07-IP Multicast Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10007-IP Multicast Command Reference
07-MSDP commands
07-MSDP commands 117.34 KB
MSDP commands
cache-sa-enable
Use cache-sa-enable to enable the SA message cache mechanism to cache the (S, G) entries contained in SA messages.
Use undo cache-sa-enable to disable the SA message cache mechanism.
cache-sa-enable
The SA message cache mechanism is enabled, and the device caches the (S, G) entries contained in received SA messages.
MSDP view
# Enable the SA message cache mechanism on the public network, so that the device caches the (S, G) entries contained in the received SA messages.
[Sysname] msdp
[Sysname-msdp] cache-sa-enable
·     display msdp sa-cache
·     display msdp sa-count
display msdp brief
Use display msdp brief to display brief information about MSDP peers.
display msdp [ vpn-instance vpn-instance-name ] brief [ state { connect | disabled | established | listen | shutdown } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays brief information about MSDP peers on the public network.
state: Specifies a state. If you do not specify this keyword, the command displays brief information about MSDP peers in all states.
connect: Specifies the connecting state.
disabled: Specifies the connection failure state.
established: Specifies the session state.
listen: Specifies the listening state.
shutdown: Specifies the shutdown state.
# Display brief information about MSDP peers in all states on the public network.
<Sysname> display msdp brief
Configured   Established  Listen       Connect      Shutdown     Disabled
1            1            0            0            0            0
Peer address    State       Up/Down time    AS         SA count   Reset count
20.20.20.20     Established 00:00:13        100        0          0
Configured
Number of MSDP peers that have been configured.
Established
Number of MSDP peers in established state.
Listen
Number of MSDP peers in listening state.
Connect
Number of MSDP peers in connecting state.
Shutdown
Number of MSDP peers in shutdown state.
Disabled
Number of MSDP peers in disabled state.
Peer address
MSDP peer address.
MSDP peer status:
·     Established—A session has been established and the MSDP peer is in session.
·     Listen—A session has been established and the local device acts as the server in listening state.
·     Connect—A session is not established and the local device acts as a client in connecting state.
·     ShutdownThe session has been torn down.
·     DownThe connection failed.
Up/Down time
Length of time since the MSDP peering connection was established or torn down.
AS
Number of the AS where the MSDP peer is located. If the system could not obtain the AS number, this field displays a question mark (?).
SA count
Number of (S, G) entries in the SA cache.
Reset count
MSDP peering connection reset times.
display msdp peer-status
Use display msdp peer-status to display detailed status of MSDP peers.
display msdp [ vpn-instance vpn-instance-name ] peer-status [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays detailed status of the MSDP peers on the public network.
peer-address: Specifies an MSDP peer by its address. If you do not specify an MSDP peer, this command displays the detailed status of all MSDP peers.
# Display detailed status of MSDP peer 20.20.20.20 on the public network.
<Sysname> display msdp peer-status 20.20.20.20
MSDP peer 20.20.20.20; AS 100
 Description:
 Information about connection status:
   State: Disabled
   Up/down time: 14:41:08
   Resets: 0
   Connection interface: LoopBack0 (20.20.20.30)
   Received/sent messages: 867/867
   Discarded input messages: 0
   Discarded output messages: 0
   Elapsed time since last connection or counters clear: 14:42:40
   Mesh group peer joined: momo
   Last disconnect reason: Hold timer expired with truncated message
   Truncated packet: 5 bytes in buffer, type: 1, length: 20, without packet time: 75s
 Information about (Source, Group)-based SA filtering policy:
   Import policy: None
   Export policy: None
 Information about SA-Requests:
   Policy to accept SA-Requests: None
   Sending SA-Requests status: Disable
 Minimum TTL to forward SA with encapsulated data: 0
 SAs learned from this peer: 0, SA cache maximum for the peer: 4294967295
 Input queue size: 0, Output queue size: 0
 Counters for MSDP messages:
   RPF check failure: 0
   Incoming/outgoing SA: 0/0
   Incoming/outgoing SA-Request: 0/0
   Incoming/outgoing SA-Response: 0/0
   Incoming/outgoing Keepalive: 867/867
   Incoming/outgoing Notification: 0/0
   Incoming/outgoing Traceroutes in progress: 0/0
   Incoming/outgoing Traceroute reply: 0/0
   Incoming/outgoing Unknown: 0/0
   Incoming/outgoing data packet: 0/0
MSDP peer
MSDP peer address.
AS
MSDP peer status:
·     DisabledThe connection failed.
Up/Down time
Resets
Interface and IP address used for setting up a TCP connection with the remote MSDP peer.
Number of SA messages sent and received through this connection.
Number of discarded incoming messages.
Number of discarded outgoing messages.
Elapsed time since the MSDP peer information was last cleared.
Mesh group that the MSDP peer has joined. This field is not displayed if the MSDP peer does not join a mesh group.
Reason why last MSDP peering connection was torn down. If the connection is not terminated, this field does not display any value.
·     Hold timer expired without message—Hold timer expires and the receiving cache has no messages.
·     Hold timer expired with truncated message—Hold timer expires and messages in the receiving buffer are not intact.
¡     bytes in buffer—Size of data in the receiving buffer when the connection was terminated.
¡     type—Type of packets in the receiving buffer when the connection was terminated.
¡     length—Length of packets in the receiving buffer when the connection was terminated. If the packet is too small in size, this field cannot be resolved and is not displayed.
¡     without packet time—Length of time since packets were last processed.
·     Remote peer has been closed—The MSDP peering connection has been torn down.
·     TCP ERROR/HUP event received—Error/hup event received by the TCP socket when the MSDP peer sent messages.
·     Illegal message received—The MSDP peer received illegal messages.
·     Notification received—The MSDP peer received notification messages.
·     Reset command executed—The user executed the reset msdp peer command.
·     Shutdown command executed—The user executed the shutdown command.
·     Interface downed—The MSDP peer received the interface down event when connecting to the remote MSDP peer.
SA message filtering list information:
·     Import policy—Filter list for receiving SA messages from the specified MSDP peer.
·     Export policy—Filter list for forwarding SA messages from the specified MSDP peer.
SA request information:
·     Policy to accept SA request messages—Filtering rule for receiving or forwarding SA request messages from the specified MSDP peer. If SA request messages are not filtered, this field displays None.
·     Sending SA requests status—Whether the MSDP peer is enabled to send an SA request message to the designated MSDP peer after receiving a new join message.
Lower TTL threshold for the multicast packets encapsulated in SA messages.
Number of cached (S, G) entries learned from the specified MSDP peer.
SA-cache maximum for the peer
Maximum number of (S, G) entries learned from the specified MSDP peer that the device can cache.
Input queue size
Data size cached in the input queue.
Output queue size
Data size cached in the output queue.
MSDP peer statistics:
·     RPF check failure—Number of SA messages discarded because of RPF check failure.
·     Incoming/outgoing SA—Number of received and sent SA messages.
·     Incoming/outgoing SA-Request—Number of received and sent SA requests.
·     Incoming/outgoing SA-Response—Number of received and sent SA responses.
·     Incoming/outgoing Keepalive—Number of received and sent keepalive messages.
·     Incoming/outgoing Notification—Number of received and sent notification messages.
·     Incoming/outgoing Traceroutes in progress—Number of received and sent traceroute-in-progress messages.
·     Incoming/outgoing Traceroute reply—Number of received and sent traceroute replies.
·     Incoming/outgoing Unknown—Number of received and sent unknown messages.
·     Incoming/outgoing data packet—Number of received and sent SA messages encapsulated with multicast data.
Use display msdp sa-cache to display (S, G) entries in the SA cache.
display msdp [ vpn-instance vpn-instance-name ] sa-cache [ group-address | source-address | as-number ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays (S, G) entries in the SA cache on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays (S, G) entries in the SA cache for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays (S, G) entries in the SA cache for all sources.
as-number: Specifies an AS number in the range of 1 to 4294967295. If you do not specify an AS number, this command displays (S, G) entries in the SA cache for all ASs.
You must execute the cache-sa-enable command before you execute this command. Otherwise, this command does not display any output.
# Display (S, G) entries in the SA cache on the public network.
<Sysname> display msdp sa-cache
Total Source-Active Cache - 5 entries
Matched 5 entries
Source          Group           Origin RP       Pro  AS         Uptime   Expires
10.10.1.2       225.0.0.1       10.10.10.10     BGP  100        00:00:11 00:05:49
10.10.1.2       225.0.0.2       10.10.10.10     BGP  100        00:00:11 00:05:49
10.10.1.2       225.0.0.3       10.10.10.10     BGP  100        00:00:11 00:05:49
10.10.1.2       225.0.0.4       10.10.10.10     BGP  100        00:00:11 00:05:49
10.10.1.2       225.0.0.5       10.10.10.10     BGP  100        00:00:11 00:05:49
Total number of multicast sources in the SA cache.
Matched
Total number of (S, G) entries that match a multicast sources.
Source
Multicast source address.
Group
Multicast group address.
Origin RP
Address of the RP that generated the (S, G) entry.
Pro
Type of protocol from which the AS number of the origin RP originates. If the system could not obtain the AS number, this field displays a question mark (?).
AS
AS number of the origin RP. If the system could not obtain the AS number, this field displays a question mark (?).
Uptime
Length of time for which the cached (S, G) entry has existed.
Expires
Length of time in which the cached (S, G) entry will expire.
cache-sa-enable
Use display msdp sa-count to display the number of (S, G) entries in the SA cache.
display msdp [ vpn-instance vpn-instance-name ] sa-count [ as-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the number of (S, G) entries in the SA cache on the public network.
as-number: Specifies an AS number in the range of 1 to 4294967295. If you do not specify an AS number, this command displays the number of (S, G) entries in the SA cache for all ASs.
This command displays the output only after you execute the cache-sa-enable command.
# Display the number of (S, G) entries in the SA cache on the public network.
<Sysname> display msdp sa-count
(S, G) entries statistics, counted by peer
  Peer address       SA count
  10.10.10.10        5
(S, G) entries statistics, counted by AS
  AS         Source count        Group count
  ?          3                   3
5 (S, G) entries in total
Number of (S, G) entries on an MSDP peer basis.
Peer address
Address of the MSDP peer that sent SA messages.
SA count
Number of (S, G) entries from this MSDP peer.
Number of cached (S, G) entries on an AS basis.
AS
AS number. If the system could not obtain the AS number, this field displays a question mark (?).
Source count
Number of multicast sources in this AS.
Group count
Number of multicast groups in this AS.
Total number of (S, G) entries.
cache-sa-enable
encap-data-enable
Use encap-data-enable to enable multicast data encapsulation in SA messages.
Use undo encap-data-enable to restore the default.
encap-data-enable
An SA message contains only (S, G) entries. Multicast data is not encapsulated in an SA message.
MSDP view
# Enable multicast data encapsulation in SA messages on the public network.
[Sysname] msdp
[Sysname-msdp] encap-data-enable
import-source
Use import-source to configure an SA message creation policy.
Use undo import-source to remove the configured SA message creation policy.
import-source [ acl acl-number ]
undo import-source
When an SA message is created, all the (S, G) entries within the domain are advertised in the SA message.
MSDP view
acl-number: Specifies an IPv4 basic or advanced ACL number in the range of 2000 to 3999. If you specify an ACL, this command advertises only the (S, G) entries that the ACL permits. The command does not advertise any (S, G) entries when one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have any valid rules.
This command controls the creation of SA messages. To control forwarding or acceptance of SA messages, use the peer sa-policy command.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
·     For the rule to take effect, do not specify the vpn-instance keyword.
·     In a basic ACL, the source keyword matches multicast group address in register messages.
·     In an advanced ACL, the source keyword and the destination keyword match the multicast source address and multicast group address in register messages, respectively.
·     Other optional parameters except the destination, fragment, source, and time-range keywords do not take effect.
# On the public network, configure an SA creation policy to advertise only the (10.10.0.0/16, 225.1.0.0/16) entries when creating an SA message.
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
peer sa-policy
msdp
Use msdp to enable MSDP and enter MSDP view.
Use undo msdp to disable MSDP and remove the configurations in MSDP view to release the resources occupied by MSDP.
undo msdp [ vpn-instance vpn-instance-name ]
MSDP is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command applies to the public network.
You must enable IP multicast routing on the public network or for a VPN instance before you execute this command.
# Enable IP multicast routing and MSDP on the public network, and enter public network MSDP view.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] msdp
[Sysname-msdp]
multicast routing
originating-rp
Use originating-rp to configure the originating RP of SA messages.
Use undo originating-rp to restore the default.
originating-rp interface-type interface-number
undo originating-rp
SA messages are originated by real RPs.
MSDP view
# On the public network, configure VLAN-interface 100 as the originating RP of SA messages.
[Sysname] msdp
[Sysname-msdp] originating-rp vlan-interface 100
peer
Use peer to specify an MSDP peer.
Use undo peer to remove an MSDP peer.
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
MSDP peers do not exist.
MSDP view
peer-address: Specifies an MSDP peer by its IP address.
connect-interface interface-type interface-number: Specifies an interface by its type and number. The local device uses the primary IP address of the specified interface as the source IP address when setting up a TCP connection with the remote MSDP peer.
You must execute this command before you use any other peer commands. Otherwise, the system notifies you that the MSDP peer does not exist.
# On the public network, configure the router with IP address 125.10.7.6 as the MSDP peer of the local router, and configure VLAN-interface 100 as the local connection port.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface vlan-interface 100
peer description
Use peer description to configure a description for an MSDP peer.
Use undo peer description to delete a description for an MSDP peer.
peer peer-address description text
undo peer peer-address description
No description exists for an MSDP peer.
MSDP view
text: Specifies a description, a case-sensitive string of 1 to 80 characters, including spaces.
# On the public network, configure a description of CustomerA for MSDP peer 125.10.7.6.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description CustomerA
peer mesh-group
Use peer mesh-group to assign an MSDP peer to a mesh group.
Use undo peer mesh-group to remove an MSDP peer from a mesh group.
peer peer-address mesh-group name
undo peer peer-address mesh-group
An MSDP peer does not belong to a mesh group.
MSDP view
name: Specifies a mesh group, a case-sensitive string of 1 to 32 characters. A mesh group name must not contain any spaces.
# On the public network, assign MSDP peer 125.10.7.6 to the mesh group Group1.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Group1
peer minimum-ttl
Use peer minimum-ttl to set the lower TTL threshold for multicast data packets encapsulated in SA messages.
Use undo peer minimum-ttl to restore the default.
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
The lower TTL threshold for a multicast packet to be encapsulated in an SA message is 0.
MSDP view
ttl-value: Specifies the lower TTL threshold in the range of 0 to 255.
# On the public network, set the lower TTL threshold of multicast packets to be encapsulated in SA messages for MSDP peer 110.10.10.1 to 10. Only multicast data packets whose TTL values are larger than or equal to 10 can be encapsulated in SA messages and forwarded to the MSDP peer.
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
peer password
Use peer password to configure an MD5 authentication key used by both MSDP peers to establish a TCP connection.
Use undo peer password to restore the default.
peer peer-address password { cipher | simple } password
undo peer peer-address password
MSDP peers do not perform MD5 authentication to establish TCP connections.
MSDP view
cipher: Specifies a ciphertext MD5 authentication key.
simple: Specifies a plaintext MD5 authentication key.
password: Specifies a key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 80 characters. If cipher is specified, it must be a ciphertext string of 33 to 137 characters.
The MSDP peers involved in MD5 authentication must be configured with the same authentication method and key. Otherwise, the authentication fails and the TCP connection cannot be established.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
# On the public network, configure an MD5 authentication key in plaintext as aabbcc for the TCP connections between the local end and MSDP peer 10.1.100.1.
[Sysname] msdp
[Sysname-msdp] peer 10.1.100.1 password simple aabbcc
peer request-sa-enable
Use peer request-sa-enable to enable the device to send an SA request message to an MSDP peer after receiving a new join message.
Use undo peer request-sa-enable to disable the device from sending an SA request message to an MSDP peer.
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
After receiving a new join message, the device does not send an SA request message to any MSDP peers. Instead, it waits for an SA message.
MSDP view
You must disable SA message cache mechanism before you execute this command. Otherwise, the device does not send out SA request messages.
# On the public network, disable the SA message cache mechanism.
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
# Enable the device to send an SA request message to MSDP peer 125.10.7.6 after it receives a new join message.
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
·     cache-sa-enable
·     display msdp peer-status
peer sa-cache-maximum
Use peer sa-cache-maximum to set the maximum number of (S, G) entries in the SA cache learned from an MSDP peer.
Use undo peer sa-cache-maximum to restore the default.
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
The device can cache a maximum of 4294967295 (S, G) entries learned from any MSDP peer.
MSDP view
sa-limit: Specifies the maximum number of (S, G) entries in the SA cache, in the range of 1 to 4294967295.
# On the public network, set the maximum number of (S, G) entries in the SA cache learned from its MSDP peer 125.10.7.6 to 100.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
·     display msdp brief
peer sa-policy
Use peer sa-policy to configure an SA incoming or outgoing policy.
Use undo peer sa-policy to remove the configured SA incoming or outgoing policy.
peer peer-address sa-policy { export | import } [ acl acl-number ]
undo peer peer-address sa-policy { export | import }
All SA messages are accepted and forwarded.
MSDP view
export: Specifies the outgoing direction.
import: Specifies the incoming direction.
acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999. If you specify an ACL, the device accepts and forwards only SA messages that the ACL permits. The device discards all SA messages when one of the following conditions exists:
This command controls the acceptance or forwarding of SA messages. To control the creation of SA messages, use the import-source command.
When you configure a rule in the IPv4 advanced ACL, follow these restrictions and guidelines:
·     The source keyword and the destination keyword match multicast source address and multicast group address in SA messages, respectively.
# On the public network, configure an SA outgoing policy to forward only SA messages that ACL 3100 permits to MSDP peer 125.10.7.6.
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
·     import-source
peer sa-request-policy
Use peer sa-request-policy to configure an SA request policy.
Use undo peer sa-request-policy to remove the configured SA request policy.
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
SA request policies are not configured.
MSDP view
acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the device accepts only SA requests that the ACL permits. The device discards all SA requests when one of the following conditions exists:
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
·     The source keyword matches the multicast group address in SA request messages.
·     Other optional parameters except the fragment, source, and time-range keywords do not take effect.
# On the public network, configure an SA request policy to process SA requests originated from MSDP peer 175.58.6.5 with multicast groups in the range of 225.1.1.0/24.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
reset msdp peer
Use reset msdp peer to reset the TCP connection with an MSDP peer and clear statistics for the MSDP peer.
reset msdp [ vpn-instance vpn-instance-name ] peer [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command resets the TCP connection with the specified MSDP peer and clears statistics for the MSDP peer on the public network.
peer-address: Specifies an MSDP peer by its IP address. If you do not specify an MSDP peer, this command resets the TCP connections with all MSDP peers and clears statistics for all MSDP peers.
# On the public network, reset the TCP connection with MSDP peer 125.10.7.6 and clear all statistics for this MSDP peer.
<Sysname> reset msdp peer 125.10.7.6
reset msdp sa-cache
Use reset msdp sa-cache to clear (S, G) entries from the SA cache.
reset msdp [ vpn-instance vpn-instance-name ] sa-cache [ group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears (S, G) entries from the SA cache on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command clears the cached (S, G) entries for all multicast groups from the SA cache.
# Clear the (S, G) entries for multicast group 225.5.4.3 from the SA cache on the public network.
<Sysname> reset msdp sa-cache 225.5.4.3
·     cache-sa-enable
reset msdp statistics
Use reset msdp statistics to clear statistics for an MSDP peer without resetting the TCP connection with the MSDP peer.
reset msdp [ vpn-instance vpn-instance-name ] statistics [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the specified MSDP peer without resetting the TCP connection with the MSDP peer on the public network.
peer-address: Specifies an MSDP peer by its IP address. If you do not specify an MSDP peer, this command clears statistics for all MSDP peers without resetting the TCP connection with all MSDP peers.
# On the public network, clear statistics for MSDP peer 125.10.7.6 without resetting the TCP connection with the peer.
<Sysname> reset msdp statistics 125.10.7.6
shutdown (MSDP view)
Use shutdown to tear down the connection with an MSDP peer.
Use undo shutdown to re-establish the connection an MSDP peer.
shutdown peer-address
undo shutdown peer-address
The connections with an MSDP peer is active.
MSDP view
# Tear down the connection with MSDP peer 125.10.7.6 on the public network.
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
static-rpf-peer
Use static-rpf-peer to configure a static RPF peer.
Use undo static-rpf-peer to remove a static RPF peer.
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
No static RPF peers exist.
MSDP view
rp-policy ip-prefix-name: Specifies a filtering policy based on RP addresses in SA messages by its name, a case-sensitive string of 1 to 63 characters. If you specify a filtering policy, the device does not perform RPF checks on SA messages permitted by the policy. If you do not specify a filtering policy, the device performs RPF checks on all SA messages.
This command prevents SA messages forwarded by the static RPF peer from undertaking the RPF check.
# Specify 130.10.7.6 as the static RPF peer to exempt SA messages originated by RPs on subnet 130.10.0.0/16 from RPF checks on the public network.
[Sysname] ip prefix-list list1 permit 130.10.0.0 16 great-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface vlan-interface 100
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
·     ip prefix-list
timer retry
Use timer retry to set the MSDP connection retry interval.
Use undo timer retry to restore the default.
timer retry interval
undo timer retry
The MSDP connection retry interval is 30 seconds.
MSDP view
interval: Specifies an MSDP connection retry interval in the range of 1 to 60 seconds.
# Set the MSDP connection retry interval to 60 seconds on the public network.
[Sysname] msdp
[Sysname-msdp] timer retry 60
