| 04-DLDP Commands | 86.52 KB |
display dldp
display dldp [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Specifies a port by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display dldp command to display the DLDP configuration of a port.
If you do not provide the interface-type interface-number argument, this command displays the DLDP configuration of all the DLDP-enabled ports.
# Display the DLDP configuration of all the DLDP-enabled ports.
<Sysname> display dldp
DLDP global status : enable
DLDP interval : 5s
DLDP work-mode : normal
DLDP authentication-mode : none
DLDP unidirectional-shutdown : auto
DLDP delaydown-timer : 1s
The number of enabled ports is 1.
Interface GigabitEthernet3/0/1
DLDP port state : advertisement
DLDP link state : up
The neighbor number of the port is 1 (the maximum number ever detected is 2).
Neighbor mac address : 0000-0000-0100
Neighbor port index : 79
Neighbor state : two way
Neighbor aged time : 13
DLDP port state : disable
The neighbor number of the port is 0.
Table 1 Output description
DLDP global status |
Global DLDP state (enable or disable) |
DLDP interval |
Interval to send Advertisement packets (in seconds) |
DLDP work-mode |
DLDP mode (enhance or normal) |
DLDP authentication-mode |
DLDP authentication mode (none, simple, or md5) |
password |
Password for DLDP authentication |
DLDP unidirectional-shutdown |
Port shutdown mode (auto or manual) after unidirectional links are detected |
DLDP delaydown-timer |
Setting of the DelayDown timer |
The number of enabled ports |
Number of the DLDP-enabled ports |
Index of a DLDP-enabled port |
DLDP port state |
DLDP state on a port (initial, inactive, active, advertisement, probe, disable, or delaydown) |
DLDP link state |
Port state (up or down) |
The neighbor number of the port |
Number of the neighbors of a port |
the maximum number ever detected is 2 |
Maximum number of neighbors ever detected on the port (this field is displayed only when the number of current neighbors is different from the maximum number of neighbors ever detected) |
Neighbor mac address |
MAC address of a neighbor |
Neighbor port index |
Neighbor state |
Neighbor state (unknown, one way, or two way) |
Neighbor aged time |
Neighbor aging time |
display dldp statistics
display dldp statistics [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display dldp statistics command to display the statistics on the DLDP packets passing through a port.
If you do not provide the interface-type interface-number argument, this command displays the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Display the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> display dldp statistics
Packets sent : 142
Packets received : 142
Invalid packets received : 0
Loop packets received : 142
Authentication failed packets received : 0
Valid packets received : 0
Interface GigabitEthernet3/0/2
Packets sent : 0
Packets received : 0
Loop packets received : 0
Interface GigabitEthernet3/0/5
Packets sent : 0
Table 2 Output description
Port index |
Packets sent |
Total number of DLDP packets sent |
Packets received |
Total number of DLDP packets received |
Invalid packets received |
Number of the invalid packets received |
Loop packets received |
Number of the loopback packets received |
Authentication failed packets received |
Number of the received packets that failed to pass the authentication |
Valid packets received |
Number of the valid packets received |
dldp authentication-mode
dldp authentication-mode { md5 md5-password | none | simple simple-password }
undo dldp authentication-mode
View
Default level
2: System level
md5 md5-password: Specifies the switch to perform MD5 authentication and sets the password. The md5-password argument is the password, a string of 1 to 16 characters or a 24-bit string. The former indicates a plain text password and the latter indicates a cipher text password. This argument is case-sensitive.
none: Specifies the switch not to perform authentication.
simple simple-password: Specifies the switch to perform plain text authentication and sets the password. The simple-password argument is the password, a case-sensitive string of 1 to 16 characters.
Use the dldp authentication-mode command to configure DLDP authentication.
Use the undo dldp authentication-mode command to restore the default.
By default, DLDP authentication is not performed.
To enable DLDP to operate properly, make sure the DLDP authentication modes and the passwords of both sides of a link are the same.
# Configure to perform plain text authentication, setting the password as abc (assuming that Switch A and Switch B are connected by the DLDP link).
· Configure Switch A:
[SwitchA] dldp authentication-mode simple abc
· Configure Switch B:
[SwitchB] dldp authentication-mode simple abc
dldp delaydown-timer
dldp delaydown-timer time
undo dldp delaydown-timer
View
Default level
2: System level
Time: Setting of the DelayDown timer, which ranges from 1 to 5 seconds.
Use the dldp delaydown-timer command to set the DelayDown timer.
Use the undo dldp delaydown-timer command to restore the default.
By default, the setting of the DelayDown timer is 1 second.
The DelayDown timer setting applies to all the DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
dldp enable
dldp enable
undo dldp enable
View
System view, Ethernet interface view, port group view
Default level
2: System level
None
Use the dldp enable command to enable DLDP.
Use the undo dldp enable command to disable DLDP.
By default, DLDP is disabled both globally and on each port.
· When executed in system view, this command enables/disables DLDP globally.
· When executed in Ethernet interface view, this command enables/disables DLDP on the current port.
· When executed in port group view, this command enables/disables DLDP on all the ports in the port group.
DLDP takes effect on a port only when DLDP is enabled both globally and on the port.
# Enable DLDP globally and on GigabitEthernet 4/0/1.
[Sysname] dldp enable
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] dldp enable
# Enable DLDP globally and for all the ports in port group 1.
[Sysname] port-group manual 1
[Sysname-port-group-manual-1] group-member gigabitethernet 4/0/1 to gigabitethernet 4/0/3
[Sysname-port-group-manual-1] dldp enable
dldp interval
dldp interval time
undo dldp interval
View
Default level
2: System level
time: Interval to send Advertisement packets, which ranges from 1 to 100 seconds.
Use the dldp interval command to set the interval to send Advertisement packets.
Use the undo dldp interval command to restore the default.
By default, the interval to send Advertisement packets is 5 seconds.
This command applies to all DLDP-enabled ports.
# Set the interval to send Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
dldp reset
dldp reset
View
Default level
2: System level
None
Use the dldp reset command to reset DLDP state for ports in the DLDP down state to enable them to perform unidirectional link detection.
When executed in system view, this command applies to all the ports in the DLDP down state. When executed in Ethernet interface view, this command applies to the current port. When executed in port group view, this command applies to all the ports in the port group in the DLDP down state.
Related commands: dldp enable and dldp unidirectional-shutdown.
# Reset DLDP state for all the ports in the DLDP down state.
[Sysname] dldp reset
# Reset DLDP state for GigabitEthernet 4/0/1 (assuming that GigabitEthernet 4/0/1 is in the DLDP down state).
[Sysname-GigabitEthernet4/0/1] dldp reset
# Reset DLDP state for all the ports in port group 1 in the DLDP down state.
[Sysname-port-group-manual-1] dldp reset
dldp unidirectional-shutdown { auto | manual }
undo dldp unidirectional-shutdown
View
Default level
2: System level
auto: Configures the port shutdown mode as auto mode, where, when a unidirectional link is detected, the port involved is shut down by DLDP.
manual: Configures the port shutdown mode as manual mode, where, when a unidirectional link is detected, DLDP generates log and traps to prompt you to shut down the involved port instead of doing so automatically.
Use the dldp unidirectional-shutdown command to set the port shutdown mode.
Use the undo dldp unidirectional-shutdown command to restore the default.
By default, the port shutdown mode is the auto mode.
Related commands: dldp work-mode.
# Set the port shutdown mode as auto mode.
[Sysname] dldp unidirectional-shutdown auto
dldp work-mode
dldp work-mode { enhance | normal }
undo dldp work-mode
View
Default level
2: System level
enhance: Specifies the enhanced DLDP mode.
normal: Specifies the normal DLDP mode.
Use the dldp work-mode command to set the DLDP mode.
Use the undo dldp work-mode command to restore the default DLDP mode.
By default, the switch operates in normal DLDP mode.
# Configure the switch to operate in enhanced DLDP mode.
[Sysname] dldp work-mode enhance
reset dldp statistics
reset dldp statistics [ interface-type interface-number ]
View
Default level
1: Monitor level
Use the reset dldp statistics command to clear the statistics on DLDP packets passing through a port.
If you do not provide the interface-type interface-number argument, this command clears the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Clear the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> reset dldp statistics
