06-IP Multicast Configuration Guide
HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10006-IP Multicast Configuration Guide
05-Multicast routing and forwarding configuration
Configuring multicast routing and forwarding
Overview
The following tables are involved in multicast routing and forwarding:
·           Multicast routing table of each multicast routing protocol, such as the PIM routing table.
·           General multicast routing table that summarizes multicast routing information generated by different multicast routing protocols. The multicast routing information from multicast sources to multicast groups are stored in a set of (S, G) routing entries.
·           Multicast forwarding table that guides multicast forwarding. The optimal routing entries in the multicast routing table are added to the multicast forwarding table.
The term "interface" in this chapter refers to VLAN interfaces.
RPF check mechanism
A multicast routing protocol relies on the existing unicast routes or static multicast routes to create multicast routing entries. When creating multicast routing entries, the multicast routing protocol uses the reverse path forwarding (RPF) check to ensure the multicast data delivery along the correct paths. The RPF check also helps avoid data loops.
A multicast routing protocol uses the following tables to perform an RPF check:
·           Unicast routing table—Contains unicast routing information.
·           Static multicast routing table—Contains RPF routes that are manually configured.
A static multicast routing table is used for RPF check rather than multicast routing.
RPF check process
A router performs the RPF check on a multicast packet as follows:
1.      The router chooses an optimal route back to the packet source separately from the unicast routing table and the static multicast routing table.
A "packet source" means different things in different situations:
¡  For a packet that travels along the SPT, the packet source is the multicast source.
¡  For a packet that travels along the RPT, the packet source is the RP.
¡  For a bootstrap message from the BSR, the packet source is the BSR.
For more information about the concepts of SPT, RPT, source-side RPT, RP, and BSR, see "Configuring PIM."
2.      The router selects one of the two optimal routes as the RPF route as follows:
¡  If the router uses the longest prefix match principle, the route with a higher subnet mask becomes the RPF route. If the routes have the same mask, the route with a higher route preference becomes the RPF route. If the routes have the same route preference, the unicast route becomes the RPF route.
For more information about the route preference, see Layer 3—IP Routing Configuration Guide.
¡  If the router does not use the longest prefix match principle, the route with a higher route preference becomes the RPF route. If the routes have the same preference, the unicast route becomes the RPF route.
The RPF route determines the RPF interface and the RPF neighbor.
¡  If the RPF route is a unicast route, the outgoing interface of the route is the RPF interface, and the next hop is the RPF neighbor.
¡  If the RPF route is a static multicast route, the RPF interface and RPF neighbor are those specified in the route.
3.      The router checks whether the packet arrived at the RPF interface. If yes, the RPF check succeeds and the packet is forwarded. If not, the RPF check fails and the packet is discarded.
RPF check implementation in multicast
Implementing an RPF check on each received multicast packet brings a big burden to the router. The use of a multicast forwarding table is the solution to this issue. When the router creates a multicast forwarding entry for an (S, G) packet, it sets the RPF interface of the packet as the incoming interface of the (S, G) forwarding entry. After the router receives another (S, G) packet, it looks up the multicast forwarding table for the matching (S, G) entry:
·           If no match is found, the router first determines the RPF route back to the packet source. Then, it creates a forwarding entry with the RPF interface as the incoming interface and performs one of the following actions:
¡  If the receiving interface is the RPF interface, the RPF check succeeds and the router forwards the packet out of all the outgoing interfaces.
¡  If the receiving interface is not the RPF interface, the RPF check fails and the router discards the packet.
·           If a match is found and the receiving interface is the incoming interface of the forwarding entry, the router forwards the packet out of all the outgoing interfaces.
·           If a match is found but the receiving interface is not the incoming interface of the forwarding entry, the router first determines the RPF route back to the packet source. Then, the router performs one of the following actions:
¡  If the RPF interface is the incoming interface, it means that the forwarding entry is correct but the packet traveled along a wrong path. The packet fails the RPF check, and the router discards the packet.
¡  If the RPF interface is not the incoming interface, it means that the forwarding entry has expired. The router replaces the incoming interface with the RPF interface and matches the receiving interface against the RPF interface. If the receiving interface is the RPF interface, the router forwards the packet out of all outgoing interfaces. Otherwise, it discards the packet.
Figure 1 RPF check process
As shown in Figure 1, assume that unicast routes are available in the network and no static multicast routes have been configured on Switch C. Multicast packets travel along the SPT from the multicast source to the receivers. The multicast forwarding table on Switch C contains the (S, G) entry, with VLAN-interface 20 as the incoming interface.
·           If a multicast packet arrives at Switch C on VLAN-interface 20, the receiving interface is the incoming interface of the (S, G) entry. Switch C forwards the packet out of all outgoing interfaces.
·           If a multicast packet arrives at Switch C on VLAN-interface 10, the receiving interface is not the incoming interface of the (S, G) entry. Switch C looks up its unicast routing table and finds that the outgoing interface to the source (the RPF interface) is VLAN-interface 20. In this case, the (S, G) entry is correct, but the packet traveled along a wrong path. The packet fails the RPF check and Switch C discards the packet.
Static multicast routes
Depending on the application environment, a static multicast route can change an RPF route or create an RPF route.
Changing an RPF route
Typically, the topology structure of a multicast network is the same as that of a unicast network, and multicast traffic follows the same transmission path as unicast traffic does. You can configure a static multicast route for a multicast source to change the RPF route. As a result, the router creates a transmission path for multicast traffic that is different from the transmission path for unicast traffic.
Figure 2 Changing an RPF route
As shown in Figure 2, when no static multicast route is configured, Switch C's RPF neighbor on the path back to the source is Switch A. The multicast data from the source travels through Switch A to Switch C. You can configure a static multicast route on Switch C and specify its RPF neighbor on the route back to the source as Switch B. Then, the multicast data from the source travels along the path: Switch A to Switch B and then to Switch C.
Creating an RPF route
When a unicast route is blocked, multicast forwarding might be stopped due to lack of an RPF route. In this case, you can create an RPF route by configuring a static multicast route for a multicast source. Then, a multicast routing entry is created to guide multicast forwarding.
Figure 3 Creating an RPF route
As shown in Figure 3, the RIP domain and the OSPF domain are unicast isolated from each other. For the receiver hosts in the OSPF domain to receive multicast packets from the multicast source in the RIP domain, you must configure Switch C and Switch D as follows:
·           On Switch C, configure a static multicast route for the multicast source and specify Switch B as the RPF neighbor.
·           On Switch D, configure a static multicast route for the multicast source and specify Switch C as the RPF neighbor.
A static multicast route is effective only on the multicast router on which it is configured, and will not be advertised throughout the network or redistributed to other routers.
Multicast routing and forwarding configuration task list
Tasks at a glance
(Required.) Enabling IP multicast routing
(Optional.) Configuring multicast routing and forwarding
·          Configuring static multicast routes
·          Specifying the longest prefix match principle
·          Configuring multicast load splitting
·          Configuring a multicast forwarding boundary
·          Configuring static multicast MAC address entries_Ref357688262
The device can route and forward multicast data only through the primary IP addresses of interfaces, rather than their secondary addresses or unnumbered IP addresses. For more information about primary and secondary IP addresses, and IP unnumbered, see Layer 3—IP Services Configuration Guide.
Enable IP multicast routing before you configure any Layer 3 multicast functionality on the public network or VPN instance.
To enable IP multicast routing:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable IP multicast routing and enter MRIB view.
By default, IP multicast routing is disabled.
Before you configure multicast routing and forwarding, complete the following tasks:
·           Configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
·           Enable PIM-DM or PIM-SM.
To configure a static multicast route for a given multicast source, you can specify an RPF interface or an RPF neighbor for the multicast traffic from that source.
To configure a static multicast route:
Step
Remarks
N/A
2.      Configure a static multicast route.
ip rpf-route-static  [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number } [ preference preference ]
By default, static multicast routes do not exist.
3.      (Optional.) Delete static multicast routes.
·          Delete a specific static multicast route:
undo ip rpf-route-static [ vpn-instance vpn-instance-name ]
·          Delete all static multicast routes:
delete ip rpf-route-static
N/A
You can enable the multicast router to use the longest prefix match principle for RPF route selection. For more information about RPF route selection, see "RPF check process."
To specify the longest prefix match principle:
Step
Remarks
N/A
2.      Enter MRIB view.
N/A
3.      Specify the longest prefix match principle.
longest-match
By default, the route preference principle is used.
You can enable the multicast router to split multiple data flows on a per-source basis or on a per-source-and-group basis.
To configure multicast load splitting:
Step
Remarks
N/A
2.      Enter MRIB view.
N/A
3.      Configure multicast load splitting.
By default, multicast load splitting is disabled.
This command does not take effect on BIDIR-PIM.
You can configure an interface as a multicast forwarding boundary for a multicast group range. The interface cannot receive nor forward multicast packets for the group.
TIP
TIP:
You do not need to enable IP multicast routing before this configuration.
To configure a multicast forwarding boundary:
Step
Remarks
N/A
2.      Enter interface view.
N/A
3.      Configure the interface as a multicast forwarding boundary for a multicast group range.
By default, the interface is not configured as a multicast forwarding boundary for a multicast group range.
In Layer 2 multicast, multicast MAC address entries can be dynamically created or added through Layer 2 multicast protocols (such as IGMP snooping). You can also manually configure static multicast MAC address entries by binding multicast MAC addresses and ports to control the destination ports of the multicast data.
TIP
TIP:
·       You do not need to enable IP multicast routing before this configuration.
·       The multicast MAC address that can be manually configured in a multicast MAC address entry must be unused. A multicast MAC address is the MAC address in which the least significant bit of the most significant octet is 1.
You can configure static multicast MAC address entries on the specified interfaces in system view or on the current interface in interface view.
To configure a static multicast MAC address entry in system view:
Step
Remarks
N/A
2.      Configure a static multicast MAC address entry.
By default, static multicast MAC address entries do not exist.
To configure a static multicast MAC address entry in interface view:
Step
Remarks
N/A
2.      Enter Ethernet interface/Layer 2 aggregate interface view.
N/A
3.      Configure a static multicast MAC address entry.
Displaying and maintaining multicast routing and forwarding
CAUTION
CAUTION:
The reset commands might cause multicast data transmission failures.
Display information about static multicast MAC address table.
Display information about the interfaces maintained by the MRIB.
Display multicast boundary information.
Display information about the DF for multicast forwarding.
display multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
Display statistics for multicast forwarding events.
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
Display multicast forwarding table information.
Display information about the DF list in the multicast forwarding table.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
Display information about the multicast routing table.
Display information about the static multicast routing table.
Display RPF route information about the multicast source.
Clear statistics for multicast forwarding events.
Clear forwarding entries from the multicast forwarding table.
Clear routing entries from the multicast routing table.
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number } * | all }
When a routing entry is removed, the associated forwarding entry is also removed. When a forwarding entry is removed, the associated routing entry is also removed.
Multicast routing and forwarding configuration examples
Network requirements
As shown in Figure 4:
·           PIM-DM runs in the network. All switches in the network support multicast.
·           Switch A, Switch B and Switch C run OSPF.
·           Typically, the receiver host can receive the multicast data from the source through the path: Switch A to Switch B, which is the same as the unicast route.
Configure the switches so that the receiver host receives the multicast data from the source through the following path: Switch A to Switch C to Switch B. This path is different than the unicast route.
Figure 4 Network diagram
Configuration procedure
1.      Assign an IP address and subnet mask to each interface according to Figure 4. (Details not shown.)
2.      Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3.      Enable IP multicast routing, and enable IGMP and PIM-DM:
# On Switch B, enable IP multicast routing.
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable IGMP on the receiver-side interface (VLAN-interface 100).
[SwitchB-Vlan-interface100] igmp enable
# Enable PIM-DM on the other interfaces.
[SwitchB-Vlan-interface101] pim dm
[SwitchB-Vlan-interface102] pim dm
# On Switch A, enable IP multicast routing, and enable PIM-DM on each interface.
[SwitchA] multicast routing
[SwitchA-mrib] quit
[SwitchA-Vlan-interface200] pim dm
[SwitchA-Vlan-interface102] pim dm
# Enable IP multicast routing and PIM-DM on Switch C in the same way Switch A is configured. (Details not shown.)
4.      Display the RPF route to Source on Switch B.
[SwitchB] display multicast rpf-info 50.1.1.100
 RPF information about source 50.1.1.100:
     RPF interface: Vlan-interface102, RPF neighbor: 30.1.1.2
     Referenced route/mask: 50.1.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
The output shows that the current RPF route on Switch B is contributed by a unicast routing protocol and the RPF neighbor is Switch A.
5.      Configure a static multicast route on Switch B, specifying Switch C as its RPF neighbor on the route to Source.
[SwitchB] ip rpf-route-static 50.1.1.100 24 20.1.1.2
# Display information about the RPF route to Source on Switch B.
     RPF interface: Vlan-interface101, RPF neighbor: 20.1.1.2
     Referenced route type: multicast static
The output shows that:
·           The RPF route on Switch B is the configured static multicast route.
·           The RPF neighbor of Switch B is Switch C.
As shown in Figure 5:
·           PIM-DM runs in the network and all switches in the network support IP multicast.
·           Switch B and Switch C run OSPF, and have no unicast routes to Switch A.
·           Typically, the receiver host receives the multicast data from the Source 1 in the OSPF domain.
Configure the switches so that the receiver host receives multicast data from the Source 2, which is outside the OSPF domain.
Figure 5 Network diagram
1.      Assign an IP address and subnet mask to each interface according to Figure 5. (Details not shown.)
2.      Configure OSPF on Switch B and Switch C. (Details not shown.)
# On Switch C, enable IP multicast routing.
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC-Vlan-interface100] igmp enable
# Enable PIM-DM on VLAN-interface 101.
[SwitchC] interface vlan-interface 101
[SwitchC-Vlan-interface101] pim dm
[SwitchC-Vlan-interface101] quit
[SwitchA-mrib] quit
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] pim dm
[SwitchA-Vlan-interface300] quit
# Enable IP multicast routing and PIM-DM on Switch B in the same way Switch A is configured. (Details not shown.)
4.      Display information about their RPF routes to Source 2 on Switch B and Switch C.
[SwitchC] display multicast rpf-info 50.1.1.100
No output is displayed, because no RPF routes to Source 2 exist on Switch B or Switch C.
5.      Configure a static multicast route:
# Configure a static multicast route on Switch B, specifying Switch A as its RPF neighbor on the route to Source 2.
[SwitchB] ip rpf-route-static 50.1.1.100 24 30.1.1.2
# Configure a static multicast route on Switch C, specifying Switch B as its RPF neighbor on the route to Source 2.
[SwitchC] ip rpf-route-static 10.1.1.100 24 20.1.1.2
# Display information about their RPF routes to Source 2 on Switch B and Switch C.
The output shows that the RPF routes to Source 2 exist on Switch B and Switch C. The routes are the configured static routes.
Troubleshooting multicast routing and forwarding
Static multicast route failure
Symptom
No dynamic routing protocol is enabled on the routers, and the physical status and link layer status of interfaces are both up, but the static multicast route fails.
Solution
To resolve the problem:
1.      Use the display multicast routing-table static command to display information about static multicast routes. Verify that the static multicast route has been correctly configured and that the route entry exists in the static multicast routing table.
2.      Check the type of interface that connects the static multicast route to the RPF neighbor. If the interface is not a point-to-point interface, be sure to specify the address for the RPF neighbor.
3.      If the problem persists, contact H3C Support.
