13-OAA Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10013-OAA Command Reference
02-OAP commands
02-OAP commands 68.88 KB
OAP commands
OAP commands are available only on an LSU1FWCEA0.
display oap client info
Use display oap client info to display OAP client information.
display oap client info [ client-id ]
client-id: Specifies an OAP client by its ID in the range of 1 to 255. If you do not specify this argument, the command displays information about all OAP clients in ascending order of client IDs.
Client IDs are assigned by the OAP manager to OAP clients to uniquely identify the clients.
The OAP manager obtains OAP client information from notification packets received from OAP clients. If the information about a field is missing, the field is not displayed.
# Display information about OAP client 1.
<Sysname> display oap client info 1
Client ID: 1
 Client Description: SecBlade NS
 Hardware: A.0
 System Software: COMWAREV500R002B83D217SP01
 Application Software: V300R001B08D317SP02
 CPU: RMI XLR732 1000MHz
 PCB Version: A.0
 CPLD Version: 1.0
 Bootrom Version: Basic BootRom Version:1.28,Extend BootRom Version:1.50
 Storage Card: 247M Bytes Compact Flash Storage Device
 Memory: 3584M Bytes DDR2 SDRAM Memory
# Display information about all OAP clients.
Client ID: 1
 Hardware: A.0
 PCB Version: A.0
 CPLD Version: 1.0
display oap client summary
Use display oap client summary to display the summary registration information of OAP clients.
display oap client summary [ client-id ]
client-id: Specifies an OAP client by its ID in the range of 1 to 255. If you do not specify this argument, the command displays the summary registration information of all OAP clients in ascending order of client IDs.
# Display the summary registration information of OAP client 1.
<Sysname> display oap client summary 1
Client ID: 1
 Status: Registered
 MAC Address: 5cdd-70ab-1bc2
 Interface: Ten-GigabitEthernet1/1/0/1
 Last registered: 07/31/2014 10:25:07
# Display the summary registration information of all OAP clients.
Client ID: 1
 Status: Registered
Status
Status of the OAP client, which is always Registered.
MAC Address
MAC address of the OAP client.
Interface used to communicate with the OAP client.
Last registered
Registration time of the client.
oap client close
Use oap client close to shut down an OAP client.
oap client close client-id
This command applies only to OAP clients on Linux.
When you execute this command for a client in registered state, the OAP manager sends a shutdown notification to the specified OAP client. The client stops after receiving the notification. When you execute this command for a non-existent client, an error message appears.
# Shut down OAP client 1.
[Sysname] oap client close 1
·     display oap client summary
·     oap client reboot
oap client reboot
Use oap client reboot to restart an OAP client.
oap client reboot client-id
When you execute this command for a client in registered state, the OAP manager sends a restart notification to the specified OAP client. The client restarts after receiving the notification. When you execute this command for a non-existent client, an error message appears.
# Restart OAP client 1.
[Sysname] oap client reboot 1
·     oap client close
oap enable
Use oap enable to enable OAP.
Use undo oap enable to disable OAP.
oap enable
undo oap enable
OAP is disabled on an interface.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
# Enable OAP on interface Ten-GigabitEthernet 1/1/0/1.
[Sysname] interface ten-gigabitEthernet 1/1/0/1
[Sysname-Ten-GigabitEthernet1/1/0/1] oap enable
oap timer clock-sync
Use oap timer clock-sync to set the clock synchronization timer.
Use undo oap timer clock-sync to restore the default.
oap timer clock-sync minutes
The clock synchronization timer is set to 5 minutes.
minutes: Specifies the clock synchronization timer value in minutes, in the range of 0 to 1440. Setting this argument to 0 disables clock synchronization.
The clock synchronization timer regularly triggers the OAP manager to send clock and time zone synchronization notifications to OAP clients. These notifications keep the clients' clocks synchronized to the manager's clock.
# Set the clock synchronization timer to 20 minutes.
[Sysname] oap timer clock-sync 20
oap timer monitor
Use oap timer monitor to set the client monitoring timer.
Use undo oap timer monitor to restore the default.
oap timer monitor seconds
The client monitoring timer is set to 5 seconds.
seconds: Specifies the client monitoring timer in seconds, in the range of 0 to 10. Setting this argument to 0 disables client monitoring.
The client monitoring timer regularly triggers the OAP manager to send client monitoring packets to OAP clients.
# Set the client monitoring timer to 6 seconds.
[Sysname] oap timer monitor 6
