02-Virtual Technologies Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810 2600 3600 Routers Configuration Guides(V7)-R0707-6W30102-Virtual Technologies Configuration Guide
01-IRF configuration
01-IRF configuration 385.10 KB
Configuring an IRF fabric· 1
About IRF· 1
IRF network model 1
IRF benefits· 1
Basic concepts· 2
IRF network topology· 4
Master election· 5
Interface naming conventions· 5
File system naming conventions· 6
Configuration synchronization· 7
Multi-active handling procedure· 7
MAD mechanisms· 8
Restrictions: Hardware compatibility with IRF· 11
Restrictions and guidelines: IRF configuration· 12
Hardware compatibility with IRF· 12
Software requirements for IRF· 12
IRF fabric size· 13
Candidate IRF physical interfaces· 13
Transceiver modules and cables selection for IRF· 13
IRF port connection· 13
IRF physical interface configuration restrictions and guidelines· 14
Feature compatibility and configuration restrictions with IRF· 15
Licensing requirements for IRF· 15
Configuration rollback restrictions· 15
IRF tasks at a glance· 16
Planning the IRF fabric setup· 17
Setting up an IRF fabric· 17
Assigning a member ID to each IRF member device· 17
Specifying a priority for each member device· 17
Binding physical interfaces to IRF ports· 17
Saving configuration to the next-startup configuration file· 18
Connecting IRF physical interfaces· 18
Setting the operating mode to IRF mode· 18
Accessing the IRF fabric· 19
Configuring MAD·· 19
Restrictions and guidelines for MAD configuration· 19
Configuring LACP MAD·· 20
Configuring BFD MAD·· 20
Excluding service interfaces from the shutdown action upon detection of multi-active collision· 24
Recovering an IRF fabric· 25
Optimizing IRF settings for an IRF fabric· 25
Changing the member ID of a member device· 25
Changing the priority of a member device· 26
Adding physical interfaces to an IRF port 26
Bulk-configuring basic IRF settings for a member device· 27
Enabling IRF auto-merge· 28
Configuring a member device description· 28
Configuring the IRF bridge MAC address· 29
Enabling software auto-update for software image synchronization· 29
Setting the IRF link down report delay· 30
Removing an interface module that has IRF physical interfaces· 31
Replacing an interface module that has IRF physical interfaces· 31
Display and maintenance commands for IRF· 31
About IRF
The Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
IRF network model
Figure 1 shows an IRF fabric that has two devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF benefits
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
Basic concepts
Operating mode
The device operates in one of the following modes:
·     Standalone mode—The device cannot form an IRF fabric with other devices.
·     IRF mode—The device can form an IRF fabric with other devices.
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices automatically elect a new master. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. Two devices cannot form an IRF fabric if they use the same member ID. A device cannot join an IRF fabric if its member ID has been used in the fabric.
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device has two IRF ports.
In standalone mode, the IRF ports are named IRF-port 1 and IRF-port 2.
In IRF mode, the IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down when all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward traffic between member devices, including IRF protocol packets and data packets that must travel across IRF member devices.
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 2. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 2 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 3.
Figure 3 IRF merge
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 settings, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 4, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to determine whether the packet is from the local IRF fabric. Then, the member device can handle the packet correctly.
Figure 4 A network that contains two IRF domains
An IRF fabric uses a daisy-chain topology. As shown in Figure 5.
Figure 5 Daisy-chain topology
As shown in Figure 6, you can connect two distant IRF member devices through Layer 2 relay devices (for example, Layer 2 switches).
Figure 6 IRF fabric connected through relay devices
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when split IRF fabrics merge. For information about the master device of the merged IRF fabric, see "Failure recovery."
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election.
A physical interface is numbered in the format of chassis-number/slot-number/interface-index.
·     chassis-number—Device ID. The default value for this argument is 1. In IRF mode, the device ID is the IRF member ID. After the device converts from IRF mode to standalone mode, it still uses the IRF member ID as its device ID.
·     slot-number—Slot number of the interface. In standalone mode, the interfaces on an MSR router are numbered in the format of slot-number/interface-index. No member ID is included.
·     interface-index—Interface index on the device. Interface index depends on the number of physical interfaces available on the device. To identify the index of a physical interface, examine its index mark on the chassis.
For example:
# In standalone mode, GigabitEthernet 0/1 represents the first fixed physical interface on the device. Set its link type to trunk, as follows:
[Sysname] interface gigabitethernet 0/1
[Sysname-GigabitEthernet0/1] port link-type trunk
# On the IRF fabric Sysname, GigabitEthernet 2/0/1 represents the first fixed port on member device 2. Set its link type to trunk, as follows:
[Sysname-GigabitEthernet2/0/1] port link-type trunk
In standalone mode, you can use the storage device name to access the device's file system.
On a multichassis IRF fabric, you can use the storage device name to access the file system of the master. To access the file system of any other member device, use the name in the slotmember-ID#storage-device-name format.
For more information about storage device naming conventions, see Fundamentals Configuration Guide.
For example:
·     To create and access the test folder under the root directory of the flash memory on the master device:
<Master> mkdir test
<Master> cd test
<Master> dir
Directory of flash:/test
The directory is empty.
524288 KB total (29832 KB free)
·     To create and access the test folder under the root directory of the flash memory on member device 2:
<Master> mkdir slot2#flash:/test
Creating directory slot2#flash:/test... Done.
<Master> cd slot2#flash:/test
<Master> dir
Directory of slot2#flash:/test
524288 KB total (128812 KB free)
IRF uses a strict running-configuration synchronization mechanism. In an IRF fabric, all devices obtain and run the running configuration of the master. Configuration changes are automatically propagated from the master to the remaining devices. The configuration files of these devices are retained, but the files do not take effect. The devices use their own startup configuration files only after they are removed from the IRF fabric.
As a best practice, back up the next-startup configuration file on a device before adding the device to an IRF fabric as a subordinate.
A subordinate device's next-startup configuration file might be overwritten if the master and the subordinate use the same file name for their next-startup configuration files. You can use the backup file to restore the original configuration after removing the subordinate from the IRF fabric.
For more information about configuration management, see Fundamentals Configuration Guide.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
IRF provides MAD mechanisms by extending LACP and BFD to detect multi-active collisions. As a best practice, configure a minimum of one MAD mechanism on an IRF fabric. For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
For information about LACP, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide. For information about BFD, see High Availability Configuration Guide.
Collision handling
When MAD detects a multi-active collision, it sets all IRF fabrics except one to the Recovery state. The fabric that is not placed in Recovery state can continue to forward traffic. The Recovery-state IRF fabrics are inactive and cannot forward traffic.
LACP MAD and BFD MAD use the following process to handle a multi-active collision:
1.     Compare the number of members in each fabric.
2.     Set all fabrics to the Recovery state except the one that has the most members.
3.     Compare the member IDs of the masters if all IRF fabrics have the same number of members.
4.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shut down all service interfaces in the Recovery-state fabrics except for the following service interfaces:
¡     Service interfaces automatically excluded from being shut down by the system.
¡     Service interfaces specified by using the mad exclude interface command.
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
After the failed IRF link between two split IRF fabrics is recovered, log in to the inactive IRF fabric to reboot its member devices if the system requires you to do so. If the IRF auto-merge feature is enabled, the inactive IRF member devices will automatically reboot and a manual reboot is typically not required. After these member devices join the active IRF fabric as subordinate devices, the IRF merge is complete, as shown in Figure 7. The network ports that have been shut down by MAD automatically restore their original state.
If you inadvertently reboot the active IRF fabric, its member devices will join the inactive IRF fabric with their network ports shut down by MAD. To restore the original states of the network ports, use the mad restore command.
Figure 7 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 8), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. This command brings up all network ports that were shut down by MAD. After the IRF link is repaired, merge the two parts into a unified IRF fabric.
Figure 8 Active IRF fabric fails before the IRF link is recovered
MAD mechanisms
IRF provides MAD mechanisms by extending LACP and BFD.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenarios
LACP MAD
·     Detection speed is fast.
·     Runs on existing aggregate links without requiring MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
BFD MAD
·     Intermediate device, if used, can come from any vendor.
Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic. The MSR routers support Layer 3 aggregate interfaces for BFD MAD and the interfaces must operate in static aggregation mode.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for IRF fabrics that have only two members that are geographically close to one another.
LACP MAD
As shown in Figure 9, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID (the member ID of the master). The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 9 LACP MAD scenario
BFD MAD
BFD MAD detects multi-active collisions by using BFD.
You can use common or management Ethernet ports for BFD MAD.
If management Ethernet ports are used, BFD MAD has the following requirements:
·     An intermediate device is required and each IRF member device must have a BFD MAD link to the intermediate device.
·     Each member device is assigned a MAD IP address on the master's management Ethernet port.
If common Ethernet ports are used, BFD MAD has the following requirements:
·     If an intermediate device is used, each member device must have a BFD MAD link to the intermediate device. If no intermediate device is used, all member devices must have a BFD MAD link to each other. As a best practice, use an intermediate device to connect IRF member devices if the IRF fabric has more than two member devices. A full mesh of IRF members might cause broadcast loops.
·     Ports on BFD MAD links are assigned to a VLAN (or Layer 3 aggregate interface) used for BFD MAD. Each member device is assigned a MAD IP address on the VLAN interface (or Layer 3 aggregate interface).
The BFD MAD links and BFD MAD VLAN (or Layer 3 aggregate interface) must be dedicated. Do not use BFD MAD links or BFD MAD VLAN (or Layer 3 aggregate interface) for any other purposes.
When you use a Layer 3 aggregate interface for BFD MAD, make sure its member ports do not exceed the maximum number of Selected ports allowed for an aggregation group. If the number of member ports exceeds the maximum number of Selected ports, some member ports cannot become Selected. BFD MAD will be unable to work correctly and its state will change to Faulty. For more information about setting the maximum number of Selected ports for an aggregation group, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
·     The MAD addresses identify the member devices and must belong to the same subnet.
·     Of all management Ethernet ports on an IRF fabric, only the master's management Ethernet port is accessible.
Figure 10 shows a typical BFD MAD scenario that uses an intermediate device. On the intermediate device, assign the ports on the BFD MAD links to the same VLAN.
Figure 11 shows a typical BFD MAD scenario that does not use an intermediate device.
With BFD MAD, the master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
Figure 10 BFD MAD scenario with an intermediate device
Figure 11 BFD MAD scenario without an intermediate device
Hardware
IRF compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
No
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
No
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3610-I-DP, MSR3610-IE-DP
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
The MSR routers in Table 2 support IRF. To establish an IRF fabric successfully, make sure the member device models meet the compatibility requirements in Table 2.
Table 2 Hardware compatibility matrix for IRF establishment
Hardware
IRF member restrictions
MSR 2630
All members are the same model.
IMPORTANT
IMPORTANT:
·     Voice, WLAN, or FCM modules cannot operate in IRF mode.
·     If you install a SIC-CNDE module on one IRF member device, you must install SIC-CNDE modules on all other member devices.
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
IRF fabric size
An IRF fabric can contain a maximum of two member devices.
Typically, use high-speed ports as IRF physical interfaces. The following compatibility matrix shows the candidate IRF physical interfaces for the hardware platforms:
Hardware
MSR 2630
All fixed GE ports
The lowest numbered fixed GE port
All fixed GE ports
MSR 3610, MSR 3620, MSR 3640, MSR 3660
All fixed GE ports
MSR 3620-DP
All fixed GE ports
When you select transceiver modules and cables, follow these restrictions and guidelines:
·     Use straight-through or crossover copper Ethernet cables to connect copper Ethernet ports for a short-distance connection.
·     Use transceiver modules and fibers to connect fiber Ethernet ports for a long-distance connection.
·     The transceiver modules at the two ends of an IRF link must be the same type.
Support for transceiver modules and cables varies by device model.
For more information about the transceiver modules and cables, see the switch installation guide and H3C Transceiver Modules User Guide.
The transceiver modules and cables available for the switch are subject to change over time. For the most up-to-date list of transceiver modules and cables, contact your H3C sales representative.
IRF port connection
When you connect two neighboring IRF members, follow these restrictions and guidelines:
·     You must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
·     For high availability, bind multiple physical interfaces to an IRF port. You can bind a maximum of two physical interfaces to an IRF port.
IMPORTANT
IMPORTANT:
Because of hardware restrictions, do not bind CPU WAN ports and switching WAN ports to the same IRF port on the MSR 3600-28-X1, MSR 3600-28-X1-DP, MSR 3600-51-X1, or MSR 3600-51-X1-DP router. In addition, the two ends of an IRF physical link must use the same type of WAN ports. If you bind a CPU WAN port to an IRF port, you cannot bind a switching WAN port to the neighboring IRF port.
On the MSR 3600-28-X1 or MSR 3600-28-X1-DP router, GE 0/0 to GE 0/3 and GE 0/27 are switching WAN ports, and GE 0/28 is a CPU WAN port. On the MSR 3600-51-X1 or MSR 3600-51-X1-DP router, GE 0/0 to GE 0/3 and GE 0/51 are switching WAN ports, and GE 0/52 is a CPU WAN port.
Figure 12 Connecting IRF physical interfaces
Grouped port binding restrictions
You can use 40-GE ports for IRF links, or use 10-GE breakout interfaces of a 40-GE port for IRF links. To split a 40-GE port, use the using tengige command.
When you use the 10-GE breakout interfaces of a 40-GE port for IRF links, follow these restrictions and guidelines:
·     If you use one breakout interface as an IRF physical interface, the remaining breakout interfaces can only act as IRF physical interfaces. You cannot use them for any other purposes. To use a breakout interface for any purpose other than IRF physical interfaces, do not bind any of the interfaces to an IRF port.
·     The four breakout interfaces can be bound to different IRF ports.
·     You must shut down all the breakout interfaces before you can assign or remove any of the interfaces to or from an IRF port. To bring up the interfaces after the assignment or removal is complete, execute the undo shutdown command.
The physical interfaces on the interface modules are grouped. When you use the physical interfaces in a group for IRF links, follow these restrictions and guidelines:
·     If you use one physical interface in a group as an IRF physical interface, the remaining physical interfaces in the group can only act as IRF physical interfaces. You cannot use them for any other purposes. To use a physical interface in a group for any purpose other than IRF physical interfaces, do not bind any of the interfaces in the group to an IRF port.
·     The physical interfaces in a group can be bound to different IRF ports.
·     You must shut down all physical interfaces in a group before you can assign or remove any of the interfaces to or from an IRF port. To bring up the interfaces after the assignment or removal is complete, execute the undo shutdown command.
Command configuration restrictions
On a physical interface bound to an IRF port, you can execute only the:Ethernet interface commands, including the description and shutdown commands.
For more information about these commands, see Ethernet interface configuration in Interface Command Reference.
Suppressing SNMP notifications of packet drops on IRF physical interfaces
Before an IRF member device forwards a packet, it examines its forwarding path in the IRF fabric for a loop. If a loop exists, the device discards the packet on the source interface of the looped path. This loop elimination mechanism will drop a large number of broadcast packets on the IRF physical interfaces.
To suppress SNMP notifications of packet drops that do not require attention, do not monitor packet forwarding on the IRF physical interfaces.
Feature
Layer 2 forwarding
IRF ports cannot forward Layer 2 traffic.
Layer 2 link aggregation
Layer 2 link aggregation is not supported across multiple chassis.
IPsec and IKE
The IPsec anti-replay and IKE DPD features must be handled on the same member device.
Session
Session backup is not supported between member devices. The packets must be sent and received on the same member device for the services that require session establishment. For example, NAT, ASPF, and AFT.
Dialing
The AUX, AM, and ISDN dialing features are not supported in IRF mode.
Web network management
Built-in AC
The features are not supported in IRF mode.
Routing
To form an IRF fabric, all member devices must use the same settings for the following routing features:
·     Maximum number of ECMP routes (set by using the max-ecmp-num command).
·     ECMP mode (set by using the ecmp mode command).
For more information about the routing features, see basic IP routing configuration in Layer 3—IP Routing Configuration Guide.
ACL
To form an IRF fabric, all member devices in the IRF fabric must use the same ACL hardware mode. For more information about hardware-based ACLs, see ACL and QoS Configuration Guide.
VLAN
In IRF mode, all Ethernet switching modules on the master and subordinate devices must support the same maximum number of VLANs.
For a license-based feature to run correctly on an IRF fabric, make sure the licenses installed for the feature on all member devices are the same. For more information about feature licensing, see Fundamentals Configuration Guide.
The configuration rollback feature cannot roll back the following IRF settings:
·     Member device description (set by using the irf member description command).
·     Member device priority (set by using the irf member priority command).
·     IRF physical interface and IRF port bindings (set by using the port group interface command).
For more information about the configuration rollback feature, see configuration file management in Fundamentals Configuration Guide.
To configure IRF, perform the following tasks:
1.     Setting up an IRF fabric
a.     Assigning a member ID to each IRF member device
b.     (Optional.) Specifying a priority for each member device
c.     Binding physical interfaces to IRF ports
d.     Saving configuration to the next-startup configuration file
e.     Connecting IRF physical interfaces
f.     Setting the operating mode to IRF mode
g.     Accessing the IRF fabric
2.     Configuring MAD
Configure a minimum of one MAD mechanism on an IRF fabric.
¡     Configuring LACP MAD
¡     Configuring BFD MAD
¡     Excluding service interfaces from the shutdown action upon detection of multi-active collision
This feature excludes a service interface from the shutdown action for management or other special purposes when an IRF fabric transits to the Recovery state.
¡     Recovering an IRF fabric
3.     (Optional.) Optimizing IRF settings for an IRF fabric
¡     Changing the member ID of a member device
Changing member IDs in an IRF fabric can void member ID-related configuration and cause unexpected problems. Make sure you understand the impact on your live network before you change member IDs.
¡     Changing the priority of a member device
¡     Adding physical interfaces to an IRF port
¡     Bulk-configuring basic IRF settings for a member device
You can configure member IDs, priorities, domain ID, IRF physical interfaces separately or in bulk.
¡     Enabling IRF auto-merge
When two IRF fabrics merge, this feature enables the IRF fabric that failed the master election to automatically reboot all its member devices to complete the merge.
¡     Configuring a member device description
¡     Configuring the IRF bridge MAC address
¡     Enabling software auto-update for software image synchronization
This feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
¡     Setting the IRF link down report delay
¡     Removing an interface module that has IRF physical interfaces
¡     Replacing an interface module that has IRF physical interfaces
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master device.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
·     IRF physical interfaces.
About assigning an IRF member ID
Assign a unique IRF member ID to a device before changing the device's operating mode to IRF. If you do not assign a member ID to the device, the device automatically uses the member ID of 1 after the mode changes to IRF.
2.     Assign an IRF member ID to the device.
irf member member-id
By default, the device operates in standalone mode and does not have an IRF member ID.
About specifying an IRF member priority
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. A larger priority value indicates a higher priority.
2.     Specify a priority for the device in standalone mode.
irf priority priority
The default IRF member priority is 1.
About IRF port binding
In standalone mode, IRF port binding operations do not affect the current configuration of the interface. However, when the operating mode changes to IRF mode, the default configuration is restored on the physical interface.
2.     Enter IRF port view in standalone mode.
irf-port irf-port-number
3.     Bind a physical interface to the IRF port.
port group interface interface-type interface-number
By default, no physical interfaces are bound to an IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port.
About running configuration saving
Save the running configuration before converting to the IRF mode. The mode change requires a reboot, which causes all unsaved settings to be lost.
To save the running configuration to the next-startup configuration file, execute the following command in any view:
save
For more information about this command, see configuration file management in Fundamentals Command Reference.
Follow the restrictions in "IRF port connection" to connect IRF physical interfaces as well as based on the topology and cabling scheme.
About setting IRF mode
By default, the device operates in standalone mode. To assign the device to an IRF fabric, you must change its operating mode to IRF mode.
After you change the operating mode, the device automatically reboots for the change to take effect.
During the reboot, you may choose to have the system automatically convert the startup configuration file. Automatic configuration conversion prevents slot- or interface-related settings from becoming invalid. For example, the system adds member ID information to interface numbers and file paths in IRF mode.
Upon an operating mode change, the system automatically converts interface names by adding or deleting the first number segment (the member ID) in the interface number. When performing this task, the system converts every string in a valid interface name format without identifying whether or not they are interface names. To avoid undesirable configuration changes that result from false modification, do not name any objects except interfaces in a valid interface name format.
The following are valid interface name formats:
·     interface-type interface-number, which has a space between the two arguments.
·     interface-typeinterface-number, which does not have a space between the two arguments.
The system uses the space-separated format to match CPOS E1, E3, T1, and T3 interfaces and uses the non-space format to match other types of physical interfaces.
If a string (except the string configured by using the description command) matches a valid interface name, the system converts that string. For example, if a VLAN exists with a name of GigabitEthernet0/7 in standalone mode, the VLAN name will change to GigabitEthernetn/0/7 in IRF mode. The n argument represents the IRF member ID.
Before you change the operating mode, verify that a unique IRF member ID has been assigned to the device.
2.     Set the operating mode to IRF mode.
chassis convert mode irf
The default operating mode is standalone mode.
IRF generates packets on a device in IRF mode even if the device does not form an IRF fabric with any other devices. To conserve system resources, set a device to standalone mode after removing it from an IRF fabric. To restore the standalone mode, use the undo chassis convert mode command.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any member device.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet and SNMP.
The IRF fabric appears as one device after it is formed. When you log in to an IRF fabric, you are placed at the CLI of the master, regardless of at which member device you are logged in. You configure and manage all IRF members at the CLI of the master. All settings you have made are automatically propagated to the IRF members.
For more information, see login configuration in Fundamentals Configuration Guide.
Configuring MAD
Assigning IRF domain IDs
An IRF fabric has only one IRF domain ID.
You can change the IRF domain ID by using the irf domain or mad enable command. The IRF domain IDs configured by using the commands overwrite each other.
If LACP MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
Bringing up service interfaces shut down by MAD
To prevent a service interface from being shut down when the IRF fabric transits to the Recovery state, use the mad exclude interface command. To bring up service interfaces in a Recovery-state IRF fabric, use the mad restore command instead of the undo shutdown command. The mad restore command activates the Recovery-state IRF fabric.
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
3.     Create an aggregate interface and enter aggregate interface view.
¡     Enter Layer 2 aggregate interface view.
¡     Enter Layer 3 aggregate interface view.
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
LACP MAD takes effect only on dynamic aggregate interfaces.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
7.     Enter Ethernet interface view or interface range view.
¡     Enter Ethernet interface view.
¡     Enter interface range view. Choose one of the following commands:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-24> ]
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
Multichassis link aggregation is allowed.
Configuring BFD MAD
Restrictions and guidelines for configuring BFD MAD
Before you configure BFD MAD, choose a BFD MAD link scheme as described in "BFD MAD."
As a best practice, connect the BFD MAD links after you finish the BFD MAD configuration.
When you configure BFD MAD on a VLAN interface, follow these restrictions and guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks:
¡     On the IRF fabric and the intermediate device, create a VLAN for BFD MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of BFD MAD links to the BFD MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the BFD MAD VLAN.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN and its member ports for any purpose other than configuring BFD MAD.
·     Use only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
When you configure BFD MAD on a Layer 3 aggregate interface, follow these restrictions and guidelines:
Category
BFD MAD-enabled Layer 3 aggregate interface
·     Make sure the Layer 3 aggregate interface operates in static aggregation mode.
·     Make sure the member ports in the aggregation group do not exceed the maximum number of Selected ports allowed for an aggregation group. If the number of member ports exceeds the maximum number of Selected ports, some member ports cannot become Selected. BFD MAD will be unable to work correctly and its state will change to Faulty.
BFD MAD VLAN
·     On the intermediate device (if any), assign the ports on the BFD MAD links to the same VLAN. Do not assign the ports to an aggregate interface. If the ports are hybrid ports, make sure these ports are untagged members of their PVIDs.
·     If the intermediate device acts as a BFD MAD intermediate device for multiple IRF fabrics, assign different BFD MAD VLANs to the IRF fabrics.
·     Do not use the BFD MAD VLAN on the intermediate device for any purposes other than BFD MAD.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
BFD MAD-enabled Layer 3 aggregate interface and feature compatibility
Use only the mad bfd enable and mad ip address commands on the BFD MAD-enabled interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled interface.
When you configure BFD MAD that uses management Ethernet ports, follow these restrictions and guidelines:
Category
Management Ethernet ports for BFD MAD
Connect a management Ethernet port on each IRF member device to the common Ethernet ports on the intermediate device.
BFD MAD VLAN
·     On the intermediate device, create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
Configuring BFD MAD on a VLAN interface
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
3.     Create a VLAN dedicated to BFD MAD.
vlan vlan-id
By default, only VLAN 1 exists.
4.     Return to system view.
5.     Enter Ethernet interface view or interface range view.
To assign a range of ports to the BFD MAD VLAN, enter interface range view.
To assign one port to the BFD MAD VLAN, enter Ethernet interface view.
6.     Assign the port or the range of ports to the BFD MAD VLAN.
¡     Assign the ports to the VLAN as access ports.
port access vlan vlan-id
¡     Assign the ports to the VLAN as trunk ports.
port trunk permit vlan vlan-id
¡     Assign the ports to the VLAN as hybrid ports.
port hybrid vlan vlan-id { tagged | untagged }
The link type of BFD MAD ports can be access, trunk, or hybrid.
The default link type of a port is access.
7.     Return to system view.
8.     Enter VLAN interface view.
interface vlan-interface vlan-interface-id
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the VLAN interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on any VLAN interfaces.
Repeat this step to assign a MAD IP address to each member device on the VLAN interface.
Configuring BFD MAD on a Layer 3 aggregate interface
3.     Create a Layer 3 aggregate interface for BFD MAD.
5.     Enter interface view or interface range view.
To assign a range of ports to the aggregation group for the aggregate interface, enter interface range view.
To assign one port to the aggregation group for the aggregate interface, enter Ethernet interface view.
6.     Assign the port or the range of ports to the aggregation group for the aggregate interface.
port link-aggregation group number
8.     Enter Layer 3 aggregate interface view.
9.     Enable BFD MAD.
mad bfd enable
10.     Assign a MAD IP address to a member device on the Layer 3 aggregate interface.
By default, no MAD IP addresses are configured on aggregate interfaces.
Repeat this step to assign a MAD IP address to each member device on the aggregate interface.
Configuring BFD MAD that uses management Ethernet ports
3.     Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
4.     Enable BFD MAD.
mad bfd enable
5.     Assign a MAD IP address to each member device.
By default, no MAD IP addresses are configured.
About excluding service interfaces from being shut down
When an IRF fabric transits to the Recovery state, the system automatically excludes the following service interfaces from being shut down:
·     Member interfaces of an aggregate interface if the aggregate interface is excluded from being shut down.
You can exclude a service interface from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
If the Layer 2 ports of a VLAN interface are distributed on multiple member devices, the exclusion operation might introduce IP collision risks. The VLAN interface might be up on both active and inactive IRF fabrics.
2.     Configure a service interface to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all service interfaces on a Recovery-state IRF fabric are shut down, except for the service interfaces automatically excluded by the system.
About recovering an IRF fabric
For split IRF fabrics, if the active IRF fabric fails before the IRF link is recovered, perform this task on the inactive IRF fabric to recover the inactive IRF fabric. The manual recovery operation brings up all service interfaces that were shut down by MAD on the inactive IRF fabric.
2.     Recover the inactive IRF fabric.
mad restore
CAUTION
CAUTION:
In IRF mode, an IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on your live network.
The new member ID takes effect at reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical network ports) are removed, regardless of whether you have saved the configuration.
2.     Change the member ID of a member device.
irf member member-id renumber new-member-id
By default, the device uses the member ID that is set in standalone mode.
3.     Save the running configuration.
save [ safely ] [ force ]
4.     Return to user view.
5.     Reboot the member device.
reboot [ slot slot-number ]
The slot-number must be the same as the member-id specified in the irf member member-id renumber new-member-id command.
About changing IRF member priority
You can change the priority of a member device so it can be elected the master in the next master election.
A change to member priority can affect the master re-election result. However, it does not cause an immediate master re-election.
2.     Specify a priority for a member of an IRF fabric.
irf member member-id priority priority
Make sure the IRF physical interfaces of an IRF port use the same binding mode. In IRF mode, IRF physical interfaces of an IRF port cannot be configured to use different binding modes.
2.     Enter Ethernet interface view or interface range view.
To shut down one IRF physical interface, enter its interface view.
To shut down a range of IRF physical interfaces, enter interface range view.
3.     Shut down the physical interfaces.
shutdown
By default, a physical interface is not administratively down.
If you cannot shut down a physical interface, follow the system instruction to shut down its peer interface.
5.     Enter IRF port view.
irf-port member-id/irf-port-number
6.     Bind each physical interface to the IRF port.
8.     Enter Ethernet interface view or interface range view.
9.     Bring up the physical interfaces.
10.     Return to system view.
11.     Save the running configuration.
save
Activating IRF port settings causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the configuration on the IRF port.
irf-port-configuration active
After this step is performed, the state of the IRF port changes to UP. The member devices elect a master, and the subordinate device reboots automatically.
After the IRF fabric is formed, you can add physical interfaces to an IRF port (in UP state) without repeating this step.
About easy IRF
Use the easy IRF feature to bulk-configure basic IRF settings for a device in IRF mode, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
·     Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
·     Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
The device reboots immediately after you specify a new member ID for it. Make sure you are aware of the impact on the network.
If you execute the easy-irf command multiple times, the following settings take effect:
·     The most recent settings for the member ID, domain ID, and priority.
·     IRF port bindings added through repeated executions of the command. To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
If you specify IRF physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
·     Do not enter spaces between the interface type and interface number.
·     Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
2.     Bulk-configure basic IRF settings for the device.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
Make sure the new member ID is unique in the IRF fabric to which the device will be added.
About IRF auto-merge
When two IRF fabrics merge, you must reboot the member devices in the IRF fabric that fails in the master election. The auto-merge feature enables the IRF fabric to automatically reboot all its member devices to complete the merge.
If this feature is disabled, you must manually reboot the devices that failed the master election to complete the merge.
2.     Enable IRF auto-merge.
irf auto-merge enable
By default, this feature is enabled.
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
About IRF bridge MAC address and IRF bridge MAC persistence
The bridge MAC address of a system must be unique on a switched LAN. IRF bridge MAC address identifies an IRF fabric by Layer 2 protocols (for example, LACP) on a switched LAN.
By default, an IRF fabric uses the bridge MAC address of the master as the IRF bridge MAC address. After the master leaves, the IRF bridge MAC address persists for a period of time or permanently depending on the IRF bridge MAC persistence setting. When the IRF bridge MAC persistence timer expires, the IRF fabric uses the bridge MAC address of the current master as the IRF bridge MAC address.
The following is how IRF handles the IRF bridge MAC address if IRF fabrics merge:
·     When IRF fabrics merge, IRF ignores the IRF bridge MAC address and checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
·     After IRF fabrics merge, the merged IRF fabric uses the bridge MAC address of the merging IRF fabric that won the master election as the IRF bridge MAC address.
CAUTION
CAUTION:
The bridge MAC address change causes transient traffic disruption.
If the IRF fabric has multichassis aggregate links, do not use the undo irf mac-address persistent command. Use of this command might cause traffic disruption.
Configuring IRF bridge MAC persistence
2.     Configure IRF bridge MAC persistence.
¡     Retain the bridge MAC address permanently even if the address owner has left the fabric.
irf mac-address persistent always
¡     Retain the bridge MAC address for 6 minutes after the address owner leaves the fabric.
irf mac-address persistent timer
¡     Change the bridge MAC address as soon as the address owner leaves the fabric.
By default, the IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves.
The irf mac-address persistent timer command avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
About IRF software auto-update
The software auto-update feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
To join an IRF fabric, a device must use the same software images as the master in the fabric.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as its main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric if software auto-update is disabled.
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting member devices during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status messages to configuration terminals (see Network Management and Monitoring Configuration Guide).
Make sure the device you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the Bootware menu to delete files.
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
About IRF link down report delay
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
Make sure the IRF link down report delay is shorter than the heartbeat or hello timeout settings of upper-layer protocols (for example, CFD and OSPF). If the report delay is longer than the timeout setting of a protocol, unnecessary recalculations might occur.
Set the delay to 0 seconds in the following situations:
·     The IRF fabric requires a fast master/subordinate or IRF link switchover.
·     The BFD or GR feature is used.
·     You want to shut down an IRF physical interface or reboot an IRF member device. (After you complete the operation, reconfigure the delay depending on the network condition.)
2.     Set the IRF link down report delay.
irf link-delay interval
By default, the IRF link down report delay is 0 milliseconds.
To remove an interface module that provides IRF physical interfaces:
1.     Perform one of the following tasks to eliminate temporary packet loss:
¡     Remove cables from the IRF physical interfaces on the module.
¡     Shut down the IRF physical interfaces on the module by using the shutdown command.
2.     Remove the module.
Replacing the old module with a different model replacement module
1.     Shut down the IRF physical interfaces on the old module by using the shutdown command.
2.     Remove the IRF port bindings that contain the physical interfaces.
3.     Remove the old module, and then install the replacement module.
4.     Verify that the replacement module has been correctly installed by using the display device command.
5.     Reconfigure the IRF port bindings, as described in "Adding physical interfaces to an IRF port."
6.     Activate the IRF port settings by using the irf-port-configuration active command.
You can skip this step if the IRF port is in UP state when you add bindings.
Replacing the old module with the same model replacement module
2.     Remove the old module, and then install the replacement module.
3.     Verify that the replacement module has been correctly installed by using the display device command.
Bring up the physical interfaces by using the undo shutdown command after the interface module completes startup.
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
display irf configuration
Display MAD configuration.
display mad [ verbose ]
