- 10-High Availability Configuration Examples
- 01-H3C_S7500E-XS_Ethernet_OAM_Configuration_Examples
- 02-H3C_S7500E-XS_CFD_Configuration_Examples
- 03-H3C_S7500E-XS_DLDP_Configuration_Examples
- 04-H3C_S7500E-XS_RRPP_configuration_examples
- 05-H3C_S7500E-XS_Smart_Link_Configuration_Examples
- 06-H3C_S7500E-XS_VRRP_Configuration_Examples
- 07-H3C_S7500E-XS_BFD_Configuration_Examples
07-H3C_S7500E-XS_BFD_Configuration_Examples | 409.05 KB |
H3C S7500E-XS BFD Configuration Examples
Copyright © 2016 Hangzhou H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
General configuration restrictions and guidelines
Example: Configuring VRRP-BFD-Track collaboration
Configuring interface IP addresses
Configuring the interfaces that connect the gateways
Disabling the spanning tree feature on uplink interfaces
Configuring static routes from Device E and Device F to the virtual IP addresses of the VRRP groups
Example: Configuring BFD for static routing
Configuring BFD parameters on Device A
Example: Configuring BFD for RIP
Example: Configuring BFD for OSPF
Example: Configuring BFD for IS-IS
Example: Configuring BFD for BGP
Example: Configuring BFD for PBR
Configuring routing policies on Device A··
Introduction
This document provides BFD configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BFD, VRRP, Track, OSPF, and IS-IS.
When you configure BFD, follow these restrictions and guidelines:
· IP tunnels (for example, IPv6 over IPv4 tunnels) do not support BFD.
· To avoid echo packet loss, do not configure the echo packet mode on a device with uRPF enabled.
Network requirements
As shown in Figure 1:
· Two distribution layer devices, Device A and Device B, are deployed at the egress of area A and area B.
· Device A and Device B belong to VRRP group 1 and VRRP group 2.
· Device A is the master in VRRP group 1. Device B is the master in VRRP group 2.
· The default gateway is VRRP group 1 for users in area A and VRRP group 2 for users in area B.
Configure VRRP-Track-BFD collaboration to meet the following requirements:
· When Device A and Device B are operating correctly, they forward traffic for users in area A and area B, respectively.
· When one gateway device or the uplink of the device fails, BFD can detect the failure and the other device takes over to implement link switchover.
· When the downlink of a gateway device fails, L2 Switch A or L2 Switch B forwards user traffic to the gateway through interface Ten-GigabitEthernet 1/1/2. When the fault is cleared, L2 Switch A or L2 Switch B forwards user traffic to the gateway through interface Ten-GigabitEthernet 1/1/1.
Requirements analysis
To meet the network requirements, you must perform the following tasks:
· For Device A to become the master in VRRP group 1, configure a higher priority (110) for Device A in VRRP group 1 (Device B uses the default priority 100). For Device B to become the master in VRRP group 2, configure a higher priority (110) for Device B in VRRP group 2 (Device A uses the default priority 100).
· To enable the failed master to forward traffic when it recovers, configure both VRRP groups to operate in preemptive mode.
· To enable Device A to communicate with Device B by using VRRP advertisement packets and BFD packets of different VLANs, configure the ports connecting Device A and Device B to allow packets from VLAN 2 and VLAN 3 to pass through.
· To eliminate Layer 2 loops, configure MSTP. Map VLAN 2 to MSTI 1 and map VLAN 3 to MSTI 2. The configuration traffic in MSTI 1 and MSTI 2 is forwarded through Ten-GigabitEthernet 1/1/1 of L2 Switch A and Ten-GigabitEthernet 1/1/1 of L2 Switch B, respectively.
· To prevent MSTP from blocking uplink interface Ten-GigabitEthernet 1/1/1 of Device A and Device B, disable the spanning tree feature on the interfaces.
Software version used
This configuration example was created and verified on S7500EXS-CMW710-R7178.
When you configure VRRP-BFD-Track collaboration, follow these restrictions and guidelines:
· Make sure the VRRP versions on all devices of the VRRP group are the same.
· The source IP address for BFD echo packets cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
· The virtual IP address of an IPv4 VRRP group and the downlink interface IP address of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet might fail to access external networks.
Configuration procedures
1. Configure Device A:
[DeviceA] vlan 101
[DeviceA-vlan101] port ten-gigabitethernet 1/1/1
[DeviceA-vlan101] quit
[DeviceA] interface vlan-interface 101
[DeviceA-Vlan-interface101] ip address 1.1.1.1 24
[DeviceA-Vlan-interface101] quit
2. Configure other devices in the same way Device A is configured. (Details not shown.)
# Configure Ten-Gigabitethernet 1/1/4 as a trunk port, remove the interface from VLAN 1, and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface ten-gigabitethernet 1/1/4
[DeviceA-Ten-GigabitEthernet1/1/4] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/1/4] undo port trunk permit vlan 1
[DeviceA-Ten-GigabitEthernet1/1/4] port trunk permit vlan 2 to 3
[DeviceA-Ten-GigabitEthernet1/1/4] port trunk pvid vlan 2
[DeviceA-Ten-GigabitEthernet1/1/4] quit
2. Configure Device B:
[DeviceB] interface ten-gigabitethernet 1/1/4
[DeviceB-Ten-GigabitEthernet1/1/4] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/1/4] undo port trunk permit vlan 1
[DeviceB-Ten-GigabitEthernet1/1/4] port trunk permit vlan 2 to 3
[DeviceB-Ten-GigabitEthernet1/1/4] port trunk pvid vlan 2
[DeviceB-Ten-GigabitEthernet1/1/4] quit
1. Disable the spanning tree feature on Ten-GigabitEthernet 1/1/1 of Device A:
[DeviceA] interface ten-gigabitethernet 1/1/1
[DeviceA-Ten-GigabitEthernet1/1/1] undo stp enable
[DeviceA-Ten-GigabitEthernet1/1/1] quit
2. Disable the spanning tree feature on Ten-GigabitEthernet 1/1/1 of Device B:
[DeviceB] interface ten-gigabitethernet 1/1/1
[DeviceB-Ten-GigabitEthernet1/1/1] undo stp enable
[DeviceB-Ten-GigabitEthernet1/1/1] quit
1. Configure Device E:
Configure static routes to the virtual IP addresses of VRRP group 1 and VRRP group 2.
<DeviceE> system-view
[DeviceE] ip route-static 10.1.1.0 255.255.255.0 1.1.1.1
[DeviceE] ip route-static 10.1.2.0 255.255.255.0 1.1.1.1
2. Configure Device F:
[DeviceF] ip route-static 10.1.1.0 255.255.255.0 1.1.2.1
[DeviceF] ip route-static 10.1.2.0 255.255.255.0 1.1.2.1
Configuring VRRP groups
# Configure the virtual IP address for VRRP group 1, set the preemption delay, and configure the priority of Device A in VRRP group 1.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[DeviceA-Vlan-interface2] vrrp vrid 1 priority 110
[DeviceA-Vlan-interface2] vrrp vrid 1 preempt-mode delay 500
[DeviceA-Vlan-interface2] quit
# Configure the virtual IP address for VRRP group 2, and set the preemption delay.
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] vrrp vrid 2 virtual-ip 10.1.2.1
[DeviceA-Vlan-interface3] vrrp vrid 2 preempt-mode delay 500
[DeviceA–Vlan-interface3] quit
# Configure the virtual IP address for VRRP group 1, and set the preemption delay.
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[DeviceB-Vlan-interface2] vrrp vrid 1 preempt-mode delay 500
[DeviceB-Vlan-interface2] quit
# Configure the virtual IP address for VRRP group 2, set the preemption delay, and configure the priority of Device B in VRRP group 2.
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] vrrp vrid 2 virtual-ip 10.1.2.1
[DeviceB-Vlan-interface3] vrrp vrid 2 priority 110
[DeviceB-Vlan-interface3] vrrp vrid 2 preempt-mode delay 500
[DeviceB–Vlan-interface3] quit
Configuring BFD
# Configure the source IP address for BFD echo packets.
[DeviceA] bfd echo-source-ip 10.10.10.10
[DeviceB] bfd echo-source-ip 11.11.11.11
Configuring Track
# Create track entry 1, and associate it with the BFD session to verify the reachability of Device E.
[DeviceA] track 1 bfd echo interface vlan-interface 101 remote ip 1.1.1.2 local ip 1.1.1.1
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to negative.
[DeviceA-Vlan-interface2] vrrp vrid 1 track 1 priority reduced 20
Configure Device B:
# Create track entry 1, and associate it with the BFD session to verify the reachability of Device F.
[DeviceB] track 1 bfd echo interface vlan-interface 101 remote ip 1.1.2.2 local ip 1.1.2.1
# Associate VRRP group 2 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to negative.
[DeviceB-Vlan-interface3] vrrp vrid 2 track 1 priority reduced 20
[DeviceB-Vlan-interface3] quit
Configuring MSTP
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name vrrp
[DeviceA-mst-region] instance 1 vlan 2
[DeviceA-mst-region] instance 2 vlan 3
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
[DeviceA] stp instance 1 root primary
[DeviceA] stp instance 2 root secondary
[DeviceA] stp global enable
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name vrrp
[DeviceB-mst-region] instance 1 vlan 2
[DeviceB-mst-region] instance 2 vlan 3
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
[DeviceB] stp instance 2 root primary
[DeviceB] stp instance 1 root secondary
[DeviceB] stp global enable
3. Configure L2 Switch A:
[SwitchA] stp region-configuration
[SwitchA-mst-region] region-name vrrp
[SwitchA-mst-region] instance 1 vlan 2
[SwitchA-mst-region] active region-configuration
[SwitchA-mst-region] quit
[SwitchA] stp global enable
4. Configure L2 Switch B:
[SwitchB] stp region-configuration
[SwitchB-mst-region] region-name vrrp
[SwitchB-mst-region] instance 2 vlan 3
[SwitchB-mst-region] active region-configuration
[SwitchB-mst-region] quit
1. Verify that the hosts in the LAN can access the external network when Device A and Device B are operating correctly:
# Ping 1.1.1.2 from host A in area A.
<host A> ping 1.1.1.2
PING 1.1.1.2 (1.1.1.2): 56 data bytes
56 bytes from 1.1.1.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 1.1.1.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 1.1.1.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 1.1.1.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 1.1.1.2: seq=4 ttl=128 time=9.11 ms
--- 1.1.1.2 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 7.17/11.01/22.43 ms
# Ping 1.1.2.2 from host C in area B.
<host C> ping 1.1.2.2
PING 1.1.2.2 (1.1.2.2): 56 data bytes
56 bytes from 1.1.2.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 1.1.2.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 1.1.2.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 1.1.2.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 1.1.2.2: seq=4 ttl=128 time=9.11 ms
--- 1.1.2.2 ping statistics ---
The output shows that the hosts in area A and area B can access the external network.
# Display BFD session information on Device A.
[DeviceA] display bfd session
Total Session Num: 1 Up Session Num: 1 Init Mode: Active
IPv4 Session Working Under Echo Mode:
LD SourceAddr DestAddr State Holdtime Interface
65 1.1.1.1 1.1.1.2 Up 500ms Vlan101
The output shows that a BFD session has been established.
# Display detailed VRRP group information on Device A.
[DeviceA] display vrrp verbose
Running Mode : Standard
Interface Vlan-interface2
VRID : 1 Adver Timer : 100
Admin Status : Up State : Master
Config Pri : 110 Running Pri : 110
Preempt Mode : Yes Delay Time : 500
Auth Type : None
Virtual IP : 10.1.1.1
Virtual MAC : 0000-5e00-0101
Master IP : 10.1.1.101
VRRP Track Information:
Track Object : 1 State : Positive Pri Reduced : 20
Interface Vlan-interface3
VRID : 2 Adver Timer : 100
Admin Status : Up State : Backup
Config Pri : 100 Running Pri : 100
Become Master : 3600ms left
Auth Type : None
Virtual IP : 10.1.2.1
Master IP : 10.1.2.102
# Display detailed VRRP group information on Device B.
[DeviceB] display vrrp verbose
Become Master : 3100ms left
Auth Type : None
Auth Type : None
Virtual MAC : 0000-5e00-0102
¡ In VRRP group 1, Device A is the master, and Device B is the backup. Hosts that use default gateway 10.1.1.1/24 access the Internet through Device A.
¡ In VRRP group 2, Device B is the master, and Device A is the backup. Hosts that use default gateway 10.1.2.1/24 access the Internet through Device B.
2. Verify that the hosts in the LAN can access the external network when the uplink monitored by Device A fails:
Total Session Num: 1 Up Session Num: 0 Init Mode: Active
65 1.1.1.1 1.1.1.2 Down / Vlan101
The output shows that the BFD session has been terminated.
Auth Type : None
Master IP : 10.1.1.102
Auth Type : None
The output shows that Device B becomes the master in VRRP group 1. Hosts in area A access the external network through Device B.
# When the fault is cleared, display BFD session information on Device A.
65 1.1.1.1 1.1.1.2 Up 1000ms Vlan101
The output shows that the BFD session is resumed.
Auth Type : None
Become Master : 3550ms left
Auth Type : None
The output shows that Device A resumes its priority and becomes the master in VRRP group 1 again. Hosts in area B access the external network through Device A.
Configuration files
· Device A:
vlan 2 to 3
vlan 101
region-name vrrp
instance 1 vlan 2
instance 2 vlan 3
stp global enable
interface Vlan-interface2
ip address 10.1.1.101 255.255.255.0
interface Vlan-interface3
ip address 10.1.2.101 255.255.255.0
interface Vlan-interface101
ip address 1.1.1.1 255.255.255.0
interface Ten-GigabitEthernet1/1/1
port link-mode bridge
port access vlan 101
undo stp enable
interface Ten-GigabitEthernet1/1/2
port access vlan 2
interface Ten-GigabitEthernet1/1/3
port access vlan 3
interface Ten-GigabitEthernet1/1/4
track 1 bfd echo interface Vlan-interface101 remote ip 1.1.1.2 local ip 1.1.1.1
· Device B:
vlan 2 to 3
vlan 101
region-name vrrp
instance 1 vlan 2
instance 2 vlan 3
stp global enable
ip address 10.1.1.102 255.255.255.0
ip address 10.1.2.102 255.255.255.0
ip address 1.1.2.1 255.255.255.0
undo stp enable
port access vlan 2
port access vlan 3
track 1 bfd echo interface Vlan-interface101 remote ip 1.1.2.2 local ip 1.1.2.1
· L2 Switch A:
vlan 2
region-name vrrp
instance 1 vlan 2
stp global enable
port access vlan 2
port access vlan 2
· L2 Switch B:
vlan 3
region-name vrrp
instance 2 vlan 3
stp global enable
port access vlan 3
port access vlan 3
· Device E:
vlan 101
ip address 1.1.1.2 255.255.255.0
· Device F:
vlan 101
ip address 1.1.2.2 255.255.255.0
· Device A has two paths to reach Device B: one over a Layer 2 switch, and the other over Device C.
· A Layer 2 switch connects Device A and Device B.
Because Device B does not support BFD, enable BFD echo packet mode on Device A. When the link between Device B and the Layer 2 switch fails, Device A switches the path over Device C to reach Device B.
Device |
IP address |
Device A |
Vlan-int10 |
192.168.10.101/24 |
Device A |
Vlan-int20 |
192.168.20.101/24 |
Device A |
Vlan-int40 |
192.168.40.101/24 |
Device B |
Vlan-int10 |
192.168.10.102/24 |
Device B |
Vlan-int30 |
192.168.30.101/24 |
Device B |
Vlan-int50 |
192.168.50.101/24 |
Device C |
Vlan-int20 |
192.168.20.102/24 |
Device C |
Vlan-int30 |
192.168.30.102/24 |
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 1/1/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 192.168.10.101 24
# Configure two static routes with the same destination network 192.168.50.0/24 and different preferences. Configure the BFD echo packet mode for the preferred static route (Device A –> L2 Switch–> Device B).
[DeviceA] ip route-static 192.168.50.0 24 vlan-interface 10 192.168.10.102 bfd echo-packet
[DeviceA] ip route-static 192.168.50.0 24 vlan-interface 20 192.168.20.102 preference 65
# Configure two static routes with the same destination network 192.168.40.0/24 and different preferences. Configure the BFD echo packet mode for the preferred static route (Device B –> L2 Switch–> Device A).
[DeviceB] ip route-static 192.168.40.0 24 vlan-interface 10 192.168.10.101
[DeviceB] ip route-static 192.168.40.0 24 vlan-interface 30 192.168.30.102 preference 65
3. Configure Device C:
# Configure static routes with destination networks 192.168.40.0/24 and 192.168.50.0/24.
[DeviceC] ip route-static 192.168.40.0 24 vlan-interface 20 192.168.20.101
[DeviceC] ip route-static 192.168.50.0 24 vlan-interface 30 192.168.30.101
# Configure the minimum interval for receiving BFD echo packets and the single-hop detection time multiplier.
[DeviceA-Vlan-interface10] bfd min-echo-receive-interval 100
[DeviceA-Vlan-interface10] bfd detect-multiplier 3
1. Verify the configuration when Device A and Device B and the link between them are operating correctly:
# Display static route information on Device A.
[DeviceA] display ip routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
192.168.50.0/24 Static 60 0 192.168.10.102 Vlan10
Static Routing table Status : <Inactive>
Summary Count : 0
The output shows that Device A communicates with Device B through the Layer 2 switch.
67 192.168.10.101 192.168.10.102 Up 300ms Vlan10
2. Verify the configuration when the link between Device B and the Layer 2 switch is faulty:
Summary Count : 1
Summary Count : 1
192.168.50.0/24 Static 65 0 192.168.20.102 Vlan20
Summary Count : 0
The output shows that Device A communicates with Device B through Device C.
Configuration files
· Device A:
vlan 10
vlan 20
vlan 40
ip address 192.168.10.101 255.255.255.0
interface Vlan-interface20
ip address 192.168.20.101 255.255.255.0
interface Vlan-interface40
ip address 192.168.40.101 255.255.255.0
port access vlan 10
port access vlan 20
port access vlan 40
ip route-static 192.168.50.0 24 Vlan-interface10 192.168.10.102 bfd echo-packet
ip route-static 192.168.50.0 24 Vlan-interface20 192.168.20.102 preference 65
· Device B:
vlan 10
vlan 30
vlan 50
ip address 192.168.10.102 255.255.255.0
interface Vlan-interface30
ip address 192.168.30.101 255.255.255.0
interface Vlan-interface50
ip address 192.168.50.101 255.255.255.0
port access vlan 10
port access vlan 30
port access vlan 50
ip route-static 192.168.40.0 24 Vlan-interface10 192.168.10.101
ip route-static 192.168.40.0 24 Vlan-interface30 192.168.30.102 preference 65
· Device C:
vlan 20
vlan 30
ip address 192.168.20.102 255.255.255.0
ip address 192.168.30.102 255.255.255.0
port access vlan 20
port access vlan 30
ip route-static 192.168.40.0 24 Vlan-interface20 192.168.20.101
ip route-static 192.168.50.0 24 Vlan-interface30 192.168.30.101
As shown in Figure 3, Device A, Device B, and Device C run RIP. Device A and Device C are connected through a Layer 2 switch.
Enable BFD echo packet mode on Device A (Device C does not support BFD) to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies RIP to switch to the path over Device B.
Device |
IP address |
Device A |
Vlan-int10 |
10.1.0.101/24 |
Device A |
Vlan-int20 |
192.168.0.101/24 |
Device A |
Vlan-int100 |
120.1.1.1/24 |
Device B |
Vlan-int20 |
192.168.0.102/24 |
Device B |
Vlan-int30 |
13.1.1.101/24 |
Device C |
Vlan-int10 |
10.1.0.102/24 |
Device C |
Vlan-int30 |
13.1.1.102/24 |
Device C |
Vlan-int100 |
121.1.1.1/24 |
[DeviceA] vlan 10
[DeviceA] interface vlan-interface10
[DeviceA-Vlan-interface10] ip address 10.1.0.101 24
Configuring RIP
# Configure basic RIP functions, import direct routes, and enable BFD for RIP.
[DeviceA] rip 1
[DeviceA-rip-1] version 2
[DeviceA-rip-1] undo summary
[DeviceA-rip-1] network 10.1.0.0
[DeviceA-rip-1] network 192.168.0.0
[DeviceA-rip-1] import-route direct
[DeviceA-rip-1] quit
[DeviceA-Vlan-interface10] rip bfd enable
# Configure basic RIP functions, and import direct routes.
[DeviceB] rip 1
[DeviceB-rip-1] version 2
[DeviceB-rip-1] undo summary
[DeviceB-rip-1] network 192.168.0.0
[DeviceB-rip-1] network 13.1.1.0
[DeviceB-rip-1] import-route direct
[DeviceB-rip-1] quit
<DeviceC> system-view
[DeviceC] rip 1
[DeviceC-rip-1] version 2
[DeviceC-rip-1] undo summary
[DeviceC-rip-1] network 10.1.0.0
[DeviceC-rip-1] network 13.1.1.0
[DeviceC-rip-1] import-route direct
[DeviceC-rip-1] quit
[DeviceA] bfd echo-source-ip 11.11.11.11
[DeviceA] display bfd session verbose
Local Discr: 2049
Source IP: 10.1.0.101 Destination IP: 10.1.0.102
Session State: Up Interface: Vlan-interface10
Hold Time: 300ms Act Tx Inter: 100ms
Min Rx Inter: 100ms Detect Inter: 300ms
Rx Count: 0 Tx Count: 910
Connect Type: Direct Running Up for: 00:00:46
Detect Mode: Async Slot: 1
Protocol: RIP
Diag Info: No Diagnostic
The output shows that a BFD session has been established and is up.
# Display information about the routes to network 121.1.1.0/24 on Device A.
<DeviceA> display ip routing-table 121.1.1.0 24 verbose
Summary Count : 1
Destination: 121.1.1.0/24
Protocol: RIP Process ID: 1
SubProtID: 0x1 Age: 04h20m37s
Cost: 1 Preference: 100
Tag: 0 State: Active Adv
TableID: 0x2 OrigAs: 0
NBRID: 0x26000002 LastAs: 0
AttrID: 0xffffffff Neighbor: 10.1.0.102
Flags: 0x1008c OrigNextHop: 10.1.0.102
Label: NULL RealNextHop: 10.1.0.102
BkLabel: NULL BkNextHop: N/A
Tunnel ID: Invalid Interface: Vlan-interface10
BkTunnel ID: Invalid BkInterface: N/A
The output shows that Device A communicates with Device C through the Layer 2 switch.
# When the link between Device C and the Layer 2 switch fails, view BFD log information.
%Oct 9 18:42:17:650 2013 Device A BFD/5/BFD_CHANGE_FSM: -MDC=1;Sess[10.1.0.101/10.1.0.102, LD/RD:2049/2049, Interface:Vlan10, SessType:Echo, LinkType:INET] , Sta: UP-> DOWN, Diag:1
The output shows that BFD can quickly detect the failure and notify RIP.
Summary Count : 1
Protocol: RIP Process ID: 2
Cost: 2 Preference: 100
AttrID: 0xffffffff Neighbor: 192.168.0.102
Flags: 0x1008c OrigNextHop: 192.168.0.102
Label: NULL RealNextHop: 192.168.0.102
Tunnel ID: Invalid Interface: Vlan-interface20
The output shows that Device A communicates with Device C through Device B.
Configuration files
· Device A:
rip 1
undo summary
version 2
network 10.0.0.0
network 192.168.0.0
import-route direct
vlan 10
vlan 20
vlan 100
ip address 10.1.0.101 255.255.255.0
bfd min-transmit-interval 100
bfd min-receive-interval 100
ip address 192.168.0.101 255.255.255.0
interface Vlan-interface100
ip address 120.1.1.1 255.255.255.0
port access vlan 10
port access vlan 20
port access vlan 100
· Device B:
rip 1
undo summary
version 2
network 192.168.0.0
network 13.1.1.0
import-route direct
vlan 20
vlan 30
ip address 192.168.0.102 255.255.255.0
ip address 13.1.1.101 255.255.255.0
port access vlan 20
port access vlan 30
· Device C:
rip 1
undo summary
version 2
network 10.1.0.0
network 13.1.1.0
import-route direct
vlan 10
vlan 30
vlan 100
ip address 10.1.0.102 255.255.255.0
ip address 13.1.1.102 255.255.255.0
ip address 121.1.1.1 255.255.255.0
port access vlan 10
port access vlan 30
As shown in Figure 4, Device A, Device B, and Device C run OSPF. Device A and Device C are connected through a Layer 2 switch.
Enable BFD control packet mode on Device A and Device C to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies OSPF to switch to the path over Device B.
Table 3 Interface and IP address assignment
Device |
IP address |
Device A |
Vlan-int10 |
10.1.0.101/24 |
Device A |
Vlan-int20 |
192.168.0.101/24 |
Device A |
Vlan-int100 |
120.1.1.1/24 |
Device B |
Vlan-int20 |
192.168.0.102/24 |
Device B |
Vlan-int30 |
13.1.1.101/24 |
Device C |
Vlan-int10 |
10.1.0.102/24 |
Device C |
Vlan-int30 |
13.1.1.102/24 |
Device C |
Vlan-int100 |
121.1.1.1/24 |
In BFD control packet mode, a minimum of one end must operate in active mode for a BFD session to be established.
[DeviceA] vlan 10
Configuring OSPF
# Configure basic OSPF functions, and enable BFD for OSPF.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 120.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
[DeviceA-Vlan-interface10] ospf bfd enable
# Configure basic OSPF functions.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 121.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ospf bfd enable
[DeviceC-Vlan-interface10] quit
# Configure the session establishment mode as active (this is the default mode).
[DeviceA] bfd session init-mode active
# Configure the minimum interval for sending and receiving single-hop BFD control packets and the single-hop detection time multiplier.
[DeviceA-Vlan-interface10] bfd min-transmit-interval 100
[DeviceA-Vlan-interface10] bfd min-receive-interval 100
2. Configure Device C:
[DeviceC] bfd session init-mode active
[DeviceC-Vlan-interface10] bfd min-transmit-interval 100
[DeviceC-Vlan-interface10] bfd min-receive-interval 100
[DeviceC-Vlan-interface10] bfd detect-multiplier 3
# Ping host C (connected to Device C) from host A (connected to Device A) to verify the connectivity.
<host A> ping 121.1.1.2
PING 121.1.1.2 (121.1.1.2): 56 data bytes
56 bytes from 121.1.1.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 121.1.1.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 121.1.1.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 121.1.1.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 121.1.1.2: seq=4 ttl=128 time=9.11 ms
--- 121.1.1.2 ping statistics ---
The output shows that host C can be pinged successfully.
# Display detailed OSPF neighbor information on Device A.
[DeviceA] display ospf peer verbose
Neighbors
Area 0.0.0.0 interface 10.1.0.101(Vlan-interface10)'s neighbors
Router ID: 1.1.1.1 Address: 10.1.0.102 GR State: Normal
State: Full Mode: Nbr is Slave Priority: 1
DR: 10.1.0.101 BDR: 10.1.0.102 MTU: 0
Options is 0x42 (-|O|-|-|-|-|E|-)
Dead timer due in 39 sec
Neighbor is up for 00:09:01
Neighbor state change count: 5
BFD status: Enabled(Control mode)
The output shows that Device A has established OSPF neighbor relationship with Device C.
# Display BFD session information on Device A and Device C.
Local Discr: 2049 Remote Discr: 2049
Min Tx Inter: 100ms Act Tx Inter: 100ms
Rx Count: 536 Tx Count: 536
Connect Type: Direct Running Up for: 00:04:48
Hold Time: 300ms Auth mode: None
Protocol: OSPF
[DeviceC] display bfd session verbose
Source IP: 10.1.0.102 Destination IP: 10.1.0.101
Rx Count: 3971 Tx Count: 3776
Connect Type: Direct Running Up for: 00:06:52
Protocol: OSPF
The output shows that BFD sessions have been established and are up.
<DeviceA> display ip routing-table 121.1.1.0 verbose
Summary Count : 1
Protocol: OSPF Process ID: 1
AttrID: 0xffffffff Neighbor: 0.0.0.0
%Oct 9 15:22:23:154 2013 DeviceC BFD/5/BFD_CHANGE_FSM: -MDC=1; Sess[10.1.0.1
02/10.1.0.101, LD/RD:2049/2049, Interface:Vlan10, SessType:Ctrl, LinkType:INET] ,
Sta: UP-> DOWN, Diag: 1
%Oct 9 15:22:23:155 2013 DeviceC OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 1 Neighbor 10.1
.0.101(Vlan-interface10) from FULL to DOWN.
The output shows that BFD can quickly detect the failure and notify OSPF.
Summary Count : 1
Neighbors
Protocol: OSPF
Protocol: OSPF
Summary Count : 1
Summary Count : 1
Configuration files
· Device A:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
vlan 100
ospf bfd enable
port access vlan 10
port access vlan 20
· Device B:
ospf 1
area 0.0.0.0
vlan 20
vlan 30
port access vlan 20
port access vlan 30
· Device C:
ospf 1
area 0.0.0.0
vlan 10
vlan 30
vlan 100
ospf bfd enable
port access vlan 10
port access vlan 30
As shown in Figure 5, Device A, Device B, and Device C run IS-IS. Device A and Device C are connected through a Layer 2 switch.
Enable BFD control packet mode on Device A and Device C to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies IS-IS to switch to the path over Device B.
Table 4 Interface and IP address assignment
Device |
IP address |
Device A |
Vlan-int10 |
10.1.0.101/24 |
Device A |
Vlan-int20 |
192.168.0.101/24 |
Device A |
Vlan-int100 |
120.1.1.1/24 |
Device B |
Vlan-int20 |
192.168.0.102/24 |
Device B |
Vlan-int30 |
13.1.1.101/24 |
Device C |
Vlan-int10 |
10.1.0.102/24 |
Device C |
Vlan-int30 |
13.1.1.102/24 |
Device C |
Vlan-int100 |
121.1.1.1/24 |
[DeviceA] vlan 10
Configuring IS-IS
# Configure basic IS-IS functions, and enable BFD for IS-IS.
[DeviceA] isis
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] isis enable
[DeviceA-Vlan-interface20] quit
[DeviceA-Vlan-interface10] isis enable
[DeviceA-Vlan-interface10] isis bfd enable
# Configure basic IS-IS functions.
[DeviceB] isis
[DeviceB-isis-1] network-entity 10.0000.0000.0003.00
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] isis enable
[DeviceB-Vlan-interface20] quit
[DeviceB] interface vlan-interface 30
[DeviceB-Vlan-interface30] isis enable
[DeviceB-Vlan-interface30] quit
[DeviceC] isis
[DeviceC-isis-1] network-entity 10.0000.0000.0002.00
[DeviceC-isis-1] quit
[DeviceC-Vlan-interface10] isis enable
[DeviceC-Vlan-interface10] isis bfd enable
[DeviceC] interface vlan 30
[DeviceC-Vlan-interface30] isis enable
[DeviceC-Vlan-interface30] quit
[DeviceC] interface vlan 10
# Display detailed IS-IS neighbor information on Device A.
[DeviceA] display isis peer verbose
Peer information for IS-IS(1)
System ID: 0000.0000.0002
Interface: Vlan10 Circuit Id: 0000.0000.0002.01
State: Up HoldTime: 6s Type: L1(L1L2) PRI: 64
Area address(es): 00
Peer IP address(es): 10.1.0.102
Peer local circuit ID: 1
Peer circuit SNPA address: ce9d-d91d-d100
Uptime: 00:01:19
Adj protocol: IPv4
Graceful Restart capable
Restarting signal: No
Suppress adjacency advertisement: No
Local topology:
0
Remote topology:
0
The output shows that Device A has established IS-IS neighbor relationship with Device C.
Rx Count: 3 Tx Count: 3
Connect Type: Direct Running Up for: 00:06:09
Protocol: ISIS_BR_L1/ISIS_BR_L2
Connect Type: Direct Running Up for: 00:07:10
Summary Count : 1
Protocol: isis Process ID: 1
Cost: 20 Preference: 15
OrigTblID: 0x2 OrigVrf: default-vrf
%Oct 9 16:11:24:163 2013 DeviceC BFD/5/BFD_CHANGE_FSM: -MDC=1; Sess[10.1.0.102/10.1.0.101, LD/RD:2049/2049, Interface:Vlan10, SessType:Ctrl, LinkType:INET] , S
%Oct 9 16:11:24:164 2013 DeviceC ISIS/5/ISIS_NBR_CHG: -MDC=1; IS-IS 1, Level-1 adj
acency 0000.0000.0001 (Vlan-interface10), state change to: DOWN.
%Oct 9 16:11:24:164 2013 DeviceC ISIS/5/ISIS_NBR_CHG: -MDC=1; IS-IS 1, Level-2 adj
The output shows that BFD can quickly detect the failure and notify IS-IS.
Summary Count : 1
Configuration files
· Device A:
isis 1
vlan 10
vlan 20
vlan 100
isis enable 1
isis bfd enable
isis enable 1
port access vlan 10
port access vlan 20
· Device B:
isis 1
vlan 20
vlan 30
isis enable 1
isis enable 1
port access vlan 20
port access vlan 30
· Device C:
isis 1
vlan 10
vlan 30
vlan 100
isis enable 1
isis bfd enable
isis enable 1
port access vlan 10
port access vlan 30
As shown in Figure 6, the devices in AS 100 run OSPF to reach each other. There are two paths between Device B and Device D:
· Path A—Path over Device C.
· Path B—Path over Device E.
When both paths are available, BGP uses the path over Device C to forward traffic between Device A and Device F.
Enable BFD control packet mode on Device B and Device D to monitor the path over Device C. When BFD detects a link failure, it notifies BGP to switch to the path over Device E.
Table 5 Interface and IP address assignment
Device |
IP address |
Device A |
Vlan-int100 |
120.1.0.1/24 |
Device B |
Vlan-int10 |
10.1.0.101/24 |
Device B |
Vlan-int30 |
192.168.0.101/24 |
Device B |
Vlan-int100 |
120.1.0.2/24 |
Device C |
Vlan-int10 |
10.1.0.102/24 |
Device C |
Vlan-int20 |
10.2.0.102/24 |
Device D |
Vlan-int20 |
10.2.0.101/24 |
Device D |
Vlan-int40 |
13.1.1.101/24 |
Device D |
Vlan-int100 |
120.2.0.2/24 |
Device E |
Vlan-int30 |
192.168.0.102/24 |
Device E |
Vlan-int40 |
13.1.1.102/24 |
Device F |
Vlan-int100 |
120.2.0.1/24 |
For Path A to become the primary path, use a routing policy to set a lower cost for Path A than Path B.
[DeviceA] vlan 100
[DeviceA-vlan100] port ten-gigabitethernet 1/1/1
[DeviceA-vlan100] quit
[DeviceA] interface vlan-interface100
[DeviceA-Vlan-interface100] ip address 120.1.0.1 24
[DeviceA-Vlan-interface100] quit
Configuring OSPF in AS 100
1. Configure Device B:
[DeviceB] ospf
[DeviceB-ospf-1] import-route direct
[DeviceB-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceC] ospf
[DeviceC-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
3. Configure Device D:
[DeviceD] ospf
[DeviceD-ospf-1] import-route direct
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
4. Configure Device E:
[DeviceE] ospf
[DeviceE-ospf-1] area 0
[DeviceE-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] quit
[DeviceE-ospf-1] quit
Configuring BGP
# Enable BGP and set the local AS number to 200.
[DeviceA] bgp 200
[DeviceA-bgp] router-id 1.1.1.1
# Establish an EBGP connection with Device B.
[DeviceA-bgp] peer 120.1.0.2 as-number 100
# Create the BGP IPv4 unicast address family and enter its view.
[DeviceA-bgp] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, inject local network 120.1.0.0/24 to the BGP routing table.
[DeviceA-bgp-ipv4] network 120.1.0.0 255.255.255.0
# Enable BGP to exchange IPv4 unicast routing information with peer 120.1.0.2.
[DeviceA-bgp-ipv4] peer 120.1.0.2 enable
[DeviceA-bgp-ipv4] quit
# Enable BGP and set the local AS number to 100.
[DeviceB] bgp 100
[DeviceB-bgp] router-id 2.2.2.2
# Establish an EBGP connection with Device A.
[DeviceB-bgp] peer 120.1.0.1 as-number 200
# Establish IBGP connections with Device D.
[DeviceB-bgp] peer 10.2.0.101 as-number 100
[DeviceB-bgp] peer 13.1.1.101 as-number 100
[DeviceB-bgp] address-family ipv4 unicast
# Enable BGP to exchange IPv4 unicast routing information with peer 10.2.0.101.
[DeviceB-bgp-ipv4] peer 10.2.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 10.2.0.101.
[DeviceB-bgp-ipv4] peer 10.2.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 13.1.1.101.
[DeviceB-bgp-ipv4] peer 13.1.1.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 13.1.1.101.
[DeviceB-bgp-ipv4] peer 13.1.1.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 120.1.0.1.
[DeviceB-bgp-ipv4] peer 120.1.0.1 enable
[DeviceB-bgp-ipv4] quit
[DeviceD] bgp 100
[DeviceD-bgp] router-id 4.4.4.4
# Establish IBGP connections with Device B.
[DeviceD-bgp] peer 10.1.0.101 as-number 100
[DeviceD-bgp] peer 192.168.0.101 as-number 100
# Establish an EBGP connection with Device F.
[DeviceD-bgp] peer 120.2.0.1 as-number 300
[DeviceD-bgp] address-family ipv4 unicast
# Enable BGP to exchange IPv4 unicast routing information with peer 10.1.0.101.
[DeviceD-bgp-ipv4] peer 10.1.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 10.1.0.101.
[DeviceD-bgp-ipv4] peer 10.1.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 192.168.0.101.
[DeviceD-bgp-ipv4] peer 192.168.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 192.168.0.101.
[DeviceD-bgp-ipv4] peer 192.168.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 120.2.0.1.
[DeviceD-bgp-ipv4] peer 120.2.0.1 enable
[DeviceD-bgp-ipv4] quit
4. Configure Device F:
# Enable BGP and set the local AS number to 300.
[DeviceF] bgp 300
[DeviceF-bgp] router-id 6.6.6.6
# Establish an EBGP connection with Device D.
[DeviceF-bgp] peer 120.2.0.2 as-number 100
[DeviceF-bgp] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, inject local network 120.2.0.0/24 to the BGP routing table.
[DeviceF-bgp-ipv4] network 120.2.0.0 255.255.255.0
# Enable BGP to exchange IPv4 unicast routing information with peer 120.2.0.2.
[DeviceF-bgp-ipv4] peer 120.2.0.2 enable
[DeviceF-bgp-ipv4] quit
# Create ACL 2000 to permit packets sourced from 120.1.0.0/24.
[DeviceB] acl number 2000
[DeviceB-acl-basic-2000] rule permit source 120.1.0.0 0.0.0.255
[DeviceB-acl-basic-2000] quit
# Set a local preference of 200 for routes advertised to peer 10.2.0.101, and set the preference for IBGP routes to 100.
[DeviceB] route-policy local-pre permit node 10
[DeviceB-route-policy-local-pre] if-match ip address acl 2000
[DeviceB-route-policy-local-pre] apply local-preference 200
[DeviceB-route-policy-local-pre] quit
[DeviceB] bgp 100
[DeviceB-bgp-ipv4] peer 10.2.0.101 route-policy local-pre export
[DeviceB-bgp-ipv4] preference 255 100 130
2. Configure Device D:
# Create ACL 2000 to permit packets sourced from 120.2.0.0/24.
[DeviceD] acl number 2000
[DeviceD-acl-basic-2000] rule permit source 120.2.0.0 0.0.0.255
[DeviceD-acl-basic-2000] quit
# Set a local preference of 200 for routes learned from peer 10.1.0.101, and configure the preference for IBGP routes as 100.
[DeviceD] route-policy local-pre permit node 10
[DeviceD-route-policy-local-pre] if-match ip address acl 2000
[DeviceD-route-policy-local-pre] apply local-preference 200
[DeviceD-route-policy-local-pre] quit
[DeviceD] bgp 100
[DeviceD-bgp-ipv4] peer 10.1.0.101 route-policy local-pre export
[DeviceD-bgp-ipv4] preference 255 100 130
Configuring BFD
# Enable BFD for the link to BGP peer 10.2.0.101.
[DeviceB] bgp 100
[DeviceB-bgp] peer 10.2.0.101 bfd
[DeviceB-bgp] quit
# Enable BFD for the link to BGP peer 10.1.0.101.
[DeviceD] bgp 100
[DeviceD-bgp] peer 10.1.0.101 bfd
[DeviceD-bgp] quit
# Ping Device F from Device A to verify the connectivity.
[DeviceA] ping 120.2.0.1
Ping 120.2.0.1 (120.2.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 120.2.0.1: icmp_seq=0 ttl=252 time=1.189 ms
56 bytes from 120.2.0.1: icmp_seq=1 ttl=252 time=1.095 ms
56 bytes from 120.2.0.1: icmp_seq=2 ttl=252 time=1.086 ms
56 bytes from 120.2.0.1: icmp_seq=3 ttl=252 time=1.097 ms
56 bytes from 120.2.0.1: icmp_seq=4 ttl=252 time=1.089 ms
--- Ping statistics for 120.2.0.1 ---
round-trip min/avg/max/std-dev = 1.086/1.111/1.189/0.039 ms
The output shows that Device F can be pinged successfully.
# Display BGP peer information on Device B.
[DeviceB] display bgp peer ipv4
BGP local router ID: 2.2.2.2
Local AS number: 100
Total number of peers: 3 Peers in established state: 3
10.2.0.101 100 6 4 0 1 00:00:56 Established
13.1.1.101 100 6 5 0 1 00:00:56 Established
120.1.0.1 200 6 5 0 1 00:00:56 Established
· Two IBGP connections have been established between Device B and Device D.
· An EBGP connection has been established between Device B and Device A.
# Display detailed BFD session information on Device B.
[DeviceB] display bfd session verbose
Local Discr: 2049 Remote Discr: 0
Source IP: 10.1.0.101 Destination IP: 10.2.0.101
Session State: UP Interface: N/A
Min Tx Inter: 1000400ms Act Tx Inter: 1000400ms
Min Rx Inter: 1000400ms Detect Inter: 50002000ms
Connect Type: Indirect Running Up for: 00:00:00
Hold Time: 0ms Auth mode: None
Protocol: BGP
# Display information about the routes to network 120.2.0.0/24 on Device B.
[DeviceB] display ip routing-table 120.2.0.0 24 verbose
Summary Count : 3
Destination: 120.2.0.0/24
Protocol: BGP Process ID: 0
SubProtID: 0x1 Age: 00h24m48s
Cost: 0 Preference: 100
TableID: 0x2 OrigAs: 300
NibID: 0x15000001 LastAs: 300
AttrID: 0x1 Neighbor: 10.2.0.101
Flags: 0x10060 OrigNextHop: 10.2.0.101
SubProtID: 0x8 Age: 00h26m19s
Cost: 1 Preference: 150
Tag: 1 State: Inactive Adv
NibID: 0x13000005 LastAs: 0
Flags: 0x41 OrigNextHop: 10.1.0.102
NibID: 0x13000003 LastAs: 0
Flags: 0x41 OrigNextHop: 192.168.0.102
Tunnel ID: Invalid Interface: Vlan-interface30
The output shows that Device B communicates with Device D through path over Device C.
# When the path over Device C fails, ping Device F from Device A.
<DeviceA> ping 120.2.0.1
Ping 120.1.0.1 (120.2.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 120.2.0.1: icmp_seq=0 ttl=252 time=0.680 ms
56 bytes from 120.2.0.1: icmp_seq=1 ttl=252 time=0.295 ms
56 bytes from 120.2.0.1: icmp_seq=2 ttl=252 time=0.423 ms
56 bytes from 120.2.0.1: icmp_seq=3 ttl=252 time=0.464 ms
56 bytes from 120.2.0.1: icmp_seq=4 ttl=252 time=0.445 ms
round-trip min/avg/max/std-dev = 0.295/0.461/0.680/0.124 ms
<DeviceB> display ip routing-table 120.2.0.0 24 verbose
Summary Count : 2
SubProtID: 0x1 Age: 00h00m18s
SubProtID: 0x8 Age: 00h00m18s
NibID: 0x13000001 LastAs: 0
The output shows that Device B communicates with Device D through path over Device E.
Configuration files
· Device A:
vlan 100
ip address 120.1.0.1 255.255.255.0
bgp 200
router-id 1.1.1.1
· Device B:
ospf 1
import-route direct
area 0.0.0.0
vlan 10
vlan 30
vlan 100
ip address 120.1.0.2 255.255.255.0
port access vlan 10
port access vlan 30
bgp 100
router-id 2.2.2.2
peer 10.2.0.101 bfd
acl number 2000
rule 0 permit source 120.1.0.0 0.0.0.255
· Device C:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
ip address 10.2.0.102 255.255.255.0
port access vlan 10
port access vlan 20
· Device D:
ospf 1
import-route direct
area 0.0.0.0
vlan 20
vlan 40
vlan 100
ip address 10.2.0.101 255.255.255.0
port access vlan 20
port access vlan 40
bgp 100
router-id 4.4.4.4
peer 10.1.0.101 bfd
acl number 2000
rule 0 permit source 120.2.0.0 0.0.0.255
· Device E:
ospf 1
area 0.0.0.0
vlan 30
vlan 40
port access vlan 30
port access vlan 40
· Device F:
vlan 100
ip address 120.2.0.1 255.255.255.0
bgp 300
router-id 6.6.6.6
As shown in Figure 7, Device A has two paths to reach Device C:
· Link A.
· Link B.
Configure PBR to enable Device A to forward traffic with source IP address 40.0.0.2 over Link B.
Enable BFD echo packet mode on Device A (Device C does not support BFD) to monitor Link B. When BFD detects a link failure, Device A switches the path to Link A.
[DeviceA] vlan 40
[DeviceA-vlan40] port ten-gigabitethernet 1/1/2
[DeviceA-vlan40] quit
[DeviceA] int vlan-interface 40
[DeviceA-Vlan-interface40] ip address 40.0.0.1 24
[DeviceA-Vlan-interface40] quit
# Configure a static route to reach network 50.0.0.0.
[DeviceA] ip route-static 50.0.0.0 24 vlan-interface 200 13.13.13.2
[DeviceB] ip route-static 50.0.0.0 24 vlan-interface 101 24.24.24.4
# Create ACL 3010 to permit packets sourced from 40.0.0.2.
[DeviceA] acl number 3010
[DeviceA-acl-adv-3010] rule 0 permit ip source 40.0.0.2 0
[DeviceA-acl-adv-3010] quit
# Create routing policy aaa to set next hop 12.12.12.2 for packets matching ACL 3010, and associate the next hop with track entry 11.
[DeviceA] policy-based-route aaa permit node 5
[DeviceA-pbr-aaa-5] if-match acl 3010
[DeviceA-pbr-aaa-5] apply next-hop 12.12.12.2 track 11
[DeviceA-pbr-aaa-5] quit
# Apply routing policy aaa to VLAN-interface 40.
[DeviceA] interface vlan-interface 40
[DeviceA-Vlan-interface40] ip policy-based-route aaa
[DeviceA] bfd echo-source-ip 3.3.3.3
# Configure the minimum interval for receiving BFD echo packets and the single-hop detection time multiplier, and associate track entry 11 with BFD.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] bfd min-echo-receive-interval 100
[DeviceA-Vlan-interface100] bfd detect-multiplier 3
[DeviceA] track 11 bfd echo interface vlan-interface100 remote ip 12.12.12.2 local ip 12.12.12.1
# Display outbound traffic statistics for all interfaces on Device A.
<DeviceA> reset counters interface
<DeviceA> display counters outbound interface
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
XGE1/1/1 0 0 0 0
XGE1/1/2 0 0 0 0
XGE1/1/3 585414 0 0 0
XGE1/1/4 0 0 0 0
XGE1/1/5 0 0 0 0
XGE1/1/6 0 0 0 0
The output shows that the traffic sourced from 40.0.0.0 is forwarded through VLAN-interface 100 (Link B).
Local Discr: 2049
Source IP: 12.12.12.1 Destination IP: 12.12.12.2
Session State: Up Interface: Vlan-interface100
Rx Count: 128234 Tx Count: 371950
Connect Type: Direct Running Up for: 00:01:04
Protocol: TRACK
# When the link between Device A and Device B fails, view BFD log information.
%Dec 10 16:39:46:210 2013 DeviceA BFD/5/BFD_CHANGE_FSM: -MDC=1; Sess[12.12.12.1/
12.12.12.2, LD/RD:2049/2049, Interface:Vlan100, SessType:Echo, LinkType:INET] , S
%Dec 10 16:39:47:342 2013 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Ten-GigabitEtherne
t1/1/3 link status is down.
%Dec 10 16:39:47:343 2013 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol on
the interface Ten-GigabitEthernet1/1/3 is down.
%Dec 10 16:39:47:343 2013 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Vlan-interface100
The output shows that the BFD session is down.
# Clear the interface statistics, and display outbound traffic statistics for all interfaces on Device A again.
XGE1/1/1 863764 0 0 0
XGE1/1/2 0 0 0 0
XGE1/1/3 0 0 0 0
XGE1/1/4 0 0 0 0
XGE1/1/5 0 0 0 0
XGE1/1/6 0 0 0 0
The output shows that the traffic sourced from 40.0.0.0 is forwarded through VLAN-interface 200 (Link A).
Configuration files
· Device A:
vlan 40
vlan 100
vlan 200
if-match acl 3010
ip address 40.0.0.1 255.255.255.0
ip address 12.12.12.1 255.255.255.0
interface Vlan-interface200
ip address 13.13.13.1 255.255.255.0
port access vlan 200
port access vlan 40
ip route-static 50.0.0.0 24 Vlan-interface200 13.13.13.2
ip local policy-based-route aaa
acl number 3010
track 11 bfd echo interface Vlan-interface100 remote ip 12.12.12.2 local ip 12.
12.12.1
· Device B:
vlan 100 to 101
interface NULL0
ip address 12.12.12.2 255.255.255.0
ip address 24.24.24.2 255.255.255.0
ip route-static 50.0.0.0 24 Vlan-interface101 24.24.24.4
· Device C:
vlan 50
vlan 101
vlan 200
interface NULL0
ip address 50.0.0.1 255.255.255.0
ip address 24.24.24.4 255.255.255.0
ip address 13.13.13.2 255.255.255.0
port access vlan 50
Related documentation
· H3C S7500E-XS Switch Series High Availability Command Reference-Release 7178
· H3C S7500E-XS Switch Series High Availability Configuration Guide-Release 7178
· H3C S7500E-XS Switch Series Layer 2—LAN Switching Command Reference-Release 7178
· H3C S7500E-XS Switch Series Layer 2—LAN Switching Configuration Guide-Release 7178
