- 12-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-EAA configuration
- 09-Process monitoring and maintenance configuration
- 10-Mirroring configuration
- 11-NetStream configuration
- 12-IPv6 NetStream configuration
- 13-sFlow configuration
- 14-Information center configuration
- 15-GOLD configuration
- 16-Packet capture configuration
| 10-Mirroring configuration | 415.09 KB |
Port mirroring classification and implementation
Configuring local port mirroring
Local port mirroring configuration task list
Creating a local mirroring group
Configuring source ports for the local mirroring group
Configuring source CPUs for the local mirroring group
Configuring the monitor port for the local mirroring group
Configuring Layer 2 remote port mirroring
Layer 2 remote port mirroring with configurable reflector port configuration task list
Layer 2 remote port mirroring with egress port configuration task list
Configuring a remote destination group on the destination device
Configuring a remote source group on the source device
Configuring Layer 3 remote port mirroring
Layer 3 remote port mirroring configuration task list
Configuring local mirroring groups
Configuring source ports for a local mirroring group
Configuring source CPUs for a local mirroring group
Configuring the monitor port for a local mirroring group
Displaying and maintaining port mirroring
Port mirroring configuration examples
Local port mirroring configuration example (in source port mode)
Local port mirroring configuration example (in source CPU mode)
Layer 2 remote port mirroring configuration example (reflector port configurable)
Layer 2 remote port mirroring configuration example (with egress port)
Layer 3 remote port mirroring configuration example
Flow mirroring configuration task list
Configuring a traffic behavior
Applying a QoS policy to an interface
Applying a QoS policy to a VLAN
Applying a QoS policy globally
Applying a QoS policy to the control plane
Configuring port mirroring
Overview
Port mirroring copies the packets passing through a port or CPU to a port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports or CPUs. The monitored ports and CPUs called source ports and source CPUs, respectively.
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination is the destination port (also known as the monitor port) of mirrored packets and connects to a data monitoring device. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port 1 when the following conditions exist:
· Port 1 is monitoring bidirectional traffic of Port 2 and Port 3 on the same device.
· The packet travels from Port 2 to Port 3.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
· Inbound—Copies packets received.
· Outbound—Copies packets sent.
· Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through mirroring groups, which include local, remote source, and remote destination groups. For more information about the mirroring groups, see "Port mirroring classification and implementation."
Reflector port, egress port, and remote probe VLAN
Reflector ports, remote probe VLANs, and egress ports are used for Layer 2 remote port mirroring. The remote probe VLAN is a dedicated VLAN for transmitting mirrored packets to the destination device. Both the reflector port and egress port reside on a source device and send mirrored packets to the remote probe VLAN. For more information about the reflector port, egress port, remote probe VLAN, and Layer 2 remote port mirroring, see "Port mirroring classification and implementation."
NOTE: On port mirroring devices, all ports except source, destination, reflector, and egress ports are called common ports. |
Port mirroring includes local port mirroring and remote port mirroring.
· Local port mirroring—The mirroring sources and the mirroring destination are on the same device.
· Remote port mirroring—The mirroring sources and the mirroring destination are on different devices.
In local port mirroring, the following conditions exist:
· The source device is directly connected to a data monitoring device.
· The source device acts as the destination device to forward mirrored packets to the data monitoring device.
A local mirroring group is a mirroring group that contains the mirroring sources and the mirroring destination on the same device. The mirroring sources and the mirroring destination can be located on different cards on the switch.
RPR logical interfaces support only local port mirroring and can only be configured as source ports for local mirroring groups. For more information about RPR logical interfaces, see High Availability Configuration Guide.
Figure 1 Local port mirroring implementation
As shown in Figure 1, the source port GigabitEthernet 1/0/1 and the monitor port GigabitEthernet 1/0/2 reside on the same device. Packets received on GigabitEthernet 1/0/1 are copied to GigabitEthernet 1/0/2. GigabitEthernet 1/0/2 then forwards the packets to the data monitoring device for analysis.
In remote port mirroring, the following conditions exist:
· The source device is not directly connected to a data monitoring device.
· The source device copies mirrored packets to the destination device, which forwards them to the data monitoring device.
· The mirroring sources and the mirroring destination reside on different devices and are in different mirroring groups.
A remote source group is a mirroring group that contains the mirroring sources. A remote destination group is a mirroring group that contains the mirroring destination. Intermediate devices are the devices between the source device and the destination device.
Remote port mirroring includes Layer 2 and Layer 3 remote port mirroring.
· Layer 2 remote port mirroring—The mirroring sources and the mirroring destination are located on different devices on a same Layer 2 network.
Layer 2 remote port mirroring can be implemented when a reflector port or an egress port is available on the source device. The method to use the reflector port and the method to use the egress port are called reflector port method and egress port method, respectively.
¡ Reflector port method—Packets are mirrored as follows:
- The source device copies packets received on the mirroring sources to the reflector port.
- The reflector port broadcasts the mirrored packets in the remote probe VLAN.
- The intermediate devices transmit the mirrored packets to the destination device through the remote probe VLAN.
- Upon receiving the mirrored packets, the destination device determines whether the ID of the mirrored packets is the same as the remote probe VLAN ID. If the two VLAN IDs are the same, the destination device forwards the mirrored packets to the data monitoring device through the monitor port.
A reflector port can be fixed or configurable. The switch supports only the configurable reflector port.
Figure 2 Layer 2 remote port mirroring implementation through the reflector port method
¡ Egress port method—Packets are mirrored as follows:
- The source device copies packets received on the mirroring sources to the egress port.
- The egress port forwards the mirrored packets to the intermediate devices.
- The intermediate devices flood the mirrored packets in the remote probe VLAN and transmit the mirrored packets to the destination device.
Figure 3 Layer 2 remote port mirroring implementation through the egress port method
In the reflector port method, the reflector port broadcasts mirrored packets in the remote probe VLAN. By assigning a non-source port on the source device to the remote probe VLAN, you can use the reflector port method to implement local port mirroring. The egress port method cannot implement local port mirroring in this way.
To ensure Layer 2 forwarding of the mirrored packets, assign the ports connecting intermediate devices to the source and destination devices to the remote probe VLAN.
To monitor the bidirectional traffic of a source port, disable MAC address learning for the remote probe VLAN on the source, intermediate, and destination devices. For more information about MAC address learning, see Layer 2—LAN Switching Configuration Guide.
· Layer 3 remote port mirroring—The mirroring sources and the mirroring destination are separated by IP networks.
Layer 3 remote port mirroring is implemented through creating a local mirroring group on both the source device and the destination device. For example, in a network as shown in Figure 4, Layer 3 remote port mirroring works in the following flow:
a. The source device sends one copy of a packet received on the source port GigabitEthernet 1/0/1 to the tunnel interface.
The tunnel interface acts as the monitor port in the local mirroring group created on the source device.
b. The tunnel interface on the source device forwards the mirrored packet to the tunnel interface on the destination device through the GRE tunnel.
c. The destination device receives the mirrored packet from the physical interface of the tunnel interface.
The tunnel interface acts as the source port in the local mirroring group created on the destination device.
d. The physical interface of the tunnel interface sends one copy of the packet to the monitor port GigabitEthernet 1/0/2.
e. GigabitEthernet 1/0/2 forwards the packet to the data monitoring device.
For more information about GRE tunnels and tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Figure 4 Layer 3 remote port mirroring implementation
A local mirroring group takes effect only when you configure the monitor port and the source ports or source CPUs for the local mirroring group.
Tasks at a glance |
1. (Required.) Creating a local mirroring group |
2. (Required.) Perform at least one of the following tasks: |
3. (Required.) Configuring the monitor port for the local mirroring group |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a local mirroring group. |
mirroring-group group-id local |
By default, no local mirroring group exists. |
To configure source ports for a local mirroring group, use one of the following methods:
· Assign a list of source ports to the mirroring group in system view.
· Assign a port to the mirroring group as a source port in interface view.
To assign multiple ports to the mirroring group as source ports in interface view, repeat the operation.
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
· A mirroring group can contain multiple source ports.
· Layer 2 or Layer 3 aggregate interfaces cannot be configured as source ports for mirroring groups.
· For port mirroring to operate correctly, do not configure an EVB-enabled port as a source port. For more information about EVB, see EVB Configuration Guide.
· Typically, a port can act as a source port for only one mirroring group. On the switch, a port can be a source port for multiple mirroring groups that have different monitor ports.
· A source port cannot be configured as a reflector port, egress port, or monitor port.
Configuring source ports in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source ports for a local mirroring group. |
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound } |
By default, no source port is configured for a local mirroring group. |
Configuring source ports in interface view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure the port as a source port for a local mirroring group. |
mirroring-group group-id mirroring-port { both | inbound | outbound } |
By default, a port does not act as a source port for any local mirroring groups. |
CPUs on the MPUs LSUM1MPU06B0 and LSUM1MPU10C0 cannot be configured as source CPUs.
In an IRF 3 system, CPUs on PEXs cannot be configured as source CPUs. For more information about IRF 3 systems and PEXs, see Virtual Technologies Configuration Guide.
A mirroring group can contain multiple source CPUs.
To configure source CPUs for a local mirroring group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source CPUs for a local mirroring group. |
· In standalone mode: · In IRF mode: |
By default, no source CPU is configured for a local mirroring group. |
To configure the monitor port for a mirroring group, use one of the following methods:
· Configure the monitor port for the mirroring group in system view.
· Assign a port to the mirroring group as the monitor port in interface view.
When you configure the monitor port for a local mirroring group, follow these restrictions and guidelines:
· Do not enable the spanning tree feature on the monitor port.
· For port mirroring to operate correctly, do not configure an EVB-enabled port as the monitor port. For more information about EVB, see EVB Configuration Guide.
· For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
· A mirroring group contains only one monitor port.
· Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
Configuring the monitor port in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the monitor port for a local mirroring group. |
mirroring-group group-id monitor-port interface-type interface-number |
By default, no monitor port is configured for a local mirroring group. |
Configuring the monitor port in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the monitor port for a mirroring group. |
mirroring-group group-id monitor-port |
By default, a port does not act as the monitor port for any local mirroring groups. |
To configure Layer 2 remote port mirroring, perform the following tasks:
· Configure a remote source group on the source device.
· Configure a cooperating remote destination group on the destination device.
· If intermediate devices exist, configure the following devices and ports to allow the remote probe VLAN to pass through.
¡ Intermediate devices.
¡ Ports connected to the intermediate devices on the source and destinations devices.
When you configure Layer 2 remote port mirroring, follow these restrictions and guidelines:
· The egress port must be assigned to the remote probe VLAN. The configurable reflector port is not necessarily assigned to the remote probe VLAN.
· For a mirrored packet to successfully arrive at the remote destination device, make sure its VLAN ID is not removed or changed.
· Do not configure both MVRP and Layer 2 remote port mirroring. Otherwise, MVRP might register the remote probe VLAN with incorrect ports, which would cause the monitor port to receive undesired copies. For more information about MVRP, see Layer 2—LAN Switching Configuration Guide.
· As a best practice, configure devices in the order of the destination device, the intermediate devices, and the source device.
Creating a remote destination group
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a remote destination group. |
mirroring-group group-id remote-destination |
By default, no remote destination group exists on a device. |
Configuring the monitor port for a remote destination group
When you configure the monitor port for a remote destination group, follow these restrictions and guidelines:
· A mirroring group must contain only one monitor port.
· A monitor port can belong to only one mirroring group.
Configuring the monitor port for a remote destination group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the monitor port for a remote destination group. |
By default, no monitor port is configured for a remote destination group. |
Configuring the monitor port for a remote destination group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the monitor port for a remote destination group. |
By default, a port does not act as the monitor port for any remote destination groups. |
Configuring the remote probe VLAN for a remote destination group
When you configure the remote probe VLAN for a remote destination group, follow these restrictions and guidelines:
· Only an existing static VLAN can be configured as a remote probe VLAN.
· When a VLAN is configured as a remote probe VLAN, use the remote probe VLAN for port mirroring exclusively.
· Configure the same remote probe VLAN for the remote groups on the source and destination devices.
To configure the remote probe VLAN for a remote destination group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the remote probe VLAN for a remote destination group. |
mirroring-group group-id remote-probe vlan vlan-id |
By default, no remote probe VLAN is configured for a remote destination group. |
Assigning the monitor port to the remote probe VLAN
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter the interface view of the monitor port. |
N/A |
3. Assign the port to the remote probe VLAN. |
· For an access port: · For a trunk port: · For a hybrid port: |
For more information about the port access vlan, port trunk permit vlan, and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference. |
Creating a remote source group
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a remote source group. |
mirroring-group group-id remote-source |
By default, no remote source group exists on a device. |
Configuring source ports for a remote source group
To configure source ports for a mirroring group, use one of the following methods:
When you configure source ports for a remote source group, follow these restrictions and guidelines:
· Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
· A source port cannot be configured as a reflector port, monitor port, or egress port.
Configuring source ports for a remote source group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source ports for a remote source group. |
By default, no source port is configured for a remote source group. |
Configuring a source port for a remote source group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as a source port for a remote source group. |
By default, a port does not act as a source port for any remote source groups. |
Configuring source CPUs for a remote source group
To configure source CPUs for a remote source group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source CPUs for a remote source group. |
By default, no source CPU is configured for a remote source group. |
Configuring the reflector port for a remote source group
To configure the reflector port for a remote source group, use one of the following methods:
· Configure the reflector port for the remote source group in system view.
· Assign a port to the remote source group as the reflector port in interface view.
When you configure the reflector port for a remote source group, follow these restrictions and guidelines:
· The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
· When a port is configured as a reflector port, all existing configurations of the port are cleared. You cannot configure other features on the reflector port.
· A mirroring group contains only one reflector port.
· You can configure a port as a reflector port only when the port is operating with the default duplex mode, speed, and MDI settings. You cannot change these settings for a reflector port.
· In an IRF 3 system, PEXs do not support reflector ports for Layer 2 remote port mirroring. For more information about IRF 3 and PEXs, see Virtual Technologies Configuration Guide.
Configuring the reflector port for a remote source group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the reflector port for a remote source group. |
mirroring-group group-id reflector-port interface-type interface-number |
By default, no reflector port is configured for a remote source group. |
Configuring the reflector port for a remote source group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the reflector port for a remote source group. |
mirroring-group group-id reflector-port |
By default, a port does not act as the reflector port for any remote source groups. |
Configuring the egress port for a remote source group
To configure the egress port for a remote source group, use one of the following methods:
· Configure the egress port for the remote source group in system view.
· Assign a port to the remote source group as the egress port in interface view.
When you configure the egress port for a remote source group, follow these restrictions and guidelines:
· Disable the following features on the egress port:
¡ Spanning tree.
¡ 802.1X.
¡ IGMP snooping.
¡ Static ARP.
¡ MAC address learning.
· A mirroring group contains only one egress port.
· A port of an existing mirroring group cannot be configured as an egress port.
Configuring the egress port for a remote source group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the egress port for a remote source group. |
mirroring-group group-id monitor-egress interface-type interface-number |
By default, no egress port is configured for a remote source group. |
Configuring the egress port for a remote source group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the egress port for a remote source group. |
mirroring-group group-id monitor-egress |
By default, a port does not act as the egress port for any remote source groups. |
Configuring the remote probe VLAN for a remote source group
When you configure the remote probe VLAN for a remote source group, follow these restrictions and guidelines:
· The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
To configure the remote probe VLAN for a remote source group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the remote probe VLAN for a remote source group. |
By default, no remote probe VLAN is configured for a remote source group. |
To configure Layer 3 remote port mirroring, perform the following tasks:
· Create a local mirroring group on both the source device and the destination device.
· Configure the monitor port and source ports or source CPUs for each mirroring group.
The source and destination devices are connected by a tunnel. If intermediate devices exist, configure a unicast routing protocol on the intermediate devices to ensure Layer 3 reachability between the source and destination devices.
On the source device, perform the following tasks:
· Configure source ports or source CPUs you want to monitor.
· Configure the tunnel interface as the monitor port.
On the destination device, perform the following tasks:
· Configure the physical interface corresponding to the tunnel interface as the source port.
· Configure the port that connects the data monitoring device as the monitor port.
Tasks at a glance |
(Required.) Configuring the source device: 1. Configuring local mirroring groups 2. Perform at least one of the following tasks: ¡ Configuring source ports for a local mirroring group |
(Required.) Configuring the destination device: 1. Configuring local mirroring groups |
Configuration prerequisites
Before configuring Layer 3 remote mirroring, complete the following tasks:
· Create a tunnel interface and a GRE tunnel.
· Configure the source and destination addresses of the tunnel interface as the IP addresses of the physical interfaces on the source and destination devices, respectively.
IP addresses of physical interfaces on the following interface modules cannot be used as the source or destination IP address for the tunnel interface:
¡ LSUM2GP24TSSA0
¡ LSUM2GP48SA0
¡ LSUM2GT48SA0
For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Configure a local mirroring group on both the source device and the destination device.
To create a local mirroring group:
Step |
Command |
Remarks |
system-view |
N/A |
By default, no local mirroring group exists on a device. |
On the source device, configure the ports you want to monitor as the source ports. On the destination device, configure the physical interface corresponding to the tunnel interface as the source port.
Step |
Command |
Remarks |
system-view |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
On the source device, configure the CPUs of the cards to be monitored as the source CPUs. The destination device does not support source CPU configuration.
Step |
Command |
Remarks |
system-view |
N/A |
On the source device, configure the tunnel interface as the monitor port. On the destination device, configure the port that connects to a data monitoring device as the monitor port.
· Assign a port to a mirroring group as the monitor port in interface view.
· As a best practice, use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
Step |
Command |
Remarks |
system-view |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the monitor port for a local mirroring group. |
Task |
Command |
Display mirroring group information. |
display mirroring-group { group-id | all | local | remote-destination | remote-source } |
Network requirements
As shown in Figure 5, configure local port mirroring in source port mode to enable the server to monitor the bidirectional traffic of the Marketing department and the Technical department.
Configuration procedure
# Create local mirroring group 1.
[Device] mirroring-group 1 local
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 as source ports for local mirroring group 1.
[Device] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 gigabitethernet 1/0/2 both
# Configure GigabitEthernet 1/0/3 as the monitor port for local mirroring group 1.
[Device] mirroring-group 1 monitor-port gigabitethernet 1/0/3
# Disable the spanning tree feature on the monitor port (GigabitEthernet 1/0/3).
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] undo stp enable
[Device-GigabitEthernet1/0/3] quit
# Verify the mirroring group configuration.
[Device] display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/1 Both
GigabitEthernet1/0/2 Both
Monitor port: GigabitEthernet1/0/3
As shown in Figure 6, GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are located on the card in slot 1.
Configure local port mirroring in source CPU mode to enable the server to monitor all packets matching the following criteria:
· Received and sent by the Marketing department and the Technical department.
· Processed by the CPU of the card in slot 1 of the device.
# Configure the CPU of the card in slot 1 of the device as a source CPU for local mirroring group 1.
[Device] mirroring-group 1 mirroring-cpu slot 1 both
Mirroring group 1:
Type: Local
Status: Active
Mirroring CPU:
Slot 1 Both
As shown in Figure 7, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing department.
1. Configure Device C (the destination device):
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLAN 2.
<DeviceC> system-view
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 2
# Create a remote destination group.
[DeviceC] mirroring-group 2 remote-destination
# Create VLAN 2.
[DeviceC] vlan 2
# Disable MAC address learning for VLAN 2.
[DeviceC-vlan2] undo mac-address mac-learning enable
[DeviceC-vlan2] quit
# Configure VLAN 2 as the remote probe VLAN for the mirroring group.
[DeviceC] mirroring-group 2 remote-probe vlan 2
# Configure GigabitEthernet 1/0/2 as the monitor port for the mirroring group.
[DeviceC-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/2] undo stp enable
# Assign GigabitEthernet 1/0/2 to VLAN 2.
[DeviceC-GigabitEthernet1/0/2] port access vlan 2
2. Configure Device B (the intermediate device):
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-vlan2] undo mac-address mac-learning enable
[DeviceB-vlan2] quit
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 2
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 2
3. Configure Device A (the source device):
# Create a remote source group.
[DeviceA] mirroring-group 1 remote-source
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] undo mac-address mac-learning enable
[DeviceA-vlan2] quit
[DeviceA] mirroring-group 1 remote-probe vlan 2
# Configure GigabitEthernet 1/0/1 as a source port for the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
# Configure GigabitEthernet 1/0/3 as the reflector port for the mirroring group.
[DeviceA] mirroring-group 1 reflector-port gigabitethernet 1/0/3
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 2
# Verify the mirroring group configuration on Device C.
[DeviceC] display mirroring-group all
Mirroring group 2:
Type: Remote destination
Status: Active
Monitor port: GigabitEthernet1/0/2
Remote probe VLAN: 2
# Verify the mirroring group configuration on Device A.
[DeviceA] display mirroring-group all
Mirroring group 1:
Type: Remote source
Status: Active
Mirroring port:
Reflector port: GigabitEthernet1/0/3
On the Layer 2 network shown in Figure 8, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing department.
# Create VLAN 2.
[DeviceC] vlan 2
# Assign GigabitEthernet 1/0/2 to VLAN 2 as an access port.
# Create VLAN 2.
[DeviceB] vlan 2
# Create VLAN 2.
[DeviceA] vlan 2
# Configure VLAN 2 as the remote probe VLAN of the mirroring group.
# Configure GigabitEthernet 1/0/2 as the egress port for the mirroring group.
[DeviceA] mirroring-group 1 monitor-egress gigabitethernet 1/0/2
# Configure port GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLAN 2.
# Disable the spanning tree feature on the port.
[DeviceA-GigabitEthernet1/0/2] undo stp enable
Mirroring group 2:
Status: Active
Mirroring group 1:
Type: Remote source
Status: Active
Mirroring port:
Monitor egress port: GigabitEthernet1/0/2
On a Layer 3 network shown in Figure 9, configure Layer 3 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing department.
1. Configure IP addresses for the tunnel interfaces and related ports on the devices. (Details not shown.)
2. Configure Device A (the source device):
# Create a service loopback group 1 and specify the unicast tunnel service for the group.
[DeviceA] service-loopback group 1 type tunnel
# Assign GigabitEthernet 1/0/3 to the service loopback group 1.
[DeviceA-GigabitEthernet1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y
# Create tunnel interface Tunnel 1 that operates in GRE mode, and configure an IP address and subnet mask for the interface.
[DeviceA] interface tunnel 1 mode gre
[DeviceA-Tunnel1] ip address 50.1.1.1 24
# Configure source and destination IP addresses for Tunnel 1.
[DeviceA-Tunnel1] source 20.1.1.1
[DeviceA-Tunnel1] destination 30.1.1.2
[DeviceA-Tunnel1] quit
# Enable the OSPF protocol.
[DeviceA] ospf 1
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
[DeviceA] mirroring-group 1 local
# Configure GigabitEthernet 1/0/1 as a source port and Tunnel 1 as the monitor port of local mirroring group 1.
[DeviceA] mirroring-group 1 monitor-port tunnel 1
3. Enable the OSPF protocol on Device B (the intermediate device).
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
4. Configure Device C (the destination device):
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface gigabitethernet 1/0/3
[DeviceC-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 1 mode gre
[DeviceC-Tunnel1] ip address 50.1.1.2 24
[DeviceC-Tunnel1] source 30.1.1.2
[DeviceC-Tunnel1] destination 20.1.1.1
[DeviceC-Tunnel1] quit
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] mirroring-group 1 local
# Configure GigabitEthernet 1/0/1 as a source port for local mirroring group 1.
[DeviceC] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 inbound
# Configure GigabitEthernet 1/0/2 as the monitor port for local mirroring group 1.
[DeviceC] mirroring-group 1 monitor-port gigabitethernet 1/0/2
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
Monitor port: Tunnel1
# Display information about all mirroring groups on Device C.
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/1 Inbound
Configuring flow mirroring
The flow mirroring feature is available on both Layer 2 and Layer 3 Ethernet interfaces. The term "interface" in this chapter collectively refers to these two types of interfaces. You can use the port link-mode command to configure an Ethernet port as a Layer 2 or Layer 3 interface (see Layer 2—LAN Switching Configuration Guide).
Flow mirroring copies packets matching a class to a destination for packet analyzing and monitoring. It is implemented through QoS policies.
To configure flow mirroring, perform the following tasks:
· Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
· Configure traffic behaviors to mirror the matching packets to the specified destination.
You can configure an action to mirror the matching packets to one of the following destinations:
· Interface—The matching packets are copied to an interface connecting to a data monitoring device. The data monitoring device analyzes the packets received on the interface.
· CPU—The matching packets are copied to the CPU of the card where they are received. The CPU analyzes the packets or delivers them to upper layers.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
Tasks at a glance |
(Required.) Configuring match criteria |
(Required.) Configuring a traffic behavior |
(Required.) Configuring a QoS policy |
(Required.) Applying a QoS policy: · Applying a QoS policy to an interface · Applying a QoS policy to a VLAN |
For more information about the following commands except the mirror-to command, see ACL and QoS Command Reference.
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a class and enter class view. |
traffic classifier tcl-name [ operator { and | or } ] |
By default, no traffic class exists. |
3. Configure match criteria. |
if-match match-criteria |
By default, no match criterion is configured in a traffic class. |
To configure a traffic behavior:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a traffic behavior and enter traffic behavior view. |
traffic behavior behavior-name |
By default, no traffic behavior exists. |
3. Configure a mirroring action for the traffic behavior. |
· Mirror traffic to an interface: · Mirror traffic to the CPU: |
By default, no mirroring action is configured for a traffic behavior. |
4. (Optional.) Display traffic behavior configuration. |
display traffic behavior |
Available in any view. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a QoS policy and enter QoS policy view. |
qos policy policy-name |
By default, no QoS policy exists. |
3. Associate a class with a traffic behavior in the QoS policy. |
classifier tcl-name behavior behavior-name |
By default, no traffic behavior is associated with a class. |
4. (Optional.) Display QoS policy configuration. |
display qos policy |
By applying a QoS policy to an interface, you can mirror the traffic in the specified direction of the interface. A policy can be applied to multiple interfaces. In one direction (inbound or outbound) of an interface, only one policy can be applied.
To apply a QoS policy to an interface:
Step |
Command |
system-view |
3. Apply a policy to the interface. |
qos apply policy policy-name { inbound | outbound } |
You can apply a QoS policy to a VLAN to mirror the traffic in the specified direction on all ports in the VLAN.
To apply the QoS policy to a VLAN:
Step |
Command |
system-view |
2. Apply a QoS policy to a VLAN. |
qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound } |
You can apply a QoS policy globally to mirror the traffic in the specified direction on all ports.
To apply a QoS policy globally:
Step |
Command |
system-view |
2. Apply a QoS policy globally. |
qos apply policy policy-name global { inbound | outbound } |
You can apply a QoS policy to the control plane to mirror the traffic in the specified direction of all ports on the control plane.
To apply a QoS policy to the control plane:
Step |
Command |
system-view |
2. Enter control plane view. |
3. Apply a QoS policy to the control plane. |
Flow mirroring configuration example
As shown in Figure 10, configure flow mirroring so that the server can monitor the following traffic:
· All traffic that the Technical department sends to access the Internet.
· IP traffic that the Technical department sends to the Marketing department during working hours (8:00 to 18:00) on weekdays.
# Create working hour range work, in which working hours are from 8:00 to 18:00 on weekdays.
[DeviceA] time-range work 8:00 to 18:00 working-day
# Create ACL 3000 to allow packets from the Technical department to access the Internet and to the Marketing department during working hours.
[DeviceA] acl number 3000
[DeviceA-acl-adv-3000] rule permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
[DeviceA-acl-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range work
[DeviceA-acl-adv-3000] quit
# Create traffic class tech_c, and configure the match criterion as ACL 3000.
[DeviceA] traffic classifier tech_c
[DeviceA-classifier-tech_c] if-match acl 3000
[DeviceA-classifier-tech_c] quit
# Create traffic behavior tech_b, configure the action of mirroring traffic to port GigabitEthernet 1/0/3.
[DeviceA] traffic behavior tech_b
[DeviceA-behavior-tech_b] mirror-to interface gigabitethernet 1/0/3
[DeviceA-behavior-tech_b] quit
# Create QoS policy tech_p, and associate traffic class tech_c with traffic behavior tech_b in the QoS policy.
[DeviceA] qos policy tech_p
[DeviceA-qospolicy-tech_p] classifier tech_c behavior tech_b
[DeviceA-qospolicy-tech_p] quit
# Apply QoS policy tech_p to the incoming packets of GigabitEthernet 1/0/4.
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] qos apply policy tech_p inbound
[DeviceA-GigabitEthernet1/0/4] quit
# Verify that the server can monitor the following traffic:
· All traffic sent by the Technical department to access the Internet.
· IP traffic that the Technical department sends to the Marketing department during working hours on weekdays.
