12-Network Management and Monitoring Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10012-Network Management and Monitoring Command Reference
15-GOLD commands
15-GOLD commands 89.67 KB
GOLD commands
diagnostic event-log size
Use diagnostic event-log size to configure the maximum number of GOLD log entries.
Use undo diagnostic event-log size to restore the default.
diagnostic event-log size number
GOLD can save up to 512 log entries.
number: Specifies the maximum number of log entries, in the range of 0 to 1024.
If you specify a number smaller than the number of existing log entries, the system automatically deletes the oldest excess entries.
When the number of GOLD log entries exceeds the configured log buffer size, the system automatically deletes the oldest excess entries.
# Configure the maximum number of log entries as 600.
[Sysname] diagnostic event-log size 600
diagnostic monitor enable
Use diagnostic monitor enable to enable monitoring diagnostics.
Use undo diagnostic monitor enable to disable monitoring diagnostics.
In standalone mode:
diagnostic monitor enable slot slot-number-list [ test test-name ]
undo diagnostic monitor enable slot slot-number-list [ test test-name ]
In IRF mode:
diagnostic monitor enable chassis chassis-number slot slot-number-list [ test test-name ]
undo diagnostic monitor enable chassis chassis-number slot slot-number-list [ test test-name ]
The default enabling status varies by monitoring diagnostic test. To view the status of diagnostic tests, use the display diagnostic content command.
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. Each item specifies a card by its slot number or a range of cards in the form of start-slot-number to end-slot-number. (In standalone mode.)
chassis chassis-number slot slot-number-list: Specifies cards on an IRF member device or specifies PEXs. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of a PEX. The slot-number-list argument specifies a space-separated list of up to seven slot number items. An item specifies a card by its slot number, a range of cards in the form of start-slot-number to end-slot-number, or a PEX by its virtual slot number. The virtual slot number is fixed at 0 for the PEX. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
test test-name: Specifies a test by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command enables all monitoring diagnostic tests on the specified cards.
Monitoring diagnostics enable the system to periodically run diagnostic tests to detect hardware faults and record test results. Monitoring diagnostics execute only non-disruptive tests.
Disruptive diagnostic tests that are being executed affect device operation or even disable certain functions, but non-disruptive diagnostic tests do not.
The system automatically executes enabled monitoring diagnostic tests after the device starts. Use the diagnostic monitor enable command to enable diagnostic tests that are disabled by default.
# (In standalone mode.) Enable test HGMonitor on card 2.
[Sysname] diagnostic monitor enable slot 2 test HGMonitor
# (In IRF mode.) Enable test HGMonitor on card 2 of IRF member device 2.
[Sysname] diagnostic monitor enable chassis 2 slot 2 test HGMonitor
diagnostic monitor interval
Use diagnostic monitor interval to configure an execution interval for monitoring diagnostic tests.
Use undo diagnostic monitor interval to restore the default.
In standalone mode:
diagnostic monitor interval slot slot-number-list [ test test-name ] time time
undo diagnostic monitor interval slot slot-number-list [ test test-name ]
In IRF mode:
diagnostic monitor interval chassis chassis-number slot slot-number-list [ test test-name ] time time
undo diagnostic monitor interval chassis chassis-number slot slot-number-list [ test test-name ]
The default execution interval varies by monitoring diagnostic test. To view the execution interval of diagnostic tests, use the display diagnostic content command.
test test-name: Specifies a test by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command applies to all monitoring diagnostic tests on the specified cards.
time: Sets an execution interval in the form of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is both 0 to 59. If you specify only the hh argument, you can omit the mm and ss segments. If you specify only the hh and mm arguments, you can omit the ss segment. For example, to specify 01:00:00, you can enter 1.
Use this command to configure the interval at which the system automatically executes enabled monitoring diagnostic tests.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
# (In standalone mode.) Set the execution interval to 1 minute for test HGMonitor on card 1.
<Sysname> system-view.
[Sysname] diagnostic monitor interval slot 1 test HGMonitor time 00:01:00
# (In IRF mode.) Set the execution interval to 1 minute for test HGMonitor on card 1 of IRF member device 2.
[Sysname] diagnostic monitor interval chassis 2 slot 1 test HGMonitor time 00:01:00
·     diagnostic monitor enable
·     display diagnostic content
diagnostic ondemand failure
Use diagnostic ondemand failure to set the maximum number of failed on-demand diagnostic tests.
Use undo diagnostic ondemand failure to restore the default.
diagnostic ondemand failure failure-number
The maximum number of failed on-demand diagnostic tests is not specified.
failure-number: Specifies the maximum number of failed tests, in the range of 1 to 999.
After you use the diagnostic ondemand start command to enable on-demand diagnostics, you can stop the diagnostic tests by using any of the following commands:
·     Use the diagnostic ondemand stop command to immediately stop the tests.
·     Use the diagnostic ondemand repeating command to configure the number of executions for the tests. The system stops executing the tests when the threshold is reached.
·     Use the diagnostic ondemand failure command to configure the maximum number of failed tests. The system stops a test when the number of failures reaches the configured threshold and the test is not executed as many times as specified.
Use this command to configure the maximum number of failed tests for diagnostic tests to be enabled. This command does not survive a device reboot.
# Configure the maximum number of failed tests as 5 for all on-demand diagnostic tests.
<Sysname> diagnostic ondemand failure 5
·     diagnostic ondemand repeating
·     diagnostic ondemand start
·     display diagnostic ondemand configuration
Use diagnostic ondemand repeating to configure the number of executions for on-demand diagnostic tests.
Use undo diagnostic ondemand repeating to restore the default.
diagnostic ondemand repeating repeating-number
The default number of executions is 1.
repeating-number: Specifies the number of executions for on-demand diagnostic tests, in the range of 1 to 999.
Use this command to configure the number of executions for diagnostic tests to be enabled. This command does not survive a device reboot.
Do not specify a number smaller than the configured number of failed tests.
# Configure the number of executions as 2 for all on-demand diagnostic tests.
<Sysname> diagnostic ondemand repeating 2
·     diagnostic ondemand failure
·     display diagnostic configuration
Use diagnostic ondemand start to enable on-demand diagnostics.
In standalone mode:
diagnostic ondemand start slot slot-number-list test { non-disruptive | test-name } [ para parameters ]
In IRF mode:
diagnostic ondemand start chassis chassis-number slot slot-number-list test { non-disruptive | test-name } [ para parameters ]
All on-demand diagnostic tests need to be manually enabled.
non-disruptive: Executes all non-disruptive diagnostic tests.
para parameters: Specifies an extended parameter. It is not supported.
On-demand diagnostics allow you to manually execute certain diagnostic tests. These tests are known as on-demand diagnostic tests.
You can configure the number of executions and the maximum number of failed tests for on-demand diagnostic tests at the CLI. When either threshold is reached, the system immediately stops executing the tests.
# (In standalone mode.) Start all non-disruptive diagnostic tests on card 1.
<Sysname> diagnostic ondemand start slot 1 test non-disruptive
# (In IRF mode.) Start all non-disruptive diagnostic tests on card 2 of IRF member device 1.
<Sysname> diagnostic ondemand start chassis 1 slot 2 test non-disruptive
Use diagnostic ondemand stop to stop on-demand diagnostic tests.
In standalone mode:
diagnostic ondemand stop slot slot-number-list test { non-disruptive | test-name }
In IRF mode:
diagnostic ondemand stop chassis chassis-number slot slot-number-list test { non-disruptive | test-name }
# (In standalone mode.) Stop all non-disruptive diagnostic tests on card 1.
<Sysname> diagnostic ondemand stop slot 1 test non-disruptive
# (In IRF mode.) Stop all non-disruptive diagnostic tests on card 1 of IRF member device 2.
<Sysname> diagnostic ondemand stop chassis 2 slot 1 test non-disruptive
diagnostic simulation
Use diagnostic simulation to simulate diagnostic tests.
Use undo diagnostic simulation to restore the default.
In standalone mode:
diagnostic simulation slot slot-number-list test test-name { failure | random-failure | success }
undo diagnostic simulation slot slot-number-list test test-name
In IRF mode:
diagnostic simulation chassis chassis-number slot slot-number-list test test-name { failure | random-failure | success }
undo diagnostic simulation chassis chassis-number slot slot-number-list test test-name
All diagnostic tests are executed instead of simulated.
failure: Configures the system to generate failure results.
random-failure: Configures the system to randomly generate results.
success: Configures the system to generate success results.
Test simulation is used to verify GOLD frame functionality. After you execute this command, the system simulates the specified test if the execution requirements for the test are met. The test is not actually executed and does not trigger hardware correcting actions.
This command only applies to monitoring diagnostic tests and on-demand diagnostic tests.
# (In standalone mode.) Simulate test HGMonitor as failed on card 1.
<Sysname> diagnostic simulation slot 1 test HGMonitor failure
# (In IRF mode.) Simulate test HGMonitor as failed on card 1 of IRF member device 1.
<Sysname> diagnostic simulation chassis 1 slot 1 test HGMonitor failure
display diagnostic simulation
Use display diagnostic content to display information about diagnostic tests.
In standalone mode:
display diagnostic content [ slot slot-number ] [ verbose ]
In IRF mode:
display diagnostic content [ chassis chassis-number [ slot slot-number ] ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command applies to all cards. (In standalone mode.)
chassis chassis-number [ slot slot-number ]: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify an IRF member device or virtual chassis, the command applies to all member devices and PEXs. If you do not specify a card or PEX, the command applies to all cards of the specified member device or all PEXs in the specified virtual chassis. (In IRF mode.)
verbose: Displays detailed information about diagnostic tests. If you do not specify this keyword, the command displays brief information about the diagnostic tests.
# (In standalone mode.) Display brief information about all diagnostic tests on card 1.
<Sysname> display diagnostic content slot 1
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Slot 1 :
Name                      Attributes              Interval
HGMonitor                              **M*PI                               00:00:10
# (In IRF mode.) Display brief information about all diagnostic tests on card 1 of IRF member device 1.
<Sysname> display diagnostic content chassis 1 slot 1
Chassis 1 slot 1 :
# (In standalone mode.) Display detailed information about all diagnostic tests on card 1.
<Sysname> display diagnostic content slot 1 verbose
Slot 1 :
Test name        : HGMonitor
Test attributes  : **M*PI
Test interval    : 00:00:10
Min interval     : 00:00:10
Correct-action   : -NA-
Description       : A Real-time test, disabled by default that checks link status between ports.
exec             : -NA-
# (In IRF mode.) Display detailed information about all diagnostic tests on card 1 of IRF member device 1.
<Sysname> display diagnostic content chassis 1 slot 1 verbose
Chassis 1 slot  1:
exec             : -NA-
B/*
Boot-up/Not boot-up.
O/*
On-demand/Not on-demand.
M/*
Monitoring/Not monitoring.
D/*
Disruptive/Non-disruptive.
P/*
Port-related/Not port-related.
A/I/*
Active and monitoring/Inactive and monitoring/Not monitoring.
Test name
Name of the diagnostic test.
Test attributes
Attributes of the diagnostic test. The characters from left to right indicate whether or not the test is boot-up, on-demand, monitoring, disruptive, port-related, or active. The asterisks (*) indicate that the test does not have the corresponding attributes.
Test interval
Execution interval for the test. If the execution interval for the test is not set, –NA–is displayed.
Min interval
Minimum execution interval for the test. If the test does not have a minimum execution interval, –NA–is displayed.
Correct-action
Correcting action triggered by failure of the test.
Description for the test.
exec
Path for the Tcl script bound to the diagnostic test. If the diagnostic test is not bound to any Tcl script, –NA–is displayed.
display diagnostic event-log
Use display diagnostic event-log to display GOLD log entries.
display diagnostic event-log [ error | info ]
error: Displays all error log entries.
info: Displays all log entries except error log entries.
If you do not specify the error and info keywords, the command displays all GOLD log entries.
The system records information about test execution in the form of logs. A log entry contains test name, execution time, test result, and failure cause. Log entries are generated for every execution. To reduce the burden of the information center, GOLD logs are not sent to the information center.
GOLD logs are cleared when the device starts or when an active and standby switchover occurs.
# (In IRF mode.) Display all GOLD log entries.
<Sysname> display diagnostic event-log
Event: E_INFO, Wed Jan  7 11:39:53:314 2012, -Chassis=4-Slot=2 TestName->SystemMgmtBus, Event_INFO: Result->Success.
Event: E_ERROR, Wed Jan  7 11:39:53:314 2012, -Chassis=4-Slot=2 TestName->SystemMgmtBus, Event_INFO: Result->Failure Reason->The port 9 is offline.
# (In IRF mode.) Display all GOLD error log entries.
<Sysname> display diagnostic event-log error
# (In IRF mode.) Display all GOLD log entries except error log entries.
<Sysname> display diagnostic event-log info
Use display diagnostic ondemand configuration to display configurations of on-demand diagnostic tests.
# Display the number of executions and the number of failed tests configured for on-demand diagnostic tests.
<Sysname> display diagnostic ondemand configuration
Maximum test-repeating times: 4
Maximum test-failure times: 1
# Display the number of executions configured for on-demand diagnostic tests.
Maximum test-failure times: Not configured
display diagnostic result
Use display diagnostic result to display test results.
In standalone mode:
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ]
In IRF mode:
display diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ] [ verbose ]
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify an IRF member device or virtual chassis, the command applies to all member devices and PEXs. If you do not specify a card or PEX, the command applies to all cards of the specified member device or all PEXs in the specified virtual chassis. (In IRF mode.)
test test-name: Specifies a test by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command applies to all diagnostic tests on the specified card.
verbose: Displays detailed test results for diagnostic tests that are enabled or executed. (Statistics are not included.) If you do not specify this parameter, the command displays brief test results for the diagnostic tests.
# (In standalone mode.) Display brief test results for all diagnostic tests on card 1.
<Sysname> display diagnostic result slot 1
Slot 1 :
  Name                    Run count    Failure count    Last result
  HGMonitor               10           3                Failure
# (In IRF mode.) Display brief test results for all diagnostic tests on card 1 of IRF member device 1.
<Sysname> display diagnostic result chassis 1 slot 1
Chassis 1 slot 1 :
# (In standalone mode.) Display detailed test results for all diagnostic tests.
<Sysname> display diagnostic result verbose
Slot 1 :
  Total run count          : 10
  Total failure count      : 3
  Consecutive failure count: 3
  Last execution time      : Tue Oct 30 10:36:55 2012
  First failure time       : Tue Oct 30 10:36:25 2012
  Last failure time        : Tue Oct 30 10:36:55 2012
  Last pass time           : Tue Oct 30 10:36:15 2012
  Last execution result    : Failure
  Last failure reason      : Failed to send packets.
  Next execution time      : Tue Oct 30 10:37:05 2012
Test name
Name of the test.
Total run count
Total number of executions.
Total failure count
Total number of failed tests.
Number of consecutive failed tests.
Last execution time
Most recent execution time.
First failure time
First failed test time. If no failure occurs, –NA– is displayed.
Last failure time
Most recent failed test time. If no failure occurs, –NA– is displayed.
Last pass time
Most recent success test time. If no success occurs, –NA– is displayed.
Most recent test result.
Last failure reason
Cause for the most recent failed test. If the failed test is simulated, Simulated Test is displayed. If no failure occurs, –NA– is displayed.
Next execution time
Time for the next execution. If the test is a monitoring test, its next execution time is the most recent execution time plus the execution interval. If the test is an on-demand or boot-up test, –NA– is displayed.
display diagnostic result statistics
Use display diagnostic result statistics to display statistics for packet-related diagnostic tests.
In standalone mode:
display diagnostic result [ slot slot-number [ test test-name ] ] statistics
In IRF mode:
display diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ] statistics
test test-name: Specifies a test by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command applies to all packet-related diagnostic tests on the specified card.
# (In standalone mode.) Display statistics for test PortLoopback on card 1.
<Sysname> display diagnostic result slot 1 test PortLoopback statistics
Slot 1 :
  Test name: PortLoopback
  Port    Packets sent    Packets received   Packets lost
  1       0               0                  0
  2       0               0                  0
  3       0               0                  0
  4       4               4                  0
  5       4               4                  0
  6       4               4                  0
  7       4               4                  0
  8       0               0                  0
# (In IRF mode.) Display statistics for test PortLoopback on card 1 of IRF member device 1.
<Sysname> display diagnostic result chassis 1 slot 1 test PortLoopback statistics
Chassis 1 slot 1 :
  1       0               0                  0
  2       0               0                  0
  3       0               0                  0
  4       4               4                  0
  5       4               4                  0
  6       4               4                  0
  7       4               4                  0
  8       0               0                  0
Test name
Name of the test.
Port
Port number.
Packets sent
Number of packets that the device sends.
Packets received
Number of packets that the device receives.
Packets lost
Number of lost packets.
Use display diagnostic simulation to display configurations for simulated diagnostic tests.
In standalone mode:
display diagnostic simulation [ slot slot-number ]
In IRF mode:
display diagnostic simulation [ chassis chassis-number [ slot slot-number ] ]
This command only displays configurations for simulated diagnostic tests. If no simulated diagnostic test exists, no information is displayed.
# (In standalone mode.) Display configurations for all simulated diagnostic tests on card 1.
<Sysname> display diagnostic simulation slot 1
Slot 1 :
Name                            Mode
HGMonitor                       failure
# (In IRF mode.) Display configurations for all simulated diagnostic tests on card 1 of IRF member device 1.
<Sysname> display diagnostic simulation chassis 1 slot 1
Chassis 1 slot 1 :
  Name                            Mode
  HGMonitor                       failure
reset diagnostic event-log
Use reset diagnostic event-log to clear GOLD logs.
# Clear GOLD logs.
<Sysname> reset diagnostic event-log
reset diagnostic result
Use reset diagnostic result to clear test results.
In standalone mode:
reset diagnostic result [ slot slot-number [ test test-name ] ]
In IRF mode:
reset diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ]
This command does not clear the next execution time in detailed test results.
# (In standalone mode.) Clear test results for test HGMonitor on card 1.
<Sysname> reset diagnostic result slot 1 test HGMonitor
# (In IRF mode.) Clear test results for test HGMonitor on card 1 of IRF member device 1.
<Sysname> reset diagnostic result chassis 1 slot 1 test HGMonitor
