01-EVI commands | 238.62 KB |
display evi isis graceful-restart status
display evi neighbor-discovery client member
display evi neighbor-discovery client statistics
display evi neighbor-discovery client summary
display evi neighbor-discovery server member
display evi neighbor-discovery server statistics
display evi neighbor-discovery server summary
evi isis timer holding-multiplier
evi neighbor-discovery authentication
evi neighbor-discovery client enable
evi neighbor-discovery client register-interval
evi neighbor-discovery server enable
evi selective-flooding mac-address
reset evi neighbor-discovery client statistics
reset evi neighbor-discovery server statistics
snmp-agent trap enable evi-isis
EVI commands
EVI requires a license to run on the device. For information about feature licensing, see Fundamentals Configuration Guide.
display evi arp-suppression
Use display evi arp-suppression to display ARP flood suppression entries.
In standalone mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
In IRF mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
interface tunnel interface-number: Specifies an EVI tunnel interface by its number.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries on Tunnel 101.
<Sysname> display evi arp-suppression interface tunnel 101
IP Address????? MAC Address??? VLAN ID? Interface??????????????? Aging Status
1.1.1.2???????? 000f-e201-0101 1??????? EVI-link1??????????????? 14??? Valid
1.1.1.3???????? 000f-e201-0202 1??????? EVI-link1??????????????? 18??? Invalid
1.1.1.4???????? 000f-e201-0203 1??????? EVI-link1??????????????? 10??? Collision
# Display the total number of ARP flood suppression entries on Tunnel 101.
<Sysname> display evi arp-suppression interface tunnel 101 count
Total entries: 3
EVI-Link interface where the entry has been learned. |
Aging |
Remaining lifetime (in minutes) of the EVI ARP flood suppression entry. When the timer expires, the entry is deleted. |
Status |
Entry status: · Valid—The edge device can use this entry to reply to ARP requests. · Invalid—No update packets were received for this entry in the most recent 15 minutes. An invalid entry cannot be used. If the Invalid state lasts 10 minutes, the entry will be deleted. · Collision—An ARP reply was received for the IP address in this entry, but the sender MAC address in the reply was different from the MAC address in this entry. This entry cannot be used and will be removed one minute later after its state changed to Collision. |
evi arp-suppression enable
reset evi arp-suppression
display evi isis brief
Use display evi isis brief to display brief information about EVI IS-IS processes.
display evi isis brief [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays brief information about all EVI IS-IS processes.
# Display brief information about an EVI IS-IS process.
<Sysname> display evi isis brief
Site ID: 10
Isolation Count: 0
Process ID: 0
Network-entity: 00.0011.2200.0001.00
LSP-length receive: 16384
LSP-length originate: 1400
Timers:
? LSP-max-age: 1200s
? LSP-refresh: 900s
Site ID |
Local site ID. |
Isolation Count |
Number of remote sites that have isolated the device because of site ID conflicts. · If the isolation count is 0, there is no conflict. The device can send hello packets. · If the isolation count is not 0, there are conflicts. The device cannot send hello packets. You must reconfigure the site ID. |
Network-entity |
Network entity name of the EVI IS-IS process. |
LSP-length receive |
Maximum length of incoming LSPs. |
LSP-length originate |
Maximum length of LSPs that the EVI IS-IS process can generate. |
Timers |
· LSP-max-age—Maximum lifetime for the LSPs generated by the EVI IS-IS process. · LSP-refresh—Interval at which the EVI IS-IS process sends LSPs to refresh remote LSDBs. |
Use display evi isis graceful-restart status to display the GR state of EVI IS-IS processes.
display evi isis graceful-restart status [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays the GR state of all EVI IS-IS processes.
# Display the GR state of all EVI IS-IS processes.
<Sysname> display evi isis graceful-restart status
Process ID: 0
Restart status: RESTARTING
Restart phase: LSDB synchronization
Restart interval: 300s
T3 remaining time: 65531s
Total number of interfaces: 1
Number of waiting LSPs: 0
T2 remaining time: 56s
? Interface: EVI-Link0
??? T1 remaining time: 2
??? RA received: N
??? CSNP received: N
??? T1 expired number: 3
Restart status |
Graceful Restart state: · COMPLETE—Restart has been completed. · STARTING—EVI IS-IS process begins to restart. · RESTARTING—EVI IS-IS process is restarting. · UNKNOWN—Unknown state. |
Restart phase |
Restart phase: · Initialization—EVI IS-IS process is initializing. · LSDB synchronization—Peer EVI IS-IS processes are synchronizing LSDBs. · MAC receiving—EVI IS-IS process is receiving reported local MAC addresses. · LSP stable—EVI IS-IS process is generating LSPs. · LSP generation—EVI IS-IS process is refreshing and flooding LSPs to adjacent EVI neighbors. · Finish—Graceful Restart is complete. · Unknown—Unknown phase. |
T3 remaining time |
The remaining time (in seconds) of the T3 timer. The GR process fails if it is not complete before this timer expires. |
T2 remaining time |
The remaining time (in seconds) of the T2 timer. The T2 timer sets the LSDB synchronization interval. |
T1 remaining time |
The remaining time (in seconds) of the T1 timer. The T1 timer sets the interval for the restarting device to retransmit hello messages with the RR bit set (restart request messages). |
display evi isis local-mac
Use display evi isis local-mac to display local MAC reachability information maintained by EVI IS-IS.
display evi isis local-mac { dynamic | static } [ interface tunnel interface-number [ vlan vlan-id ] [ filtered | passed ] [ count ] ]
display evi isis local-mac nonadvertised [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
dynamic: Displays the dynamic MAC addresses for the local site.
nonadvertised: Displays the MAC addresses that cannot be advertised to remote sites. Nonadvertised MAC addresses include blackhole MAC addresses, multiport unicast MAC addresses, multicast MAC addresses, and MAC addresses that have been configured by using the evi selective-flooding mac-address command.
static: Displays the static MAC addresses for the local site.
interface tunnel interface-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays local MAC reachability information that EVI IS-IS maintains for each EVI tunnel interface.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays local MAC reachability information for all VLANs.
filtered: Specifies the local MAC addresses that are filtered by a routing policy. These MAC addresses cannot be advertised to remote sites.
passed: Specifies the local MAC addresses that are not filtered by a routing policy. These MAC addresses can be advertised to remote sites.
count: Displays the number of MAC addresses that match the command.
# Display local dynamic MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac dynamic
Process ID: 0
Tunnel interface: Tunnel1
? VLAN ID: 100
??? MAC address: 00aa-00bb-00cc
??? MAC address: 00aa-00cc-00bb (Filtered)
??? MAC address: 00cc-00aa-00bb
? VLAN ID: 50
??? MAC address: 00bb-00aa-00cc
??? MAC address: 00bb-00cc-00aa
# Display advertisable local dynamic MAC addresses on EVI tunnel interface Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed
Process ID: 0
? VLAN ID: 100
? VLAN ID: 50
# Display local nonadvertised MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac nonadvertised
MAC Flags: F-Flooding, B-Blackhole, P-Multiport, M-Multicast
Process ID: 3
? Tunnel interface: Tunnel3
? VLAN ID: 111
??? MAC address: 0005-0005-0005
????????? Flags: F
# Display local static MAC reachability information for all EVI tunnel interfaces.
<Sysname> display evi isis local-mac static
Process ID: 0
? VLAN ID: 100
? VLAN ID: 50
# Display the local static MAC addresses that are filtered by the routing policy on Tunnel 1. These MAC addresses cannot be advertised.
<Sysname> display evi isis local-mac static interface tunnel 1 filtered
Process ID: 0
? VLAN ID: 100
? VLAN ID: 50
# Display the number of local dynamic MAC addresses on Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 count
5 MAC addresses found.
# Display the number of advertisable local dynamic MAC addresses on Tunnel 1.
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed count
4 MAC addresses found.
# Display the number of local static MAC addresses that are filtered by the routing policy on Tunnel 1.
<Sysname> display evi isis local-mac static interface tunnel 1 filtered count
1 MAC addresses found.
Process ID |
EVI IS-IS process ID. |
Tunnel interface |
EVI tunnel interface where the EVI IS-IS process is running. |
VLAN ID |
Active VLAN on the EVI tunnel interface. |
MAC address |
MAC addresses in the VLAN. |
(Filtered) |
The MAC address is filtered by a routing policy. It cannot be advertised to remote sites. |
Flags |
Flag of a local nonadvertised MAC address: · F—MAC address that has been configured by using the evi selective-flooding mac-address command. · B—Blackhole MAC address. · P—Multiport unicast MAC address. · M—Multicast MAC address. |
display evi isis lsdb
Use display evi isis lsdb to display the LSDBs of EVI IS-IS processes.
display evi isis lsdb [ local | lsp-id lspid | verbose ] * [ process-id ]
local: Displays locally generated LSPs.
lsp-id lspid: Specifies an LSP identifier in SYSID.Pseudonode ID-fragment num format. The SYSID argument represents the originating node or pseudo node. The Pseudonode ID argument is separated by a dot from SYSID and by a hyphen from fragment num.
verbose: Displays detailed information about LSPs in the LSDB. If you do not specify this keyword, this command displays LSP summaries.
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays LSP information for all EVI IS-IS processes.
# Display LSP summaries for all EVI IS-IS processes.
<Sysname> display evi isis lsdb
???????????? ??Link state database information for EVI-ISIS(0)
LSP ID???????????????? Seq num???? Checksum? Holdtime? Length??? Overload
0011.2200.0001.00-00*? 0x000000f3? 0xd95e??? 45??????? 47??????? 0
0011.2200.0101.00-00?? 0x00000017? 0xbb6f??? 1139????? 85??????? 0
0011.2200.0101.02-00?? 0x00000002? 0x7973??? 805?????? 54??????? 0
Flags: *-Self LSP, +-Self LSP(Extended)
# Display detailed LSP information for all EVI IS-IS processes.
<Sysname> display evi isis lsdb verbose
??????????????? Link state database information for EVI-ISIS(1)
LSP ID: 3822.d69e.ee00.00-00*
Sequence number: 0x00000001
Checksum: 0xe0b5
Holdtime: 820s
Length: 47
Overload: 0
Source: 3822.d69e.ee00.00
Neighbour
??? ID: 3ce5.a600.7600.02, Cost: 16777214
LSP ID: 3ce5.a600.7600.00-00
Sequence number: 0x00000007
Checksum: 0xc98a
Holdtime: 1163s
Length: 72
Overload: 0
Source: 3ce5.a600.7600.00
Neighbour
MAC addresses:
? VLAN ID: 1?? Confidence: 1
??? 3822-d69e-ef68
??? d485-64aa-7f23
??? 3408-0499-b44c
LSP ID: 3ce5.a600.7600.02-00
Checksum: 0xe16d
Holdtime: 819s
Length: 54
Overload: 0
Source: 3ce5.a600.7600.02
Neighbour
??? ID: 3822.d69e.ee00.00, Cost: 0
??? ID: 3ce5.a600.7600.00, Cost: 0
Table 5 Command output
LSP ID |
LSP ID: · An asterisk mark (*) suffix indicates that the LSP segment is generated by the default EVI IS-IS system on the local device. · A plus sign (+) suffix indicates that the LSP segment is generated by an EVI IS-IS virtual system on the local device. · IDs of remote LSPs do not have a suffix. |
Holdtime |
LSP lifetime in seconds, which counts down over time. |
Overload |
Overload bit flag in the LSP: · 1—The bit is set. · 0—The bit is not set. |
Source |
System ID of the LSP generating device. |
Neighbour |
Neighbors of the LSP generating device. |
ID |
System ID of the neighbor. |
Cost |
Cost of the link between the LSP generating device and its neighbor. |
MAC addresses |
MAC addresses that can be reached through the LSP generating device. |
VLAN ID |
VLAN in which the MAC addresses are learned. |
Confidence |
LSP credibility: · 0—Trustworthy. · 1—Untrustworthy. |
display evi isis peer
Use display evi isis peer to display EVI IS-IS neighbor information.
display evi isis peer [ process-id ]
process-id: Specifies an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command displays neighbor information for all EVI IS-IS processes.
# Display neighbor information for EVI IS-IS process 0. In this example, no site ID conflict exists.
<Sysname> display evi isis peer 0
Process ID: 0
System ID: 0011.2200.0101
Link interface: Tunnel1
Circuit ID: 0011.2200.0301.01
State: Up
Site ID: 1
Hold time: 29s
Neighbour DED priority: 64
Uptime: 00:10:56
Process ID: 0
Link interface: EVI-Link0
Circuit ID: ---
State: Init
Site ID: 1
Hold time: 29s
Uptime: 00:00:58
# Display neighbor information for EVI IS-IS process 0. In this example, a site ID conflict exists.
Process ID: 0
System ID: 0011.2200.0301
Circuit ID: ---
State: Init
Site ID: 1 (Conflict)
Hold time: 27s
Neighbor DED priority: 64
Uptime: 00:00:00
Table 6 Command output
System ID |
System ID of the EVI neighbor. |
Link interface |
· Tunnel—Local tunnel interface. · EVI-link—Local EVI-Link interface. |
Circuit ID |
Link ID. |
State |
Adjacency state: · Init—Neighbor state is initializing. · Up—Adjacency has been established. · Down—Adjacency is lost. |
Site ID |
Site ID of the EVI neighbor. (Conflict) indicates that the site ID of the neighbor conflicts with the local site ID. A site ID conflict occurs in the following situations: · The edge devices at different sites use the same site ID. · The edge devices at a multihomed site use different site IDs. |
Hold time |
Adjacency hold timer in seconds, which counts down over time. If no hello packet has been received from the neighbor before this timer expires, the device removes the adjacency with the neighbor. If a hello packet is received, the hold timer restarts. |
Neighbour DED Priority |
DED priority of the neighbor. |
Uptime |
The amount of time that the adjacency with the neighbor has lasted. This field uses the hours:minutes:seconds format. |
display evi isis remote-mac
Use display evi isis remote-mac to display remote MAC reachability information maintained by EVI IS-IS.
display evi isis remote-mac [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
interface tunnel interface-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays remote MAC reachability information that EVI IS-IS maintains for each EVI tunnel interface.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays remote MAC reachability information for all VLANs.
count: Displays the number of remote MAC addresses that match the command.
# Display remote MAC reachability information that EVI IS-IS has for all EVI tunnel interfaces.
<Sysname> display evi isis remote-mac
Process ID: 0
? Tunnel interface: Tunnel1
??VLAN ID: 3
??? MAC address: 0033-0011-0022
????? Interface:? EVI-Link0
????? ????Flags:? 0x2
? VLAN ID: 2
??? MAC address: 0022-0033-0011
??? MAC address: 0033-0022-0011
# Display the number of remote MAC addresses that EVI IS-IS has on Tunnel 1.
<Sysname> display evi isis remote-mac interface tunnel 1 count
3 mac address(es) found.
Table 7 Command output
Process ID |
EVI IS-IS process ID. The ID of an EVI IS-IS process is always the same as the EVI tunnel interface where the EVI IS-IS process is running. |
Tunnel interface |
VLAN ID |
MAC address |
EVI link index. |
Flags |
Remote MAC address flag: · 0x1—The remote MAC address conflicts with a local dynamic MAC address. · 0x2—The remote MAC address has been added to the MAC address table in the data plane. · 0x4—The remote MAC address conflicts with a local static MAC address or a MAC address that has been configured for selective flooding. |
display evi isis tunnel
Use display evi isis tunnel to display EVI IS-IS settings on EVI tunnel interfaces.
display evi isis tunnel [ tunnel-number ]
tunnel-number: Specifies an EVI tunnel interface by its number. If you do not specify an EVI tunnel interface, this command displays EVI IS-IS settings on all EVI tunnel interfaces.
# Display EVI IS-IS settings on Tunnel 101.
<Sysname> display evi isis tunnel 101
Tunnel101
MTU: 1400
DED: Yes
DED priority: 80
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
LSP transmit-throttle count: 5
AEF: Yes
EVI-Link0??? DED: Yes
LAV:
? 1,50,100
Table 8 Command output
MTU |
Link MTU of the tunnel. |
DED |
DED election result: · Yes—The device is a DED in the EVI network. · No—The device is not a DED in the EVI network. |
DED priority |
DED priority of the device on the EVI tunnel interface. |
Hello timer |
Interval (in seconds) at which EVI IS-IS sends hello packets to maintain the adjacencies with its neighbors. |
Hello multiplier |
Multiplier for calculating the EVI IS-IS adjacency hold time. |
CSNP timer |
Interval at which the edge device sends CSNP packets to advertise LSP summaries for LSDB synchronization. |
LSP timer |
Minimum LSP transmit interval in milliseconds. |
LSP transmit-throttle count |
Maximum number of LSPs that can be sent at each interval. |
AEF |
Qualification of the device to be an appointed edge forwarder for extended VLANs at a multihomed site: · No—The EVI tunnel interface of the device has been down. The device cannot be an appointed edge forwarder for any extended VLANs. · Yes—The EVI tunnel interface of the device is up. The device can be an appointed edge forwarder for extended VLANs. |
EVI-link |
EVI virtual link. |
LAV |
Active VLANs on the EVI tunnel interface. The interface extends only active VLANs to remote sites. |
display evi link
Use display evi link to display information about EVI links on an EVI tunnel.
display evi link interface tunnel interface-number
# Display information about EVI links on Tunnel 1.
<Sysname> display evi link interface tunnel 1
Interface???? Status Source????????? Destination
EVI-Link0???? UP???? 1.1.1.1???????? 1.1.2.1
EVI-Link1???? UP???? 1.1.1.1???????? 1.1.3.1
Table 9 Command output
EVI-Link interface name. |
Status |
EVI link status: · UP—The EVI link is connected. · DOWN—The EVI link is disconnected. |
Source |
Local address of the EVI link. All the EVI links use the source address of the EVI tunnel. |
Destination |
Remote address of the EVI link. |
display evi mac-address
Use display evi mac-address to display remote MAC address entries.
In standalone mode:
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ slot slot-number ]
In IRF mode:
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ chassis chassis-number slot slot-number ]
mac-address mac-address: Specifies a remote MAC address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the global active MPU. (In standalone mode.)
count: Displays the number of remote MAC address entries that match the command.
# Display remote MAC address entries on Tunnel 101.
<Sysname> display evi mac-address interface tunnel 101
MAC Address????? VLAN ID?? Port
000f-e201-0101?? 1???????? EVI-link1
000f-e202-0101?? 2???????? EVI-link1, EVI-link2
# Display the total number of remote MAC address entries on Tunnel 101.
<Sysname> display evi mac-address interface tunnel 101 count
Total entries: 2
Table 10 Command output
MAC Address |
Remote MAC address. |
VLAN ID |
VLAN that has the remote MAC address. |
Port |
Outgoing EVI-Link interface for reaching the remote MAC address. N/A indicates that the EVI-Link interface where the MAC address was learned has been removed. |
Use display evi neighbor-discovery client member to display information about EVI neighbors that ENDCs have learned.
display evi neighbor-discovery client member [ interface tunnel interface-number | [ local local-ip | remote client-ip | server server-ip ] [ vpn-instance vpn-instance-name ] ]
local local-ip: Specifies all EVI tunnel interfaces that use the IP address specified by the local-ip argument.
remote client-ip: Specifies the IPv4 address of an EVI neighbor.
server server-ip: Specifies the IPv4 address of an ENDS.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays EVI neighbor entries for all VPN instances and the public network.
Each EVI neighbor entry includes a neighbor's IP address, bridge MAC address, entry creation time, aging time, and EVI link status.
If you do not specify any parameters, this command displays IPv4 neighbor entries that all local ENDCs have learned.
# Display IPv4 neighbor entries that all local ENDCs have learned.
<Sysname> display evi neighbor-discovery client member
Interface: Tunnel1??? Network ID: 1??? Vpn-instance: vpn1
Local Address: 20.0.0.2
Server Address: 20.0.1.1
Neighbor??????? System ID???????? Created Time?????????? Expire??? Status
20.0.2.1??????? 000F-0000-0A3E??? 2015/01/01 12:12:12??? 13??????? Up
20.0.3.1??????? 000F-0000-0A3F??? 2015/01/01 12:12:12??? 12??????? Up
Server Address: 20.0.1.2
20.0.2.1??????? 000F-0000-0A3E??? 2015/01/01 12:12:12??? 25??????? Up
20.0.3.1??????? 000F-0000-0A3F??? 2015/01/01 12:12:12??? 19??????? Up
Interface: Tunnel2??? Network ID: 2??? Vpn-instance: [No Vrf]
Local Address: 21.0.0.1
Server Address: 21.0.1.2
21.0.2.1??????? 000F-0000-0A3E??? 2015/01/01 12:12:12??? 25??????? Up
21.0.3.1??????? 000F-0000-0A3F??? 2015/01/01 12:12:12??? 19??????? Down
Interface: Tunnel3??? Network ID: 3??? Vpn-instance: [No Vrf]
Local Address: 21.0.0.2
Server Address: NA
21.0.2.1??????? NA??????????????? 2015/01/01 12:12:12??? 25??????? Up
21.0.3.1??????? NA??????????????? 2015/01/01 12:12:12??? 19? ??????Up
# Display IPv4 neighbor entries that all local ENDCs have learned on EVI tunnel interface 2.
<Sysname> display evi neighbor-discovery client member interface tunnel 2
Local Address: 10.1.1.1
Server Address: 10.1.1.1
Neighbor??????? System ID???? ????Created Time?????????? Expire??? Status
10.1.1.2??????? 000f-e20e-0817?? ?2014/08/14 09:59:44?? ?62?????? ?Up
# Display VPN instance vpn1's IPv4 neighbor entries that all local ENDCs have learned from the ENDS at 10.1.1.1.
<Sysname> display evi neighbor-discovery client member server 10.1.1.1 Vpn-instance vpn1
Interface: Tunnel1??? Network ID: 1????? Vpn-instance: vpn1
10.1.1.2??? ????000f-e20e-0817??? 2014/08/14 09:58:59??? 73??????? Up
Table 11 Command output
Name of an ENDC-enabled EVI tunnel interface. |
Network ID |
EVI network ID. |
Vpn-instance |
VPN instance associated with the EVI tunnel. |
Local Address |
Source IP address of the EVI tunnel. |
Server Address |
IP address of the ENDS. This field displays NA if the ENDS is unknown. |
Neighbor |
IP address of the neighbor learned from the ENDS. |
System ID |
Bridge MAC address of the neighbor. This field displays NA if the bridge MAC address is unknown. |
Created Time |
Time when the neighbor entry was created. |
Expire |
Remaining lifetime (in seconds) of the neighbor entry. |
Status |
EVI link status: · Up—The EVI link is up. · Down—The EVI link is down. · NA—No EVI link has been established with the neighbor. |
Use display evi neighbor-discovery client statistics to display ENDP packet statistics for an ENDC-enabled EVI tunnel interface.
display evi neighbor-discovery client statistics interface tunnel interface-number
# Display ENDP packet statistics for ENDCs on IPv4 tunnel interface Tunnel 1.
<Sysname> display evi neighbor-discovery client statistics interface tunnel 1
Server Address: 10.0.0.1??? Vpn-instance: vpn1
Received packets:
? Reply:??????? 170????????????? Error:????? 1
Sent packets:
? Register:???? 170????????????? Purge:????? 0
Server Address: 10.0.0.2??? Vpn-instance: vpn1
Received packets:
? Reply:??????? 99?????????????? Error:????? 1
Sent packets:
? Register:???? 100????????????? Purge:????? 0
Table 12 Command output
Server Address |
IP address of the ENDS. |
Vpn-instance |
Received packets |
Packets received by the ENDC: · Reply—Registration replies received from the ENDS. · Error—ENDP error packets. |
Sent packets |
Packets sent by the ENDC: · Register—Registration packets sent to the ENDS. · Purge—Deregistration packets sent to the ENDS. |
Use display evi neighbor-discovery client summary to display ENDC settings and connectivity to ENDSs.
# Display ENDC settings and connectivity to IPv4 ENDSs.
<Sysname> display evi neighbor-discovery client summary
????????????????? ???????Status: I-Init? E-Establish? P-Probe
Interface??? Local Address?? Server Address? Network ID? Reg? Auth????? Status Vpn-instance
Tunnel1????? 20.0.0.2??????? 20.0.0.1??????? 1??????? 15? enabled?? E????? Vpn1
Tunnel1????? 20.0.0.2??????? 20.0.0.3??????? 1??????? 15? enabled?? P????? [No Vrf]
Tunnel2????? 21.0.0.2??????? 21.0.0.1??????? 2??????? 15? disabled? P ?????[No Vrf]
Table 13 Command output
Local Address |
Source IP address of the EVI tunnel. This field displays NA if no source IP address has been assigned to the EVI tunnel. |
Server Address |
Network ID |
This field displays NA if no network ID has been configured. |
Reg |
Registration update interval. |
Auth |
ENDP authentication status: · enabled. · disabled. |
Status |
Status of the connection between the ENDC and the ENDS: · I—The connection is initializing. · E—The connection has been set up. · P—The ENDC is probing for the ENDS to set up a connection. |
Vpn-instance |
Use display evi neighbor-discovery server member to display information about EVI neighbors that have registered with an ENDS on the device.
display evi neighbor-discovery server member [ interface tunnel interface-number | [ local local-ip | remote client-ip ] [ vpn-instance vpn-instance-name ] ]
local local-ip: Specifies the IPv4 address of an ENDS on the device.
This command displays neighbor entries learned by ENDSs on the device. Each neighbor entry includes a neighbor's IP address, bridge MAC address, entry creation time, and aging time.
If you do not specify any parameters, this command displays all IPv4 EVI neighbors that have registered with each ENDS on the device.
# Display IPv4 EVI neighbor entries of all ENDSs on the device.
<Sysname> display evi neighbor-discovery server member
IP Address: 11.0.0.1
Client Address? System ID???????? Expire??? Created Time????
11.0.0.3??????? 000F-0001-0001??? 25??????? 2015/01/01 00:00:43
11.0.0.4??????? 000F-0001-0002??? 15??????? 2015/01/01 01:00:46
11.0.0.5??????? 000F-0001-0003??? 20??????? 2015/01/01 01:02:13
IP Address: 11.0.1.2
Client Address? System ID???????? Expire??? Created Time??????
11.0.1.3??????? 000F-0001-0011??? 19??????? 2015/01/01 00:19:31
11.0.1.4??????? 000F-0001-0012??? 30??????? 2015/01/01 02:00:43
11.0.1.5??????? 000F-0001-0013??? 20??????? 2015/01/01 01:02:13
IP Address: 12.0.0.1
12.0.0.2??????? 000F-0002-0001??? 30??????? 2015/01/01 03:20:43
12.0.0.3??????? 000F-0002-0002??? 37??????? 2015/01/01 03:27:46
# Display IPv4 neighbor entries that all ENDSs have learned on EVI tunnel interface 1.
<Sysname> display evi neighbor-discovery server member interface tunnel 1
Interface: Tunnel1??? Network ID: 1???? Vpn-instance: vpn1
IP Address: 10.1.1.1
10.1.1.1??????? 000f-e20e-0811??? 66??????? 2014/08/13 18:44:13
10.1.1.2??????? 000f-e20e-0817??? 69??????? 2014/08/14 09:58:47
# Display VPN instance vpn1's IPv4 neighbor entry for the ENDC at 10.1.1.1.
<Sysname> display evi neighbor-discovery server member remote 10.1.1.1 Vpn-instance vpn1
10.1.1.1??????? 000f-e20e-0811??? 61??????? 2014/08/13 18:44:13
Table 14 Command output
Name of an ENDS-enabled EVI tunnel interface. |
Network ID |
EVI network ID. |
Vpn-instance |
IP Address |
Client Address |
IP address of the neighbor. |
System ID |
Bridge MAC address of the neighbor. |
Expire |
Remaining lifetime of the neighbor entry. |
Created Time |
Use display evi neighbor-discovery server statistics to display ENDP packet statistics for an ENDS-enabled EVI tunnel interface.
display evi neighbor-discovery server statistics interface tunnel interface-number
# Display ENDP packet statistics on ENDS-enabled IPv4 EVI tunnel interface Tunnel 1.
<Sysname> display evi neighbor-discovery server statistics interface tunnel1
Received packets:
? Register:???? 170????????????? Purge:????? 13??
Sent packets:
? Reply:??????? 170????????????? Error:????? 1???
Table 15 Command output
Received packets |
Packets received by the ENDS: · Register—Registration requests received from ENDCs. · Purge—Deregistration packets received from ENDCs. |
Sent packets |
Packets sent by the ENDS: · Reply—Registration replies sent to ENDCs. · Error—ENDP error packets. |
Use display evi neighbor-discovery server summary to display ENDS information.
ENDS information includes ENDP authentication status (enabled or disabled) and the total number of ENDCs that have registered with each ENDS.
# Display IPv4 ENDS information.
<Sysname> display evi neighbor-discovery server summary
Interface????? Local Address?? Network ID??? Auth??????? Members?? Vpn-instance
Tunnel1??????? 20.0.0.1??????? 1???????????? enabled???? 10????? ??vpn1
Tunnel2??????? 21.0.0.1??????? 2???????????? disabled??? 20????? ??[No Vrf]
Tunnel3??????? 22.0.0.1??????? NA??????????? disabled??? 0?????? ??[No Vrf]
Table 16 Command output
Local Address |
Network ID |
Auth |
Members |
Total number of ENDCs that have registered with the ENDS. |
Vpn-instance |
display interface evi-link
Use display interface evi-link to display EVI-Link interface information.
display interface [ evi-link [ interface-number ] ] [ brief [ description | down ] ]
evi-link [ interface-number ]: Specifies EVI-Link interfaces. If you specify an EVI-Link interface number, this command displays information about the specified interface. If you specify only the evi-link keyword, this command displays information about all EVI-Link interfaces. If you do not specify the evi-link [ interface-number ] option, this command displays information about all interfaces.
description: Displays the complete interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description string.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display detailed information about EVI-Link 0.
<Sysname> display interface evi-link 0
EVI-Link0
Current state: UP
Description: EVI-Link0 Interface
PVID: 1
Port link-type: Trunk
?VLAN Passing:?? None
?VLAN permitted: None
?Trunk port encapsulation:? IEEE 802.1q
This EVI-Link belongs to Tunnel1
Source 1.1.1.1, Destination 1.1.2.1
Network ID 1
Table 17 Command output
Current state |
EVI-Link interface state: · DOWN—Physical state of the interface is down. · UP—Physical state of the interface is up. |
Interface description. |
PVID |
Port VLAN ID of the interface. |
Port link-type: Trunk |
Interface link type: Fixed at Trunk. |
VLAN Passing |
VLANs that have been created and allowed to pass through the interface. For EVI-Link interfaces, this field always displays None. |
VLAN permitted |
VLANs to which the interface has been assigned. They do not necessarily have been created. For EVI interfaces, this field always displays None. |
Trunk port encapsulation |
Link layer protocol of the interface. |
This EVI-Link belongs to Tunnel1 |
EVI tunnel that conveys the EVI link. |
Source |
Local tunnel address of the EVI link. |
Destination |
Remote tunnel address of the EVI link. |
Network ID |
EVI network ID of the EVI link. |
Last 300 seconds input rate |
Average input rate for the last 300 seconds. |
Last 300 seconds output rate |
Average output rate for the last 300 seconds. |
Input: 0 packets, 0 bytes, 0 drops |
Incoming traffic statistics on the interface: · Number of incoming packets. · Number of incoming bytes. · Number of dropped incoming packets. |
Output: 0 packets, 0 bytes, 0 drops |
Outgoing traffic statistics on the interface: · Number of outgoing packets. · Number of outgoing bytes. · Number of dropped outgoing packets. |
# Display brief information about EVI-Link 0.
<Sysname> display interface evi-link 0 brief
Speed: (a) - auto
Interface??????????? Link Speed?? Duplex Type PVID Description
EVI0? ???????????????UP? ?--??? ??--???? T??? 1
# Display physically down EVI-Link interfaces and the down reason.
<Sysname> display interface evi-link brief down
Interface??????????? Link?? Cause
EVI0???????????????? DOWN?? Not connected
Table 18 Command output
Brief information on interface(s) under bridge mode |
Brief information about the physical Layer 2 interface for the EVI-Link interface. |
Interface name abbreviation. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type: · A—Access. · T—Trunk. · H—Hybrid. |
PVID |
Interface description set by using the description command. This field displays up to 27 characters if you execute the display interface brief command without the description keyword. This field displays the complete interface description if you execute the display interface brief command with the description keyword. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). |
Use evi arp-suppression enable to enable EVI ARP flood suppression.
Use undo evi arp-suppression enable to disable EVI ARP flood suppression.
EVI ARP flood suppression is disabled.
Tunnel interface view
Use ARP flood suppression to reduce ARP request broadcasts on the EVI network.
This feature snoops ARP replies on an EVI tunnel interface to populate the ARP flood suppression table with remote MAC addresses. If an ARP request has a matching entry, the edge device replies to the request on behalf of the remote-site host. If no match is found, the edge device floods the request to the EVI network.
# Enable EVI ARP flood suppression on EVI tunnel interface Tunnel 101.
[Sysname] interface tunnel 101 mode evi
[Sysname-tunnel 101] evi arp-suppression enable
mac-address timer (Layer 2—LAN Switching Command Reference)
evi enable
Use evi enable to enable EVI on a transport-facing physical interface.
Use undo evi enable to disable EVI on a transport-facing physical interface.
evi enable
undo evi enable
EVI is disabled on an interface.
Enable EVI on physical interfaces that provide transport network access.
# Enable EVI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] evi enable
evi extend-vlan
Use evi extend-vlan to configure a list of VLANs that can be extended to remote sites over an EVI tunnel.
Use undo evi extend-vlan to remove the configuration.
evi extend-vlan vlan-list
undo evi extend-vlan vlan-list
No extended VLANs are configured.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. The value range for VLAN IDs is 1 to 4094.
If the site has more than one edge device in the EVI network, the EVI tunnel extends only active extended VLANs to remote sites.
# Specify extended VLANs 1 to 10, 15, and 100 to 200 on EVI tunnel interface Tunnel 101.
[Sysname-tunnel101] evi extend-vlan 1 to 10 15 100 to 200
evi flooding enable
Use evi flooding enable to enable EVI flooding for all destination-unknown frames.
Use undo evi flooding enable to disable EVI flooding for all destination-unknown frames.
evi flooding enable
EVI flooding is disabled. The device floods unknown unicast and multicast frames only to internal interfaces.
EVI flooding enables the device to flood all destination-unknown frames to an EVI tunnel interface.
If selective flooding is also enabled for a MAC address in a list of VLANs, EVI flooding has higher priority than the selective flooding setting. The device will flood frames destined for that MAC address, whether or not the frames are from a VLAN in the VLAN list for selective flooding.
As a best practice, do not configure both the evi flooding enable command and the evi selective-flooding mac-address command.
# Enable EVI flooding on Tunnel 101.
[Sysname-tunnel 101] evi flooding enable
evi isis ded-priority
Use evi isis ded-priority to change the DED priority of the edge device on an EVI tunnel interface.
Use undo evi isis ded-priority to restore the default DED priority.
evi isis ded-priority priority
The DED priority value is 64.
priority: Specifies a DED priority value in the range of 0 to 127.
DEDs include site DEDs and inter-site DEDs.
An inter-site DED is elected from between the edge devices on each EVI link to send CSNP packets for LSDB synchronization.
A site DED is elected from among the redundant edge devices at a multihomed site to distribute extended VLANs among them so the traffic of a VLAN always enters or leaves the site from the same edge device.
The edge devices on an EVI link exchange their DED priority in EVI IS-IS hello packets to elect the inter-site DED for periodic LSDB synchronization.
The edge devices at a multihomed site exchange their DED priority in EVI IS-IS hello packets to elect the site DED for distributing extended VLANs among them.
The edge device with higher DED priority is more likely to be elected as a site DED or inter-site DED. If two edge devices have the same DED priority, the one with the highest MAC address is elected.
# Set the DED priority value of Tunnel 101 to 2.
[Sysname-tunnel101] evi isis ded-priority 2
evi isis timer csnp
Use evi isis timer csnp to set the CSNP transmit interval.
Use undo evi isis timer csnp to restore the default.
evi isis timer csnp seconds
The CSNP transmit interval is 10 seconds.
seconds: Specifies an interval in the range of 1 to 600 seconds.
The setting takes effect only if the edge device is the DED on an EVI link in the tunnel.
The inter-site DEDs in an EVI network regularly send CSNP packets to advertise LSP summaries to remote sites for LSDB synchronization.
# Set the CSNP transmit interval to 15 seconds.
[Sysname-tunnel101] evi isis timer csnp 15
evi isis timer hello
Use evi isis timer hello to set the EVI IS-IS hello interval.
Use undo evi isis timer hello to restore the default.
evi isis timer hello seconds
The EVI IS-IS hello interval is 10 seconds.
seconds: Specifies an interval in the range of 3 to 255 seconds.
Set the hello interval depending on the network convergence requirement and system resources.
· To increase the speed of network convergence, decrease the hello interval.
· To conserve resources, increase the hello interval.
If the edge device is a DED, its hello interval is one-third of the hello interval set by using this command.
# Set the EVI IS-IS hello interval to 6 seconds.
[Sysname-tunnel101] evi isis timer hello 6
Use evi isis timer holding-multiplier to configure the hello multiplier for calculating the EVI IS-IS adjacency hold time.
Use undo evi isis timer holding-multiplier to restore the default.
evi isis timer holding-multiplier value
The multiplier for calculating the EVI IS-IS adjacency hold time is 3.
value: Specifies a multiplier in the range of 3 to 1000.
Adjacency hold time is the amount of time that the remote edge devices can retain the adjacency with the local edge device before an adjacency update.
· If Graceful Restart is disabled, the adjacency hold time equals the EVI IS-IS hello interval multiplied by the hello multiplier.
· If Graceful Restart is enabled, the adjacency hold time equals the greater of the following values:
? The restart interval.
? The EVI IS-IS hello interval multiplied by the hello multiplier.
If an edge device is a DED, its hello interval is one-third of the hello interval set by using the evi isis timer hello command.
Edge devices send their adjacency hold time in hello packets to update the adjacencies with their neighbors. An edge device removes the adjacency with a neighbor if it does not receive a hello packet from the neighbor before the timer expires.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the actual adjacency hold time is set to 65535 seconds.
# Set the multiplier to 6 for calculating EVI IS-IS adjacency hold time.
[Sysname-tunnel101] evi isis timer holding-multiplier 6
evi isis timer lsp
Use evi isis timer lsp to configure the minimum LSP transmit interval and the maximum number of LSPs that can be sent at each interval.
Use undo evi isis timer lsp to restore the default.
evi isis timer lsp time [ count count ]
The minimum LSP transmit interval is 100 milliseconds. A maximum of five LSPs can be sent at each interval.
time: Specifies the minimum LSP transmit interval, a multiple of 100 in the range of 100 to 1000 milliseconds.
count count: Specifies the maximum number of LSP segments that can be sent at each interval. The value range is 1 to 1000.
The edge device generates an LSP update when any LSDB content changes. For example, an LSP update is generated when a MAC address is removed or added.
Use this command to control the number of LSP segments that the edge device sends out. To decrease the number of LSP segments, increase the interval and decrease the maximum number of LSP segments sent at each interval.
# Set the minimum LSP transmit interval to 500 ms.
[Sysname-tunnel101] evi isis timer lsp 500
evi isis track
Use evi isis track to associate an EVI tunnel interface with a track entry.
Use undo evi isis track to remove the track entry association for an EVI tunnel interface.
evi isis track track-entry-number
undo evi isis track
An EVI tunnel interface is not associated with any track entry.
track-entry-number: Specifies a track entry number in the range of 1 to 1024.
You can associate an EVI tunnel interface with only one track entry. If you execute this command multiple times, the most recent association takes effect.
EVI IS-IS uses a hello mechanism to monitor the connectivity of each EVI link on an EVI tunnel. To detect the connectivity of a particular EVI link more quickly, you can associate its tunnel interface with a track entry. The monitoring protocol used in this entry can only be BFD.
EVI IS-IS changes the state of an EVI-Link interface in response to the track entry state, as shown in Table 19.
Table 19 Action on the monitored EVI-Link in response to the track entry state change
Track entry state |
State of the monitored EVI link |
Action on the EVI-Link interface |
Positive |
The EVI link is operating correctly. |
Places the EVI-Link interface in up state. |
Negative |
The EVI link has failed. |
Places the EVI-Link interface in down state. |
NotReady |
The EVI link is not monitored. This situation occurs when the Track module or the monitoring module is not ready, for example, because the Track module is restarting or the monitoring settings are incomplete. In this situation, EVI cannot obtain information about the EVI link from the Track module. |
N/A |
For more information about configuring a track entry, see Track configuration in High Availability Configuration Guide.
# Associate Tunnel 101 with track entry 1.
[Sysname-tunnel101] evi isis track 1
Use evi neighbor-discovery authentication to enable ENDP authentication.
Use undo evi neighbor-discovery authentication to disable ENDP authentication.
evi neighbor-discovery authentication { cipher | simple } string
ENDP authentication is disabled.
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 24 characters. Its encrypted form is a case-sensitive string of 1 to 65 characters.
Configure ENDP authentication in an insecure network to prevent malicious registration with an ENDS.
For successful neighbor relationship establishment, make sure all authentication-enabled ENDCs and ENDSs in an EVI network use the same authentication key.
If authentication is disabled on an ENDS, all ENDCs, including authentication-enabled ENDCs, can register with the ENDS without authentication.
If authentication is enabled on an ENDS, only authentication-enabled ENDCs that use the same authentication key as the ENDS can register with the ENDS.
# Enable ENDP authentication on EVI tunnel interface Tunnel 1 and specify web-evi as the authentication key.
<Sysname> system
[Sysname] interface tunnel 1 mode evi
[Sysname-Tunnel1] evi neighbor-discovery authentication simple web-evi
Use evi neighbor-discovery client enable to configure an EVI tunnel interface as the ENDC of an ENDS.
Use undo evi neighbor-discovery client enable to remove an ENDS from an EVI tunnel interface.
evi neighbor-discovery client enable server-ip
undo evi neighbor-discovery client enable server-ip
The ENDC feature is disabled.
server-ip: Specifies the IP address of a remote ENDS-enabled EVI tunnel interface.
For redundancy, you can configure up to two ENDS addresses on an EVI tunnel interface. These two ENDSs work independently. The failure of one ENDS does not affect the neighbor discovery and EVI link maintenance in the EVI network.
On an ENDS-enabled EVI tunnel interface, you can use the evi neighbor-discovery client enable command to add only one ENDS address. An ENDS is always an ENDC of itself. When you enable ENDS on an EVI tunnel interface, an ENDC is automatically enabled, with the source address of the EVI tunnel as the ENDS address.
To guarantee that each edge device can obtain the addresses of all its EVI neighbors, make sure the ENDSs are the same across the EVI network.
# Configure Tunnel 1 as an ENDC of the ENDS at 11.0.0.1.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client enable 11.0.0.1
Use evi neighbor-discovery client register-interval to configure the interval at which the ENDCs on an EVI tunnel interface update their registration with their ENDSs.
Use undo evi neighbor-discovery client register-interval to restore the default.
evi neighbor-discovery client register-interval interval
An ENDC updates its registration with its ENDS every 15 seconds.
interval: Specifies a registration update interval in the range of 5 to 120 seconds.
ENDP uses an ENDS probe timer and a registration aging timer in addition to the ENDC register timer set by using this command.
· ENDS probe timer—Sets the interval for an ENDC to detect an ENDS. This timer is maintained on ENDCs and is not user configurable.
· ENDC register timer—Sets the interval for an ENDC to update its registration with an ENDS. This timer is by default 15 seconds and can be changed by using the evi neighbor-discovery client register-interval command on ENDCs.
· Registration aging timer—This timer is five times the ENDC register timer. This timer is maintained on ENDSs. When the registration aging timer for an ENDC expires, ENDS removes the ENDC from its ENDC database.
When an ENDC sends a register request to join the EVI network, a 5-second ENDS probe timer starts. The ENDC sends a register request to the ENDS every 5 seconds until it receives a response from the ENDS.
When the ENDC receives a response from the ENDS, the ENDS probe timer stops and an ENDC register timer starts. The ENDC regularly sends register updates at the interval set by the register timer.
If the ENDC does not receive a response after sending five consecutive register packets, the ENDC clears its neighbor information database and starts the ENDS probe timer.
The ENDC adds the register timer setting to each register packet. The ENDS records this timer setting when it adds the ENDC to the ENDC database. If no register update is received from the ENDC before five times the timer is reached, ENDS removes the ENDC from the EVI network.
# Set the ENDC registration update interval to 30 seconds on EVI tunnel interface Tunnel 1.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client register-interval 30
Use evi neighbor-discovery server enable to enable ENDS on an EVI tunnel interface.
Use undo evi neighbor-discovery server enable to disable ENDS on an EVI tunnel interface.
ENDS is disabled on an EVI tunnel interface.
When you enable ENDS on an EVI tunnel interface, an ENDC is automatically enabled, with the source address of the EVI tunnel as the ENDS address. You can use the evi neighbor-discovery client register-interval command to modify the interval at which the ENDC registers with the ENDS.
# Enable IPv4 ENDS.
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery server enable
evi network-id
Use evi network-id to assign a network ID to an EVI tunnel interface.
Use undo evi network-id to remove the network ID on an EVI tunnel interface.
evi network-id number
undo evi network-id
No network ID is assigned to an EVI tunnel interface.
number: Specifies a network ID in the range of 1 to 16777215.
An edge device can belong to multiple EVI networks. Each EVI network is uniquely identified by a network ID.
Each edge device has only one EVI tunnel in each EVI network. To assign an edge device to an EVI network, you must create an EVI tunnel interface and assign the network ID of the EVI network to the EVI tunnel interface.
Assign the same network ID to the EVI tunnel interfaces of all edge devices in an EVI network.
# Assign EVI network ID 123 to EVI tunnel interface Tunnel 1.
[Sysname-Tunnel1] evi network-id 123
interface tunnel (Layer 3—IP Services Command Reference)
Use evi selective-flooding mac-address to enable selective flooding for a MAC address on an EVI tunnel interface.
Use undo evi selective-flooding mac-address to disable selective flooding for a MAC address on an EVI tunnel interface.
evi selective-flooding mac-address mac-address vlan vlan-id-list
undo evi selective-flooding mac-address mac-address vlan vlan-id-list
Selective flooding is disabled for all MAC addresses. The device floods unknown unicast and multicast frames only to internal interfaces.
mac-address: Specifies a MAC address, which cannot be all Fs.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of start-vlan-id to end-vlan-id. The end VLAN ID must be greater than the start VLAN ID. The value range for VLAN IDs is 1 to 4094.
CAUTION: Do not configure selective flooding for a local unicast MAC address. The setting might cause remote devices to drop packets destined for that MAC address. |
The device floods a frame to an EVI tunnel interface if the frame meets all of the following conditions:
· The frame's destination MAC address and VLAN ID match a selective flooding entry.
· The VLAN is an active extended VLAN on the EVI tunnel interface.
Enable selective flooding for special multicast addresses that require flooding across sites but cannot be added to a multicast forwarding table by IGMP snooping.
# Configure selective flooding for 000f-e201-0101 in VLANs 1 to 10 on EVI tunnel interface Tunnel 101.
[Sysname-tunnel 101] evi selective-flooding mac-address 000f-e201-0101 vlan 1 to 10
evi site-id
Use evi site-id to configure a site ID for the device.
Use undo evi site-id to restore the default.
evi site-id site-id
undo evi site-id
The site ID of the device is 0.
site-id: Specifies a site ID in the range of 1 to 65535.
By default, all edge devices in an EVI network have a site ID of 0.
To uniquely identify the sites in an EVI network, you can change their site IDs. To avoid site ID conflict, follow these guidelines when you configure site IDs:
· The edge devices at a dual-homed site cannot use the default site ID. You must manually assign the same site ID to them.
· The edge device at a single-homed site can use the default or manually assigned site ID. Site conflict does not occur if the edge devices at different sites all use the default site ID.
· Manually assigned site IDs must be unique among sites.
When the site IDs of two devices conflict, EVI IS-IS isolates the device with the lower MAC address. The isolated device cannot exchange any EVI IS-IS packets with other neighbors except that it can receive EVI IS-IS hello packets. To identify isolated devices, use the display evi isis brief command or the display evi isis peer command.
# Assign a site ID of 201 to the device.
[Sysname] evi site-id 201
display evi-isis brief
evi-isis
Use evi-isis to create an EVI IS-IS process and enter its view, or enter the view of an existing EVI IS-IS process.
Use undo evi-isis to delete an EVI IS-IS process or clear the configuration that has made in EVI IS-IS process view.
evi-isis process-id
undo evi-isis process-id
No EVI IS-IS processes exist.
Each EVI network has one EVI IS-IS process. Before you can configure settings in EVI IS-IS process view, you must create the process. The EVI IS-IS process takes effect after you configure extended VLANs on the tunnel interface.
An EVI IS-IS process is created automatically when you perform a task that can trigger automatic EVI IS-IS process creation on a tunnel interface. The ID of an automatically created process is the same as the EVI tunnel interface number. For more information about automatic EVI IS-IS process creation, see EVI Configuration Guide.
Alternatively, you can use the evi-isis command to create an EVI IS-IS process manually.
To delete a manually created EVI IS-IS process, you must use the undo evi-isis command.
· If EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command only deletes settings configured in EVI IS-IS process view.
· If no EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command deletes both the EVI IS-IS process and all settings configured in EVI IS-IS process view.
An automatically created EVI IS-IS process is automatically deleted when you delete all EVI IS-IS settings from the EVI tunnel interface.
# Enter EVI IS-IS process view.
[Sysname] evi-isis 101
[Sysname-evi-isis-101]
filter-policy
Use filter-policy to specify a routing policy for an EVI IS-IS process.
Use undo filter-policy to remove the routing policy on an EVI IS-IS process.
filter-policy policy-name
undo filter-policy
No routing policy is assigned to an EVI IS-IS process.
policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters.
You can configure a routing policy to match MAC reachability information that can be advertised to the remote EVI sites. The routing policy is also called a reachability information filtering policy.
The routing policy for EVI IS-IS can only contain the following filters:
· MAC list.
· VLAN list.
For more information about configuring routing policies, see Layer 3—IP Routing Configuration Guide.
# Specify routing policy EVI-Filter for EVI IS-IS process 101.
[Sysname-evi-isis-101] filter-policy EVI-Filter
graceful-restart
Use graceful-restart to enable Graceful Restart for an EVI IS-IS process.
Use undo graceful-restart to disable Graceful Restart for an EVI IS-IS process.
graceful-restart
Graceful Restart is disabled for an EVI IS-IS process.
To guarantee nonstop forwarding while the peer EVI IS-IS processes are re-establishing their adjacency after a process restart or active/standby switchover occurs, enable Graceful Restart for the peer EVI IS-IS processes at two ends of the EVI tunnel.
# Enable Graceful Restart for EVI IS-IS process 101.
[Sysname-evi-isis-101] graceful-restart
graceful-restart interval
Use graceful-restart interval to configure the GR restart interval for EVI IS-IS.
Use undo graceful-restart interval to restore the default.
The GR restart interval is 300 seconds.
interval: Specifies the GR restart interval (the intended restart time), in the range of 30 to 1800 seconds.
# Set the GR restart interval to 120 seconds for EVI IS-IS process 1.
[Sysname-evi-isis-1] graceful-restart interval 120
gre key vlan-id
Use gre key vlan-id to enable an EVI tunnel interface to generate a GRE key for tunneled packets based on their VLAN IDs.
Use undo gre key to restore the default.
gre key vlan-id
undo gre key
EVI tunneled packets do not contain a GRE key.
The GRE key setting must be the same across an EVI network.
Use this command on an EVI tunnel interface if any remote edge devices generate VLAN ID-based GRE keys for EVI tunneled packets. The EVI tunnel interface accepts an incoming tunneled packet only if the GRE key in the packet matches one of the local GRE keys.
# Enable EVI tunnel interface 1 to generate VLAN ID-based GRE keys for tunneled packets.
[Sysname-Tunnel2] gre key vlan-id
display interface tunnel (Layer 3—IP Services Command Reference)
keepalive
Use keepalive to configure the keepalive interval on an EVI tunnel interface and configure the maximum number of consecutive keepalive failures that are allowed before a remote end is declared unavailable.
Use undo keepalive to restore the default.
keepalive [ seconds [ times ] ]
undo keepalive
The EVI link keepalive interval is 5 seconds and the permitted maximum number of consecutive keepalive failures is two.
seconds: Specifies a keepalive interval in the range of 1 to 32767 seconds.
times: Specifies the maximum number of consecutive keepalive failures in the range of 1 to 255.
The EVI-Link interfaces on an EVI tunnel regularly send keepalive packets to test the availability of their peer ends.
If no acknowledgment is received from the peer end before the timeout timer expires, an EVI-Link interface retransmits a keepalive packet. The timeout timer is the same as the keepalive interval.
When the maximum number of consecutive keepalive failures is reached, the EVI-Link interface state changes to Down. The EVI-Link interface state changes back to Up after the interface receives a keepalive acknowledgment or keepalive packet.
# Set the keepalive interval to 20 seconds and the maximum number of consecutive keepalive failures to 5.
[Sysname-Tunnel1] keepalive 20 5
log-peer-change enable
Use log-peer-change enable to enable EVI IS-IS adjacency change logging.
Use undo log-peer-change enable to disable EVI IS-IS adjacency change logging.
EVI IS-IS adjacency change logging is enabled.
Adjacency change logging enables an EVI IS-IS process to send a log message to the information center when an adjacency change occurs. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
# Disable adjacency change logging for an EVI IS-IS process.
[Sysname-evi-isis-1] undo log-peer-change enable
reset evi arp-suppression
Use reset evi arp-suppression to clear EVI ARP flood suppression entries.
reset evi arp-suppression interface tunnel interface-number [ vlan vlan-id ]
interface tunnel interface-number: Specifies a tunnel interface by its number.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears the flood suppression entries in every VLAN.
# Clear the EVI ARP flood suppression entries on Tunnel 101.
<Sysname> reset evi arp-suppression interface tunnel 101
This will delete all entries under the specified interface. Continue? [Y/N]:y
display evi arp-suppression
reset evi isis all
Use reset evi isis all to clear dynamic EVI IS-IS data.
reset evi isis all [ process-id ]
process-id: Specify an EVI IS-IS process ID in the range of 0 to 65535. If you do not specify a process, this command clears all EVI IS-IS processes' dynamic data.
# Clear dynamic data on EVI IS-IS process 1.
<Sysname> reset evi isis all 1
reset evi neighbor-discovery client statistics
Use reset evi neighbor-discovery client statistics to clear ENDP packet statistics for the ENDC on an EVI tunnel interface.
reset evi neighbor-discovery client statistics interface tunnel interface-number
# Clear ENDP packet statistics for the ENDC on Tunnel 1.
<Sysname> reset evi neighbor-discovery client statistics interface tunnel 1
reset evi neighbor-discovery server statistics
Use reset evi neighbor-discovery server statistics to clear ENDP packet statistics for the ENDS on an EVI tunnel interface.
reset evi neighbor-discovery server statistics interface tunnel interface-number
# Clear ENDP packet statistics for the ENDS on Tunnel 1.
<Sysname> reset evi neighbor-discovery server statistics interface tunnel 1
snmp context-name
Use snmp context-name to configure an SNMP context for an EVI IS-IS process.
Use undo snmp context-name to restore the default.
No SNMP context is configured for an EVI IS-IS process.
context-name: Specifies a context name, a case-sensitive string of 1 to 32 characters.
In addition to the private EVI IS-IS MIB, EVI IS-IS shares the standard IS-IS MIB with IS-IS and other protocols that use IS-IS in the control plane. For SNMP to correctly identify a protocol's management information in the standard IS-IS MIB, you must configure a unique context for each of these protocols. If a protocol supports multiple processes, you must assign a unique context to each process.
The context names must be unique among all the protocols and their processes.
Context is a method introduced to SNMPv3 for multiple instance managements. For SNMPv1/v2c, you must specify a context name as a community name for protocol identification.
# Configure the SNMP context name as eviisis100 for EVI IS-IS process 100.
[Sysname] evi-isis 100
[Sysname-evi-isis-100] snmp context-name eviisis100
snmp-agent trap enable evi-isis
Use snmp-agent trap enable evi-isis to enable EVI IS-IS SNMP notifications.
Use undo snmp-agent trap enable evi-isis to disable EVI IS-IS SNMP notifications.
snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
undo snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
All EVI IS-IS SNMP notifications are enabled.
adjacency-state-change: Specifies notifications about EVI IS-IS adjacency status changes.
area-mismatch: Specifies notifications about area address mismatches between hello packets.
buffsize-mismatch: Specifies notifications about buffer size mismatches for LSPs.
id-length-mismatch: Specifies notifications about system ID length mismatches of EVI IS-IS packets.
link-disconnect: Specifies notifications about EVI link failures.
lsp-parse-error: Specifies notifications about LSP parse failures.
lsp-size-exceeded: Specifies notifications about propagation failures caused by oversized LSPs.
max-seq-exceeded: Specifies notifications about attempts to exceed the maximum LSP sequence number.
maxarea-mismatch: Specifies notifications about maximum area address mismatches of hello packets.
new-ded: Specifies notifications about the device's being elected as the DED.
own-lsp-purge: Specifies notifications about attempts to remove the local LSP.
protocol-support: Specifies notifications about supported-protocol mismatches for non-pseudo node LSPs.
rejected-adjacency: Specifies notifications about adjacency creation failures.
skip-sequence-number: Specifies notifications about LSP sequence number duplications.
topology-change: Specifies notifications about edge device topology changes at the local site. This notification will not be sent if a new-ded notification has been sent for the same event.
version-skew: Specifies notifications about hello packet version mismatches.
To report critical EVI IS-IS events to an NMS, enable SNMP notifications for EVI IS-IS.
If you do not specify a notification, this command enables all EVI IS-IS SNMP notifications.
For EVI IS-IS SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable EVI IS-IS adjacency status change notifications.
[Sysname] snmp-agent trap enable evi-isis adjacency-state-change
timer lsp-max-age
Use timer lsp-max-age to specify the maximum lifetime of LSPs.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The maximum LSP lifetime is 1200 seconds.
seconds: Specifies the maximum LSP lifetime in the range of 3 to 65535 seconds.
This command specifies the maximum amount of time an LSP generated by the local EVI IS-IS process can be valid in an LSDB. When the timer decreases to zero, the LSP is removed from the LSDB.
# Set the maximum LSP lifetime to 25 minutes (1500 seconds) on EVI IS-IS process 101.
[Sysname-evi-isis-101] timer lsp-max-age 1500
timer lsp-refresh
Use timer lsp-refresh to specify the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The LSP update interval is 900 seconds.
seconds: Specifies an LSP refresh interval in the range of 1 to 65534 seconds.
Each edge device updates the LSPs that they generated at the LSP refresh interval to maintain LSDB consistency across the EVI network.
To avoid unnecessary LSP age-outs at remote edge devices, make sure the LSP refresh interval is shorter than the LSP lifetime.
# Set the LSP refresh interval to 1500 seconds.
[Sysname-evi-isis-101] timer lsp-refresh 1500
timer lsp-max-age
virtual-system
Use virtual-system to create an EVI IS-IS virtual system.
Use undo virtual-system to delete an EVI IS-IS virtual system.
virtual-system systemid
undo virtual-system systemid
No EVI IS-IS virtual systems exist.
systemid: Specifies a virtual system ID in the XXXX.XXXX.XXXX format. Each X represents a hexadecimal digit.
The virtual system ID must be unique in the EVI network.
An EVI IS-IS process sends all local MAC reachability information in one LSP. By default, an LSP can convey up to 55 x 210 MAC address entries.
To increase this number to accommodate all local MAC address entries, create virtual systems. Each virtual system represents an increase of 55 x 210 MAC address entries.
# Create virtual system 0001.0001.0001.
[Sysname-evi-isis-101] virtual-system 0001.0001.0001
