06-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guides-Release1828P04-6W18206-Layer 3 - IP Services Configuration Guide
10-IPv6 Basics Configuration
10-IPv6 Basics Configuration 391.99 KB
Configuring IPv6 basics 1
Overview·· 1
IPv6 features 1
IPv6 addresses 2
IPv6 neighbor discovery protocol 5
IPv6 path MTU discovery· 7
IPv6 transition technologies 8
Protocols and standards 9
IPv6 basics configuration task list 9
Configuring basic IPv6 functions 10
Enabling IPv6· 10
Configuring IPv6 global unicast addresses 10
Configuring an IPv6 link-local address 11
Configuring an IPv6 anycast address 12
Configuring IPv6 ND·· 13
Configuring a static neighbor entry· 13
Configuring the maximum number of neighbors dynamically learned· 13
Setting the age timer for ND entries in stale state· 14
Configuring parameters related to RA messages 14
Configuring the maximum number of attempts to send an NS message for DAD·· 17
Configuring ND snooping· 17
Enabling ND proxy· 19
Configuring path MTU discovery· 21
Configuring the interface MTU·· 21
Configuring a static path MTU for a specific IPv6 address 21
Configuring the aging time for dynamic path MTUs 21
Configuring IPv6 TCP properties 22
Configuring IPv6 FIB load sharing· 22
Configuring ICMPv6 packet sending· 23
Configuring the maximum ICMPv6 error packets sent in an interval 23
Enabling replying to multicast echo requests 23
Enabling sending ICMPv6 time exceeded messages 24
Enabling sending ICMPv6 destination unreachable messages 24
Enabling a device to discard IPv6 packets that contain extension headers 25
Displaying and maintaining IPv6 basics configuration· 25
IPv6 basics configuration example· 27
Network requirements 27
Configuration procedure· 27
Verifying the configuration· 29
Troubleshooting IPv6 basics configuration· 32
Symptom·· 32
Solution· 32
Overview
Internet Protocol Version 6 (IPv6), also called IP next generation (IPng), was designed by the Internet Engineering Task Force (IETF) as the successor to Internet Protocol version 4 (IPv4). The significant difference between IPv6 and IPv4 is that IPv6 increases the IP address size from 32 bits to 128 bits.
IPv6 features
Header format simplification
IPv6 removes several IPv4 header fields or moves them to the IPv6 extension headers to reduce the length of the basic IPv6 packet header. The basic IPv6 packet header has a fixed length of 40 bytes to simplify IPv6 packet handling and to improve the forwarding efficiency. Although an IPv6 address size is four times larger than an IPv4 address, the basic IPv6 packet header size is only twice the size of the option-less IPv4 packet header.
Figure 1 IPv4 packet header format and basic IPv6 packet header format
Larger address space
The source and destination IPv6 addresses are 128 bits (or 16 bytes) long. IPv6 can provide 3.4 x 1038 addresses to meet the requirements of hierarchical address division and the allocation of public and private addresses.
Hierarchical address structure
IPv6 uses hierarchical address structure to quicken route searches and keep IPv6 routing tables small by route aggregation.
Address autoconfiguration
To simplify host configuration, IPv6 supports stateful and stateless address autoconfiguration.
·     Stateful address autoconfiguration enables a host to acquire an IPv6 address and other configuration information from a server (for example, a DHCP server).
·     Stateless address autoconfiguration enables a host to automatically generate an IPv6 address and other configuration information by using its link-layer address and the prefix information advertised by a router.
To communicate with other hosts on the same link, a host automatically generates a link-local address based on its link-layer address and the link-local address prefix (FE80::/10).
Built-in security
IPv6 defines extension headers to support IPsec. IPsec provides end-to-end security for network security solutions and enhances interoperability among different IPv6 applications.
QoS support
The Flow Label field in the IPv6 header allows the switch to label the packets and facilitates the special handling of a flow.
Enhanced neighbor discovery mechanism
The IPv6 neighbor discovery protocol is implemented through a group of Internet Control Message Protocol version 6 (ICMPv6) messages to manage the information exchange among neighboring nodes on the same link. The group of ICMPv6 messages replaces Address Resolution Protocol (ARP) messages, Internet Control Message Protocol version 4 (ICMPv4) Router Discovery messages, and ICMPv4 Redirect messages and provides a series of other functions.
Flexible extension headers
IPv6 eliminates the Options field in the header and introduces optional extension headers to provide scalability and improve efficiency. The Options field in the IPv4 packet header contains 40 bytes at most, whereas the IPv6 extension headers are restricted to the maximum size of IPv6 packets only.
IPv6 addresses
IPv6 address format
An IPv6 address is represented as a set of 16-bit hexadecimals separated by colons. An IPv6 address is divided into eight groups, and each 16-bit group is represented by four hexadecimal numbers, for example, 2001:0000:130F:0000:0000:09C0:876A:130B.
To simplify the representation of IPv6 addresses, zeros in IPv6 addresses can be handled as follows:
·     The leading zeros in each group can be removed. For example, 2001:0000:130F:0000:0000:09C0:876A:130B can be represented in a shorter format as 2001:0:130F:0:0:9C0:876A:130B.
·     If an IPv6 address contains two or more consecutive groups of zeros, they can be replaced by a double colon (::). For example, 2001:0000:130F:0000:0000:09C0:876A:130B can be represented in the shortest format as 2001:0:130F::9C0:876A:130B.
IMPORTANT
IMPORTANT:
A double colon might appear once or not at all in an IPv6 address. This limit allows the switch to determine how many zeros the double colon represents, and correctly converts it to zeros to restore a 128-bit IPv6 address.
An IPv6 address consists of two parts: an address prefix and an interface ID, which are equivalent to the network ID and the host ID of an IPv4 address respectively.
An IPv6 address prefix is written in IPv6-address/prefix-length notation where the IPv6-address is represented in any of the formats above and the prefix-length is a decimal number indicating how many leftmost bits of the IPv6 address are the address prefix.
IPv6 address types
IPv6 addresses include the following types:
·     Unicast addressAn identifier for a single interface, similar to an IPv4 unicast address. A packet sent to a unicast address is delivered to the interface identified by that address.
·     Multicast addressAn identifier for a set of interfaces (belonging to different nodes), similar to an IPv4 multicast address. A packet sent to a multicast address is delivered to all interfaces identified by that address.
·     Anycast addressAn identifier for a set of interfaces (belonging to different nodes). A packet sent to an anycast address is delivered to the nearest one of the interfaces identified by that address. The nearest interface is chosen according to the routing protocols' measure of distance.
There are no broadcast addresses in IPv6. Their function is replaced by multicast addresses.
The type of an IPv6 address is designated by the first several bits called the format prefix. Table 1 lists the mappings between address types and format prefixes.
Table 1 Mappings between address types and format prefixes
Format prefix (binary)
IPv6 prefix ID
Unicast address
Unspecified address
00...0 (128 bits)
::/128
Loopback address
00...1 (128 bits)
::1/128
Link-local address
1111111010
FE80::/10
Site-local address
1111111011
FEC0::/10
Global unicast address
Other forms
N/A
Multicast address
11111111
FF00::/8
Anycast address
Anycast addresses use the unicast address space and have the identical structure of unicast addresses.
Unicast addresses
Unicast addresses include the following types:
·     Global unicast addresses, equivalent to public IPv4 addresses, are provided for network service providers. This type of address allows efficient prefix aggregation to restrict the number of global routing entries.
·     Link-local addresses are used for communication among link-local nodes for neighbor discovery and stateless autoconfiguration. Packets with link-local source or destination addresses are not forwarded to other links.
·     Site-local unicast addresses are similar to private IPv4 addresses. Packets with site-local source or destination addresses are not forwarded out of the local site (or a private network).
·     The loopback address is 0:0:0:0:0:0:0:1 (or ::1). It might never be assigned to any physical interface and can be used by a node to send an IPv6 packet to itself in the same way as the loopback address in IPv4.
·     The unspecified address is 0:0:0:0:0:0:0:0 (or ::). It cannot be assigned to any node. Before acquiring a valid IPv6 address, a node fills this address in the source address field of IPv6 packets. The unspecified address cannot be used as a destination IPv6 address.
Multicast addresses
IPv6 multicast addresses listed in Table 2 are reserved for special purposes.
Table 2 Reserved IPv6 multicast addresses
Address
Application
FF01::1
Node-local scope all-nodes multicast address
FF02::1
Link-local scope all-nodes multicast address
FF01::2
Node-local scope all-routers multicast address
FF02::2
Link-local scope all-routers multicast address
FF05::2
Site-local scope all-routers multicast address
Multicast addresses also include solicited-node addresses. A node uses a solicited-node multicast address to acquire the link-layer address of a neighboring node on the same link and to detect duplicate addresses. Each IPv6 unicast or anycast address has a corresponding solicited-node address. The format of a solicited-node multicast address is:
FF02:0:0:0:0:1:FFXX:XXXX
Where FF02:0:0:0:0:1:FF is fixed and consists of 104 bits, and XX:XXXX is the last 24 bits of an IPv6 unicast address or anycast address.
EUI-64 address-based interface identifiers
An interface identifier is 64 bits and uniquely identifies an interface on a link.
Various types of interfaces generate EUI-64 address-based interface identifiers in different ways.
·     On an IEEE 802 interfaces (such as an Ethernet interface and a VLAN interface)
The interface identifier is derived from the link-layer address (typically a MAC address) of the interface. To expand the 48-bit MAC address to a 64-bit interface identifier, the hexadecimal number FFFE (16 bits of 1111111111111110) is inserted into the MAC address (behind the 24th high-order bit). To make sure the obtained interface identifier is unique, the universal/local (U/L) bit (which is the seventh high-order bit) is set to 1. Thus, an EUI-64 address-based interface identifier is obtained.
Figure 2 shows the process of how an EUI-64 address-based interface identifier is generated from a MAC address.
Figure 2 Converting a MAC address into an EUI-64 address-based interface identifier
·     On a tunnel interface
The lower 32 bits of the EUI-64 address-based interface identifier are the source IPv4 address of the tunnel interface. The higher 32 bits of the EUI-64 address-based interface identifier of an ISATAP tunnel interface are 0000:5EFE, whereas those of other tunnel interfaces are all zeros. For more information about tunnels, see "Configuring tunneling."
·     On an interface of another type (such as a serial interface)
The EUI-64 address-based interface identifier is generated randomly by the switch.
The IPv6 Neighbor Discovery (ND) protocol uses five types of ICMPv6 messages to implement the following functions:
·     Address resolution
·     Neighbor reachability detection
·     Duplicate address detection
·     Router/prefix discovery and address autoconfiguration
·     Redirection
Table 3 ICMPv6 messages used by ND
ICMPv6 message
Function
Neighbor Solicitation (NS) message
135
Acquires the link-layer address of a neighbor.
Verifies whether a neighbor is reachable.
Detects duplicate addresses.
Neighbor Advertisement (NA) message
136
Responds to an NS message.
Notifies the neighboring nodes of link layer changes.
Router Solicitation (RS) message
133
Requests for an address prefix and other configuration information for autoconfiguration after startup.
Router Advertisement (RA) message
134
Responds to an RS message.
Advertises information such as the Prefix Information options and flag bits.
Redirect message
137
Informs the source host of a better next hop on the path to a particular destination when certain conditions are met.
Address resolution
This function is similar to the ARP function in IPv4. An IPv6 node acquires the link-layer addresses of neighboring nodes on the same link through NS and NA message exchanges. Figure 3 shows how Host A acquires the link-layer address of Host B on a single link.
Figure 3 Address resolution
The address resolution process is:
1.     Host A multicasts an NS message. The source address of the NS message is the IPv6 address of the sending interface of Host A and the destination address is the solicited-node multicast address of Host B. The NS message contains the link-layer address of Host A.
2.     After receiving the NS message, Host B judges whether the destination address of the packet is its solicited-node multicast address. If yes, Host B learns the link-layer address of Host A, and then unicasts an NA message containing its link-layer address.
3.     Host A acquires the link-layer address of Host B from the NA message.
After Host A acquires the link-layer address of its neighbor Host B, Host A can use NS and NA messages to check whether Host B is reachable.
1.     Host A sends an NS message whose destination address is the IPv6 address of Host B.
2.     If Host A receives an NA message from Host B, Host A decides that Host B is reachable. Otherwise, Host B is unreachable.
After Host A acquires an IPv6 address, it performs Duplicate Address Detection (DAD) to check whether the address is being used by any other node (similar to the gratuitous ARP function in IPv4). DAD is accomplished through NS and NA message exchanges. Figure 4 shows the DAD process.
Figure 4 Duplicate address detection
1.     Host A sends an NS message whose source address is the unspecified address and whose destination address is the corresponding solicited-node multicast address of the IPv6 address to be detected. The NS message contains the IPv6 address.
2.     If Host B uses this IPv6 address, Host B returns an NA message. The NA message contains the IPv6 address of Host B.
3.     Host A learns that the IPv6 address is being used by Host B after receiving the NA message from Host B. If receiving no NA message, Host A decides that the IPv6 address is not in use and uses this address.
Router/prefix discovery enables a node to locate the neighboring routers and to learn from the received RA message configuration parameters such as the prefix of the network where the node is located.
Stateless address autoconfiguration enables a node to generate an IPv6 address automatically according to the information obtained through router/prefix discovery.
Router/prefix discovery is implemented through RS and RA messages:
1.     At startup, a node sends an RS message to request from any available router for the address prefix and other configuration information for autoconfiguration.
2.     A router returns an RA message containing information such as Prefix Information options. (The router also periodically sends an RA message.)
3.     The node automatically generates an IPv6 address and other configuration information according to the address prefix and other configuration parameters in the RA message.
In addition to an address prefix, the Prefix Information option also contains the preferred lifetime and valid lifetime of the address prefix. Nodes update the preferred lifetime and valid lifetime accordingly through periodic RA messages.
An automatically generated address is applicable within the valid lifetime and is removed when the valid lifetime expires.
Redirection
A newly started host might contain only a default route to the gateway in its routing table. When certain conditions are met, the gateway sends an ICMPv6 Redirect message to the source host so that the host can select a better next hop to forward packets (similar to the ICMP redirection function in IPv4).
The gateway sends an ICMPv6 Redirect message when the following conditions are met:
·     The receiving interface is the forwarding interface.
·     The selected route itself is not created or modified by an ICMPv6 Redirect message.
·     The selected route is not the default route.
·     The IPv6 packet to be forwarded does not contain any routing header.
The links that a packet passes from a source to a destination might have different maximum transmission units (MTUs). In IPv6, when the packet size exceeds the path MTU of a link, the packet is fragmented at the source end of the link to reduce the processing pressure on intermediate switches and use network resources effectively.
The path MTU discovery mechanism is designed to find the minimum MTU of all links in the path between a source and a destination. Figure 5 shows how a source host discovers the path MTU to a destination host.
Figure 5 Path MTU discovery process
1.     The source host compares its MTU with the packet to be sent, performs necessary fragmentation, and sends the resulting packet to the destination host.
2.     If the MTU supported by a forwarding interface is smaller than the packet, the switch discards the packet and returns an ICMPv6 error packet containing the interface MTU to the source host.
3.     After receiving the ICMPv6 error packet, the source host uses the returned MTU to limit the packet size, performs fragmentation, and sends the resulting packet to the destination host.
4.     Step 2 and step 3 are repeated until the destination host receives the packet. In this way, the source host decides the minimum MTU of all links in the path to the destination host.
Dual stack
Before IPv6 dominates the Internet, high-efficient, seamless IPv6 transition technologies are needed to enable communication between IPv4 and IPv6 networks. There are several IPv6 transition technologies, which can be used in different environments and periods, such as dual stack (RFC 2893), tunneling (RFC 2893), NAT-PT (RFC 2766), and 6PE.
Dual stack is the most direct transition approach. A network node that supports both IPv4 and IPv6 is called a dual stack node. A dual stack node configured with an IPv4 address and an IPv6 address can forward both IPv4 and IPv6 packets. For an upper layer application that supports both IPv4 and IPv6, either TCP or UDP can be selected at the transport layer, whereas the IPv6 stack is preferred at the network layer. Dual stack is suitable for communication between IPv4 nodes or between IPv6 nodes. It is the basis of all transition technologies. However, it does not solve the IPv4 address depletion issue because each dual stack node must have a globally unique IP address.
Tunneling
Tunneling is an encapsulation technology that utilizes one network protocol to encapsulate packets of another network protocol and transfer them over the network. For more information about tunneling, see "Configuring tunneling."
NAT-PT
Network Address Translation – Protocol Translation (NAT-PT) is usually applied on a switch between IPv4 and IPv6 networks to translate between IPv4 and IPv6 packets, allowing communication between IPv4 and IPv6 nodes. It performs IP address translation, and according to different protocols, performs semantic translation for packets. This technology is only suitable for communication between a pure IPv4 node and a pure IPv6 node. For more information about NAT-PT, see "Configuring NAT-PT."
The switch does not support NAT-PT.
6PE
6PE is a transition technology by which Internet service providers (ISPs) can use existing IPv4 backbone networks to allow communications between isolated IPv6 networks.
6PE adds labels to the IPv6 routing information for customer networks and advertises the information into the IPv4 backbone network over Internal Border Gateway Protocol (IBGP) sessions. IPv6 packets are labeled and forwarded over tunnels on the backbone network. The tunnels can be GRE tunnels or MPLS LSPs. For more information about 6PE, see Layer 3—IP Routing Configuration Guide.
·     RFC 1881, IPv6 Address Allocation Management
·     RFC 1887, An Architecture for IPv6 Unicast Address Allocation
·     RFC 1981, Path MTU Discovery for IP version 6
·     RFC 2375, IPv6 Multicast Address Assignments
·     RFC 2460, Internet Protocol, Version 6 (IPv6) Specification
·     RFC 2461, Neighbor Discovery for IP Version 6 (IPv6)
·     RFC 2462, IPv6 Stateless Address Autoconfiguration
·     RFC 2463, Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification
·     RFC 2464, Transmission of IPv6 Packets over Ethernet Networks
·     RFC 2526, Reserved IPv6 Subnet Anycast Addresses
·     RFC 3307, Allocation Guidelines for IPv6 Multicast Addresses
·     RFC 3513, Internet Protocol Version 6 (IPv6) Addressing Architecture
Remarks
Enabling IPv6
Required.
Required to configure one.
Configuring IPv6 ND
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Enabling ND proxy
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Required.
Enabling IPv6
Enable IPv6 before you perform any IPv6-related configuration. Without IPv6 enabled, an interface cannot forward IPv6 packets even if it has an IPv6 address configured.
To enable IPv6:
Step
Remarks
N/A
2.     Enable IPv6.
ipv6
Disabled by default.
IPv6 global unicast addresses can be configured in the following ways:
·     Automatic configuration—When the EUI-64 format is used, the IPv6 address prefix of an interface is the configured prefix, and the interface identifier is generated automatically by the interface.
·     Manual configurationThe IPv6 global unicast address is configured manually.
When you configure IPv6 global unicast addresses, follow these guidelines:
·     You can configure multiple IPv6 global unicast addresses with different prefixes on an interface.
·     A manually configured global unicast address takes precedence over an automatically generated one. If a global unicast address has been automatically generated on an interface when you manually configure another one with the same address prefix, the latter overwrites the previous. The overwritten automatic global unicast address will not be restored even if the manual one is removed. Instead, a new global unicast address will be automatically generated based on the address prefix information in the RA message that the interface receives at the next time.
EUI-64 format
To configure an interface to generate an EUI-64 IPv6 address:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure the interface to generate an IPv6 address in EUI-64 format.
ipv6 address ipv6-address | prefix-length eui-64
By default, no IPv6 global unicast address is configured on an interface.
To specify an IPv6 address manually for an interface:
Step
Remarks
N/A
N/A
3.     Configure an IPv6 address manually.
ipv6 address { ipv6-address prefix-length | ipv6-address | prefix-length }
IPv6 link-local addresses can be configured in either of the following ways:
·     Automatic generationThe switch automatically generates a link-local address for an interface according to the link-local address prefix (FE80::/10) and the link-layer address of the interface.
·     Manual assignmentIPv6 link-local addresses can be assigned manually.
An interface can have only one link-local address. To avoid link-local address conflicts, use the automatic generation method.
Manual assignment takes precedence over automatic generation.
·     If you first use automatic generation and then manual assignment, the manually assigned link-local address will overwrite the automatically generated one.
·     If you first use manual assignment and then automatic generation, the automatically generated link-local address will not take effect and the link-local address is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated.
Configuration guidelines
When you configure automatic generation of an IPv6 link-local address for an interface, follow these guidelines:
·     After an IPv6 global unicast address is configured for an interface, a link-local address is generated automatically. The automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command. If a link-local address is manually assigned to an interface, this manual link-local address takes effect. If the manually assigned link-local address is removed, the automatically generated link-local address takes effect.
·     The undo ipv6 address auto link-local command can only remove the link-local addresses generated through the ipv6 address auto link-local command. However, if an IPv6 global unicast address is already configured for an interface, the interface still has a link-local address because the system automatically generates one for the interface. If no IPv6 global unicast address is configured, the interface has no link-local address.
To configure automatic generation of an IPv6 link-local address for an interface:
Step
Remarks
N/A
N/A
3.     Configure the interface to automatically generate an IPv6 link-local address.
Optional.
By default, no link-local address is configured on an interface.
To configure an IPv6 link-local address manually:
Step
Remarks
N/A
N/A
3.     Configure an IPv6 link-local address manually.
Optional.
Step
Remarks
N/A
N/A
3.     Configure an IPv6 anycast address.
ipv6 address ipv6-address | prefix-length anycast
Optional.
By default, no IPv6 anycast address is configured on an interface.
Configuring IPv6 ND
The IPv6 address of a neighboring node can be resolved into a link-layer address dynamically through NS and NA messages or through a manually configured static neighbor entry.
The switch uniquely identifies a static neighbor entry according to the neighbor IPv6 address and the local Layer 3 interface number. There are two configuration methods:
·     Associate a neighbor IPv6 address and link-layer address with the Layer 3 interface of the local node.
·     Associate a neighbor IPv6 address and link-layer address with a port in a VLAN containing the local node.
You can use either method above to configure a static neighbor entry for a VLAN interface.
·     After a static neighbor entry is configured by using the first method, the switch needs to resolve the corresponding Layer 2 port information for the VLAN interface.
·     If you use the second method, make sure the corresponding VLAN interface exists and that the Layer 2 port specified by port-type port-number belongs to the VLAN specified by vlan-id. After a static neighbor entry is configured, the switch associates the VLAN interface with the IPv6 address to identify the static neighbor entry uniquely.
To configure a static neighbor entry:
Step
2.     Configure a static neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number } [ vpn-instance vpn-instance-name ]
IMPORTANT:
In IRF mode, the mac-address argument in a static neighbor entry cannot be the same as that in the multi-port unicast MAC address entry. Otherwise, conflicts might occur. For more information about the multi-port unicast MAC address entry, see Layer 2—LAN Switching Configuration Guide.
The switch can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table. A large table might reduce the forwarding performance of the switch. You can restrict the size of the neighbor table by setting the maximum number of neighbors that an interface can dynamically learn. When the number of dynamically learned neighbors reaches the threshold, the interface will stop learning neighbor information.
To configure the maximum number of neighbors dynamically learned:
Step
Remarks
N/A
N/A
3.     Configure the maximum number of neighbors dynamically learned by an interface.
ipv6 neighbors max-learning-num number
Optional.
By default, the maximum number of neighbors that a Layer 2 Ethernet interface can learn is the maximum neighbor number supported by the adopted system working mode.
ND entries in stale state have an age timer. If an ND entry in stale state is not refreshed before the timer expires, it transits to the delay state. If it is still not refreshed in 5 seconds, the ND entry transits to the probe state, and the device sends an NS message for detection. If no response is received after three ND messages are sent, the device removes the ND entry.
To set the age timer for ND entries in stale state:
Step
Remarks
N/A
2.     Set the age timer for ND entries in stale state.
Optional.
4 hours by default.
You can enable an interface to send RA messages, and configure the interval for sending RA messages and parameters in RA messages. After receiving an RA message, a host can use these parameters to perform operations. Table 4 lists and describes the configurable parameters in an RA message.
Table 4 Parameters in an RA message and their descriptions
Cur Hop Limit
When sending an IPv6 packet, a host uses the value to fill the Hop Limit field in IPv6 headers. The value is also filled into the Hop Limit field in the response packet of a switch.
After receiving the prefix information advertised by the switch, the hosts on the same link can perform stateless autoconfiguration.
MTU
This field is used to make sure all nodes on a link use the same MTU value.
M flag
This field determines whether hosts use the stateful autoconfiguration to acquire IPv6 addresses.
If the M flag is set to 1, hosts use the stateful autoconfiguration (for example, through a DHCP server) to acquire IPv6 addresses. Otherwise, hosts use the stateless autoconfiguration to acquire IPv6 addresses. Hosts generate IPv6 addresses according to their own link-layer addresses and the prefix information advertised by the router.
O flag
This field determines whether hosts use stateful autoconfiguration to acquire other configuration information.
If the O flag is set to 1, hosts use stateful autoconfiguration (for example, through a DHCP server) to acquire other configuration information. Otherwise, hosts use stateless autoconfiguration to acquire other configuration information.
Router Lifetime
This field tells the receiving hosts how long this router can serve as a default router. According to the router lifetime in the received RA messages, hosts determine whether the router sending RA messages can serve as the default router.
Retrans Timer
If the switch fails to receive a response message within the specified time after sending an NS message, the switch will retransmit the NS message.
Reachable Time
If the neighbor reachability detection shows that a neighbor is reachable, the switch considers the neighbor reachable within the specified reachable time. If the switch needs to send a packet to a neighbor after the specified reachable time expires, the switch will reconfirm whether the neighbor is reachable.
To allow sending of RA messages:
Step
Remarks
N/A
N/A
3.     Disable RA message suppression.
undo ipv6 nd ra halt
By default, RA messages are suppressed.
4.     Configure the maximum and minimum intervals for sending RA messages.
ipv6 nd ra interval max-interval-value min-interval-value
Optional.
By default, the maximum interval for sending RA messages is 600 seconds, and the minimum interval is 200 seconds.
The switch sends RA messages at random intervals between the maximum interval and the minimum interval.
The minimum interval should be less than or equal to 0.75 times the maximum interval.
To configure parameters related to RA messages:
Step
Remarks
N/A
2.     Configure the hop limit.
ipv6 nd hop-limit value
Optional.
64 by default.
3.     Enter interface view.
N/A
4.     Configure the prefix information in RA messages.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
Optional.
By default, no prefix information is configured for RA messages, and the IPv6 address of the interface sending RA messages is used as the prefix information with valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (7 days).
5.     Turn off the MTU option in RA messages.
ipv6 nd ra no-advlinkmtu
Optional.
By default, RA messages contain the MTU option.
6.     Set the M flag bit to 1.
Optional.
By default, the M flag bit is set to 0. Hosts acquire IPv6 addresses through stateless autoconfiguration.
7.     Set the O flag bit to 1.
ipv6 nd autoconfig other-flag
Optional.
By default, the O flag bit is set to 0. Hosts acquire other configuration information through stateless autoconfiguration.
8.     Configure the router lifetime in RA messages.
ipv6 nd ra router-lifetime value
Optional.
1800 seconds by default.
9.     Set the NS retransmission timer.
Optional.
By default, the local interface sends NS messages at 1000 millisecond intervals, and the value of the Retrans Timer field in RA messages sent by the local interface is 0.
10.     Set the reachable time.
ipv6 nd nud reachable-time value
Optional.
By default, the neighbor reachable time on the local interface is 30000 milliseconds, and the value of the Reachable Time field in the RA messages sent by the local interface is 0.
·     The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages, so that the router can be updated through an RA message before expiration.
·     The values of the NS retransmission timer and the reachable time configured for an interface are sent to hosts through RA messages. Furthermore, this interface sends NS messages at the interval of the NS retransmission timer and considers a neighbor reachable within the reachable time.
An interface sends an NS message for DAD after acquiring an IPv6 address. If the interface does not receive a response within a specific time (determined by the ipv6 nd ns retrans-timer command), it continues to send an NS message. If it still does not receive a response after the number of sent attempts reaches the threshold (specified with the ipv6 nd dad attempts command), the acquired address is considered usable.
To configure the attempts to send an NS message for DAD:
Step
Remarks
N/A
N/A
3.     Configure the number of attempts to send an NS message for DAD.
ipv6 nd dad attempts value
Optional.
1 by default. When the value argument is set to 0, DAD is disabled.
Configuration preparation
Complete the following task before you configure ND snooping:
Execute the acl ipv6 enable command in system view.
For more information about the command acl ipv6 enable, see ACL and QoS Configuration References.
Introduction
The ND snooping feature is used in Layer 2 switching networks. It creates ND snooping entries using DAD NS messages.
ND snooping entries are used to:
·     Cooperate with the ND detection function. For more information about ND detection, see Security Configuration Guide.
·     Cooperate with the IP Source Guard function. For more information about IP Source Guard, see Security Configuration Guide.
After you enable ND snooping on a VLAN of a switch, ND packets received by the interfaces of the VLAN are redirected to the CPU. The CPU uses the ND packets to create or update ND snooping entries comprising source IPv6 address, source MAC address, receiving VLAN, and receiving port information.
The following describes how an ND snooping entry is created, updated, and aged out.
1.     Create an ND snooping entry.
The switch only uses received DAD NS messages to create ND snooping entries.
2.     Update an ND snooping entry.
Upon receiving an ND packet, the switch searches the ND snooping table for an entry containing the source IPv6 address of the packet. If the entry was refreshed within one second, the switch does not update the entry. If the entry is not refreshed for more than one second, the switch matches the MAC address of the ND packet and the receiving port against that in the entry.
¡     If both of them match those in the entry, the device updates the aging time of the ND snooping entry.
¡     If neither of them matches the entry and the received packet is a DAD NS message, the message is ignored.
¡     If neither of them matches the entry and the received packet is not a DAD NS message, the switch performs active acknowledgement.
The active acknowledgement process is as follows:
¡     The switch checks the validity of the existing ND snooping entry. The switch sends out a DAD NS message including the IPv6 address of the ND snooping entry. If a corresponding NA message (whose source IPv6 address, source MAC address, receiving port, and source VLAN are consistent with those of the existing entry) is received, the device updates the aging time of the existing entry. If no corresponding NA message is received within one second after the DAD NS message is sent, the device starts to check the validity of the received ND packet.
¡     To check the validity of the received ND packet (packet A for example), the switch sends out a DAD NS message including the source IPv6 address of packet A. If a corresponding NA message (whose source IPv6 address, source MAC address, receiving port, and source VLAN are consistent with those of packet A) is received, the device updates the aging time of the entry. If no corresponding NA message is received within one second after the DAD NS message is sent, the device does not update the entry.
3.     Aging out an ND snooping entry.
An ND snooping entry is aged out after 25 minutes. If an ND snooping entry is not updated within 15 minutes, the switch performs active acknowledgement as follows:
¡     If a corresponding NA message is received (the source IPv6 address, source MAC address, receiving port, and source VLAN are consistent with those of the existing entry), the device updates the aging time of the existing entry.
¡     If no corresponding NA message is received within one second after the DAD NS message is sent out, the device removes the entry when the timer expires.
To configure ND snooping:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Enable ND snooping.
ipv6 nd snooping enable
4.     Return to system view.
N/A
5.     Enter Layer 2 Ethernet interface view/Layer 2 aggregate interface view.
N/A
6.     Configure the maximum number of ND snooping entries the interface can learn.
ipv6 nd snooping max-learning-num number
Optional.
By default, the number of ND snooping entries an interface can learn is unlimited.
Enabling ND proxy
ND proxy supports the NS and NA messages only.
About ND proxy
If a host sends an NS message requesting the hardware address of another host that is isolated from the sending host at Layer 2, the device in between must be able to forward the NS message to allow Layer 3 communication between the two hosts. This is achieved by ND proxy.
Depending on application scenarios, ND proxy includes common ND proxy and local ND proxy.
·     Common ND proxy
As shown in Figure 6, GigabitEthernet 3/0/1 with IPv6 address 4:1::99/64 and GigabitEthernet 3/0/2 with IPv6 address 4:2::99/64 belong to different subnets. Host A and Host B reside on the same network but in different broadcast domains.
Figure 6 Application environment of common ND proxy
Because Host A's IPv6 address is on the same subnet as Host B's, Host A directly sends an NS message to obtain Host B's MAC address. However, Host B cannot receive the NS message because they belong to different broadcast domains.
To solve this problem, enable common ND proxy on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 of the switch. The switch replies to the NS message from Host A, and forwards packets from other hosts to Host B.
·     Local ND proxy
As shown in Figure 7, VLAN 10 is a super VLAN whose sub VLANs are VLAN 2 and VLAN 3. Host A and Host B belong to VLAN 2 and VLAN 3 respectively, and they connect to GigabitEthernet 3/0/3 and GigabitEthernet 3/0/1 respectively, which are isolated at Layer 2.
Figure 7 Application environment of local ND proxy
Because Host A's IPv6 address is on the same subnet as Host B's, Host A directly sends an NS message to obtain Host B's MAC address. However, Host B cannot receive the NS message because they belong to different VLANs.
To solve this problem, enable local ND proxy on GigabitEthernet 3/0/2 of Switch A so that Switch A can forward messages between Host A and Host B.
Local ND proxy implements Layer 3 communication for two hosts in the following cases:
¡     The two hosts must connect to different isolated Layer 2 ports of a VLAN.
¡     If a super VLAN is used, the two hosts must belong to different sub VLANs.
You can enable common ND proxy and local ND proxy in VLAN interface view, Layer 3 Ethernet interface view, or Layer 3 Ethernet subinterface view.
To enable common ND proxy:
Step
Remarks
N/A
N/A
3.     Enable common ND proxy.
proxy-nd enable
To enable local ND proxy:
Step
Remarks
N/A
N/A
3.     Enable local ND proxy.
local-proxy-nd enable
IPv6 routers do not support packet fragmentation. After an IPv6 router receives an IPv6 packet, if the packet size is greater than the MTU of the forwarding interface, the router will discard the packet. Meanwhile, the router sends the MTU to the source host through an ICMPv6 packet — Packet Too Big message. The source host fragments the packet according to the MTU and resends it. To reduce the extra flow overhead resulting from packets being discarded, a proper interface MTU should be configured according to the actual networking environment.
To configure the interface MTU:
Step
Remarks
N/A
N/A
3.     Configure the interface MTU.
ipv6 mtu mtu-size
Optional.
By default, the MTU of IPv6 packets sent over an interface is 1500 bytes.
You can configure a static path MTU for a specific destination IPv6 address. When a source host sends a packet through an interface, it compares the interface MTU with the static path MTU of the specified destination IPv6 address. If the packet size is larger than the smaller one of the two values, the host fragments the packet according to the smaller value.
To configure a static path MTU for a specific IPv6 address:
Step
Remarks
N/A
2.     Configure a static path MTU for a specific IPv6 address.
ipv6 pathmtu [ vpn-instance vpn-instance-name ] ipv6-address [ value ]
By default, no static path MTU is configured.
After the path MTU from a source host to a destination host is dynamically determined (see "IPv6 path MTU discovery"), the source host sends subsequent packets to the destination host based on this MTU. After the aging time expires, the dynamic path MTU is removed and the source host re-determines a dynamic path MTU through the path MTU mechanism.
The aging time is invalid for a static path MTU.
To configure the aging time for dynamic path MTUs:
Step
Remarks
N/A
2.     Configure the aging time for dynamic path MTUs.
ipv6 pathmtu age age-time
Optional.
10 minutes by default.
The IPv6 TCP properties you can configure include:
·     synwait timer—When a SYN packet is sent, the synwait timer is triggered. If no response packet is received before the synwait timer expires, the IPv6 TCP connection establishment fails.
·     finwait timer—When the IPv6 TCP connection status is FIN_WAIT_2, the finwait timer is triggered. If no packet is received before the finwait timer expires, the IPv6 TCP connection is terminated. If a FIN packet is received, the IPv6 TCP connection status becomes TIME_WAIT. If non-FIN packets are received, the finwait timer is reset upon receipt of the last non-FIN packet and the connection is terminated after the finwait timer expires.
·     Size of the IPv6 TCP sending/receiving buffer.
To configure IPv6 TCP properties:
Step
Remarks
N/A
2.     Set the TCP timers.
·     Set the synwait timer:
tcp ipv6 timer syn-timeout wait-time
·     Set the finwait timer:
tcp ipv6 timer fin-timeout wait-time
Optional.
By default:
·     The synwait timer is 75 seconds.
·     The finwait timer is 675 seconds.
3.     Set the size of the IPv6 TCP sending/receiving buffer.
tcp ipv6 window size
Optional.
8 KB by default.
In the IPv6 FIB load sharing mode, the switch can decide how to select equal cost multi-paths (ECMP) to forward packets. The switch supports the following load sharing modes:
·     Load sharing based on the HASH algorithm—An algorithm based on the source IPv6 address and destination IPv6 address is adopted to select an ECMP route to forward packets.
·     Load sharing based on polling—Each ECMP route is used in turn to forward packets.
To configure the IPv6 FIB load sharing:
Step
Remarks
N/A
2.     Configure the IPv6 FIB load sharing mode.
·     Configure the load sharing based on the hash algorithm:
ipv6 fib-loadbalance-type hash-based
·     Configure the load sharing based on polling:
undo ipv6 fib-loadbalance-type hash-based
Optional.
By default, the load sharing based on polling is adopted, and each ECMP route is used in turn to forward packets.
If too many ICMPv6 error packets are sent within a short time in a network, network congestion might occur. To avoid network congestion, you can control the maximum number of ICMPv6 error packets sent within a specific time by adopting the token bucket algorithm.
You can set the capacity of a token bucket to determine the number of tokens in the bucket. In addition, you can set the update interval of the token bucket, the interval for restoring the configured capacity. One token allows one ICMPv6 error packet to be sent. Each time an ICMPv6 error packet is sent, the number of tokens in a token bucket decreases by one. If the number of ICMPv6 error packets successively sent exceeds the capacity of the token bucket, the additional ICMPv6 error packets cannot be sent out until the capacity of the token bucket is restored.
To configure the capacity and update interval of the token bucket:
Step
Remarks
N/A
2.     Configure the capacity and update interval of the token bucket.
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
Optional.
By default, the capacity of a token bucket is 10 and the update interval is 100 milliseconds. At most 10 ICMPv6 error packets can be sent within 100 milliseconds.
The update interval 0 indicates that the number of ICMPv6 error packets sent is not restricted.
If hosts are configured to answer multicast echo requests, an attacker might use this mechanism to attack a host. For example, if Host A (an attacker) sends an echo request with the source being Host B to a multicast address, all the hosts in the multicast group will send echo replies to Host B. To prevent such an attack, disable a device from replying multicast echo requests by default. In some application scenarios, however, you need to enable the device to reply multicast echo requests.
To enable replying to multicast echo requests:
Step
Remarks
N/A
2.     Enable replying to multicast echo requests.
A switch sends out an ICMPv6 Time Exceeded message in the following cases:
·     If a received IPv6 packet’s destination IP address is not a local address and its hop limit is 1, the switch sends an ICMPv6 Hop Limit Exceeded message to the source.
·     Upon receiving the first fragment of an IPv6 datagram with the destination IP address being the local address, the switch starts a timer. If the timer expires before all the fragments arrive, an ICMPv6 Fragment Reassembly Timeout message is sent to the source.
If large amounts of malicious packets are received, the performance of a switch degrades greatly because it has to send back ICMP Time Exceeded messages. You can disable sending ICMPv6 Time Exceeded messages.
To enable sending ICMPv6 time exceeded messages:
Step
Remarks
N/A
2.     Enable sending ICMPv6 Time Exceeded messages.
ipv6 hoplimit-expires enable
Optional.
Enabled by default.
If the device fails to forward a received IPv6 packet due to one of the following reasons, it drops the packet and sends a corresponding ICMPv6 Destination Unreachable error message to the source.
·     If no route is available for forwarding the packet, the device sends a "no route to destination" ICMPv6 error message to the source. This feature is available only on base cards.
·     If the device fails to resolve the corresponding link layer address of the destination IPv6 address, the device sends the source an "address unreachable" ICMPv6 error message.
·     If the packet with the destination being local and transport layer protocol being UDP and the packet’s destination port number does not match the running process, the device sends the source a "port unreachable" ICMPv6 error message.
If an attacker sends abnormal traffic that causes the device to generate ICMPv6 destination unreachable messages, end users might be affected. To prevent such attacks, you can disable the device from sending ICMPv6 destination unreachable messages.
To enable sending ICMPv6 destination unreachable messages:
Step
Remarks
N/A
2.     Enable sending ICMPv6 destination unreachable messages.
ipv6 unreachables enable
This feature does not apply to IPv6 packets that are received by base cards.
To enable a device to discard IPv6 packets that contain extension headers:
Step
Remarks
N/A
2.     Enable the device to discard IPv6 packets that contain extension headers.
ipv6 option drop enable
Required.
By default, the device does not discard IPv6 packets that contain extension headers.
Remarks
Display the IPv6 FIB entries.
display ipv6 fib [ vpn-instance vpn-instance-name ] [ acl6 acl6-number | ipv6-prefix ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display the IPv6 FIB entry of a specific destination IPv6 address.
display ipv6 fib [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ | { begin | exclude | include } regular-expression ]
Display IPv6 information about the interface.
display ipv6 interface [ interface-type [ interface-number ] ] [ brief ] [ | { begin | exclude | include } regular-expression ]
Display neighbor information (in standalone mode).
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display neighbor information (in IRF mode).
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display the total number of neighbor entries meeting the specified conditions (in standalone mode).
display ipv6 neighbors { { all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count [ | { begin | exclude | include } regular-expression ]
Display the total number of neighbor entries meeting the specified conditions (in IRF mode).
display ipv6 neighbors { { all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count [ | { begin | exclude | include } regular-expression ]
Display neighbor information for a specific VPN.
display ipv6 neighbors vpn-instance vpn-instance-name [ count ] [ | { begin | exclude | include } regular-expression ]
Display the IPv6 path MTU information.
display ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | all | dynamic | static } [ | { begin | exclude | include } regular-expression ]
Display socket information (in standalone mode).
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display socket information (in IRF mode).
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of IPv6 packets and ICMPv6 packets (in standalone mode).
display ipv6 statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of IPv6 packets and ICMPv6 packets (in IRF mode).
display ipv6 statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the IPv6 TCP connection statistics.
display tcp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
Display the IPv6 TCP connection status information.
display tcp ipv6 status [ | { begin | exclude | include } regular-expression ]
Display the IPv6 UDP connection statistics.
display udp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
Display ND snooping entries.
display ipv6 nd snooping [ ipv6-address | vlan vlan-id ] [ | { begin | exclude | include } regular-expression ]
Clear IPv6 neighbor information (in standalone mode).
Available in user view.
Clear IPv6 neighbor information (in IRF mode).
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | chassis chassis-number slot slot-number | static }
Clear the path MTU values.
reset ipv6 pathmtu { all | static | dynamic}
Clear the statistics of IPv6 and ICMPv6 packets (in standalone mode).
Clear the statistics of IPv6 and ICMPv6 packets (in IRF mode).
reset ipv6 statistics [ chassis chassis-number slot slot-number ]
Clear the statistics of all IPv6 TCP connection statistics.
reset tcp ipv6 statistics
Clear the statistics of all IPv6 UDP packets.
reset udp ipv6 statistics
Clear ND snooping entries.
reset ipv6 nd snooping [ ipv6-address | vlan vlan-id ]
IMPORTANT:
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure such an interface, bring the interface up by executing the undo shutdown command.
·     Host, Switch A, and Switch B are directly connected through Ethernet ports. Add the Ethernet ports into corresponding VLANs, configure IPv6 addresses for the VLAN interfaces and verify that they are connected.
·     The global unicast addresses of VLAN-interface 1 and VLAN-interface 2 on Switch A are 2001::1/64 and 3001::1/64 respectively.
·     The global unicast address of VLAN-interface 2 on Switch B is 3001::2/64, and a route to Host is available.
·     IPv6 is enabled for Host to automatically obtain an IPv6 address through IPv6 ND, and a route to Switch B is available.
Figure 8 Network diagram
The VLAN interfaces have been created on the switches.
1.     Configure Switch A:
# Enable IPv6.
[SwitchA] ipv6
# Specify a global unicast address for VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 3001::1/64
# Specify a global unicast address for VLAN-interface 1, and allow it to advertise RA messages (no interface advertises RA messages by default).
[SwitchA-Vlan-interface1] ipv6 address 2001::1/64
[SwitchA-Vlan-interface1] undo ipv6 nd ra halt
2.     Configure Switch B:
# Enable IPv6.
[SwitchB] ipv6
# Configure a global unicast address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ipv6 address 3001::2/64
# Configure an IPv6 static route with destination IP address 2001::/64 and next hop address 3001::1.
[SwitchB] ipv6 route-static 2001:: 64 3001::1
3.     Configure the host:
Enable IPv6 for the host to automatically obtain an IPv6 address through IPv6 ND.
# Use the command ping ipv6 on Switch A to check if the switch B is reachable.
[SwitchA] ping ipv6 3001::1
  PING 3001::1 : 56  data bytes, press CTRL_C to break
    Reply from 3001::1
    bytes=56 Sequence=0 hop limit=64  time = 3 ms
    Reply from 3001::1
    bytes=56 Sequence=1 hop limit=64  time = 2 ms
    Reply from 3001::1
    bytes=56 Sequence=2 hop limit=64  time = 2 ms
    Reply from 3001::1
    bytes=56 Sequence=3 hop limit=64  time = 3 ms
    Reply from 3001::1
    bytes=56 Sequence=4 hop limit=64  time = 9 ms
  --- 3001::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/3/9 ms
# Display neighbor information on GigabitEthernet 3/0/2 of Switch A.
[SwitchA] display ipv6 neighbors interface gigabitethernet 3/0/2
                Type: S-Static    D-Dynamic
IPv6 Address                  Link-layer      VID   Interface      State T Age
FE80::215:E9FF:FEA6:7D14      0015-e9a6-7d14  1     GE3/0/2         STALE D 1238
2001::15B:E0EA:3524:E791      0015-e9a6-7d14  1     GE3/0/2         STALE D 1248
The output shows that the IPv6 global unicast address that the host obtained is 2001::15B:E0EA:3524:E791.
# Display the IPv6 interface settings on Switch A. All IPv6 global unicast addresses configured on the interface are displayed.
[SwitchA] display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE00:2
  Global unicast address(es):
    3001::1, subnet is 3001::/64
  Joined group address(es):
    FF02::1:FF00:0
    FF02::1:FF00:1
    FF02::1:FF00:2
    FF02::2
    FF02::1
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                    25829
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    47
  OutRequests:                   89
  OutForwDatagrams:              48
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   6
  InMcastNotMembers:             25747
  OutMcastPkts:                  48
[SwitchA] display ipv6 interface vlan-interface 1
Vlan-interface1 current state :UP
    2001::1, subnet is 2001::/64
    FF02::1:FF00:0
    FF02::1:FF00:1
    FF02::1:FF00:1C0
    FF02::2
    FF02::1
  MTU is 1500 bytes
  InReceives:                    272
  InTooShorts:                   0
  InTruncatedPkts:               0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    159
  OutRequests:                   1012
  OutForwDatagrams:              35
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   79
  InMcastNotMembers:             65
  OutMcastPkts:                  938
# Display the IPv6 interface settings on Switch B. All IPv6 global unicast addresses configured on the interfaces are displayed.
[SwitchB] display ipv6 interface vlan-interface 2
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE00:1234
    3001::2, subnet is 3001::/64
    FF02::1:FF00:0
    FF02::1:FF00:2
    FF02::1:FF00:1234
    FF02::2
    FF02::1
  MTU is 1500 bytes
  InReceives:                    117
  InTooShorts:                   0
  InTruncatedPkts:               0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    117
  OutRequests:                   83
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   28
  InMcastNotMembers:             0
  OutMcastPkts:                  7
# Ping Switch A and Switch B on the host, and ping Switch A and the host on Switch B to verify whether they are connected.
When you ping a link-local address, you should use the –i parameter to specify an interface for the link-local address.
[SwitchB] ping ipv6 -c 1 3001::1
    Reply from 3001::1
    1 packet(s) transmitted
    1 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/2/2 ms
[SwitchB-Vlan-interface2] ping ipv6 -c 1 2001::15B:E0EA:3524:E791
  PING 2001::15B:E0EA:3524:E791 : 56  data bytes, press CTRL_C to break
    Reply from 2001::15B:E0EA:3524:E791
    bytes=56 Sequence=1 hop limit=63  time = 3 ms
  --- 2001::15B:E0EA:3524:E791 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
The output shows that Switch B can ping Switch A and the host.
Symptom
The peer IPv6 address cannot be pinged.
Solution
1.     Use the display current-configuration command in any view or the display this command in system view to verify that IPv6 is enabled. For more information about the display current-configuration command, see Fundamentals Configuration Guide.
2.     Use the display ipv6 interface command in any view to verify that the IPv6 address of the interface is correct and the interface is up.
