03-Interface Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18203-Interface Command Reference
03-Loopback and Null Interface Commands
03-Loopback and Null Interface Commands 96.44 KB
Loopback and null interface configuration commands
default
default
View
Loopback interface view, null interface view
Default level
2: System level
None
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network.
Use default to restore the default settings for the loopback or null interface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface loopback 1.
[Sysname] interface Loopback 1
[Sysname-Loopback1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Loopback interface view, Null 0 interface view
Default level
2: System level
text: Specifies an interface description, a string of 1 to 80 characters, which supports spaces, characters and symbols found in standard English (such as numbers and case-sensitive letters), special English, and other characters or symbols that conform to the Unicode standard.
·     An interface description can be a mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified length.
·     To use a type of Unicode characters or symbols in an interface description, install the specific input method editor and log in to the switch through supported remote login software.
·     When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters might be displayed at the end of a line.
·     Each non-English Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line. This might break a Unicode character into two parts and create garbled characters at the end of a line.
Use description to configure a description for the current interface.
By default, the description of a loopback or null interface is interface name Interface, for example, LoopBack2 Interface.
Related commands: display interface.
# Set the description of interface LoopBack2 to PIM-SM RP.
[Sysname] interface Loopback 2
[Sysname-LoopBack2] description PIM-SM RP
display interface loopback
display interface [ loopback ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface [ loopback [ interface-number ] ] [ brief [ description ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of interface descriptions.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface loopback to display the information about a loopback interface.
If you do not specify the loopback keyword, this command displays information about all interfaces on the device.
If you specify the loopback keyword without the interface-number argument, this command displays information about all created loopback interfaces.
Related commands: interface loopback.
# View the information about interface Loopback 0.
<Sysname> display interface LoopBack 0
LoopBack0 current state: UP
Line protocol current state: UP (spoofing)
Description: LoopBack0 Interface
The Maximum Transmit Unit is 1536
Internet Address is 2.2.2.2/32 Primary
Physical is Loopback
Last clearing of counters:  Never
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
# Display brief information about interface loopback 0.
<Sysname> display interface Loopback 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface              Link Protocol Main IP         Description
Loop0                  UP   UP(s)    --
# Display brief information about all loopback interfaces in DOWN state.
<Sysname> display interface Loopback brief down
Interface              Link Cause
Loop1                  ADM  Administratively
current state
Physical state (up or down) of the interface.
State of the data link layer protocol: UP (spoofing). Spoofing refers to the spoofing attribute of the interface. That is, when the network layer protocol state of the interface is displayed as up, the corresponding link might not exist, or the corresponding link is non-permanent and established on demand.
Description string of the interface.
Maximum transmission unit (MTU) of the interface.
Internet protocol processing
State (enabled or disabled) of the network layer protocol.
This field appears when no IP address is configured for the interface.
Primary IP address of the interface.
This field does not appear if no primary IP address is configured for the interface.
Physical is loopback
The physical type of the interface is loopback.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If the statistics of the interface have never been cleared with the reset counters interface command since the switch starts, Never is displayed for this field.
Input rate during the latest 300 seconds, which is measured in bytes per second, bits per second, and packets per second.
Output rate during the latest 300 seconds, which is measured in bytes per second, bits per second, and packets per second.
Total number and size (in bytes) of input packets of the interface and the number of the dropped packets.
Total number and size (in bytes) of output packets of the interface and the number of the dropped packets.
Brief information about Layer 3 interfaces.
Link status:
·     ADMThe interface has been administratively shut down. To recover its physical state, perform the undo shutdown command.
·     StbyThe interface is operating as a backup interface.
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses).
Abbreviated interface name.
Link
Physical link state of the interface:
·     UPThe link is up.
·     ADMThe link has been administratively shut down. To recover its physical state, perform the undo shutdown command.
Protocol
Protocol connection state of the interface:
·     UP.
·     DOWN.
·     UP(s).
Main IP
Main IP address of the interface.
Description of the interface.
Cause
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
display interface null
display interface [ null ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface [ null [ 0 ] ] [ brief [ description ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
0: Specifies interface Null 0. The interface number is fixed at 0, because the switch has only one null interface.
Use display interface null to display information about the null interface.
If you do not specify the null keyword, this command displays information about all interfaces on the device.
If you specify the null keyword, this command displays information about interface Null 0 with or without the 0 keyword, because the device supports only one interface Null 0.
Related commands: interface null.
# View the information about interface Null 0.
<Sysname> display interface NULL 0
Description: NULL0 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
Physical is NULL DEV
# Display brief information about interface Null 0.
<Sysname> display interface NULL 0 brief
NULL0                  UP   UP(s)    --
For the command output description, see Table 1.
interface loopback
interface loopback interface-number
undo interface loopback interface-number
View
Default level
2: System level
interface-number: Specifies a loopback interface by its number in the range of 0 to 1023.
Use interface loopback to create a loopback interface or enter loopback interface view.
Use undo interface loopback to remove a loopback interface.
Related commands: display interface loopback.
# Create interface Loopback 5.
[Sysname] interface Loopback 5
[Sysname-LoopBack5]
interface null
interface null 0
View
Default level
2: System level
Use interface null to enter null interface view.
A switch has only one null interface, interface Null 0, which is always up, and cannot be disabled or removed.
Related commands: display interface null.
# Enter Null 0 interface view.
[Sysname] interface NULL 0
[Sysname-NULL0]
reset counters interface [ interface-type [ interface-number ] ]
View
Default level
2: System level
interface-number: Specifies an interface by its number.
Use reset counters interface to clear statistics for interfaces.
Before collecting statistics within a specific period of time on an interface, you must clear the existing statistics on it.
If no interface type is specified, this command clears the statistics of all interfaces.
If only the interface type is specified, this command clears the statistics of the interfaces of the specified type.
If both the interface type and interface number are specified, this command clears the statistics of the specified interface.
# Clear the statistics of Loopback 3.
<Sysname> reset counters interface Loopback 3
shutdown
shutdown
View
Default level
2: System level
None
Use shutdown to shut down the current loopback interface.
Use undo shutdown to bring up the current loopback interface.
By default, a loopback interface is up.
# Shut down loopback interface Loopback 1.
[Sysname-Loopback1] shutdown
