07-Tunnel policy commands | 55.72 KB |
display mpls tunnel
Use display mpls tunnel to display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { tunnel-ipv4-dest | tunnel-ipv6-dest } }
all: Displays all tunnels.
statistics: Displays tunnel statistics.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays tunnel information for the public network.
destination: Displays the tunnel destined for the specified address.
tunnel-ipv4-dest: Specifies the tunnel destination IPv4 address.
tunnel-ipv6-dest: Specifies the tunnel destination IPv6 address.
# Display information about all tunnels.
<Sysname> display mpls tunnel all
Destination Type Tunnel/NHLFE VPN Instance
3.3.3.3 CRLSP Tunnel2 -
Destination |
Tunnel destination address. |
Type |
Tunnel type. |
Tunnel/NHLFE |
Tunnel or NHLFE entry. NHLFEnumber represents the ingress LSP that matches the NHLFE entry with NID of number. |
VPN Instance |
VPN instance name. If the tunnel belongs to the public network, this field displays a hyphen (-). |
# Display tunnel statistics.
<Sysname> display mpls tunnel statistics
CRLSP: 1
CRLSP |
Number of CRLSPs (MPLS TE tunnels). |
preferred-path
Use preferred-path to specify a preferred tunnel in a tunnel policy.
Use undo preferred-path to restore the default.
preferred-path tunnel number
undo preferred-path tunnel number
No preferred tunnel is specified.
Tunnel policy view
tunnel number: Specifies an MPLS TE tunnel or a GRE tunnel by its tunnel interface number in the range of 1 to 511.
As a best practice for an MPLS VPN, specify a preferred tunnel and make sure the destination address of the tunnel interface identifies the peer PE. In this method, the local PE forwards traffic destined for the peer PE over the tunnel.
For a tunnel policy to solely use a tunnel, do not specify the tunnel as the preferred tunnel in other tunnel policies.
If you specify multiple preferred tunnels that have the same destination address in a tunnel policy, only the first configured tunnel takes effect. If the first tunnel is not available, the second tunnel is used, and so forth. No load balancing will be performed on these tunnels.
You can specify a maximum of 128 preferred tunnels in a tunnel policy.
# Configure tunnel 1 and tunnel 2 as preferred tunnels for tunnel policy policy1.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] preferred-path tunnel 1
[Sysname-tunnel-policy-policy1] preferred-path tunnel 2
select-seq load-balance-number
Use select-seq load-balance-number to configure the tunnel selection order and set the number of tunnels for load balancing.
Use undo select-seq to restore the default.
select-seq { cr-lsp | lsp } * load-balance-number number
undo select-seq
The device selects only one tunnel in LSP-CRLSP order.
Tunnel policy view
cr-lsp: Uses CRLSP tunnels.
lsp: Uses LSP tunnels.
load-balance-number number: Specifies the number of tunnels for load balancing. The value range for the number argument is 1 to the maximum number of ECMP routes set by the max-ecmp-num command (see Layer 3—IP Routing Command Reference).
A tunnel type closer to the select-seq keyword has a higher priority, and only the tunnel types specified in this command can be used. For example, the select-seq lsp cr-lsp load-balance-number 3 command gives LSP higher priority over CRLSP. If no LSP is available or the number of LSPs is less than 3, VPN uses CRLSP tunnels.
Tunnels selected by this method are not fixed, making it hard to plan VPN traffic. As a best practice, do not use this method.
When you configure both the select-seq load-balance-number and preferred-path commands for a tunnel policy, the tunnel policy selects tunnels in the following steps:
1. If the destination address of the preferred tunnel identifies a peer PE, the tunnel policy uses the preferred tunnel to forward traffic destined for the peer PE.
2. If not, the tunnel policy selects tunnels as configured by the select-seq load-balance-number command.
# Configure tunnel policy policy1 to use only LSP tunnels, and set the load balancing number to 2.
[Sysname-tunnel-policy-policy1] select-seq lsp load-balance-number 2
tunnel-policy (system view)
Use tunnel-policy to create a tunnel policy and enter tunnel policy view.
Use undo tunnel-policy to delete an existing tunnel policy.
tunnel-policy tunnel-policy-name
undo tunnel-policy tunnel-policy-name
No tunnel policy is configured on the device.
tunnel-policy-name: Specifies a name for the tunnel policy, a case-sensitive string of 1 to 19 characters.
# Create tunnel policy policy1 and enter its view.
