04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18204-Layer 2 - LAN Switching Configuration Guide
04-Ethernet Link Aggregation Configuration
04-Ethernet Link Aggregation Configuration 321.84 KB
When the device operating in IRF mode is enabled with enhanced IRF mode, it does not support creating Layer 3 Ethernet interfaces/subinterfaces or Layer 3 aggregate interfaces/subinterfaces.
The device supports a maximum of 240 aggregation groups. An aggregation group supports a maximum of 12 Selected ports on a single device. For IRF mode, the maximum number of Selected ports supported by an aggregation group is 12 multiplied by the number of IRF member devices.
Overview
Ethernet link aggregation, or simply link aggregation, combines multiple physical Ethernet ports into one logical link, called an aggregate link. Link aggregation delivers the following benefits:
·     Increases bandwidth beyond the limits of any single link. In an aggregate link, traffic is distributed across the member ports.
·     Improves link reliability. The member ports dynamically back up one another. When a member port fails, its traffic is automatically switched to other member ports.
As shown in Figure 1, Device A and Device B are connected by three physical Ethernet links. These physical Ethernet links are combined into an aggregate link, Link Aggregation 1. The bandwidth of this aggregate link is as high as the total bandwidth of these three physical Ethernet links. At the same time, the three Ethernet links back up one another.
Figure 1 Ethernet link aggregation
Basic concepts
Aggregation group, member port, and aggregate interface
Ethernet link aggregation is implemented through link aggregation groups. An aggregation group is a group of Ethernet interfaces aggregated together, which are called member ports of the aggregation group. For each aggregation group, a logical interface, called an aggregate interface is created. To an upper layer entity that uses the link aggregation service, a link aggregation group looks like a single logical link and data traffic is transmitted through the aggregate interface.
There are two types of aggregate interfaces: Bridge-Aggregation (BAGG) interfaces, which are Layer 2 aggregate interfaces, and Route-Aggregation (RAGG) interfaces, which are Layer 3 aggregate interfaces. When an aggregate interface is created, an aggregation group of the same type and numbered the same is created automatically. For example, when you create interface Bridge-Aggregation 1, Layer 2 aggregation group 1 is created.
To a Layer 2 aggregation group, you can assign only Layer 2 Ethernet interfaces; to a Layer 3 aggregation group, only Layer 3 Ethernet interfaces.
On a Layer 3 aggregate interface, you can create subinterfaces, which are called "Layer 3 aggregate subinterfaces." These subinterfaces are logical interfaces that operate at the network layer. They can receive VLAN tagged packets for their Layer 3 aggregate interface.
The rate of an aggregate interface equals the total rate of its member ports in selected state and its duplex mode is the same as that of the selected member ports. For more information about the states of member ports in an aggregation group, see "Aggregation states of member ports in an aggregation group."
A member port in an aggregation group can be in either of the following two aggregation states:
·     Selected—A Selected port can forward user traffic.
·     Unselected—An Unselected port cannot forward user traffic.
Operational key
When aggregating ports, the system automatically assigns each port an operational key based on port information such as port rate and duplex mode. Any change to this information triggers a recalculation of this operational key.
In an aggregation group, all selected member ports are assigned the same operational key.
Configuration classes
Every configuration setting on a member port in a link aggregation group might affect the aggregation state of the port in the group more or less. They are divided into three configuration classes:
·     Port attribute configurations—Includes port rate, duplex mode, and link status (up/down), which are the most basic port configurations.
·     Class-two configurations—A member port can be placed in selected state only if it has the same class-two configurations as the aggregate interface.
Table 1 Class-two configurations
Item
Considerations
Port isolation
Whether the port has joined an isolation group, and the isolation group to which the port belongs
QinQ
QinQ enable state (enable/disable), TPID for VLAN tags, outer VLAN tags to be added, inner-to-outer VLAN priority mappings, inner-to-outer VLAN tag mappings, inner VLAN ID substitution mappings
VLAN
Permitted VLAN IDs, PVID, link type (trunk, hybrid, or access), IP subnet-based VLAN configuration, protocol-based VLAN configuration, VLAN tagging mode
MAC address learning
MAC address learning capability, MAC address learning limit, forwarding of frames with unknown destination MAC addresses after the MAC address learning limit is reached
·     Class-two configurations made on an aggregate interface are automatically synchronized to all its member ports. These configurations are retained on the member ports even after the aggregate interface is removed.
·     Any class-two configuration change might affect the aggregation state of link aggregation member ports and thus ongoing traffic. To make sure that you are aware of the risk, the system displays a warning message every time you attempt to change a class-two configuration setting on a member port.
·     Class-one configurations—Include settings that do not affect the aggregation state of the member port even if they are different from those on the aggregate interface. GVRP and MSTP settings are examples of class-one configurations.
Reference port
When setting the aggregation state of the ports in an aggregation group, the system automatically picks a member port as the reference. This port is called the reference port of the aggregation group. The port attribute and class-two configurations of every other member port are compared with those of the reference port.
LACP protocol
The IEEE 802.3ad Link Aggregation Control Protocol (LACP) enables dynamic aggregation of physical links. It uses link aggregation control protocol data units (LACPDUs) for exchanging aggregation information between LACP-enabled network devices.
1.     LACP functions
Based on the fields carried in LACPDUs, the functions delivered by the IEEE 802.3ad LACP include basic LACP functions and extended LACP functions, as described in Table 2.
Table 2 Basic and extended LACP functions
Category
Basic LACP functions
Implemented through the basic LACPDU fields including the system LACP priority, system MAC address, port aggregation priority, port number, and operational key.
Each member port in a LACP-enabled aggregation group exchanges the above information with its peer. When a member port receives an LACPDU, it compares the received information with the information received on the other member ports. In this way the two systems reach an agreement on which ports should be placed in the selected state.
Extended LACP functions
Implemented by extending the LACPDU with new Type/Length/Value (TLV) fields. This is how the LACP multi-active detection (MAD) mechanism of the Intelligent Resilient Framework (IRF) feature is implemented.
·     If a switch supports both LACP extensions and IRF, it can participate in LACP MAD either as an IRF member switch or an intermediate switch.
·     If a switch supports LACP extensions but not IRF, it can participate in LACP MAD only as an intermediate switch.
For more information about IRF, IRF member switches, intermediate switches, and the LACP MAD mechanism, see IRF Configuration Guide.
2.     LACP priorities
There are two types of LACP priorities: system LACP priority and port aggregation priority, as described in Table 3.
Table 3 LACP priorities
Remarks
System LACP priority
Used by two peer devices (or systems) to determine which one is superior in link aggregation.
In dynamic link aggregation, the system that has higher system LACP priority sets the selected state of member ports on its side first and then the system that has lower priority sets port state accordingly.
The smaller the priority value, the higher the priority.
Port aggregation priority
Determines the likelihood of a member port to be selected on a system. The higher port aggregation priority, the higher likelihood.
3.     LACP timeout interval
The LACP timeout interval specifies how long a member port waits to receive LACPDUs from the peer port. If a local member port fails to receive LACPDUs from the peer within three times the LACP timeout interval, the member port assumes that the peer port has failed. You can configure the LACP timeout interval as the short timeout interval (1 second) or the long timeout interval (30 seconds).
Link aggregation modes
There are two link aggregation modes: dynamic and static. Dynamic link aggregation uses LACP while static link aggregation does not. A link aggregation group operating in static mode is called a static link aggregation group, while a link aggregation group operating in dynamic mode is called a dynamic link aggregation group. Table 4 compares the two aggregation modes.
Table 4 A comparison between static and dynamic aggregation modes
Aggregation mode
LACP status on member ports
Pros
Cons
Static
Disabled
Aggregation is stable. The aggregation state of the member ports is not affected by their peers.
The member ports cannot change their aggregation state in consistent with their peers. The administrator needs to manually maintain link aggregations.
Dynamic
Enabled
The administrator does not need to maintain link aggregations. The peer systems maintain the aggregation state of the member ports automatically.
The aggregation state of member ports is easily affected by the network environment, which makes dynamic aggregation less stable.
In a dynamic link aggregation group:
·     A Selected port can receive and send LACPDUs.
·     An Unselected port can receive and send LACPDUs only if it is up and have the same class-two configurations as the aggregate interface.
Aggregating links in static mode
LACP is disabled on the member ports in a static aggregation group. The aggregation state of the member ports must be maintained manually.
Static link aggregation comprises:
·     Choosing a reference port
·     Setting the aggregation state of each member port
The system chooses a reference port from the member ports that are in the up state and have the same class-two configurations as the aggregate interface.
The candidate ports are sorted by aggregation priority, duplex, and speed in the following order:
·     Lowest aggregation priority value
·     Full duplex/high speed
·     Full duplex/low speed
·     Half duplex/high speed
·     Half duplex/low speed
The one at the top is chosen as the reference port. If two ports have the same aggregation priority, duplex mode, and speed, the one with the lower port number is chosen.
After choosing the reference port, the static aggregation group sets the aggregation state of each member port as shown in Figure 2.
Figure 2 Setting the aggregation state of a member port in a static aggregation group
·     Any port attribute or class-two configuration change on a member port might change the aggregation state and cause service interruption.
·     A port that joins the static aggregation group after the Selected port limit has been reached will not be placed in the selected state even if it otherwise should be. This is can prevent ongoing traffic on the current Selected ports from being interrupted. You should avoid the situation, however, as it can cause the aggregation state of a port to change after a reboot.
Aggregating links in dynamic mode
LACP is automatically enabled on all member ports in a dynamic aggregation group. The protocol maintains the aggregation state of ports automatically.
Dynamic link aggregation comprises:
The local system (the actor) negotiates with the remote system (the partner) to choose a reference port as follows:
1.     Compare the system ID (comprising the system LACP priority and the system MAC address) of the actor with that of the partner. The system with the lower LACP priority value is chosen. If they are the same, compare the system MAC addresses. The system with the lower MAC address is chosen.
2.     Compare the port IDs of the ports on the system with the smaller system ID. A port ID comprises a port aggregation priority and a port number. First compare the port aggregation priorities. The port with the lower aggregation priority value is chosen. If two ports have the same aggregation priority, compare their port numbers. The port with the smaller port number is chosen. Thus, the port with the lowest port ID is chosen as the reference port.
After the reference port is chosen, the system with the lower system ID sets the state of each member port in the dynamic aggregation group on its side as shown in Figure 3.
Figure 3 Setting the state of a member port in a dynamic aggregation group
Meanwhile, the system with the higher system ID, being aware of the aggregation state changes on the remote system, changes the aggregation state of its ports accordingly.
When you aggregate interfaces in dynamic mode, follow these guidelines:
·     A dynamic link aggregation group preferably sets full-duplex ports as the Selected ports, and will set one, and only one, half-duplex port as a Selected port when none of the full-duplex ports can be selected or only half-duplex ports exist in the group.
·     Any member port attribute or class-two configuration change might affect the aggregation state of link aggregation member ports and ongoing traffic.
·     In a dynamic aggregation group, when the aggregation state of a local port changes, the aggregation state of the peer port also changes accordingly.
·     A port that joins a dynamic aggregation group after the Selected port limit has been reached is placed in Selected state if it is more eligible for being selected than a current member port.
Load sharing criteria for link aggregation groups
In a link aggregation group, traffic can be load-shared across the selected member ports based on a set of criteria, depending on your configuration.
You can choose one of the following criteria or any combination for load sharing:
·     Per-flow load sharing—Classifies traffic flows by source or destination MAC address, source or destination port number, ingress port, source or destination IP address, or MPLS label, or any combination of them, and forwards packets of the same flow on the same link.
·     Per-packet load sharing—Load balances traffic across member links by packet.
Ethernet link aggregation configuration task list
Remarks
Configuring an aggregation group
Configuring a static aggregation group
Select either task.
Configuring a dynamic aggregation group
Configuring an aggregate interface
Configuring the description of an aggregate interface/subinterface
Optional.
Configuring the MTU of a Layer 3 aggregate interface/subinterface
Optional.
Enabling link state trapping for an aggregate interface
Optional.
Limiting the number of Selected ports for an aggregation group
Optional.
Shutting down an aggregate interface
Optional.
Restoring the default settings for an aggregate interface
Optional.
Configuring load sharing for link aggregation groups
Optional.
Enabling link-aggregation traffic redirection
Optional.
Enabling link aggregation enhancement in IRF mode
Optional.
You can choose to create a Layer 2 or Layer 3 link aggregation group depending on the ports to be aggregated:
·     To aggregate Layer 2 Ethernet interfaces, create a Layer 2 link aggregation group;
·     To aggregate Layer 3 Ethernet interfaces, create a Layer 3 link aggregation group.
Configuration guidelines
You cannot assign a port to a Layer 2 aggregation group if any of the features listed in Table 5 is configured on the port.
Table 5 Features incompatible with Layer 2 aggregation groups
Feature
Reference
RRPP
RRPP configuration in High Availability Configuration Guide
MAC authentication
MAC authentication configuration in Security Configuration Guide
IP source guard
IP source guard configuration in Security Configuration Guide
802.1X
802.1X configuration in Security Configuration Guide
Ports specified as source interfaces in portal-free rules
Portal configuration in Security Configuration Guide
You cannot assign a port to a Layer 3 aggregation group if any of the features listed in Table 6 is configured on the port.
Table 6 Interfaces that cannot be assigned to a Layer 3 aggregation group
Interface type
Reference
Interfaces configured with IP addresses
IP addressing configuration in Layer 3—IP Services Configuration Guide
VRRP
VRRP configuration in High Availability Configuration Guide
Portal
Portal in Security Configuration Guide
If a port is used as a reflector port for port mirroring, do not assign it to an aggregation group. For more information about reflector ports, see Network Management and Monitoring Configuration Guide.
Removing an aggregate interface also removes the corresponding aggregation group. At the same time, any member ports of the aggregation group leave the aggregation group.
Do not configure any Layer 3 features, such as MPLS and VPN, on a port to be added to a Layer 3 aggregation group. Remove any Layer 3 feature configured on a port before adding it to a Layer 3 aggregation group.
After adding a port to a Layer 3 aggregation group, configure Layer 3 features on the aggregate interface instead of on the member port. If you configure any Layer 3 feature mistakenly on a member port, remove the Layer 3 feature configuration from the member port and then run the shutdown and undo shutdown commands on the aggregate interface.
Configuring a Layer 2 static aggregation group
Step
Remarks
N/A
2.     Create a Layer 2 aggregate interface and enter Layer 2 aggregate interface view.
When you create a Layer 2 aggregate interface, the system automatically creates a static aggregation group numbered the same.
3.     Return to system view.
N/A
4.     Assign an Ethernet interface to the aggregation group.
a.     Enter Layer 2 Ethernet interface view:
b.     Assign the Ethernet interface to the aggregation group:
port link-aggregation group number
Repeat this step to assign multiple Layer 2 Ethernet interfaces to the aggregation group.
5.     Assign the port an aggregation priority.
link-aggregation port-priority port-priority
Optional.
By default, the aggregation priority of a port is 32768.
Changing the aggregation priority of a port might affect the aggregation state of the ports in the static aggregation group.
Configuring a Layer 3 static aggregation group
Step
Remarks
N/A
2.     Create a Layer 3 aggregate interface and enter the Layer 3 aggregate interface view.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 static aggregation group numbered the same.
N/A
a.     Enter Layer 3 Ethernet interface view:
Repeat this step to assign multiple Layer 3 Ethernet interfaces to the aggregation group.
Optional.
To guarantee a successful dynamic aggregation, make sure that the peer ports of the ports aggregated at one end are also aggregated. The two ends can automatically negotiate the aggregation state of each member port.
Configuring a Layer 2 dynamic aggregation group
Step
Remarks
N/A
2.     Set the system LACP priority.
lacp system-priority system-priority
Optional.
By default, the system LACP priority is 32768.
Changing the system LACP priority might affect the aggregation state of the ports in dynamic aggregation groups.
3.     Create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 static aggregation group numbered the same.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
5.     Return to system view.
N/A
6.     Assign an Ethernet interface to the aggregation group.
7.     Assign the interface an aggregation priority.
Optional.
Changing the aggregation priority of a port might affect the aggregation state of the ports in the dynamic aggregation group.
8.     Set the LACP timeout interval on the port to the short timeout interval (1 second).
lacp period short
Optional.
By default, the LACP timeout interval on a port is the long timeout interval (30 seconds).
Configuring a Layer 3 dynamic aggregation group
Step
Remarks
N/A
Optional.
Changing the system LACP priority might affect the aggregation state of the ports in the dynamic aggregation group.
3.     Create a Layer 3 aggregate interface and enter the Layer 3 aggregate interface view.
N/A
7.     Assign the port an aggregation priority.
lacp port-priority port-priority
Optional.
Changing the aggregation priority of a port might affect the aggregation state of ports in the dynamic aggregation group.
lacp period short
Optional.
In addition to the configurations in this section, most of the configurations that can be performed on Layer 2 or Layer 3 Ethernet interfaces can also be performed on Layer 2 or Layer 3 aggregate interfaces.
You can configure the description of an aggregate interface for administration purposes such as describing the purpose of the interface.
To configure the description of an aggregate interface/subinterface:
Step
Remarks
N/A
2.     Enter aggregate interface view.
·     Enter Layer 2 aggregate interface view:
·     Enter Layer 3 aggregate interface/subinterface view:
Use either command.
3.     Configure the description of the aggregate interface/subinterface.
Optional.
By default, the description of an interface is interface-name Interface, such as Bridge-Aggregation1 Interface.
Maximum transmission unit (MTU) of an interface affects IP packets fragmentation and reassembly on the interface.
To change the MTU of a Layer 3 aggregate interface/subinterface:
Step
Remarks
N/A
2.     Enter Layer 3 aggregate interface/subinterface view.
N/A
3.     Configure the MTU of the interface/subinterface.
mtu size
Optional.
The default setting is 1500 bytes.
You can configure an aggregate interface to generate linkUp trap messages when its link goes up and linkDown trap messages when its link goes down. For more information, see Network Management and Monitoring Configuration Guide.
To enable link state trapping on an aggregate interface:
Step
Remarks
N/A
2.     Enable the trap function globally.
snmp-agent trap enable [ standard [ linkdown | linkup ] * ]
Optional.
By default, link state trapping is enabled globally and on all interfaces.
3.     Enter aggregate interface view.
Use either command.
4.     Enable link state trapping for the aggregate interface.
enable snmp trap updown
Optional.
By default, link state trapping is enabled for the aggregate interface.
CAUTION
CAUTION:
·     For static aggregation groups, the minimum and maximum numbers of Selected ports for the two ends must be consistent.
·     Configuring the minimum number of Selected ports required to bring up an aggregation group might cause all the member ports in the aggregation group to become unselected.
·     Configuring the maximum number of Selected ports in an aggregation group might cause some of the selected member ports in the aggregation group to become unselected.
·     If you configure both the maximum and minimum numbers of Selected ports allowed in an aggregation group, make sure that the former is no smaller than the latter.
The bandwidth of an aggregate link increases along with the number of selected member ports. To avoid congestion caused by insufficient Selected ports on an aggregate link, you can set the minimum number of Selected ports required for bringing up the specific aggregate interface.
This minimum threshold setting affects the aggregation state of both aggregation member ports and the aggregate interface:
·     All member ports change to the Unselected state and the link of the aggregate interface goes down, when the number of member ports eligible for being selected is smaller than the minimum threshold.
·     When the minimum threshold is reached, the eligible member ports change to the Selected state, and the link of the aggregate interface goes up.
The maximum number of Selected ports allowed in an aggregation group is limited by either the configured maximum number or hardware capability, whichever value is smaller.
You can configure redundancy between two ports using the following guideline: Assign two ports to an aggregation group, and configure the maximum number of Selected ports allowed in the aggregation group as 1. In this way, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port serves as a backup port.
To limit the number of Selected ports for an aggregation group:
Step
Remarks
N/A
·     Enter Layer 3 aggregate interface view:
Use either command.
3.     Set the minimum number of Selected ports for the aggregation group.
link-aggregation selected-port minimum number
By default, the minimum number of Selected ports is not specified.
Make sure the minimum number of Selected ports required to bring up an aggregation group is the same on both ends.
4.     Set the maximum number of Selected ports for the aggregation group.
link-aggregation selected-port maximum number
By default, the maximum number of Selected ports allowed in an aggregation group is limited only by the hardware capabilities of the member ports.
Shutting down or bringing up an aggregate interface affects the aggregation state and link state of ports in the corresponding aggregation group in the following ways:
·     When an aggregate interface is shut down, all Selected ports in the corresponding aggregation group become unselected and their link state becomes down.
·     When an aggregate interface is brought up, the aggregation state of ports in the corresponding aggregation group is recalculated and their link state becomes up.
To bring up an aggregate interface:
Step
Remarks
N/A
·     Enter Layer 3 aggregate interface or subinterface view:
Use either command.
3.     Shut down the aggregate interface.
shutdown
By default, aggregate interfaces are up.
Shutting down a Layer 3 aggregate subinterface does not affect any aggregation group, because Layer 3 aggregate subinterfaces are not associated with any aggregation groups.
Step
Remarks
N/A
Use either command.
3.     Restore the default settings for the aggregate interface or subinterface.
default
N/A
You can determine how traffic is load-shared in a link aggregation group by configuring load sharing criteria. The system uses hash algorithm to compute load sharing criteria based on the MPLS labels, service port numbers, IP addresses, MAC addresses, or ingress ports, or any combination of them.
Also, you can specify traffic to be load-shared by packet.
When you configure load sharing for link aggregation groups, follow these restrictions and guidelines:
·     The ingress-port criterion is mutually exclusive with any other criterion.
·     Per-packet load sharing is not configurable when the system is operating in IRF mode. Because per-packet load sharing might disorder the packets, H3C recommends not configuring per-packet load sharing when the internal interface on the OAP card belongs to an aggregation group. For more information about the OAP card, see OAA Configuration Guide.
·     All the criteria except mpls-label1, mpls-label2, mpls-label3 and per-packet, if configured, apply to equal-cost multi-path (ECMP) load sharing for unicast traffic. If per-packet load sharing is configured, ECMP load sharing is performed according to the default load sharing criteria supported by the switch. For more information about ECMP routing, see Layer 3—IP Routing Configuration Guide.
Configuration procedure
To configure load sharing for link aggregation groups:
Step
Remarks
N/A
2.     Configure the load-sharing criteria for link aggregation groups.
link-aggregation load-sharing mode { { destination-ip | destination-mac | destination-port | ingress-port | mpls-label1 | mpls-label2 | mpls-label3 | source-ip | source-mac | source-port } * | per-packet }
Optional.
By default, the switch performs load sharing based on all the criteria except ingress port and per-packet.
The setting you make by using this command affects all load-sharing link aggregation groups.
CAUTION
CAUTION:
·     To prevent traffic interruption, you must enable link-aggregation traffic redirection on switches at both ends of the aggregate link.
·     To prevent packet loss that might occur at a reboot, do not enable MSTP and link-aggregation traffic redirection at the same time.
The link-aggregation traffic redirection function is available on switches or IRF member switches. It can redirect traffic between cards or IRF member switches for a cross-card or cross-switch link aggregation group. With this function, you can prevent traffic interruption when rebooting a card or IRF member switch that contains link aggregation member ports. For more information about IRF, see IRF Configuration Guide.
To enable link-aggregation traffic redirection:
Step
Remarks
N/A
2.     Enable link-aggregation traffic redirection.
link-aggregation lacp traffic-redirect-notification enable
Optional.
By default, link-aggregation traffic redirection is disabled.
Link-aggregation traffic redirection applies to dynamic link aggregation groups only.
Link aggregation enhancement is configurable in IRF mode. It increases the maximum number of links that hardware supports in one aggregation in an IRF fabric.
If this feature is disabled, the maximum number of aggregated links supported in hardware for an aggregation is identical to the upper limit supported by one IRF member chassis.
If this feature is enabled, the maximum number of aggregated links (Selected ports) supported in hardware for an aggregation is identical to the maximum number of aggregated links supported per chassis multiplied by the number of member chassis.
For example, in a four-chassis IRF fabric, each IRF member chassis supports a maximum of 12 links per aggregation in hardware, and the link-aggregation selected-port maximum number command is set to 48 for a link aggregation group.
If link aggregation enhancement is disabled, the actual number of aggregated links in the aggregation can only reach 12. If link aggregation enhancement is enabled, the actual number of aggregated links can reach 48.
If one end is configured with this feature, make sure the other end is also configured with this feature. Otherwise, link aggregation might not work.
To enable link aggregation enhancement in IRF mode:
Step
Remarks
N/A
2.     Enable link aggregation enhancement in IRF mode.
link-aggregation irf-enhanced
By default, link aggregation enhancement is disabled in IRF mode.
Displaying and maintaining Ethernet link aggregation
Remarks
Display information for an aggregate interface or multiple aggregate interfaces.
display interface [ bridge-aggregation | route-aggregation ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description ] ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display the local system ID.
display lacp system-id [ | { begin | exclude | include } regular-expression ]
Display detailed link aggregation information for link aggregation member ports.
display link-aggregation member-port [ interface-list ] [ | { begin | exclude | include } regular-expression ]
Display the summary of all aggregation groups.
display link-aggregation summary [ | { begin | exclude | include } regular-expression ]
Display detailed information about a specific or all aggregation groups.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
Display link-aggregation load sharing criteria.
display link-aggregation load-sharing mode [ | { begin | exclude | include } regular-expression ]
Clear LACP statistics for a specific or all link aggregation member ports.
Available in user view.
Clear statistics for a specific or all aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
Ethernet link aggregation configuration examples
In an aggregation group, only ports that have the same port attributes and class-two configurations (see "Configuration classes") as the reference port (see "Reference port") can operate as Selected ports. Make sure that all member ports have the same port attributes and class-two configurations as the reference port. The other settings only need to be configured on the aggregate interface, not on the member ports.
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are in the down state. Before configuring these interfaces, use the undo shutdown command to bring them up.
Layer 2 static aggregation configuration example
Network requirements
As shown in Figure 4:
·     Configure a Layer 2 static link aggregation group on both Device A and Device B, and enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end, and VLAN 20 at one end to communicate with VLAN 20 at the other end.
·     Enable traffic to be load-shared across aggregation group member ports based on source and destination MAC addresses.
Figure 4 Network diagram
1.     Configure Device A:
# Create VLAN 10, and assign port GigabitEthernet 4/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 4/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 4/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 4/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
# Assign ports GigabitEthernet 4/0/1 through GigabitEthernet 4/0/3 to link aggregation group 1.
[DeviceA] interface gigabitethernet 4/0/1
[DeviceA-GigabitEthernet4/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet4/0/1] quit
[DeviceA] interface gigabitethernet 4/0/2
[DeviceA-GigabitEthernet4/0/2] port link-aggregation group 1
[DeviceA-GigabitEthernet4/0/2] quit
[DeviceA] interface gigabitethernet 4/0/3
[DeviceA-GigabitEthernet4/0/3] port link-aggregation group 1
[DeviceA-GigabitEthernet4/0/3] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
 Please wait... Done.
# Configure Device A to use the source and destination MAC addresses of packets as the global link-aggregation load sharing criteria.
[DeviceA] link-aggregation load-sharing mode source-mac destination-mac
2.     Configure Device B in the same way Device A is configured.
# Display summary information about all aggregation groups on Device A.
[DeviceA] display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e2ff-0001
AGG         AGG       Partner ID               Select Unselect   Share
Interface   Mode                               Ports  Ports      Type
BAGG1       S         none                     3      0          Shar
The output shows that link aggregation group 1 is a load shared Layer 2 static aggregation group and it contains three Selected ports.
# Display the global link-aggregation load sharing criteria on Device A.
[DeviceA] display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
  destination-mac address, source-mac address
The output shows that all link aggregation groups created on the device perform load sharing based on source and destination MAC addresses.
Layer 2 dynamic aggregation configuration example
As shown in Figure 5:
·     Configure a Layer 2 dynamic link aggregation group on both Device A and Device B, enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end, and VLAN 20 at one end to communicate with VLAN 20 at the other end.
Figure 5 Network diagram
# Create VLAN 10, and assign the port GigabitEthernet 4/0/4 to VLAN 10.
[DeviceA] vlan 10
# Create VLAN 20, and assign the port GigabitEthernet 4/0/5 to VLAN 20.
[DeviceA] vlan 20
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the link aggregation mode as dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure the device to use the source and destination MAC addresses of packets as the global link-aggregation load sharing criteria.
BAGG1       D         0x8000, 000f-e2ff-0002   3      0          Shar
The output shows that link aggregation group 1 is a load shared Layer 2 dynamic aggregation group and it contains three Selected ports.
Layer 3 static aggregation configuration example
As shown in Figure 6:
·     Configure a Layer 3 static link aggregation group on both Device A and Device B and configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
·     Enable traffic to be load-shared across aggregation group member ports based on source and destination IP addresses.
Figure 6 Network diagram
# Create Layer 3 aggregate interface Route-Aggregation 1, and configure an IP address and subnet mask for the aggregate interface.
[DeviceA] interface route-aggregation 1
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 3/0/1 through GigabitEthernet 3/0/3 to aggregation group 1.
[DeviceA] interface Gigabitethernet 3/0/1
[DeviceA-Gigabitethernet3/0/1] port link-aggregation group 1
[DeviceA-Gigabitethernet3/0/1] quit
[DeviceA] interface Gigabitethernet 3/0/2
[DeviceA-Gigabitethernet3/0/2] port link-aggregation group 1
[DeviceA-Gigabitethernet3/0/2] quit
[DeviceA] interface Gigabitethernet 3/0/3
[DeviceA-Gigabitethernet3/0/3] port link-aggregation group 1
[DeviceA-Gigabitethernet3/0/3] quit
# Configure the global link-aggregation load sharing criteria as the source and destination IP addresses of packets.
[DeviceA] link-aggregation load-sharing mode source-ip destination-ip
# Display the summary information about all aggregation groups on Device A.
RAGG1       S         none                     3      0          Shar
The output above shows that link aggregation group 1 is a load-sharing-capable Layer 3 static aggregation group that contains three Selected ports.
  destination-ip address,  source-ip address
The output above shows that the global link-aggregation load sharing criteria are the source and destination IP addresses of packets.
Layer 3 dynamic aggregation configuration example
As shown in Figure 7:
·     Configure a Layer 3 dynamic link aggregation group on both Device A and Device B and configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 7 Network diagram
# Create Layer 3 aggregate interface Route-Aggregation 1, configure the link aggregation mode as dynamic, and configure an IP address and subnet mask for the aggregate interface.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure to use the source and destination IP addresses of packets as the global link-aggregation load sharing criteria.
RAGG1       D         0x8000, 000f-e2ff-0002   3      0          Shar
The output shows that link aggregation group 1 is a load-shared Layer 3 dynamic aggregation group and it contains three Selected ports.
The output shows that the global link-aggregation load sharing criteria are the source and destination IP addresses of packets.
