03-ACSEI Commands | 67.41 KB |
ACSEI configuration commands
acsei client reboot
acsei client reboot client-id
View
ACSEI server view
Default level
2: System level
client-id: ID of the ACSEI client to be restarted.
Use acsei client reboot to restart the specified ACSEI client.
# Restart ACSEI client 1.
[Sysname] acsei server
[Sysname-acsei-server] acsei client reboot 1
acsei server
acsei server
View
Default level
2: System level
None
Use acsei server to enter ACSEI server view.
You can use this command to enter ACSEI server view only when you enable the ACSEI server function with the acsei server enable command.
# Enter ACSEI server view.
acsei server enable
acsei server enable
undo acsei server enable
View
Default level
2: System level
None
Use acsei server enable to enable ACSEI server.
Use undo acsei server enable to disable ACSEI server.
By default, ACSEI server is disabled.
# Enable ACSEI server.
[Sysname] acsei server enable
acsei timer clock-sync
acsei timer clock-sync minutes
undo acsei timer clock-sync
View
ACSEI server view
Default level
2: System level
minutes: Value of the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client. It is in the range of 0 to 1440 (in minutes), where value 0 disables the clock synchronization from ACSEI server to ACSEI client.
Use acsei timer clock-sync to set the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client.
Use undo acsei timer clock-sync to restore the default.
By default, the clock sychronization timer is set to 5 minutes.
# Set the clock synchronization timer from ACSEI server to ACSEI client to 20 minutes.
[Sysname-acsei-server] acsei timer clock-sync 20
acsei timer monitor
acsei timer monitor seconds
undo acsei timer monitor
View
ACSEI server view
Default level
2: System level
seconds: Value of the monitoring timer that is used for ACSEI server to monitor ACSEI clients. It in the range of 0 to 10 (in seconds), where 0 disables ACSEI server from monitoring ACSEI client.
Use acsei timer monitor to set the monitoring timer for ACSEI server to monitor ACSEI client.
Use undo acsei timer monitor to restore the default.
By default, the monitoring timer is set to 5 seconds.
# Set the monitor timer for ACSEI server to monitor ACSEI client to 6 seconds.
[Sysname-acsei-server] acsei timer monitor 6
display acsei client info
display acsei client info [ client-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
client-id: ID of an ACSEI client.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display acsei client info to display the ACSEI client information. The client information is retrieved from the advertisement packet sent by the ACSEI client, so that when there is no ACSEI client information, the command displays the information keywords only.
If executed without the client-id argument, the command displays information about all the ACSEI clients in order of registration time.
# Display information about ACSEI client 1.
<Sysname> display acsei client info 1
Total Client Number: 1
client ID: 1
client Description: SecBlade FW
Hardware: A.0
System Software: COMWAREV500R002B83D203
Application Software: V300R001B01D303
CPU: RMI XLR732 1000MHz
PCB Version: A.0
CPLD Version: 3.0
Bootrom Version: Basic BootRom Version:1.28,Extend BootRom Version:1.29
CF card: 247M Bytes Compact Flash Storage Device
Memory: 2048M Bytes DDR2 SDRAM Memory
Harddisk:
# Display information about all ACSEI clients.
Total client Number: 2
client ID: 1
Hardware: A.0
PCB Version: A.0
CPLD Version: 3.0
Harddisk:
client ID: 2
client Description: Intrusion Prevention System
Hardware: 2.0
System Software: i-Ware software, Version 1.10
Application Software: Ess 2110P01
CPU: RMI XLR732
PCB Version: Ver.A
CPLD Version: 2.0
Bootrom Version: 1.19
Storage card: 247MB
Memory: 1993MB
Harddisk: 0MB
client ID |
ID of the ACSEI client. |
client Description |
ACSEI client description. |
Hardware |
Hardware version of the ACSEI client. |
System Software |
System software name and version of the ACSEI client. |
Application Software |
Application name and version of the ACSEI client. |
CPU |
CPU information of the ACSEI client. |
PCB Version |
PCB version of the ACSEI client. |
CPLD Version |
CPLD version of the ACSEI client. |
Bootrom Version |
BootWare version of the ACSEI client. |
Storage card |
Storage card information of the ACSEI client. |
Memory |
Memory information of the ACSEI client. |
Harddisk |
Harddisk information of the ACSEI client. |
display acsei client summary
display acsei client summary [ client-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
client-id: ID of an ACSEI client whose summary is to be displayed.
Use display acsei client summary to display ACSEI client summary information. Summary information of multiple ACSEI clients is displayed in order of registration time.
If executed without the client-id argument, the command displays summary information about all the ACSEI clients.
# Display the summary of all ACSEI clients.
<Sysname> display acsei client summary
Total client Number: 1
client ID: 1
Status: Open
MAC Address: 0023-8992-020a
Interface: Ten-GigabitEthernet6/0/1
Last registered: 07/22/2010 15:53:13
client ID |
Status |
ACSEI client status. |
MAC Address |
MAC address of the ACSEI client. |
Interface carrying the ACSEI client. |
Last registered |
Last registration time of the ACSEI client. |
