09-ACL and QoS Configuration Guide
HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release757X-6W10009-ACL and QoS Configuration Guide
03-Time range configuration
03-Time range configuration 55.21 KB
Configuring time ranges
You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. For example, you can implement time-based ACL rules by applying a time range to them. If a time range does not exist, the service based on the time range does not take effect.
The following basic types of time ranges are available:
·          Periodic time range—Recurs periodically on a day or days of the week.
·          Absolute time range—Represents only a period of time and does not recur.
A time range is uniquely identified by the time range name. You can create a maximum of 1024 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements. The active period of a time range is calculated as follows:
1.        Combining all periodic statements.
2.        Combining all absolute statements.
3.        Taking the intersection of the two statement sets as the active period of the time range.
Configuration procedure
Step
Remarks
1.       Enter system view.
N/A
2.       Create or edit a time range.
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
By default, no time ranges exist.
Displaying and maintaining time ranges
Execute the display command in any view.
Display time range configuration and status.
display time-range { time-range-name | all }
Time range configuration example
Network requirements
As shown in Figure 1, configure an ACL on Device A to allow only Host A to access the server from 8:00 to 18:00 on working days from June 2015 to the end of the year.
Figure 1 Network diagram
# Create a time range for the period from 8:00 to 18:00 on working days from June 2015 to the end of the year.
[DeviceA] time-range work 08:00 to 18:00 working-day from 00:00 6/1/2015 to 24:00 12/31/2015
# Create an IPv4 basic ACL numbered 2001, and configure a rule in the ACL to permit packets only from 192.168.1.2/32 during the time range work.
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 192.168.1.2 0 time-range work
[DeviceA-acl-ipv4-basic-2001] rule deny source any time-range work
# Apply IPv4 basic ACL 2001 to filter outgoing packets on GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] packet-filter 2001 outbound
# Verify that the time range work is active on Device A.
[DeviceA] display time-range all
Current time is 13:58:35 6/29/2015 Friday
Time-range : work (Active)
 from 00:00 6/1/2015 to 00:00 1/1/2016
