14-FCoE Configuration Guide
HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release7178-6W10014-FCoE Configuration Guide
Table of Contents
Related Documents
00-Preface
00-Preface 92.52 KB
Preface
This configuration guide describes FCoE fundamentals and configuration. In an FCoE solution, the server uses an FCoE-capable Ethernet adapter. The FCoE switch (FCoE forwarder) integrates the functions of both the traditional IP switch and the FC switch. The FCoE solution reduces the number of network adapters, switches, and cables, and reduces the network operation and maintenance workload.
·     Audience.
·     Conventions.
·     About the H3C S10500 documentation set.
·     Obtaining documentation.
·     Technical support.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the S10500 switch series.
Conventions
This section describes the conventions used in the documentation.
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
The H3C S10500 documentation set includes the following categories of documents:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describes product specifications and benefits.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Quick start
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
H3C CFP Transceiver Modules Installation Guide
Guides you through installing CFP transceiver modules.
H3C QSFP+ Transceiver Modules Installation Guide
Guides you through installing QSFP+ transceiver modules.
H3C Transceiver Modules User Guide
Describes the transceiver modules available for the H3C network products, their external views, and specifications.
Software configuration
Configuration guides
Describes software features and configuration procedures.
Command references
Provides a quick reference to all available commands.
Configuration examples
Describes typical network scenarios and provide configuration examples and instructions.
Operations and maintenance
Troubleshooting
Provides troubleshooting information for common problems of using the product.
FAQ
Covers the most frequently asked questions about the hardware, software and system specifications.
Release notes
Provides information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
System log messages
Explains the system log messages.
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions. [Software Download]—Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
