- 14-WLAN Command Reference (Fat AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management commands
- 03-Band navigation commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WLAN QoS commands
- 09-Cloud connection commands
- 09-WLAN multicast optimization commands
- 10-WLAN load balancing commands
09-Cloud connection commands | 47.76 KB |
The term "AP" in this document refers to MSR routers that offer WLAN services as fat APs. For more information, see "Compatibility of hardware and AP functionality."
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the H3C Oasis server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 10 to 600 seconds.
If the device does not receive a response from the H3C Oasis server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management ping
Use cloud-management ping to set the interval at which the local device sends ping packets to the H3C Oasis server.
Use undo cloud-management ping to restore the default.
cloud-management ping interval
The local device sends ping packets to the H3C Oasis server at intervals of 60 seconds.
interval: Specifies the interval at which the local device sends ping packets to the H3C Oasis server, in the range of 10 to 600 seconds.
After the connection to the H3C Oasis server is established, the local device sends ping packets to the server periodically to prevent NAT entry aging. Reduce the interval value if the network condition is poor or the NAT entry aging time is short.
The H3C Oasis server does not respond to ping packets.
# Configure the local device to send ping packets to the H3C Oasis server at intervals of 120 seconds.
[Sysname] cloud-management ping 120
cloud-management server domain
Use cloud-management server domain to configure the domain name of the H3C Oasis server.
Use undo cloud-management server domain to restore the default.
cloud-management server domain domain-name
The domain name of the H3C Oasis server is not configured.
domain-name: Specifies the domain name of the H3C Oasis server, a case-sensitive string of 1 to 253 characters.
Before you configure the domain name of the H3C Oasis server, make sure a DNS server is configured to translate the domain name.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the H3C Oasis server as lvzhouv3.h3c.com.
[Sysname] cloud-management server domain lvzhouv3.h3c.com
cloud-management server port
Use cloud-management server port to specify the TCP port number used to establish cloud connections.
Use undo cloud-management server port to restore the default.
cloud-management server port port-number
TCP port number 443 is used to establish cloud connections.
port-number: Specifies a TCP port number in the range of 1 to 65535.
After you change the port number, the device terminates the cloud connections that have been established (if any) and uses the new port number to establish cloud connections.
# Specify the TCP port number used to establish cloud connections as 80.
[Sysname] cloud-management server port 80
display cloud-management state
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state : Established
Device state : Request_success
Cloud server address : 139.217.27.153
Cloud server domain name : oasis.h3c.com
Local port : 443
Connected at : Wed Jan 27 14:18:40 2018
Duration : 00d 00h 02m 01s
Process state : Message received
Failure reason : N/A
Last down reason : socket connection error (Details:N/A)
Last down at : Wed Jan 27 13:18:40 2018
Last report failure reason : N/A
Last report failure at : N/A
Dropped packets after reaching buffer limit : 0
Total dropped packets : 1
Last report incomplete reason : N/A
Last report incomplete at : N/A
Buffer full count : 0
Cloud connection state |
Cloud connection state: Unconnected, Request, and Established. |
Device state |
Local device state: · Idle—In idle state. · Connecting—Connecting to the H3C Oasis server. · Request_CAS_url—Sent a central authentication service (CAS) URL request. · Request_CAS_url_success—Requesting CAS URL succeeded. · Request_CAS_TGT—Sent a ticket granting ticket (TGT) request. · Request_CAS_TGT_success—Requesting TGT succeeded. · Request_CAS_ST—Sent a service ticket (ST) request. · Request_CAS_ST_success—Requesting ST succeeded. · Request_cloud_auth—Sent an authentication request. · Request_cloud_auth_success—Authentication succeeded. · Register—Sent a registration request. · Register_success—Registration succeeded. · Request—Sent a handshake request. · Request_success—Handshake succeeded. |
Cloud server address |
IP address of the H3C Oasis server. |
Cloud server domain name |
Domain name of the H3C Oasis server. |
Local port |
TCP port number used to establish cloud connections. |
Connected at |
Time when the cloud connection was established. |
Duration |
Duration since the establishment of the cloud connection. |
Process state |
Cloud connection processing state: · DNS not parsed. · DNS parsed. · Message not sent. · Message sent. · Message not received. · Message received. |
Failure reason |
Cloud connection failure reason: · DNS parse failed. · Socket connection failed. · SSL creation failed. · Sending CAS url request failed. · Sending CAS TGT failed. · Sending CAS ST failed. · Sending cloud auth failed. · Sending register failed. · Processing CAS url response failed. · Processing CAS TGT response failed. · Processing CAS ST response failed. · Processing cloud auth response failed. · Processing register response failed. · Sending handshake request failed. · Processing handshake failed. · Sending websocket request failed. · Processing websocket packet failed. |
Last down reason |
Reason for the most recent cloud connection interruption: · Device or process rebooted. · Socket connection error. · Configuration changed. · Received websocket close packet from cloud. · Keepalive expired. · Packet processing failed. · Main connection went down. · Cloud reset connection. · Memory reached threshold. |
Last down at |
Time when the cloud connection went down most recently. |
Last report failure reason |
Reason for the most recent cloud connection packet sending failure: · Tunnel is being deleted. · Tunnel socket is invalid. · Failed to convert string to json. · Failed to convert json to string. · Failed to create message node. · Tunnel is not ready. · Failed to create packet buffer. · SSL sending failure. If the reason is SSL sending failure, one of the following detailed reason will be displayed: · ssl error none. · ssl error ssl. · ssl error read. · ssl error write. · ssl error x509 lookup. · ssl error syscall. · ssl error zero return. · ssl error connect. · ssl error accept. |
Last report failure at |
Time when the most recent cloud connection packet sending failure occurred. |
Dropped packets after reaching buffer limit |
Number of packets that are dropped because the CMTNL buffer limit is reached. |
Total dropped packets |
Total number of dropped packets. |
Last report incomplete reason |
Reason for the most recent unfinished packet sending: · Interrupted system call. · Socket buffer is full. |
Last report incomplete at |
Time when the most recent unfinished packet sending occurred. |
Buffer full count |
Number of times that the buffer becomes full. |
