| 01-Active and Standby Switchover Commands | 73.38 KB |
NOTE: The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide. |
display switchover state
In standalone mode:
display switchover state [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display switchover state [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the backup state of a specified card, where slot-number represents the slot number of a card. If the slot-number argument is not specified, the backup state of the active main processing unit (MPU) is displayed. (In standalone mode)
chassis chassis-number slot slot-number: Displays the backup state of a specified card on a specified member switch of an Intelligent Resilient Framework (IRF) fabric. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. If the slot-number argument is not specified, the backup state of the active MPUs in the IRF fabric is displayed. (In IRF mode)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display switchover state command to display the backup state of the specified MPU.
# Display the backup state on the active MPU. (In standalone mode)
<Sysname> display switchover state slot 0
Master HA State to Slot [1]: Slave is absent
# Display the backup state on the active MPU of an IRF fabric. (In IRF mode)
Master HA State to Chassis 1 Slot 1: Realtime backup to slave.
Master HA State to Chassis 2 Slot 5: Realtime backup to slave.
Master HA State to Chassis 2 Slot 6: Slave is absent.
Master HA State to Slot 1 |
Backup state between the active MPU and the standby MPU, where 1 represents the number of the slot where the standby MPU resides (in standalone mode). |
Master HA State to Chassis 2 Slot 5 |
Backup state between the active MPU and an standby MPU of the IRF fabric, where 2 represents the member ID of the switch where the standby MPU resides, and 5 represents the number of the slot where the standby MPU resides (in IRF mode) |
Slave is absent |
The standby MPU is not in the slot. |
Waiting batch backup request from slave |
Waiting for the batch backup requests from the standby MPU. |
Batch backup |
Batch backup state. |
Realtime backup to slave |
Real-time backup state. |
Slave is smooth |
Data smoothing state. |
# Display the backup state on the standby MPU in slot 1. (In standalone mode)
<Sysname> display switchover state slot 1
Slave HA State: Receiving realtime data.
The output shows that the standby MPU is slot 1 is receiving real-time backup data.
# Display the backup state of the standby MPU of the IRF fabric. (In IRF mode)
<Sysname> display switchover state chassis 2 slot 5
The output shows that the standby MPU with the member ID 2 and slot number 5 is receiving real-time backup data.
Table 2 Output description
Slave HA State |
It indicates that the output information is generated by the standby MPU and it describes the switchover state of the standby MPU. |
Waiting |
The standby MPU is in the slot and waiting to enter batch backup state. |
ha slave-ignore-version-check
undo ha slave-ignore-version-check
View
Default level
2: System level
None
Use the ha slave-ignore-version-check command to ignore version check of the standby MPU, meaning not to check whether the version of the standby MPU is consistent with that of the active MPU.
Use the undo ha slave-ignore-version-check command to enable version check of the standby MPU.
By default, version check of the standby MPU is enabled.
Inconsistency of the software version of the active MPU and standby MPU may result in system failure when the system is running.
NOTE: When the switch operates in IRF mode, this command is not supported. To switch between the standalone mode and IRF mode, use the chassis convert mode irf command. |
# Ignore version check of the standby MPU.
[Sysname] ha slave-ignore-version-check
slave restart
slave restart
View
Default level
2: System level
None
Use the slave restart command to manually restart the standby MPU.
When the backup system program operates abnormally and needs to be reloaded, manually restart the standby MPU.
# Restart the standby MPU.
[Sysname] slave restart
The slave will reset! Continue?[Y/N]:y
slave switchover
slave switchover
View
Default level
2: System level
None
Use the slave switchover command to manually configure the switchover between the active MPU and standby MPU.
Related commands: slave switchover { disable | enable }.
NOTE: When the switch works in IRF mode, this command is not supported. To switch between the standalone mode and IRF mode, use the chassis convert mode irf command. |
# Manually configure the switchover between the active MPU and the standby MPU.
[Sysname] slave switchover
Caution!!! Confirm to switch slave to master?[Y/N] y
Starting.....
RAM Line....OK
View
Default level
2: System level
disable: Disables manual switchover between the active MPU and standby MPU.
enable: Enables manual switchover between the active MPU and standby MPU.
Use the slave switchover disable command to disable manual switchover function between the active MPU and standby MPU.
Use the slave switchover enable command to enable manual switchover function between the active MPU and standby MPU.
By default, manual configuration of the switchover between the active MPU and standby MPU is enabled.
Related commands: slave switchover.
# Enable manual switchover between the active MPU and standby MPU.
