh server
                Public-Key: (384 bit)
                pub:
                    04:4a:33:e5:99:8d:49:45:a7:a3:24:7b:32:6a:ed:
                    b6:36:e1:4d:cc:8c:05:22:f4:3a:7c:5d:b7:be:d1:
                    e6:9e:f0:ce:95:39:ca:fd:a0:86:cd:54:ab:49:60:
                    10:be:67:9f:90:3a:18:e2:7d:d9:5f:72:27:09:e7:
                    bf:7e:64:0a:59:bb:b3:7d:ae:88:14:94:45:b9:34:
                    d2:f3:93:e1:ba:b4:50:15:eb:e5:45:24:31:10:c7:
                    07:01:f9:dc:a5:6f:81
                ASN1 OID: secp384r1
                NIST CURVE: P-384
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
                10:16:64:2C:DA:C1:D1:29:CD:C0:74:40:A9:70:BD:62:8A:BB:F4:D5
         30:65:02:31:00:80:50:7a:4f:c5:cd:6a:c3:57:13:7f:e9:da:
         c1:72:7f:45:30:17:c2:a7:d3:ec:73:3d:5f:4d:e3:96:f6:a3:
         33:fb:e4:b9:ff:47:f1:af:9d:e3:03:d2:24:53:40:09:5b:02:
         30:45:d1:bf:51:fd:da:22:11:90:03:f9:d4:05:ec:d6:7c:41:
         fc:9d:a1:fd:5b:8c:73:f8:b6:4c:c3:41:f7:c6:7f:2f:05:2d:
         37:f8:52:52:26:99:28:97:ac:6e:f9:c7:01
# Create a PKI domain named client384 for the client's certificate and enter its view.
[RouterA] pki domain client384
[RouterA-pki-domain-client384] undo crl check enable
[RouterA-pki-domain-client384] quit
# Import local certificate file ssh-client-ecdsa384.p12 to PKI domain client384.
[RouterA] pki import domain client384 p12 local filename ssh-client-ecdsa384.p12
Please enter the key pair name[default name: client384]:
# Display information about local certificates in PKI domain client384.
[RouterA]display pki certificate domain client384 local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 2 (0x2)
        Validity
            Not Before: Aug 20 10:10:59 2015 GMT
            Not After : Aug 19 10:10:59 2016 GMT
        Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh client
                pub:
                    04:85:7c:8b:f4:7a:36:bf:74:f6:7c:72:f9:08:69:
                    d0:b9:ac:89:98:17:c9:fc:89:94:43:da:9a:a6:89:
                    41:d3:72:24:9b:9a:29:a8:d1:ba:b4:e5:77:ba:fc:
                    df:ae:c6:dd:46:72:ab:bc:d1:7f:18:7d:54:88:f6:
                    b4:06:54:7e:e7:4d:49:b4:07:dc:30:54:4b:b6:5b:
                    01:10:51:6b:0c:6d:a3:b1:4b:c9:d9:6c:d6:be:13:
                    91:70:31:2a:92:00:76
                ASN1 OID: secp384r1
                NIST CURVE: P-384
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
                BD:5F:8E:4F:7B:FE:74:03:5A:D1:94:DB:CA:A7:82:D6:F7:78:A1:B0
         30:66:02:31:00:d2:06:fa:2c:0b:0d:f0:81:90:01:c3:3d:bf:
         97:b3:79:d8:25:a0:e2:0e:ed:00:c9:48:3e:c9:71:43:c9:b4:
         2a:a6:0a:27:80:9e:d4:0f:f2:db:db:5b:40:b1:a9:0a:e4:02:
         31:00:ee:00:e1:07:c0:2f:12:3f:88:ea:fe:19:05:ef:56:ca:
         33:71:75:5e:11:c9:a6:51:4b:3e:7c:eb:2a:4d:87:2b:71:7c:
         30:64:fe:14:ce:06:d5:0a:e2:cf:9a:69:19:ff
3.      Configure the SFTP server:
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server384 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp384
[RouterB] ssh2 algorithm cipher aes256-gcm
[RouterB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp384
# Specify server384 as the PKI domain of the server's certificate.
[RouterB] ssh server pki-domain server384
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type sftp authentication-type publickey assign pki-domain client384
4.      Establish an SFTP connection to the SFTP server based on the 192-bit Suite B algorithms:
# Establish an SFTP connection to the server at 192.168.0.1.
<RouterA> sftp 192.168.0.1 suite-b 192-bit pki-domain client384 server-pki-domain server384
Username: client001
sftp>
SCP configuration examples
When the device acts as an SCP server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the SCP server.
Example: Configuring SCP with password authentication
As shown in Figure 17:
·           Router B acts as the SCP server and uses password authentication to authenticate the SCP client. The client's username and password are saved on Router B.
·           Router A acts as the SCP client. After the user on Router A logs in to Router B through SCP, the user can transfer files between routers as a network administrator.
Figure 17 Network diagram
1.      Configure the SCP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SCP server.
[RouterB] scp server enable
# Configure an IP address for GigabitEthernet 1/0. The client uses this address as the destination for SCP connection.
# Create an SSH user named client001. Specify the service type as scp and the authentication method as password for the user.
[RouterB] ssh user client001 service-type scp authentication-type password
2.      Configure an IP address for GigabitEthernet 1/0 on the SCP client.
[RouterA] quit
3.      Connect to the SCP server, download file remote.bin from the server, and save it as a local file named local.bin.
<RouterA> scp 192.168.0.1 get remote.bin local.bin
Username: client001
[email protected]’s password:
remote.bin                                       100% 2875     2.8KB/s   00:00
Example: Configuring SCP based on Suite B algorithms
As shown in Figure 18:
·           Router B acts as the SCP Suite B server (SSH2), and it uses publickey authentication to authenticate the SCP client.
·           Router A acts as an SCP Suite B client (SSH2). After the user on Router A logs in to Router B through SCP based on the SCP Suite B client software, the user can transfer files between routers as a network administrator.
Figure 18 Network diagram
1.      Generate the client's certificates and the server's certificates. (Details not shown.)
In this example, the server's certificate files are ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12. The client's certificate files are ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12.
2.      Configure the SCP client:
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an SCP client.
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate ecdsa256 and enter its view.
Certificate:
    Data:
        Version: 3 (0x2)
        Validity
                pub:
                    c7:61:4a:52:51
                NIST CURVE: P-256
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
# Create a PKI domain named client256 for the client's certificate ecdsa256 and enter its view.
Certificate:
    Data:
        Version: 3 (0x2)
        Validity
                pub:
                    12:d0:b4:8a:92
                NIST CURVE: P-256
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
# Create a PKI domain named server384 for verifying the server's certificate ecdsa384 and enter its view.
Certificate:
    Data:
        Version: 3 (0x2)
        Validity
                pub:
                ASN1 OID: secp384r1
                NIST CURVE: P-384
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
# Create a PKI domain named client384 for the client's certificate ecdsa384 and enter its view.
[RouterA] display pki certificate domain client384 local
Certificate:
    Data:
        Version: 3 (0x2)
        Validity
                pub:
                ASN1 OID: secp384r1
                NIST CURVE: P-384
        X509v3 extensions:
                CA:FALSE
            Netscape Comment:
[RouterA] quit
3.      Configure the SCP server:
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate ecdsa256 and import the file of this certificate to this domain. Create a PKI domain named server256 for the server's certificate ecdsa256 and import the file of this certificate to this domain. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate ecdsa384 and import the file of this certificate to this domain. Create a PKI domain named server384 for the server's certificate ecdsa384 and import the file of this certificate to this domain. (Details not shown.)
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp256 ecdh-sha2-nistp384
[RouterB] ssh2 algorithm cipher aes128-gcm aes256-gcm
# Create a local device management user named client002. Authorize the user to use the SSH service and assign the network-admin user role to the user.
4.      Establish an SCP connection to the SCP server:
¡  Based on the 128-bit Suite B algorithms:
# Create an SSH user client001. Specify the authentication method publickey for the user and specify client256 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type scp authentication-type publickey assign pki-domain client256
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 128-bit Suite B algorithms.
<RouterA> scp 192.168.0.1 get src.cfg suite-b 128-bit pki-domain client256 server-pki
-domain server256
Username: client001
src.cfg                                       100% 4814     4.7KB/s   00:00
<RouterA>
¡  Based on the 192-bit Suite B algorithms:
# Create an SSH user client002. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client002 service-type scp authentication-type publickey assign pki-domain client384
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 192-bit Suite B algorithms.
<RouterA> scp 192.168.0.1 get src.cfg suite-b 192-bit pki-domain client384 server-pki
-domain server384
Username: client002
<RouterA>
NETCONF over SSH configuration examples
Unless otherwise noted, devices in the configuration examples are in non-FIPS mode.
When the device acts as a NETCONF-over-SSH server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the NETCONF-over-SSH server.
Example: Configuring NETCONF over SSH with password authentication
As shown in Figure 19:
·           The router acts as the NETCONF-over-SSH server and uses password authentication to authenticate the client. The client's username and password are saved on the router.
·           The host acts as the NETCONF-over-SSH client, using SSH2 client software. After the user on the host logs in to the router through NETCONF over SSH, the user can perform NETCONF operations on the router as a network administrator.
Figure 19 Network diagram
Generating Keys...
Generating Keys...
Generating Keys...
# Enable NETCONF over SSH.
[Router] netconf ssh server enable
# Configure an IP address for GigabitEthernet 1/0. The client uses this address as the destination for NETCONF-over-SSH connection.
# Create an SSH user named client001. Specify the service type as NETCONF and the authentication method as password for the user.
[Router] ssh user client001 service-type netconf authentication-type password
# Verify that you can perform NETCONF operations after logging in to the router. (Details not shown.)
1.      Launch a client that supports NETCONF over SSH.
This example uses NetConf Browser 2015 (version 3.1).
2.      Select File > Connect… from the menu.
The Connect page appears, as shown in Figure 20.
3.      Configure connection parameters as follows:
a.    Select a connection type from the Connection type list.
This example uses SSH2-ganymed.
b.    Select 1.0 from the NETCONF version list.
c.    Enter 192.168.100.49 in the Host field.
d.    Enter 830 in the Port field.
e.    Enter client001 in the Username field.
f.     Use the default setting for the Public Key Authentication area.
4.      Click Connect.
Figure 20 Connecting to the device
5.      Enter password aabbcc, and then click OK, as shown in Figure 21.
Figure 21 Entering the password
The NETCONF configuration interface appears when the client successfully establishes an NETCONF-over-SSH connection to the device. The Log tab of the interface displays the connection information, as shown in Figure 22.
Figure 22 Logging in to the device
6.      In the Command XML area of the NETCONF configuration interface, enter <get-sessions/>, and then click Send.
The following message is displayed in the Output XML area.
<?xml version="1.0" encoding="utf-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2">
  <get-sessions>
    <Session>
      <SessionID>1</SessionID>
      <Line>vty1</Line>
      <UserName>client001</UserName>
      <Since>2016-02-03T15:05:30</Since>
      <LockHeld>false</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
