12-High Availability Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18212-High Availability Command Reference
09-BFD Commands
09-BFD Commands 116.53 KB
bfd detect-multiplier
bfd detect-multiplier value
undo bfd detect-multiplier
View
Interface view
Default level
2: System level
value: Specifies the detect time multiplier in the range of 3 to 50.
Use bfd detect-multiplier to configure the detection time multiplier.
Use undo bfd detect-multiplier to restore the default.
The default is 5.
# Configure the detection time multiplier as 6 on VLAN-interface 1.
[Sysname-Vlan-interface1] bfd detect-multiplier 6
bfd echo-source-ip
bfd echo-source-ip ip-address
undo bfd echo-source-ip
View
Default level
2: System level
ip-address: Source IP address of BFD echo packets.
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
Since a large amount of ICMP redirect packets might be sent by the remote switch, causing network congestion, do not configure the source IP address of the BFD echo packets to belong to the same network segment as any interface address of the switch.
# Configure the source IP address of echo packets as 10.1.1.1.
[Sysname] bfd echo-source-ip 10.1.1.1
bfd min-echo-receive-interval
bfd min-echo-receive-interval value
undo bfd min-echo-receive-interval
View
Interface view
Default level
2: System level
value: Minimum echo receiving interval, in milliseconds. It is a multiple of 10 and defaults to 400 milliseconds.
Use bfd min-echo-receive-interval to configure the minimum echo packet receiving interval on the interface.
Use undo bfd min-echo-receive-interval to restore the default.
By default, the minimum BFD echo packet receiving interval on the interface is 400 milliseconds.
# Configure the minimum echo receiving interval on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-echo-receive-interval 500
bfd min-receive-interval
bfd min-receive-interval value
undo bfd min-receive-interval
View
Interface view
Default level
2: System level
value: Minimum interval for receiving BFD control packets, in milliseconds. It is a multiple of 10 and defaults to 400 milliseconds.
Use bfd min-receive-interval to configure the minimum interval for receiving BFD control packets.
Use undo bfd min-receive-interval to restore the default.
By default, the minimum interval for receiving BFD control packets is 400 milliseconds.
If the remote switch sends BFD control packets at an interval shorter than the minimum receiving interval of the local switch, the remote switch changes its sending interval to the minimum receiving interval of the local switch.
# Configure the minimum interval for receiving BFD control packets on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-receive-interval 500
bfd min-transmit-interval
bfd min-transmit-interval value
undo bfd min-transmit-interval
View
Interface view
Default level
2: System level
value: Minimum interval for transmitting BFD control packets, in milliseconds. It is a multiple of 10 and defaults to 400 milliseconds.
Use bfd min-transmit-interval to configure the minimum interval for transmitting BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
By default, the minimum interval for transmitting BFD control packets is 400 milliseconds.
A proper interval ensures BFD control packets are not transmitted faster than the switch can deal with. The actual interval for transmitting BFD control packets at the local switch should be the greater between the minimum interval for sending BFD control packets configured on the local interface and the minimum interval for receiving BFD control packets on the remote switch.
# Configure the minimum interval for transmitting BFD control packets on VLAN-interface 1 as 500 milliseconds.
[Sysname-Vlan-interface1] bfd min-transmit-interval 500
bfd multi-hop destination-port
undo bfd multi-hop destination-port
View
Default level
2: System level
port-number: Destination port number of multi-hop BFD control packets, 3784 or 4784.
Use bfd multi-hop destination-port to configure the destination port number for multi-hop BFD control packets as 3784 or 4784.
Use undo bfd multi-hop destination-port to restore the default.
By default, the destination port number for multi-hop BFD control packets is 4784.
# Configure the destination port number for multi-hop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd session init-mode
undo bfd session init-mode
View
Default level
2: System level
active: Uses the active mode. In the active mode, upon being enabled with BFD, an interface actively transmits a BFD control packet to the remote switch.
passive: Uses the passive mode. In the passive mode, an interface does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
By default, BFD sessions are established in the active mode.
At least one end must operate in the active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
display bfd debugging-switches
display bfd debugging-switches [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display bfd debugging-switches to display enabled BFD debugging switches.
# Display enabled BFD debugging switches.
<Sysname> display bfd debugging-switches
BFD Error debugging is on
BFD Event debugging is on
BFD FSM debugging is on
BFD Packet Receive debugging is on
BFD Packet Send debugging is on
BFD SCM debugging is on
BFD Timer debugging is on
display bfd interface
display bfd interface [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed interface information.
Use display bfd interface to display information about BFD-enabled interfaces.
Besides the information displayed by the display bfd interface command, the display bfd interface verbose command displays brief session information of the interfaces.
# Display information about BFD-enabled interfaces.
<Sysname> display bfd interface
Total Interface Num: 1
      Interface: Vlan-interface500      Session Num: 1
Min Trans Inter: 200ms               Min Recv Inter: 200ms
     DetectMult: 3              Min Echo Recv Inter: 400ms
# Display detailed information about BFD-enabled interfaces.
<Sysname> display bfd interface verbose
LD/RD       SourceAddr      DestAddr        ConnType  State     Mode
2/2         192.168.11.11   192.168.11.10   Direct    Up        Ctrl
Interface name.
Session Num
Number of sessions established on the local interface.
Min Trans Inter
Minimum control packet transmit interval configured on the interface.
Min Recv Inter
Minimum control packet receive interval configured on the interface.
DetectMult
Detection time multiplier.
Min Echo Recv Inter
Minimum echo packet receive interval configured on the interface.
LD
Local ID of the session.
RD
Remote ID of the session.
SourceAddr
Source IP address of the session.
DestAddr
Destination IP address of the session.
ConnType
Connection type of the interface.
Session state.
Mode
Working mode of the session: control (Ctrl) mode or echo (Echo) mode.
display bfd session
Standalone mode:
display bfd session [ slot slot-number [ all | verbose ] | verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display bfd session [ chassis chassis-number slot slot-number [ all | verbose ] | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed session information.
slot slot-number: Displays the session information of the specified card. The slot-number argument refers to the card slot number. Use this option when your switch is operating in standalone mode.
all: Displays detailed information about all the BFD sessions on the card.
chassis chassis-number slot slot-number: Displays the session information of a card on an IRF member switch. The chassis-number argument refers to the ID of the member switch, and the slot-number argument refers to the number of the slot. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use display bfd session to display BFD session information.
·     If no slot number is specified, all the BFD session information of the device is displayed. If the all keyword is specified, the command displays the detailed BFD session information on the MPU in the specified slot (standalone mode).
·     If no chassis number or slot number is specified, all the BFD session information of the current member device is displayed. If the all keyword is specified together with a card and a member device, the command displays the detailed BFD session information on the specified MPU of the specified IRF member device (IRF mode).
# Display detailed information about the BFD sessions maintained by all the cards (standalone mode).
<Sysname> display bfd session verbose
Total session number: 2   Up session number: 2   Init Mode: Active
Ipv4 session working under Ctrl mode:
     Local Discr: 1                   Remote Discr: 1
       Source IP: 192.168.11.11     Destination IP: 192.168.11.10
   Session State: Up                     Interface: Vlan-interface1000
 Min Trans Inter: 200ms            Act Trans Inter: 200ms
Min Recv Inter: 200ms           Act Detect Inter: 1000ms
  Running Up for: 00:02:36               Auth mode: None
    Connect Type: Direct                 Board Num: 0
        Protocol: OSPF/RSVP/MFW
       Diag Info: No Diagnostic
     Local Discr: 2                   Remote Discr: 2
       Source IP: 192.168.12.11     Destination IP: 192.168.12.10
   Session State: Up                     Interface: GigabitEthernet4/0/2
# Display detailed information about the BFD sessions maintained by slot 0 on chassis 1 (distributed IRF member device).
<Sysname> display bfd session chassis 1 slot 0 verbose
   Session State: Up                     Interface: GigabitEthernet1/3/0/2
    Recv Pkt Num: 16927                Send Pkt Num: 17146
       Hold Time: 800ms                 Auth mode: None
    Connect Type: Direct                Chassis/Board Num: 1/0
Total number of BFD sessions.
Up session number
Total number of active BFD sessions.
Init mode
BFD operating mode, active or passive.
session working under xx mode
IPv4/IPv6 BFD session mode:
·     Ctrl—Control packet mode.
·     Echo—Echo mode.
Local Discr
Remote Discr
Source IP
Destination IP
Session State
Session state.
Name of the interface of the session.
Min Trans Inter
Expected minimum transmit interval configured on the interface.
Min Recv Inter
Expected minimum receive interval configured on the interface.
Act Trans Inter
Actual transmit interval.
Act Detect Inter
Actual session detection timer.
Recv Pkt Num
Number of packets received.
Send Pkt Num
Number of packets sent.
Hold Time
Length of time before session detection timer expires.
Auth mode
Session authentication mode. The switch does not support authentication.
Connect Type
Running up for
Time interval for which the session has been up.
Chassis/Board Num
Chassis/card maintaining the session.
Protocol
Registered protocol.
Diag Info
Diagnostic information about the session.
reset bfd session statistics
In standalone mode:
reset bfd session statistics [slot slot-number ]
In IRF mode:
reset bfd session statistics [ chassis chassis-number slot slot-number ]
View
Default level
1: Monitor level
slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone mode.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use reset bfd session statistics to clear the BFD session statistics of the current protocol. If a slot number is specified, statistics about the BFD sessions maintained by the specified board will be cleared.
# Clear statistics about the BFD sessions in Slot 6.
<Sysname> reset bfd session statistics slot 6
# Clear statistics about the BFD sessions in Slot 6 of Chassis 1.
<Sysname> reset bfd session statistics chassis 1 slot 6
