06-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18206-Layer 3 - IP Services Command Reference
13-Tunneling Commands
13-Tunneling Commands 141.02 KB
default
default
View
Tunnel interface view
Default level
2: System level
None
Use default to restore the default setting for the tunnel interface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network.
# Restore the default setting of interface Tunnel 1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Specifies the description of an interface, a string of 1 to 80 characters.
Use description to configure a description for the current interface.
By default, the description of an interface is the interface name followed by the Interface string, for example, Tunnel1 Interface.
Related commands: display interface tunnel.
# Configure the description of interface Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
destination
destination ip-address
undo destination
View
Default level
2: System level
ip-address: Specifies the tunnel destination IPv4 address.
Use destination to specify the destination address for the tunnel interface.
Use undo destination to remove the configured tunnel destination address.
By default, no tunnel destination address is configured.
The tunnel destination address is the address of the peer interface receiving packets and should be configured as the source address of the peer tunnel interface.
Automatic tunnel interfaces using the same encapsulation protocol must have different source addresses. Two or more tunnel interfaces using the same encapsulation protocol must have different source and destination addresses.
Related commands: source, interface tunnel, display interface tunnel, and display ipv6 interface tunnel.
# Set the interface VLAN-interface 100 (193.101.1.1) of Sysname 1 and the interface VLAN-interface 100 (192.100.1.1) of Sysname 2 as the source and destination interfaces of a tunnel between the two switches, respectively.
<Sysname1> system-view
[Sysname1] interface Tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
<Sysname2> system-view
[Sysname2] interface Tunnel 0
[Sysname2-Tunnel0] source 192.100.1.1
[Sysname2-Tunnel0] destination 193.101.1.1
display interface [ tunnel ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface [ tunnel [ number ] ] [ brief [ description ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Sets the number of a tunnel interface. If you specify this argument, the command displays information about the specified tunnel interface.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of interface descriptions.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface tunnel to display information about tunnel interfaces, such as the source address, destination address, and tunnel mode.
If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
Related commands: interface tunnel, source, destination, and tunnel-protocol.
# Display detailed information about interface Tunnel 0.
<Sysname> display interface tunnel 0
Tunnel0 current state: UP
The Maximum Transmit Unit is 1476
Internet Address is 10.1.2.1/24 Primary
Encapsulation is TUNNEL, service-loopback-group ID not set
Tunnel source 192.13.2.1, destination 192.13.2.2
Tunnel bandwidth 64 (kbps)
Tunnel keepalive enabled, Period(50 s), Retries(3)
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
Last clearing of counters:  Never
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    361 packets input,  9953388 bytes
    0 input error
    361 packets output,  30324 bytes
    0 output error
Physical state of the tunnel interface:
·     DOWN (Administratively)—The interface is administratively down. That is, the interface is shut down with the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down.
·     UP—Both the administrative and physical states of the interface are up.
Link layer state of the tunnel interface:
·     DOWN—The protocol state of the interface is down.
·     UP—The protocol state of the interface is up.
Description of the tunnel interface.
Maximum transmit unit allowed on the tunnel interface.
Internet Address
IP address of the tunnel interface.
If no IP address is assigned to the interface, Internet protocol processing : disabled will be displayed, which means that packets cannot be processed.
Primary indicates the primary IP address of the interface. Sub indicates a secondary IP address of the interface.
The encapsulation protocol is tunnel.
ID of the service loopback group referenced by the tunnel.
If service loopback group is not supported or not specified, service-loopback-group ID not set will be displayed.
Tunnel source
Source address of the tunnel.
destination
Destination address of the tunnel.
Tunnel bandwidth
Bandwidth of the tunnel interface.
GRE keepalive is enabled to detect the state of the tunnel interface. In this example, keepalive packets are sent every 50 seconds and can be sent up to three times.
Tunnel mode and transport protocol:
·     GRE/IPGRE over IPv4 tunnel mode.
·     IPv6/IPIPv6 over IPv4 manual tunnel mode.
·     IPv6/IP 6to4IPv6 over IPv4 6to4 tunnel mode.
·     IPv6/IP auto-tunnelAutomatic IPv6 over IPv4 tunnel mode.
·     IPv6/IP ISATAPIPv6 over IPv4 ISATAP tunnel mode.
·     CR_LSPMPLS TE tunnel mode.
GRE key disabled
The tunnel interface key option of GRE is not configured.
The GRE packet checksum function is disabled.
Last time of clearing of counters.
Average input rate in the last 300 seconds in bytes/sec or packets/sec.
Average output rate in the last 300 seconds in bytes/sec or packets/sec.
packets input
Total number of input packets.
input error
Number of input error packets.
packets output
Total number of output packets.
output error
Number of output error packets.
# Display brief information about interface Tunnel 0.
<Sysname> display interface tunnel 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface              Link Protocol Main IP         Description
Tun0                   UP   UP       1.1.1.1
# Display brief information about interface Tunnel 0, including the complete interface description.
Tun0                   UP   UP       1.1.1.1         123456789012345678901234567
890123456789012345679
# Display brief information about interface Tunnel 1 in DOWN state.
<Sysname> display interface tunnel brief down
Interface              Link Cause
Tun1                   DOWN Not connected
Brief information about Layer 3 interfaces.
Link status:
·     ADMThe interface has been administratively shut down. To recover its physical state, perform the undo shutdown command.
·     StbyThe interface is operating as a backup interface. To see the primary interface, use the display standby state command (High Availability Command Reference).
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses).
Abbreviated interface name.
Link
Physical link state of the interface:
·     UPThe link is up.
·     DOWNThe link is down.
·     ADMThe link has been administratively shut down. To recover its physical state, perform the undo shutdown command.
·     StbyThe interface operates as a backup interface.
Protocol
Protocol connection state of the interface:
·     DOWNProtocol connection is disabled on the interface.
·     UPProtocol connection is enabled.
Main IP
Main IP address of the interface.
Description of the interface.
Cause
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
display ipv6 interface tunnel [ number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Displays IPv6 information on a specific tunnel interface. If you do not specify an interface number, this command displays IPv6 information about all tunnel interfaces.
brief: Displays brief information and IPv6 packet statistics for tunnel interfaces. If you do not specify this keyword, the command displays detailed IPv6 information about tunnel interfaces.
Use display ipv6 interface tunnel to display IPv6 information about tunnel interfaces.
# Display detailed IPv6 information and IPv6 packet statistics for interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0
Tunnel0 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::202:201
  Global unicast address(es):
    3000::1, subnet is 3000::/64
  Joined group address(es):
    FF02::1:FF02:201
    FF02::1:FF00:1
    FF02::1:FF00:0
    FF02::2
    FF02::1
  MTU is 1480 bytes
IPv6 Packet statistics:
  InReceives:                    45
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    45
  OutRequests:                   45
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:             0
  OutMcastPkts:                  0
·     Administratively DOWN—The interface is administratively down. That is, the interface is shut down with the shutdown command.
IPv6 is enabled
IPv6 packet forwarding state of the tunnel interface. IPv6 packet forwarding is automatically enabled after an IPv6 address is assigned to the interface. IPv6 packet forwarding is enabled in the example.
link-local address
Link-local address configured for the tunnel interface.
Global unicast addresses configured for the tunnel interface.
Multicast addresses of the tunnel interface.
MTU is 1480 bytes
Maximum transmission unit of the tunnel interface. It is 1480 bytes in the example.
ND reachable time
Neighbor reachable time.
Interval for retransmitting a neighbor solicitation message.
Hosts use stateless autoconfiguration mode to acquire IPv6 addresses.
InReceives
All IPv6 packets received by the tunnel interface, including types of error packets.
InTooShorts
Received IPv6 packets that are too short, with a length less than 40 bytes, for example.
InTruncatedPkts
Received IPv6 packets with a length less than that specified in the packets.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the limit.
InBadHeaders
Received IPv6 packets with bad basic headers.
InBadOptions
Received IPv6 packets with bad extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of packets after reassembly rather than the number of fragments.
InFragDrops
IPv6 fragments discarded due to certain errors.
InFragTimeouts
IPv6 fragments discarded because the interval for which they had stayed in the system buffer exceeded the specified period.
OutFragFails
Packets failed in fragmentation on the outbound interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that were delivered to application layer protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 application protocols.
OutForwDatagrams
Packets forwarded by the outbound interface.
InNoRoutes
IPv6 packets that were discarded because no matched route can be found.
InTooBigErrors
IPv6 packets that were discarded because they exceeded the PMTU.
OutFragOKs
Packets that were fragmented on the outbound interface.
OutFragCreates
Number of packet fragments after fragmentation on the outbound interface.
InMcastPkts
IPv6 multicast packets received on the interface.
InMcastNotMembers
Incoming IPv6 multicast packets that were discarded because the interface did not belong to the corresponding multicast groups.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
IPv6 packets that were discarded due to invalid destination addresses.
InDiscards
Received IPv6 packets that were discarded due to resource problems rather than packet content errors.
OutDiscards
Sent packets that were discarded due to resource problems rather than packet content errors.
# Display brief IPv6 information about interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0 brief
*down: administratively down
(s): spoofing
Interface                                Physical   Protocol   IPv6 Address
Tunnel0                                    up         up       3000::1
*down
The tunnel interface is administratively down, that is, the interface is closed by using the shutdown command.
(s)
Spoofing attribute of the tunnel interface, that is, the link protocol state of the tunnel interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Name of the tunnel interface.
Physical
·     *down—The interface is administratively down. That is, the interface is shut down with the shutdown command.
·     down—The interface is administratively up but its physical state is down.
·     up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the tunnel interface:
·     down—The protocol state of the interface is down, which is usually because that no IPv6 address is assigned to the interface.
·     up—The protocol state of the interface is up.
IPv6 Address
IPv6 address of the tunnel interface. Only the first of configured IPv6 addresses is displayed. (If no address is configured for the interface, Unassigned will be displayed.)
interface tunnel
interface tunnel number
undo interface tunnel number
View
Default level
2: System level
number: Specifies the number of the tunnel interface, in the range of 0 to 1023.
Use interface tunnel to create a tunnel interface and enter its view. If the specified tunnel interface already exists, this command places you to tunnel interface view.
Use undo interface tunnel to delete a tunnel interface.
By default, no tunnel interface is created on the switch.
A tunnel interface number is only locally significant. Thus, the tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
Related commands: display interface tunnel, display ipv6 interface tunnel, source, destination, and tunnel-protocol.
# Create interface Tunnel 3 and enter its view.
[Sysname] interface tunnel 3
[Sysname-Tunnel3]
mtu
mtu mtu-size
undo mtu
View
Default level
2: System level
mtu-size: Specifies the MTU for IPv4 packets on the interface, in bytes, in the range of 64 to 9174.
Use mtu to set the MTU for IPv4 packets on an interface.
The default MTU for IPv4 packets is 1500.
# Set the MTU for IPv4 packets on interface Tunnel 3 to 2000 bytes.
[Sysname-Tunnel3] mtu 2000
ipv6 mtu
ipv6 mtu mtu-size
undo ipv6 mtu
View
Default level
2: System level
mtu-size: Specifies the IPv6 MTU of the tunnel interface, in the range of 1280 to 9174 bytes.
Use ipv6 mtu to set the IPv6 MTU on the tunnel interface.
Use undo ipv6 mtu to restore the default MTU.
By default, the IPv6 MTU on the GRE tunnel interface is 1476, and the IPv6 MTU on other tunnels is 1480 bytes.
# Set the MTU of IPv6 packets on interface Tunnel 0 to 1280 bytes.
[Sysname] interface tunnel 0
[Sysname-Tunnel0] ipv6 mtu 1280
reset counters interface
reset counters interface [ tunnel [ number ] ]
View
Default level
2: System level
number: Specifies the tunnel interface number.
Use reset counters interface to clear tunnel interface statistics.
Before sampling network traffic within a specific period of time on an interface, you need to clear the existing statistics.
If you do not specify the tunnel keyword or interface number, this command clears statistics for all interfaces.
If you specify only the tunnel keyword, this command clears statistics for all tunnel interfaces.
If you specify both the tunnel keyword and interface number, this command clears statistics for the specified tunnel interface.
# Clear statistics for Tunnel 3.
<Sysname> reset counters interface tunnel 3
shutdown
shutdown
View
Default level
2: System level
None
Use shutdown to shut down a tunnel interface.
Use undo shutdown to bring up a tunnel interface.
By default, a tunnel interface is in up state.
# Shut down interface Tunnel 1.
[Sysname-Tunnel1] shutdown
source
source { ip-address | interface-type interface-number }
undo source
View
Default level
2: System level
ip-address: Specifies the tunnel source IPv4 address.
interface-type interface-number: Specifies a tunnel interface by its type and number. The interface types include tunnel and VLAN interface.
Use source to specify the source address or interface of the tunnel interface.
Use undo source to remove the configured source address or interface of the tunnel interface.
By default, no source address or interface is specified for the tunnel interface.
The tunnel source address is the address of the interface sending packets and should be configured as the destination address of the peer tunnel interface.
Automatic tunnel interfaces using the same encapsulation protocol must have different source addresses. Manual tunnel interfaces using the same encapsulation protocol must have different source and destination addresses.
Related commands: destination, interface tunnel, display interface tunnel, and display ipv6 interface tunnel.
# Set the tunnel source address to 192.100.1.1 on Tunnel 0.
[Sysname-Tunnel0] source 192.100.1.1
Or set the tunnel source interface to VLAN-interface 100.
[Sysname-Tunnel0] source vlan-interface 100
tunnel bandwidth
tunnel bandwidth bandwidth-value
undo tunnel bandwidth
View
Default level
2: System level
bandwidth-value: Specifies the bandwidth value of the tunnel interface in kbps, in the range of 1 to 10000000.
Use tunnel bandwidth to set the bandwidth value of the tunnel interface.
Use undo tunnel bandwidth to restore the default.
By default, the bandwidth of the tunnel interface is 64 kbps.
The tunnel interface bandwidth set with the tunnel bandwidth command is for dynamical routing protocols to calculate the cost of a tunnel path, rather than changes the bandwidth of the tunnel interface. Refer to the bandwidth of the output interface of the packet when you set the bandwidth of the tunnel interface.
# Configure the bandwidth of Tunnel 0 as 100 kbps.
[Sysname-Tunnel0] tunnel bandwidth 100
tunnel-protocol
tunnel-protocol [ ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | gre | mpls te ]
undo tunnel-protocol
View
Default level
2: System level
ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
6to4: Specifies the 6to4 tunnel mode.
auto-tunnel: Specifies the automatic tunnel mode.
isatap: Specifies the ISATAP tunnel mode.
gre: Specifies the GRE over IPv4 tunnel mode.
mpls te: Specifies the MPLS TE tunnel mode.
Use tunnel-protocol to specify the tunnel mode for the tunnel interface.
Use undo tunnel-protocol to restore the default.
By default, the GRE over IPv4 tunnel mode is used.
You can select a tunnel mode according to the actual network topology and application. The two ends of a tunnel must have the same tunnel mode specified, or traffic transmission might fail.
Only one automatic tunnel can be created at the start point of a tunnel.
# Specify the IPv6 over IPv4 tunnel mode for interface Tunnel 1.
[Sysname-Tunnel1] tunnel-protocol ipv6-ipv4
