05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Command References-R7523P01-6W10005-Layer 3 - IP Services Command Reference
04-DNS commands
04-DNS commands 104.39 KB
DNS commands
display dns domain
Use display dns domain to display the domain name suffixes.
display dns domain [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained domain name suffixes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name suffixes for the public network.
# Display the statically configured and dynamically obtained domain name suffixes for the public network.
<Sysname> display dns domain
Type:
  D: Dynamic    S: Static
No.    Type   Domain suffix
1      S      com
2      D      net
No.
Sequence number.
Domain name suffix type:
·     S—A statically configured domain name suffix.
·     D—A domain name suffix dynamically obtained through DHCP or other protocols.
Domain suffix
Domain name suffixes.
dns domain
display dns host
Use display dns host to display information about domain name-to-IP address mappings.
display dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
ip: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name-to-IP address mappings for the public network.
If you do not specify the ip or ipv6 keyword, this command displays domain name-to-IP address mappings of all query types.
# Display domain name-to-IP address mappings of all query types.
<Sysname> display dns host
Type:
Total number: 3
No.  Host name         Type  TTL        Query type   IP addresses
1    sample.com        D     3132       A            192.168.10.1
                                                     192.168.10.2
                                                     192.168.10.3
2    zig.sample.com    S     -          A            192.168.1.1
3    sample.net        S     -          AAAA         FE80::4904:4448
No.
Sequence number.
Host name
Domain name.
Domain name-to-IP address mapping type:
·     S—A static mapping configured by the ip host or ipv6 host command.
·     D—A mapping dynamically obtained through dynamic domain name resolution.
TTL
Time in seconds that a mapping can be stored in the cache.
For a static mapping, a hyphen (-) is displayed.
Query type
Query type: A or AAAA.
IP addresses
Replied IP address:
·     For a type A query, the replied IP address is an IPv4 address.
·     For a type AAAA query, the replied IP address is an IPv6 address.
ip host
ipv6 host
reset dns host
display dns server
Use display dns server to display IPv4 DNS server information.
display dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv4 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays statically configured and dynamically obtained IPv4 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv4 DNS server information for the public network.
# Display IPv4 DNS server information for the public network.
<Sysname> display dns server
Type:
No. Type  IP address
1   S     202.114.0.124
2   S     169.254.65.125
No.
Sequence number.
DNS server type:
·     S—A manually configured DNS server.
·     D—DNS server information dynamically obtained through DHCP or other protocols.
IP address
IPv4 address of the DNS server.
dns server
display ipv6 dns server
Use display ipv6 dns server to display IPv6 DNS server information.
display ipv6 dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv6 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained IPv6 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 DNS server information for the public network.
# Display IPv6 DNS server information for the public network.
<Sysname> display ipv6 dns server
Type:
No. Type  IPv6 address                             Outgoing Interface
1   S     2::2
No.
Sequence number.
DNS server type:
IPv6 address
IPv6 address of the DNS server.
Outgoing Interface
Output interface.
ipv6 dns server
dns domain
Use dns domain to configure a domain name suffix.
Use undo dns domain to delete the specified domain name suffix.
dns domain domain-name [ vpn-instance vpn-instance-name ]
undo dns domain domain-name [ vpn-instance vpn-instance-name ]
No domain name suffix is configured. Only the provided domain name is resolved.
domain-name: Specifies a domain name suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, aabbcc.com. The domain name suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To configure a domain name suffix for the public network, do not specify this option.
For domain name resolution, the resolver automatically uses the suffix list to supply the missing part of an incomplete name entered by a user.
A domain name suffix applies to both IPv4 DNS and IPv6 DNS.
The system allows a maximum of 16 domain name suffixes for the public network or each VPN instance. You can specify domain name suffixes for both public network and VPN instances.
# Configure domain name suffix com for the public network.
[Sysname] dns domain com
display dns domain
dns dscp
Use dns dscp to set the DSCP value for DNS packets sent by a DNS client or DNS proxy.
Use undo dns dscp to restore the default.
dns dscp dscp-value
undo dns dscp
The DSCP value is 0 in DNS packets sent by a DNS client or DNS proxy.
dscp-value: Specifies the DSCP value in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for outgoing DNS packets.
[Sysname] dns dscp 30
dns proxy enable
Use dns proxy enable to enable DNS proxy.
Use undo dns proxy enable to disable DNS proxy.
dns proxy enable
DNS proxy is disabled.
This configuration applies to both IPv4 DNS and IPv6 DNS.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns server
Use dns server to specify the IPv4 address of a DNS server.
Use undo dns server to remove the IPv4 address of a DNS server.
dns server ip-address [ vpn-instance vpn-instance-name ]
undo dns server [ ip-address ] [ vpn-instance vpn-instance-name ]
No DNS server IPv4 address is specified.
ip-address: Specifies the IPv4 address of a DNS server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv4 address for the public network, do not use this option.
The device sends a DNS query request to the DNS servers in the order their IPv4 addresses are specified.
The system allows a maximum of six DNS server IPv4 addresses for the public network or each VPN instance. You can specify DNS server IPv4 addresses for both public network and VPN instances.
If you do not specify an IPv4 address, the undo dns server command removes all DNS server IPv4 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv4 address 172.16.1.1.
[Sysname] dns server 172.16.1.1
display dns server
dns source-interface
Use dns source-interface to specify the source interface for DNS packets.
Use undo dns source-interface to restore the default.
dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
undo dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
No source interface is specified for DNS packets. The device uses the primary IP address of the output interface of the matching route as the source IP address for a DNS request.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a source interface for the public network, do not use this option.
This configuration applies to both IPv4 and IPv6.
In IPv4 DNS, the device uses the primary IPv4 address of the specified source interface as the source IP address of a DNS query. In IPv6 DNS, the device selects an IPv6 address of the specified source interface as the source IP address of a DNS query. The method of selecting the IPv6 address is defined in RFC 3484.
The system allows only one source interface for the public network or each VPN instance. If you execute this command multiple times, the most recent configuration takes effect. You can specify source interfaces for both public network and VPN instances.
This command takes effect whether the source interface belongs to the VPN instance or not. As a best practice, specify an interface that belongs to the VPN instance as the source interface.
# Specify VLAN-interface 2 as the source interface for DNS packets on the public network.
[Sysname] dns source-interface vlan-interface 2
dns trust-interface
Use dns trust-interface to specify a DNS trusted interface.
Use undo dns trust-interface to remove a DNS trusted interface.
dns trust-interface interface-type interface-number
undo dns trust-interface [ interface-type interface-number ]
No DNS trusted interface is specified.
By default, an interface obtains DNS suffix and DNS server information from DHCP. A network attacker might act as the DHCP server to assign a wrong DNS suffix and DNS server address to the device. As a result, the device fails to obtain the resolved IP address or might get the wrong IP address. With the DNS trusted interface specified, the device only uses the DNS suffix and DNS server information obtained through the trusted interface to avoid attacks.
You can configure a maximum of 128 DNS trusted interfaces on the device.
If you do not specify an interface, the undo dns trust-interface command removes all DNS trusted interfaces and restores the default.
# Specify VLAN-interface 2 as a DNS trusted interface.
[Sysname] dns trust-interface vlan-interface 2
ip host
Use ip host to create a host name-to-IPv4 address mapping.
Use undo ip host to remove a host name-to-IPv4 address mapping.
ip host host-name ip-address [ vpn-instance vpn-instance-name ]
undo ip host host-name ip-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv4 address mappings exist.
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), and dots (.).
ip-address: Specifies the IPv4 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IP address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv4 address mappings for the public network or each VPN instance. You can configure host name-to-IPv4 address mappings for both public network and VPN instances.
For the public network or a VPN instance, each host name maps to only one IPv4 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping command parameter ip, -a, -c, -f, -h, -i, -m, -n, -p, -q, -r, -s, -t, -tos, -v, or -vpn-instance as the host name. For more information about the ping command parameters, see Network Management and Monitoring Command Reference.
# Map IPv4 address 10.110.0.1 to host name aaa for the public network.
[Sysname] ip host aaa 10.110.0.1
display dns host
ipv6 dns dscp
Use ipv6 dns dscp to set the DSCP value for IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
Use undo ipv6 dns dscp to restore the default.
ipv6 dns dscp dscp-value
undo ipv6 dns dscp
The DSCP value is 0 in IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
# Set the DSCP value to 30 for outgoing IPv6 DNS packets.
[Sysname] ipv6 dns dscp 30
ipv6 dns server
Use ipv6 dns server to specify the IPv6 address of a DNS server.
Use undo ipv6 dns server to remove the IPv6 address of a DNS server.
ipv6 dns server ipv6-address [ interface-type interface-number ] [ vpn-instance vpn-instance-name ]
undo ipv6 dns server [ ipv6-address [ interface-type interface-number ] ] [ vpn-instance vpn-instance-name ]
No DNS server IPv6 address is specified.
ipv6-address: Specifies the IPv6 address of a DNS server.
interface-type interface-number: Specifies the output interface by its type and number. If you do not specify an interface, the device forwards DNS packets out of the output interface of the matching route. Specify this argument if the IPv6 address of the DNS server is a link-local address. Do not specify this argument if the IPv6 address of the DNS server is a global unicast address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv6 address for the public network, do not use this option.
For dynamic DNS, the device sends a DNS query request to the DNS servers in the order their IPv6 addresses are specified.
The system allows a maximum of six DNS server IPv6 addresses for the public network or each VPN instance. You can specify DNS server IPv6 addresses for both public network and VPN instances.
If you do not specify an IPv6 address, the undo ipv6 dns server command removes all DNS server IPv6 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv6 address 2002::1 for the public network.
[Sysname] ipv6 dns server 2002::1
ipv6 host
Use ipv6 host to create a host name-to-IPv6 address mapping.
Use undo ipv6 host to remove a host name-to-IPv6 address mapping.
ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
undo ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv6 address mappings exist.
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters. It can include letters, digits, hyphens (-), underscores (_), and dots (.).
ipv6-address: Specifies the IPv6 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IPv6 address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv6 address mappings for the public network or each VPN instance. You can configure host name-to-IPv6 address mappings for both public network and VPN instances.
For the public network or a VPN instance, each host name maps to only one IPv6 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping ipv6 command parameter -a, -c, -i, -m, -q, -s, -t, -tc, -v, or -vpn-instance as the host name. For more information about the ping ipv6 command parameters, see Network Management and Monitoring Command Reference.
# Map IPv6 address 2001::1 to host name aaa for the public network.
[Sysname] ipv6 host aaa 2001::1
ip host
reset dns host
Use reset dns host to clear dynamic DNS entries.
reset dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic DNS entries for the public network.
If you do not specify the ip or ipv6 keyword, the reset dns host command clears dynamic DNS entries of all query types.
# Clear dynamic DNS entries of all query types for the public network.
<Sysname> reset dns host
display dns host
DDNS commands
ddns apply policy
Use ddns apply policy to apply a DDNS policy to an interface and enable DDNS update. DDNS updates the mapping between the FQDN and the primary IP address of the interface.
Use undo ddns apply policy to remove the application of a DDNS policy from an interface and to stop DDNS update.
ddns apply policy policy-name [ fqdn domain-name ]
undo ddns apply policy policy-name
No DDNS policy and FQDN are specified on the interface, and DDNS update is disabled.
Interface view
policy-name: Specifies a DDNS policy by its name, a case-insensitive string of 1 to 32 characters.
fqdn domain-name: Specifies the FQDN to replace <h> in the URL for DDNS update. The domain-name argument specifies a case-insensitive string of 1 to 253 characters. It can include letters, digits, hyphens (-), underscores (_), and dots (.).
You can apply a maximum of four DDNS policies to an interface.
If you execute this command multiple times with the same DDNS policy name but different FQDNs, both of the following occur:
·     The most recent configuration takes effect.
·     The device initiates a DDNS update request immediately.
# Apply DDNS policy steven_policy to VLAN-interface 2 to update the domain name-to-IP address mapping for FQDN www.whatever.com and enable DDNS update.
[Sysname-Vlan-interface2] ddns apply policy steven_policy fqdn www.whatever.com
ddns policy
display ddns policy
ddns dscp
Use ddns dscp to set the DSCP value for outgoing DDNS packets.
Use undo ddns dscp to restore the default.
ddns dscp dscp-value
undo ddns dscp
The DSCP value for outgoing DDNS packets is 0.
# Set the DSCP value to 30 for outgoing DDNS packets.
[Sysname] ddns dscp 30
ddns policy
Use ddns policy to create a DDNS policy and enter its view, or enter the view of an existing DDNS policy.
Use undo ddns policy to delete a DDNS policy.
ddns policy policy-name
undo ddns policy policy-name
No DDNS policies exist.
policy-name: Specifies the DDNS policy name, a case-insensitive string of 1 to 32 characters.
You can create a maximum of 16 DDNS policies on the device.
# Create a DDNS policy named steven_policy and enter its view.
[Sysname] ddns policy steven_policy
ddns apply policy
display ddns policy
display ddns policy
Use display ddns policy to display information about DDNS policies.
display ddns policy [ policy-name ]
policy-name: Specifies a DDNS policy by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a DDNS policy, this command displays information about all DDNS policies.
# Display information about DDNS policy steven_policy.
<Sysname> display ddns policy steven_policy
DDNS policy: steven_policy
  URL              : http://members.3322.org/dyndns/update?
                     system=dyndns&hostname=<h>&myip=<a>
  Username         : steven
  Password         : ******
  Method           : GET
  SSL client policy:
  Interval         : 1 days 0 hours 1 minutes
# Display information about all DDNS policies.
  URL              : http://members.3322.org/dyndns/update?system=
  Username         : steven
  Password         : ******
  Method           : GET
  SSL client policy:
  Interval         : 0 days 0 hours 30 minutes
DDNS policy: tom-policy
  Username         :
  Password         :
  Method           : GET
  SSL client policy:
  Interval         : 0 days 0 hours 15 minutes
DDNS policy: u-policy
  URL              : oray://phservice2.oray.net
  Username         : username
  Password         :
  Method           : -
  SSL client policy:
Table 5 Command output
DDNS policy
DDNS policy name.
URL
URL address for a DDNS update request. This field is empty if no URL address is configured.
Username
Username for logging in to the DDNS server. This field is empty if no username is configured.
Password
Password for logging in to the DDNS server. This field is empty if no password is configured and displays ****** if a password is configured.
Method
Parameter transmission method used to send HTTP/HTTPS-based DDNS update requests.
Method types include GET and POST.
SSL client policy
Name of the associated SSL client policy. This field is empty if no SSL client policy is associated.
Interval
Interval for sending DDNS update requests.
ddns policy
interval
Use interval to set the interval for sending DDNS update requests.
Use undo interval to restore the default.
interval days [ hours [ minutes ] ]
undo interval
The DDNS update request interval is one hour.
DDNS policy view
days: Days in the range of 0 to 365.
hours: Hours in the range of 0 to 23.
minutes: Minutes in the range of 0 to 59.
Whether the interval is reached or not, a DDNS update request is initiated immediately if either of the following conditions occurs:
·     The primary IP address of the interface changes.
·     The link state of the interface changes from down to up.
If you set the interval to 0, the device does not periodically initiate DDNS update requests. However, it initiates a DDNS update request in either of the following situations:
If you execute this command multiple times, the most recent configuration takes effect. If you change the interval for an applied DDNS policy, the device immediately initiates a DDNS update request and sets the interval as the update interval.
# Set the interval to 1 day and 1 minute for sending DDNS update requests for DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] interval 1 0 1
ddns policy
display ddns policy
method
Use method to specify the parameter transmission method for sending DDNS update requests to HTTP/HTTPS-based DDNS servers.
Use undo method to restore the default.
method { http-get | http-post }
undo method
The method http-get applies.
DDNS policy view
http-get: Uses the get operation.
http-post: Uses the post operation.
This command applies to DDNS updates in HTTP/HTTPS. If the DDNS server uses HTTP or HTTPS service, choose a parameter transmission method compatible with the DDNS server. For example, a DHS server supports the http-post method.
If the DDNS policy has been applied to an interface, a DDNS update is sent immediately after the parameter transmission is changed.
# Specify the parameter transmission method as http-post for DDNS update requests for DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] method http-post
ddns policy
display ddns policy
password
Use password to specify the password for logging in to the DDNS server.
Use undo password to restore the default.
undo password
No password is specified for logging in to the DDNS server.
DDNS policy view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
# In DDNS policy steven_policy, specify nevets as the password for logging in to the DDNS server.
[Sysname-ddns-policy-steven_policy] password simple nevets
ddns policy
display ddns policy
url
username
ssl-client-policy
Use ssl-client-policy to associate an SSL client policy with a DDNS policy.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is associated with a DDNS policy.
DDNS policy view
policy-name: Specifies a SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
The SSL client policy is effective only for HTTPS-based DDNS update requests.
If you execute this command multiple times with different SSL client policies, the most recent configuration takes effect.
# Associate SSL client policy ssl_policy with DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] ssl-client-policy ssl_policy
ddns policy
display ddns policy
ssl-client-policy (Security Command Reference)
url
Use url to specify the URL address for DDNS update requests.
Use undo url to restore the default.
url request-url
undo url
No URL address is specified for DDNS update requests.
DDNS policy view
request-url: Specifies the URL address, a case-sensitive string of 1 to 240 characters.
The URL addresses configured for update requests vary by DDNS server. Common DDNS server URL address formats are shown in Table 6.
Table 6 Common URL addresses for DDNS update request
DDNS server
URL addresses for DDNS update requests
www.3322.org
http://members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
DYNDNS
http://members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
DYNS
http://www.dyns.cx/postscript.php?host=<h>&ip=<a>
ZONEEDIT
http://dynamic.zoneedit.com/auth/dynamic.html?host=<h>&dnsto=<a>
TZO
http://cgi.tzo.com/webclient/signedon.html?TZOName=<h>IPAddress=<a>
EASYDNS
http://members.easydns.com/dyn/ez-ipupdate.php?action=edit&myip=<a>&host_id=<h>
HEIPV6TB
http://dyn.dns.he.net/nic/update?hostname=<h>&myip=<a>
CHANGE-IP
http://nic.changeip.com/nic/update?hostname=<h>&offline=1
NO-IP
http://dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
DHS
http://members.dhs.org/nic/hosts?domain=dyn.dhs.org&hostname=<h>&hostscmd=edit&hostscmdstage=2&type=1&ip=<a>
HP
https://server-name/nic/update?group=group-name&myip=<a>
ODS
ods://update.ods.org
GNUDIP
gnudip://server-name
PeanutHull
The URL address cannot contain the username or password. To configure the username and password, use the username command and the password command.
HP and GNUDIP are common DDNS update protocols. The server-name parameter is the domain name or IP address of the service provider's server using one of the update protocols.
The URL address for an update request can start with:
·     http://—The HTTP-based DDNS server.
·     https://—The HTTPS-based DDNS server.
·     ods://—The TCP-based ODS server.
·     gnudip://—The TCP-based GNUDIP server.
·     oray://—The TCP-based DDNS server.
The domain names of DDNS servers are members.3322.org and phservice2.oray.net. The domain names of PeanutHull DDNS servers can be phservice2.oray.net, phddns60.oray.net, client.oray.net, ph031.oray.net, and so on. Determine the domain name in the URL according to the actual situation.
The port number in the URL address is optional. If you do not specify a port number, the default port number is used. HTTP uses port 80, HTTPS uses port 443, and the PeanutHull server uses port 6060.
The system automatically performs the following tasks:
·     Fills <h> with the FQDN that is specified when the DDNS policy is applied to an interface.
·     Fills <a> with the primary IP address of the interface to which the DDNS policy is applied.
You can also manually specify an FQDN and an IP address in <h> and <a>, respectively. In this case, the FQDN that is specified when the DDNS policy is applied to an interface will not take effect. As a best practice, do not manually change the <h> and <a> because your configuration might be incorrect.
You cannot specify an FQDN and IP address in the URL address for contacting the PeanutHull server. Alternatively, you can specify an FQDN when applying the DDNS policy to an interface. The system automatically uses the primary IP address of the interface to which the DDNS policy is applied as the IP address for DDNS update.
To avoid misinterpretation, do not include colons (:), at signs (@), and question marks (?) in your login username or password, even if you can do so.
# Specify the URL address for DDNS update requests for DDNS policy steven_policy. The device contacts www.3322.org for DDNS update.
[Sysname-ddns-policy-steven_policy] url http:// members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
ddns policy
display ddns policy
password
username
username
Use username to specify the username for logging in to the DDNS server.
Use undo username to restore the default.
username username
undo username
No username is specified for logging in to the DDNS server.
DDNS policy view
username: Specifies the username, a case-sensitive string of 1 to 32 characters.
# In DDNS policy steven_policy, specify steven as the username for logging in to the DDNS server.
[Sysname-ddns-policy-steven_policy] username steven
ddns policy
display ddns policy
password
url
