08-IP Multicast Configuration Guide
HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guides-Release1828P04-6W18208-IP Multicast Configuration Guide
09-MBGP Configuration
09-MBGP Configuration 199.35 KB
Configuring MBGP
The term "router" in this chapter refers to both routers and Layer 3 switches.
This chapter covers configuration tasks related to multiprotocol BGP for IP multicast only. For more information about BGP, see Layer 3—IP Routing Configuration Guide.
MBGP overview
BGP-4 can carry routing information for IPv4 only. IETF defined multiprotocol BGP extensions to carry routing information for multiple network layer protocols.
For a network, the multicast topology might be different from the unicast topology. To meet the requirement, the multiprotocol BGP extensions enable BGP to carry the unicast Network Layer Reachability Information (NLRI) and multicast NLRI separately, and the multicast NLRI performs reverse path forwarding (RPF) exclusively. In this way, route selection for a destination through the unicast routing table and through the multicast routing table will have different results, ensuring normal unicast and multicast routing. For more information about RPF, see "Configuring multicast routing and forwarding."
Multi-protocol BGP is defined in RFC 2858 (Multiprotocol Extensions for BGP-4).
Multi-protocol BGP for IP multicast is referred to as Multicast BGP (MBGP) for short.
Protocols and standards
·     RFC 2858, Multiprotocol Extensions for BGP-4
·     RFC 3392, Capabilities Advertisement with BGP-4
·     draft-ietf-idmr-bgp-mcast-attr-00, BGP Attributes for Multicast Tree Construction
·     RFC 4271, A Border Gateway Protocol 4 (BGP-4)
·     RFC 5291, Outbound Route Filtering Capability for BGP-4
·     RFC 5292, Address-Prefix-Based Outbound Route Filter for BGP-4
MBGP configuration task list
Remarks
Configuring basic MBGP
Required.
Controlling route advertisement and reception
Configuring MBGP route redistribution
Required.
Configure default route redistribution into MBGP
Optional.
Configuring MBGP route summarization
Optional.
Advertising a default route to an IPv4 MBGP peer or peer group
Optional.
Configuring outbound MBGP route filtering
Optional.
Configuring inbound MBGP route filtering
Optional.
Configuring MBGP route dampening
Optional.
Configuring MBGP route attributes
Configuring MBGP route preferences
Optional.
Configuring the default local preference
Configuring the MED attribute
Configuring the NEXT_HOP attribute
Configuring the AS_PATH attribute
Optimizing MBGP networks
Configuring MBGP soft reset
Optional.
Enabling the MBGP ORF capability
Optional.
Configuring the maximum number of MBGP routes
Optional.
Configuring a large scaled MBGP network
Configuring ipv4 MBGP peer groups
Optional.
Configuring MBGP community
Optional.
Configuring an MBGP route reflector
Optional.
Before you configure MBGP, make sure that neighboring nodes can access each other at the network layer.
To configure basic MBGP functions:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Specify a peer or peer group and its AS number.
peer { group-name | ip-address } as-number as-number
Not specified by default.
4.     Enter IPv4 MBGP address family view.
ipv4-family multicast
N/A.
5.     Enable a peer or peer group created in IPv4 unicast view.
peer { group-name | ip-address } enable
N/A.
Not enabled by default.
6.     Specify a preferred value for routes from an IPv4 MBGP peer or peer group.
peer { group-name | ip-address } preferred-value value
Optional.
The default preferred value is 0.
Configuration prerequisites
You must configure basic MBGP functions before configuring this task.
MBGP can advertise routing information in the local AS to neighboring ASs. It redistributes such routing information from IGP into its routing table rather than learns the information by itself.
The Origin attribute of routes redistributed into the MBGP routing table with the import-route command is Incomplete.
The Origin attribute of routes injected into the MBGP routing table with the network command is IGP.
The networks to be injected must exist in the local IP routing table, and using a routing policy makes route control more flexible.
To configure MBGP route redistribution:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter IPv4 MBGP address family view.
N/A
4.     Configure route redistribution from another routing protocol.
·     Enable route redistribution from another routing protocol:
import-route
protocol [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
·     Inject a network into the MBGP routing table:
network ip-address [ mask | mask-length ] [ short-cut | route-policy route-policy-name ]
Use either method.
By default, no route redistribution is configured by default.
The allow-direct keyword is available only when the specified routing protocol is OSPF.
Using the import-route command cannot redistribute any default route into MBGP. This task allows you to do so.
To configure MBGP to redistribute a default route from another protocol:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter MBGP address family view.
N/A
4.     Enable route redistribution from another routing protocol.
By default, no route redistribution is configured.
5.     Enable default route redistribution into the MBGP routing table.
default-route imported
To reduce the routing table size on medium and large MBGP networks, you need to configure route summarization on peers. MBGP supports automatic and manual summarization modes.
·     Automatic summarization—Summarizes subnets redistributed from IGP. With the feature configured, MBGP advertises only summary natural networks rather than subnets. The default routes and routes injected with the network command are not summarized.
·     Manual summarization—Summarizes MBGP local routes. A manual summary route has a higher priority than an automatic one.
To configure MBGP route summarization:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure MBGP route summarization.
·     Enable automatic route summarization:
summary automatic
·     Configure manual route summarization:
aggregate
ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
By default, no route summarization is configured.
Use either method.
If both are configured, the manual route summarization takes effect.
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Advertise a default route to an MBGP peer or peer group.
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
Not advertised by default.
With the peer default-route-advertise command executed, the router sends a default route with the next hop being itself to the specified MBGP peer or peer group, whether the default route is available or not in the routing table.
If several filtering policies are configured, they are applied in the following sequence:
1.     filter-policy export
2.     peer filter-policy export
3.     peer as-path-acl export
4.     peer ip-prefix export
5.     peer route-policy export
Only the routes that have passed all the configured policies can be advertised.
To configure BGP route distribution filtering policies:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure BGP route distribution filtering policies.
·     Configure the filtering of redistributed routes:
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
·     Apply a routing policy to advertisements to an IPv4 MBGP peer/peer group:
peer { group-name | peer-address } route-policy route-policy-name export
·     Reference an ACL to filter advertisements to an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } filter-policy acl-number export
·     Reference an AS path list to filter route advertisements to an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } as-path-acl as-path-acl-number export
·     Reference an IP prefix list to filter route advertisements to an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } ip-prefix ip-prefix-name export
Use at least one method.
By default, no outbound route filtering is configured.
By configuring MBGP route reception filtering policies, you can filter out unqualified routes from an MBGP peer or peer group. Members of a peer group can have different route reception filtering policies from the peer group.
1.     filter-policy import
2.     peer filter-policy import
3.     peer as-path-acl import
4.     peer ip-prefix import
5.     peer route-policy import
To configure MBGP route reception filtering policies:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure MBGP route reception filtering policies.
·     Reference an ACL or IP prefix list to filter incoming routes:
filter-policy { acl-number | ip-prefix ip-prefix-name } import
·     Reference a routing policy to filter routes from an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } route-policy policy-name import
·     Reference an ACL to filter routing information from an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } filter-policy acl-number import
·     Reference an AS path list to filter routing information from an IPv4 MBGP peer/peer group:
 peer { group-name | ip-address } as-path-acl as-path-acl-number import
·     Reference an IP prefix list to filter routing information from an IPv4 MBGP peer/peer group:
peer { group-name | ip-address } ip-prefix ip-prefix-name import
By default, no inbound route filtering is configured.
5.     Specify the maximum number of routes that can be received from an IPv4 MBGP peer/peer group.
peer { group-name | ip-address } route-limit limit [ percentage ]
Optional.
By default, the number is unlimited.
By configuring MBGP route dampening, you can suppress unstable routes from being added to the MBGP routing table or being advertised to MBGP peers.
To configure BGP route dampening:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure BGP route dampening parameters.
Not configured by default.
You can modify MBGP route attributes to affect route selection.
Before you configure this task, you must configure basic MBGP.
You can reference a routing policy to set preferences for routes matching it. Routes not matching it use the default preferences.
To configure MBGP route preferences:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure preferences for external, internal, and local MBGP routes.
Optional.
The default preferences of multicast MBGP EBGP, MBGP IBGP, and local MBGP routes are 255, 255, and 130.
Step
Remarks
N/A
2.     Enter IPv4 MBGP address family view.
N/A
3.     Configure the default local preference.
Optional.
100 by default.
When other conditions of routes to a destination are identical, the route with the smallest MED is selected.
To configure the MED attribute:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the MED attribute.
·     Configure the default MED value:
default med med-value
·     Enable the comparison of the MED of routes from different Ass:
compare-different-as-med
·     Enable the comparison of the MED of routes from each AS:
bestroute compare-med
·     Enable the comparison of the MED of routes from confederation peers:
bestroute med-confederation
Optional.
The default MED value is 0.
You can use the peer next-hop-local command to specify the local switch as the next hop of routes sent to a MBGP IBGP peer or peer group. If load balancing is configured, the switch specifies itself as the next hop of route advertisements to the multicast IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
In a "third party next hop" network, that is, when the local switch has two multicast EBGP peers in a broadcast network, the switch does not specify itself as the next hop of routing information sent to the EBGP peers unless the peer next-hop-local command is configured.
To specify the switch as the next hop of routes sent to a peer/peer group:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Specify the switch as the next hop of routes sent to a peer/peer group.
peer { group-name | ip-address } next-hop-local
Optional.
By default, the next hop of routes sent to a MBGP EBGP peer/peer group is the advertising router, but that of routes sent to a MBGP IBGP peer/peer group is not.
In general, MBGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
To configure the AS_PATH attribute:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Specify the maximum number of times the local AS number can appear in routes from the peer/peer group.
peer { group-name | ip-address } allow-as-loop [ number ]
Optional.
By default, the local AS number cannot appear in routes from a peer/peer group.
5.     Disable BGP from considering the AS_PATH during best route selection.
bestroute as-path-neglect
Optional.
By default, BGP considers AS_PATH during best route selection.
6.     Configure updates to a peer/peer group to not keep private AS numbers.
peer { group-name | ip-address } public-as-only
Optional.
By default, BGP updates carry private AS numbers.
This task involves resetting MBGP connections and configuring load balancing.
Before you configure this task, configure basic MBGP.
After modifying a route selection policy, you have to reset MBGP connections to make it take effect.
The current MBGP implementation supports the route-refresh feature that enables dynamic route refresh without terminating MBGP connections.
However, if a peer not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command to save all routes from the peer. When the routing policy is changed, the system will update the MBGP routing table and apply the new policy.
Performing soft reset through route-refresh
If the peer is enabled with route-refresh, when the MBGP route selection policy is modified on a switch, the switch advertises a route-refresh message to its MBGP peers, which resend their routing information to the switch after receiving the message. Therefore, the local switch can perform dynamic route update and apply the new policy without terminating MBGP connections.
To configure MBGP soft reset through route-refresh:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable BGP route refresh for a peer/peer group.
peer { group-name | ip-address } capability-advertise route-refresh
Optional.
Enabled by default.
Performing a manual soft reset
If the peer does not support route-refresh, you can use the peer keep-all-routes command to save all the route updates from the peer, and then use the refresh bgp ipv4 multicast command to soft-reset MBGP connections to refresh the MBGP routing table and apply the new policy without terminating MBGP connections.
To configure MBGP manual soft reset
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Disable BGP route-refresh and multi-protocol extensions for a peer/peer group.
peer { group-name | ip-address } capability-advertise conventional
Optional.
Enabled by default.
N/A
5.     Keep all original routes from a peer/peer group regardless of whether they pass the inbound filtering policies.
peer { group-name | ip-address } keep-all-routes
Not kept by default.
6.     Return to user view.
return
N/A
7.     Soft-reset MBGP connections manually.
refresh bgp ipv4 multicast { all | ip-address | group group-name | external | internal } { export | import }
Optional.
The MBGP Outbound Router Filter (ORF) feature enables an MBGP speaker to send a set of ORFs to its MBGP peer through route-refresh messages. The peer then applies the ORFs, in addition to its local routing policies (if any), to filter updates to the MBGP speaker, thus reducing the number of exchanged update messages and saving network resources.
After you enable the ORF capability, the local MBGP-enabled switch negotiates the ORF capability with the MBGP peer through Open messages. That is, the MBGP-enabled switch determines whether to carry ORF information in messages, and if yes, whether to carry non-standard ORF information in the packets. After completing the negotiation process and establishing the neighboring relationship, the MBGP-enabled switch and its MBGP peer can exchange ORF information through specific route-refresh messages.
For the parameters configured on both sides for ORF capability negotiation, see Table 1.
To enable the MBGP ORF capability:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
Optional.
Enabled by default.
If this feature is not enabled, you need to configure this command.
For more information about the command, see Layer 3—IP Routing Command Reference.
4.     Enable the non-standard BGP ORF capability for a BGP peer/peer group.
peer { group-name | ipv6-address } capability-advertise orf non-standard
Optional.
By default, standard BGP ORF capability defined in RFC 5291 and RFC 5292 is supported.
5.     Enter MBGP address family view.
N/A
6.     Enable the ORF IP prefix negotiation capability for an MBGP peer/peer group.
peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
Optional.
Table 1 Description of the both, send, and receive parameters and the negotiation result
Local parameter
Peer parameter
Negotiation result
send
·     receive
·     both
The ORF sending capability is enabled locally and the ORF receiving capability is enabled on the peer.
receive
·     send
·     both
The ORF receiving capability is enabled locally and the ORF sending capability is enabled on the peer.
both
both
Both the ORF sending and receiving capabilities are enabled locally and on the peer.
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the maximum number of MBGP routes for load balancing.
balance number
Before you configure this task, you must make peering nodes accessible to each other at the network layer.
In a large-scale network, configuration and maintenance become difficult due to large numbers of MBGP peers. You can configure peer groups to make management easier and improve route distribution efficiency.
To configure an MBGP peer group, you must enable the corresponding IPv4 BGP unicast peer group in IPv4 MBGP address family view.
Before adding an MBGP peer to an MBGP peer group, you must add the corresponding IPv4 unicast peer to the IPv4 BGP peer group.
To configure an IPv4 MBGP peer group:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Create a BGP peer group.
group group-name [ external | internal ]
Not created by default.
4.     Add a peer into the peer group.
peer ip-address group group-name [ as-number as-number ]
No peer added by default.
5.     Enter IPv4 MBGP address family view.
N/A
6.     Enable the IPv4 unicast peer group.
peer group-name enable
N/A
7.     Add an IPv4 MBGP peer to the peer group.
N/A
The COMMUNITY attribute can be advertised between MBGP peers in different ASs. Routers in the same community share the same policy.
When you configure MBGP community, you must reference a routing policy to define the specific  COMMUNITY attributes, and apply the routing policy for route advertisement.
You can reference a routing policy to modify the COMMUNITY attribute for routes sent to a peer. In addition, you can define extended community attributes as needed. For routing policy configuration, see Layer 3—IP Routing Configuration Guide.
To configure MBGP community:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Advertise the COMMUNITY attribute to an MBGP peer/peer group.
·     Advertise the COMMUNITY attribute to an MBGP peer/peer group
peer
{ group-name | ip-address } advertise-community
·     Advertise the extended community attribute to an MBGP peer/peer group
peer { group-name | ip-address } advertise-ext-community
5.     Apply a routing policy to routes advertised to an MBGP peer/peer group.
peer { group-name | ip-address } route-policy route-policy-name export
To guarantee the connectivity between multicast IBGP peers in an AS, you need to make them fully meshed. But this becomes unpractical when large numbers of multicast IBGP peers exist. Configuring route reflectors can solve this problem.
In general, it is not required that clients of a route reflector be fully meshed. The route reflector forwards routing information between clients. If clients are fully meshed, you can disable route reflection between clients to reduce routing costs.
In general, a cluster has only one route reflector, and the router ID of the route reflector identifies the cluster. You can configure multiple route reflectors to improve network stability. In this case, you need to specify the same cluster ID for these route reflectors to avoid routing loops.
To configure an MBGP route reflector:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the router as a route reflector and specify an MBGP peer/peer group as its client.
peer { group-name | peer-address } reflect-client
5.     Enable route reflection between clients.
reflect between-clients
Optional.
Enabled by default.
6.     Configure the cluster ID of the route reflector.
reflector cluster-id cluster-id
Optional.
By default, a route reflector uses its router ID as the cluster ID.
Displaying and maintaining MBGP
Displaying MBGP
Remarks
Display the IPv4 MBGP routing table.
display ip multicast routing-table [ verbose] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display the IPv4 MBGP routing information matching the specified destination IP address.
display ip multicast routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display MBGP peer group information.
display bgp multicast group [ group-name ] [ | { begin | exclude | include } regular-expression ]
Display the advertised networks.
display bgp multicast network [ | { begin | exclude | include } regular-expression ]
Display AS path information.
display bgp multicast paths [ as-regular-expression | | { begin | exclude | include } regular-expression ]
Display MBGP peer/peer group information.
display bgp multicast peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
Display the prefix entries in the ORF information from the specified BGP peer.
display bgp multicast peer ip-address received ip-prefix [ | { begin | exclude | include } regular-expression ]
Display MBGP routing information.
display bgp multicast routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ] [ | { begin | exclude | include } regular-expression ]
Display MBGP routing information matching the AS path list.
display bgp multicast routing-table as-path-acl as-path-acl-number [ | { begin | exclude | include } regular-expression ]
Display MBGP CIDR routing information.
display bgp multicast routing-table cidr [ | { begin | exclude | include } regular-expression ]
Display MBGP routing information matching the specified BGP community.
display bgp multicast routing-table community[ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] [ | { begin | exclude | include } regular-expression ]
Display MBGP routing information matching an MBGP community list.
display bgp multicast routing-table community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> [ | { begin | exclude | include } regular-expression ]
Display MBGP dampened routing information.
display bgp multicast routing-table dampened [ | { begin | exclude | include } regular-expression ]
Display MBGP dampening parameter information.
display bgp multicast routing-table dampening parameter [ | { begin | exclude | include } regular-expression ]
Display MBGP routing information originating from different ASs.
display bgp multicast  routing-table different-origin-as [ | { begin | exclude | include } regular-expression ]
Display IPv4 MBGP routing flap statistics.
display bgp multicast routing-table flap-info [ regular-expression as-regular-expression | [ as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ] [ | { begin | exclude | include } regular-expression ] ]
Display IPv4 MBGP routing information sent to or received from an MBGP peer.
display bgp multicast  routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ] [ | { begin | exclude | include } regular-expression ]
Display IPv4 MBGP routing information matching an AS regular expression.
display bgp multicast  routing-table regular-expression as-regular-expression
Display IPv4 MBGP routing statistics.
display bgp multicast  routing-table statistic [ | { begin | exclude | include } regular-expression ]
Resetting MBGP connections
Remarks
Reset specified MBGP connections.
reset bgp ipv4 multicast { all | as-number | ip-address | group group-name | external | internal }
Available in user view.
Clearing MBGP information
Remarks
Clear dampened routing information and release suppressed routes.
reset bgp ipv4 multicast dampening [ ip-address [ mask | mask-length ] ]
Clear MBGP route flap statistics.
reset bgp ipv4 multicast flap-info [ regexp as-path-regexp | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ]
MBGP configuration example
IMPORTANT:
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are in the state of DOWN. To configure such an interface, use the undo shutdown command to bring it up first.
Network requirements
As shown in Figure 1, PIM-SM 1 is in AS 100 and PIM-SM 2 is in AS 200. OSPF is the IGP in the two ASs, and MBGP runs between the two ASs to exchange multicast route information. The multicast source belongs to PIM-SM 1, and the receiver belongs to PIM-SM 2. Configure the respective Loopback 0 of Switch A and Switch B as the C-BSR and C-RP of the respective PIM-SM domains. Set up an MSDP peer relationship between Router A and Router B through MBGP.
Figure 1 Network diagram
Device
IP address
Device
IP address
Source
N/A
10.110.1.100/24
Switch C
Vlan-int200
10.110.2.1/24
Switch A
Vlan-int100
10.110.1.1/24
Vlan-int102
192.168.2.2/24
Vlan-int101
192.168.1.1/24
Vlan-int104
192.168.4.1/24
Loop0
1.1.1.1/32
Loop0
3.3.3.3/32
Switch B
Vlan-int101
192.168.1.2/24
Switch D
Vlan-int103
192.168.3.2/24
Vlan-int102
192.168.2.1/24
Vlan-int104
192.168.4.2/24
Vlan-int103
192.168.3.1/24
Loop0
4.4.4.4/32
Loop0
2.2.2.2/32
Configuration procedure
1.     Configure IP addresses for interfaces as shown in Figure 1. (Details not shown.)
2.     Configure OSPF. (Details not shown.)
3.     Enable IP multicast routing, PIM-SM and IGMP, and configure a PIM-SM domain border:
# Enable IP multicast routing on Switch A, and enable PIM-SM on each interface.
[SwitchA] multicast routing-enable
# Enable IP multicast routing on Switch B and Switch D in the same way as Switch A, and enable PIM-SM on each interface.
# Enable IP multicast routing on Switch C, enable PIM-SM on each interface, and enable IGMP on the host-side interface VLAN-interface 200.
[SwitchC] multicast routing-enable
[SwitchC] interface vlan-interface 104
[SwitchC-Vlan-interface104] pim sm
[SwitchC-Vlan-interface104] quit
[SwitchC-Vlan-interface200] pim sm
# Configure a PIM domain border on Switch A.
[SwitchA-Vlan-interface101] pim bsr-boundary
# Configure a PIM domain border on Switch B.
[SwitchB-Vlan-interface101] pim bsr-boundary
4.     Configure Loopback 0 and the position of C-BSR, and C-RP:
# Configure Loopback 0 and configure it as the C-BSR and C-RP on Switch A.
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] quit
[SwitchA] pim
[SwitchA-pim] c-bsr loopback 0
[SwitchA-pim] c-rp loopback 0
[SwitchA-pim] quit
# Configure Loopback 0 and configure it as the C-BSR and C-RP on Switch B.
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] quit
[SwitchB] pim
[SwitchB-pim] c-bsr loopback 0
[SwitchB-pim] c-rp loopback 0
[SwitchB-pim] quit
5.     Configure BGP, specify the MBGP peer and enable direct route redistribution:
# On Switch A, configure the MBGP peer and enable direct route redistribution.
[SwitchA] bgp 100
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] peer 192.168.1.2 as-number 200
[SwitchA-bgp] import-route direct
[SwitchA-bgp] ipv4-family multicast
[SwitchA-bgp-af-mul] peer 192.168.1.2 enable
[SwitchA-bgp-af-mul] import-route direct
[SwitchA-bgp-af-mul] quit
[SwitchA-bgp] quit
# On Switch B, configure the MBGP peer and enable route redistribution from OSPF.
[SwitchB] bgp 200
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] peer 192.168.1.1 as-number 100
[SwitchB-bgp] import-route ospf 1
[SwitchB-bgp] ipv4-family multicast
[SwitchB-bgp-af-mul] peer 192.168.1.1 enable
[SwitchB-bgp-af-mul] import-route ospf 1
[SwitchB-bgp-af-mul] quit
[SwitchB-bgp] quit
6.     Configure MSDP peer:
# Specify the MSDP peer on Switch A.
[SwitchA] msdp
[SwitchA-msdp] peer 192.168.1.2 connect-interface vlan-interface 101
[SwitchA-msdp] quit
# Specify the MSDP peer on Switch B.
[SwitchB] msdp
[SwitchB-msdp] peer 192.168.1.1 connect-interface vlan-interface 101
[SwitchB-msdp] quit
7.     Verify the configuration:
Use the display bgp multicast peer command to display MBGP peers on a switch. For example:
# Display MBGP peers on Switch B.
[SwitchB] display bgp multicast peer
 BGP local router ID : 2.2.2.2
 Local AS number : 200
 Total number of peers : 1                 Peers in established state : 1
  Peer           AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  192.168.1.1    100 56       56       0    0       00:40:54 Established
Use the display msdp brief command to display MSDP peers on a switch. For example:
# Display brief information about MSDP peers on Switch B.
[SwitchB] display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
  Configured   Up           Listen       Connect      Shutdown     Down
  1            1            0            0            0            0
  Peer's Address    State    Up/Down time    AS     SA Count   Reset Count
  192.168.1.1       Up       00:07:17        100    1          0
