05-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R7523P01-6W10005-Layer 3 - IP Services Configuration Guide
09-IP performance optimization configuration
09-IP performance optimization configuration 82.94 KB
Optimizing IP performance
A customized configuration can help optimize overall IP performance. This chapter describes various techniques you can use to customize your installation.
Enabling an interface to forward directed broadcasts destined for the directly connected network
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
If an interface is allowed to forward directed broadcasts destined for the directly connected network, hackers can exploit this vulnerability to attack the target network. In some scenarios, however, an interface must send such directed broadcast packets to support UDP helper and Wake on LAN.
The task enables the interface to forward directed broadcast packets that are destined for the directly connected network and are received from another subnet to support Wake on LAN. Wake on LAN sends the directed broadcasts to wake up the hosts on the target network.
Configuration procedure
To enable an interface to forward directed broadcasts destined to the directly connected network:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Enable the interface to forward directed broadcasts destined for the directly connected network.
ip forward-broadcast
By default, an interface cannot forward directed broadcasts destined for the directly connected network.
Configuration example
Network requirements
As shown in Figure 1, the default gateway of the host is the IP address 1.1.1.2/24 of VLAN-interface 3 of Switch A.
Switch B can receive directed broadcasts from the host to IP address 2.2.2.255.
Figure 1 Network diagram
1.     Configure Switch A:
# Specify IP addresses for VLAN-interface 3 and VLAN-interface 2.
[SwitchA-Vlan-interface3] ip address 1.1.1.2 24
[SwitchA-Vlan-interface3] quit
[SwitchA-Vlan-interface2] ip address 2.2.2.2 24
# Enable VLAN-interface 2 to forward directed broadcasts directed for the directly connected network.
[SwitchA-Vlan-interface2] ip forward-broadcast
2.     Configure Switch B:
# Configure a static route to the host.
[SwitchB] ip route-static 1.1.1.1 24 2.2.2.2
# Specify an IP address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ip address 2.2.2.1 24
After the configurations are completed, if you ping the subnet-directed broadcast address 2.2.2.255 on the host, VLAN-interface 2 of Switch B can receive the ping packets. If you delete the ip forward-broadcast configuration on any switch, the interface cannot receive the ping packets.
Setting the MTU of IPv4 packets sent over an interface
When a packet exceeds the MTU of IPv4 packets sent over an interface, the device processes the packet in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set the MTU based on the network environment to avoid fragmentation.
To set the MTU of IPv4 packets sent over an interface:
Step
Remarks
N/A
N/A
3.     Set the MTU of IPv4 packets sent over the interface.
ip mtu mtu-size
By default, the MTU of IPv4 packets sent over the interface is not set.
Setting TCP MSS for an interface
The maximum segment size (MSS) option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, it fragments the segment according to the receiver's MSS.
If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
This configuration takes effect only for TCP connections established after the configuration rather than the TCP connections that already exist.
This configuration is effective only for IP packets. If MPLS is enabled on the interface, do not set the TCP MSS on the interface.
To set the TCP MSS for the interface:
Step
Remarks
N/A
N/A
3.     Set the TCP MSS for the interface.
tcp mss value
By default, the TCP MSS is not set.
Configuring TCP path MTU discovery
IMPORTANT
IMPORTANT:
All devices on a TCP connection must be enabled to send ICMP error messages by using the ip unreachables enable command.
TCP path MTU discovery (in RFC 1191) discovers the path MTU between the source and destination ends of a TCP connection. It works as follows:
1.     A TCP source device sends a packet with the Don't Fragment (DF) bit set.
2.     A router discards the packet that exceeds the MTU of the outgoing interface and returns an ICMP error message. The error message contains the MTU of the outgoing interface.
3.     Upon receiving the ICMP message, the TCP source device calculates the current path MTU of the TCP connection.
4.     The TCP source device sends subsequent TCP segments that each are smaller than the MSS (MSS = path MTU – IP header length – TCP header length).
If the TCP source device still receives ICMP error messages when the MSS is smaller than 32 bytes, the TCP source device will fragment packets.
An ICMP error message received from a router that does not support RFC 1191 has the MTU of the outgoing interface set to 0. Upon receiving the ICMP message, the TCP source device selects the path MTU smaller than the current path MTU from the MTU table as described in RFC 1191. Based on the selected path MTU, the TCP source device calculates the TCP MSS. The MTU table contains MTUs of 68, 296, 508, 1006, 1280, 1492, 2002, 4352, 8166, 17914, 32000, and 65535 bytes. Because the minimum TCP MSS specified by the system is 32 bytes, the actual minimum MTU is 72 bytes.
After you enable TCP path MTU discovery, all new TCP connections will detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
The path MTU uses the following aging mechanism to ensure that the source device can increase the path MTU when the minimum link MTU on the path increases:
·     When the TCP source device receives an ICMP error message, it reduces the path MTU and starts an aging timer for the path MTU.
·     After the aging timer expires, the source device uses a larger MSS in the MTU table, as described in RFC 1191.
·     If no ICMP error message is received within two minutes, the source device increases the MSS again until the MSS negotiated during TCP three-way handshake is reached.
To enable TCP path MTU discovery:
Step
Remarks
N/A
2.     Enable TCP path MTU discovery.
The default setting is disabled.
Enabling SYN Cookie
A TCP connection is established through a three-way handshake:
1.     The sender sends a SYN packet to the server.
2.     The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3.     The sender receives the SYN ACK packet and replies with an ACK packet. A TCP connection is established.
An attacker can exploit this mechanism to mount SYN Flood attacks. The attacker sends a large number of SYN packets, but does not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and can no longer handle normal services.
SYN Cookie can protect the server from SYN Flood attacks. When the server receives a SYN packet, it responds with a SYN ACK packet without establishing a TCP semi-connection. The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the client.
To enable SYN Cookie:
Step
Remarks
N/A
2.     Enable SYN Cookie.
tcp syn-cookie enable
By default, SYN Cookie is disabled.
Setting the TCP buffer size
Step
Remarks
N/A
2.     Set the size of TCP receive/send buffer.
tcp window window-size
The default buffer size is 63 KB.
Setting TCP timers
You can set the following TCP timers:
·     SYN wait timer—TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
·     FIN wait timer—TCP starts the FIN wait timer when TCP changes the connection state to FIN_WAIT_2. If no FIN packet is received within the timer interval, TCP terminates the connection. If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer, and tears down the connection when the timer expires.
To set TCP timers:
Step
Remarks
N/A
2.     Set TCP timers.
·     Set the TCP SYN wait timer:
·     Set the TCP FIN wait timer:
By default:
·     The TCP SYN wait timer is 75 seconds.
·     The TCP FIN wait timer is 675 seconds.
Enabling sending ICMP error messages
Perform this task to enable sending ICMP error messages, including redirect, time exceeded, and destination unreachable messages.
·     ICMP redirect messages
A host that has only one default route sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop by following these rules:
¡     The receiving and sending interfaces are the same.
¡     The selected route is not created or modified by any ICMP redirect messages.
¡     The selected route is not destined for 0.0.0.0.
¡     There is no source route option in the received packet.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing table.
·     ICMP time exceeded messages
A device sends ICMP time exceeded messages by following these rules:
¡     The device sends the source an ICMP TTL exceeded in transit message when the following conditions are met:
-     The received packet is not destined for the device.
-     The TTL field of the packet is 1.
¡     When the device receives the first fragment of an IP datagram destined for it, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
·     ICMP destination unreachable messages
A device sends ICMP destination unreachable messages by following these rules:
¡     The device sends the source an ICMP network unreachable message when the following conditions are met:
-     The packet does not match any route.
-     No default route exists in the routing table.
¡     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
-     The packet is destined for the device.
-     The transport layer protocol of the packet is not supported by the device.
If a DHCP enabled device receives an ICMP echo reply without sending any ICMP echo requests, the device does not send any ICMP protocol unreachable messages to the source. For more information about DHCP, see Layer 3—IP Services Configuration Guide.
¡     The device sends the source an ICMP port unreachable message when the following conditions are met:
-     The UDP packet is destined for the device.
-     The packet's port number does not match the corresponding process.
¡     The device sends the source an ICMP source route failed message when the following conditions are met:
-     The source uses Strict Source Routing to send packets.
-     The intermediate device finds that the next hop specified by the source is not directly connected.
¡     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
-     The MTU of the sending interface is smaller than the packet.
-     The packet has DF set.
To enable sending ICMP error messages:
Step
Remarks
N/A
2.     Enable sending ICMP error messages.
·     Enable sending ICMP redirect messages:
ip redirects enable
·     Enable sending ICMP time exceeded messages:
ip ttl-expires enable
·     Enable sending ICMP destination unreachable messages:
The default settings are disabled.
Sending ICMP error messages facilitates network management, but sending excessive ICMP messages increases network traffic. The device performance degrades if it receives a lot of malicious ICMP messages that cause it to respond with ICMP error messages.
To prevent such problems, you can disable the device from sending ICMP error messages. A device that is disabled from sending ICMP time exceeded messages does not send ICMP TTL exceeded in transit messages. However, it can still send ICMP fragment reassembly time exceeded messages.
Disabling forwarding ICMP fragments
Disabling forwarding ICMP fragments can protect your device from ICMP fragments attacks.
To disable forwarding ICMP fragments:
Step
Remarks
N/A
2.     Disable forwarding ICMP fragments.
ip icmp fragment discarding
By default, forwarding ICMP fragments is enabled.
Configuring rate limit for ICMP error messages
To avoid sending excessive ICMP error messages within a short period that might cause network congestion, you can limit the rate at which ICMP error messages are sent. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
To configure rate limit for ICMP error messages:
Step
Remarks
N/A
2.     Set the bucket size and the interval for tokens to arrive in the bucket for ICMP error messages.
By default, the bucket allows a maximum of 10 tokens. A token is placed in the bucket at an interval of 100 milliseconds.
To disable the ICMP rate limit, set the interval to 0 milliseconds.
Specifying the source address for ICMP packets
Perform this task to specify the source IP address for outgoing ping echo requests and ICMP error messages. As a best practice, specify the IP address of the loopback interface as the source IP address. This feature helps users to locate the sending device easily.
If you specify an IP address in the ping command, ping echo requests use the specified address as the source IP address rather than the IP address specified by the ip icmp source command.
To specify the source IP address for ICMP packets:
Step
Remarks
N/A
2.     Specify the source address for outgoing ICMP packets.
By default, no source address is specified for outgoing ICMP packets. The device uses the IP address of the sending interface as the source IP address for outgoing ICMP packets.
Enabling IPv4 local fragment reassembly
Perform this task to enable the local reassembly feature for IPv4 fragments that are destined for the local device. This feature improves IPv4 fragment reassembly performance.
This feature enables the receiving subordinate to reassemble the received IPv4 fragments instead of delivering them to the master for reassembly. It applies only to fragments destined for the same subordinate.
To enable IPv4 local fragment reassembly:
Step
Remarks
N/A
2.     Enable IPv4 local fragment reassembly.
ip reassemble local enable
By default, IPv4 local fragment reassembly is disabled.
Displaying and maintaining IP performance optimization
Display brief information about RawIP connections.
Display detailed information about RawIP connections.
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
Display brief information about TCP connections.
Display detailed information about TCP connections.
Display brief information about UDP connections.
Display detailed information about UDP connections.
Display IP packet statistics.
Display TCP traffic statistics.
Display UDP traffic statistics.
Display ICMP statistics.
Clear IP packet statistics.
Clear TCP traffic statistics.
reset tcp statistics
Clear UDP traffic statistics.
reset udp statistics
