13-OAA Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10313-OAA Command Reference
Table of Contents
Related Documents
01-OAP Module Commands
01-OAP Module Commands 46.78 KB
OAP module configuration commands
oap connect
oap connect slot slot-number
View
Default level
2: System level
slot slot-number: Specifies the number of the slot where an OAP module resides.
Use the oap connect command to redirect from the device to the OAP module.
To return from the operating system on the OAP module to the command-line interface (CLI) on the router, press Ctrl+K.
# Redirect from the command line interface on the router to the operating system on the OAP module in slot 3.
<Sysname> oap connect slot 3
Press CTRL+K to quit.
Connected to OAP!
oap reboot
oap reboot slot slot-number
View
Default level
2: System level
Use the oap reboot command to reset the system on an OAP module.
# Reset the system on the OAP module in slot 3.
<Sysname> oap reboot slot 3
This command will recover the OAP from shutdown or other failed state.
Warning: This command may lose the data on the hard disk if the OAP is not being shut down!
Continue? [Y/N]:y
Reboot OAP by command.
