| 07-Smart Link Commands | 87.08 KB |
Smart Link configuration commands
display smart-link flush
display smart-link flush [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display smart-link flush command to display information about the received flush messages.
# Display information about the received flush messages.
<Sysname> display smart-link flush
Received flush packets : 10
Receiving interface of the last flush packet : GigabitEthernet4/0/1
Receiving time of the last flush packet : 19:19:03 2010/04/21
Device ID of the last flush packet : 000f-e200-8500
Control VLAN of the last flush packet : 1
Table 1 Output description
Received flush packets |
Total number of received flush messages |
Receiving interface of the last flush packet |
The port that received the last flush message |
Receiving time of the last flush packet |
Time when the last flush message was received |
Device ID of the last flush packet |
Switch ID carried in the last flush message |
Control VLAN of the last flush packet |
Control VLAN ID carried in the last flush message |
display smart-link group
display smart-link group { group-id | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: Smart link group ID, which ranges from 1 to 48.
all: Displays information about all smart link groups.
Use the display smart-link group command to display information about the specified or all smart link groups.
# Display information about smart link group 1.
<Sysname> display smart-link group 1
Smart link group 1 information:
Device ID: 000f-e200-8500
Preemption mode: ROLE
Preemption delay: 1(s)
Control VLAN: 1
Protected VLAN: Reference Instance 0 to 2, 4
Member Role State Flush-count Last-flush-time
GigabitEthernet3/0/3 MASTER ACTVIE 1 16:37:20 2010/04/21
GigabitEthernet3/0/6 SLAVE STANDBY 2 17:45:20 2010/04/21
Table 2 Output description
Smart link group 1 information |
Information about smart link group 1. |
Preemption mode |
Preemption mode, which can be role for preemption enabled or none for preemption disabled. |
Preemption delay |
Preemption delay time, in seconds. |
Control-VLAN |
Control VLAN ID. |
Protected VLAN |
Protected VLANs of the smart link group. Referenced Multiple Spanning Tree Instances (MSTIs) are displayed here. To view the VLANs mapped to the referenced MSTIs, use the display stp region-configuration command. |
Member |
Member of the smart link group. |
Role |
Port role: master or slave. |
State |
Port state: active, standby, or down. |
Flush-count |
Number of transmitted flush messages. |
Last-flush-time |
The time when the last flush message was transmitted (NA indicates that no flush message has been transmitted). |
flush enable
flush enable [ control-vlan vlan-id ]
undo flush enable
View
Smart link group view
Default level
2: System level
control-vlan vlan-id: Specifies the transmit control VLAN, which transmits flush messages. The vlan-id argument ranges from 1 to 4094. If no VLAN is specified, VLAN 1 applies by default.
Use the flush enable command to enable flush update.
Use the undo flush enable command to disable flush update.
By default, flush update is enabled for smart link groups and VLAN 1 is used for flush message transmission.
You must configure different control VLANs for different smart link groups.
Related commands: smart-link flush enable.
# Disable flush message sending in smart link group 1.
[Sysname] smart-link group 1
[Sysname-smlk-group1] undo flush enable
port
port interface-type interface-number { master | slave }
undo port interface-type interface-number
View
Default level
2: System level
interface-type interface-number: Specifies a port by its type and number.
master: Specifies a port as the master port.
slave: Specifies a port as the slave port.
Use the port command to assign the specified port as the master or slave port of the current smart link group.
Use the undo port command to remove the specified port from the smart link group.
Disable the spanning tree feature and RRPP on the ports you want to add to the smart link group, and make sure that the ports are not member ports of any aggregation group. On the other hand, you cannot enable the spanning tree feature or RRPP on a smart link group member port or assign a smart link group member port to an aggregation group.
You can assign a port to a smart link group by using the port smart-link group command in Ethernet interface view or aggregate interface view.
Related commands: port smart-link group.
# Configure GigabitEthernet 4/0/1 as the slave port of smart link group 1.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] undo stp enable
[Sysname-GigabitEthernet4/0/1] quit
[Sysname-smlk-group1] protected-vlan reference-instance 0
[Sysname-smlk-group1] port gigabitethernet 4/0/1 slave
port smart-link group group-id { master | slave }
undo port smart-link group group-id
View
Ethernet interface view, Layer 2 aggregate interface view
Default level
2: System level
master: Specifies the port as the master port.
slave: Specifies the port as the slave port.
Use the port smart-link group command to configure the current port as a member of the specified smart link group.
Use the port smart-link group command to remove the port from the specified smart link group.
You can assign a port to a smart link group using the port command in smart link group view.
Related commands: port.
# Configure GigabitEthernet 4/0/1 as the master port of smart link group 1.
[Sysname-smlk-group1] quit
[Sysname] interface gigabitethernet4/0/1
[Sysname-GigabitEthernet4/0/1] port smart-link group 1 master
# Configure Layer 2 aggregate interface 1 as the master port of smart link group 1.
[Sysname-Bridge-Aggregation1] undo stp enable
[Sysname-Bridge-Aggregation1] port smart-link group 1 master
preemption delay
preemption delay delay-time
undo preemption delay
View
Default level
2: System level
delay-time: Preemption delay (in seconds), which ranges from 0 to 300.
Use the preemption delay command to set the preemption delay. When role preemption is enabled, after the preemption delay is set, the master port waits for a specific period before taking over, so as to collaborate with the switchover of upstream switches.
Use the undo preemption delay command to restore the default.
By default, the preemption delay is one second.
The preemption delay configuration takes effect only after role preemption is enabled.
Related commands: preemption mode.
# Enable role preemption and set the preemption delay to 10 seconds.
[Sysname-smlk-group1] preemption mode role
[Sysname-smlk-group1] preemption delay 10
preemption mode
undo preemption mode
View
Default level
2: System level
role: Enables role preemption, which enables the master port to preempt the slave port in active state.
Use the preemption mode command to enable role preemption.
Use the undo preemption mode command to disable role preemption.
# Enable the role preemption mode.
protected-vlan
undo protected-vlan [ reference-instance instance-id-list ]
View
Default level
2: System level
reference-instance instance-id-list: Specifies the MSTIs you want to reference in the form of instance-id-list = { instance-id [ to instance-id ] }&<1-10>, where instance-id is an MSTI ID and ranges from 0 to 47. instance-id 0 represents the common internal spanning tree (CIST). &<1-10> indicates you can specify up to 10 MSTI IDs or ID ranges. You can use the display stp region-configuration command to display the instance-to-VLAN mappings.
Use the protected-vlan command to configure protected VLANs for a smart link group by referencing MSTIs. You can use the display stp region-configuration command to view the VLANs mapped to the referenced MSTIs.
Use the undo protected-vlan command to remove the specified protected VLANs from a smart link group by referencing the specified MSTIs. If no MSTI is specified, all the protected VLANs of the smart link group are removed.
By default, no protected VLAN is configured for a smart link group.
Before assigning ports to a smart link group, make sure that you have configured protected VLANs for the smart link group.
You can remove all protected VLANs from a smart link group only when the group is empty.
Removing a smart link group also removes its protected VLAN configuration.
If the VLANs mapped to a referenced MSTI changes, the protected VLANs change accordingly.
You must configure the VLANs that the member ports of a smart link group belong to as the protected VLANs of the smart link group.
Related commands: smart-link group; display stp region-configuration (Layer 2—LAN Switching Command Reference).
# Map VLANs 1 through 30 to MSTI 1, activate the MST region configuration, and configure the VLANs mapped to MSTI 1 as the protected VLANs of smart link group 1.
[Sysname-mst-region] instance 1 vlan 1 to 30
[Sysname-mst-region] quit
[Sysname-smlk-group1] protected-vlan reference-instance 1
reset smart-link statistics
View
Default level
2: System level
None
Use the reset smart-link statistics command to clear the statistics about flush messages.
# Clear the statistics about flush messages.
<Sysname> reset smart-link statistics
smart-link flush enable [ control-vlan vlan-id-list ]
undo smart-link flush enable [ control-vlan vlan-id-list ]
View
Default level
2: System level
control-vlan vlan-id-list: Specifies the receive control VLANs, which receive flush messages. The vlan-id-list is expressed in the form of vlan-id-list = { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument ranges from 1 to 4094, and &<1-10> indicates that you can provide up to ten VLAN IDs or VLAN ID ranges.
Use the smart-link flush enable command to configure the receive control VLANs, which receive flush messages, on a port in Ethernet interface view or on all ports in system view.
Use the undo smart-link flush enable command to disable flush message processing.
By default, flush messages are not processed.
If no VLAN is specified, VLAN 1 applies.
Do not use this command on the member port of an aggregation group.
Related commands: flush enable.
# Enable GigabitEthernet 4/0/1 to process the flush messages received in VLAN 1.
[Sysname-GigabitEthernet4/0/1] smart-link flush enable
# Enable Layer 2 aggregate interface 1 to process the flush messages received in VLAN 1.
[Sysname-Bridge-Aggregation1] smart-link flush enable
smart-link group
undo smart-link group group-id
View
Default level
2: System level
Use the smart-link group command to create a smart link group and enter smart link group view.
Use the undo smart-link group command to remove a smart link group.
You cannot remove a smart link group with member ports.
# Create smart link group 1, and enter smart link group view.
