| 03-CFD Commands | 222.76 KB |
cfd ais enable
cfd ais enable
undo cfd ais enable
View
Default level
2: System level
None
Use the cfd ais enable command to enable AIS.
Use the undo cfd ais enable command to disable AIS.
By default, AIS is disabled.
# Enable AIS.
[Sysname] cfd ais enable
cfd ais level
cfd ais level level-value service-instance instance-id
undo cfd ais level level-value service-instance instance-id
View
Default level
2: System level
level level-value: Specifies the AIS frame transmission level, which is in the range of 1 to 7.
service-instance instance-id: Specifies a service instance by its ID, which is in the range of 1 to 32767.
Use the cfd ais level command to configure the AIS frame transmission level in the specified service instance.
Use the undo cfd ais level command to restore the default.
By default, no AIS frame transmission level is configured for a service instance.
If no AIS frame transmission level is configured for a service instance, the MEPs in the service instance cannot send AIS frames.
Regardless of the value of the level-value argument, the undo cfd ais level command restores the AIS frame transmission level to an invalid value.
# Configure the AIS frame transmission level as 3 in service instance 1.
[Sysname] cfd ais level 3 service-instance 1
cfd ais period
cfd ais period period-value service-instance instance-id
undo cfd ais period period-value service-instance instance-id
View
Default level
2: System level
period period-value: Specifies the AIS frame transmission period, which is in the range of 1 to 60 seconds.
Use the cfd ais period command to configure the AIS frame transmission period in the specified service instance.
Use the undo cfd ais period command to restore the default.
By default, the AIS frame transmission period is 1 second in all service instances.
Regardless of the value of the period-value argument, the undo cfd ais period command restores the AIS frame transmission period to 1 second.
# Configure the AIS frame transmission period as 60 seconds in service instance 1.
[Sysname] cfd ais period 60 service-instance 1
cfd cc enable
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
View
Default level
2: System level
service-instance instance-id: Specifies the service instance ID, in the range of 1 to 32767.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191.
Use the cfd cc enable command to enable CCM sending on a specified MEP.
Use the undo cfd cc enable command to disable CCM sending on a specified MEP.
By default, the CCM sending function is disabled.
Related commands: cfd cc interval.
# On port GigabitEthernet 3/0/1, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface GigabitEthernet3/0/1
[Sysname-GigabitEthernet3/0/1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval service-instance instance-id
View
Default level
2: System level
interval interval-value: Specifies the value of the interval field in CCM messages. The interval-value argument is in the range of 2 to 7.
Use the cfd cc interval command to set the value of the interval field in the CCM messages.
Use the undo cfd cc interval command to restore default.
By default, the value of this field is 4 for all CCMs sent.
Interval field value in the CCM messages |
Interval for sending CCM messages |
Timeout time of remote MEP |
2 |
10 milliseconds |
35 milliseconds |
3 |
100 milliseconds |
350 milliseconds |
4 |
1 second |
3.5 seconds |
5 |
10 seconds |
35 seconds |
6 |
60 seconds |
210 seconds |
7 |
600 seconds |
2100 seconds |
NOTE: · Only the MPUs with silkscreen LSR1SRP2C1, LSR1SRP2C2, or LSR1SRP2D1 have assistant CPUs. · If the switch has two MPUs with assistant CPUs, the CCM frames will be sent by the active MPU. If the active MPU is unplugged, the standby MPU will take over to send CCM frames and CC will be re-performed. · If the switch has one MPU with an assistant CPU, the CCM frames will be sent by this MPU. · If the switch has no MPUs with assistant CPUs, the CCM frames will be sent by the card where the MEP is located. The card sends and receives only low-speed CCM messages, and discards high-speed CCM messages. |
Related commands: cfd cc enable.
# Set the value of the interval field in CCMs sent by MEPs in service instance 2 to 7.
[Sysname] cfd cc interval 7 service-instance 2
cfd enable
cfd enable
undo cfd enable
View
Default level
2: System level
None
Use the cfd enable command to enable CFD.
Use the undo cfd enable command to disable CFD.
By default, CFD is disabled.
[Sysname] cfd enable
cfd linktrace
cfd linktrace service-instance instance-id mep mep-id { target-mep target-mep-id | target-mac mac-address } [ ttl ttl-value ] [ hw-only ]
View
Default level
0: Visit level
mep mep-id: Specifies the ID of the source MEP, in the range of 1 to 8191.
target-map target-mep-id: Specifies the ID of the destination MEP, in the range of 1 to 8191.
target-mac mac-address: Specifies the destination MAC address, in the format of H-H-H.
ttl ttl-value: Specifies the time to live value, in the range of 1 to 255 and defaulting to 64.
hw-only: Sets the hw-only bits of the LTMs sent. When this keyword is specified and the MIP that receives LTMs cannot find the destination MAC address in its forwarding table, the MIP does not broadcast these LTM messages. Otherwise, the MIP broadcasts these LTM messages.
Use the cfd linktrace command to find the path between the source and target MEPs, which is achieved through the transmission of LTMs between the two and detection of the responding LTRs.
Related commands: cfd linktrace auto-detection.
NOTE: The output varies by CFD protocol version. |
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] cfd version standard
[Sysname] cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361
MAC Address TTL Last MAC Relay Action
0010-FC00-6512 63 0010-FC00-6500 Hit
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the IEEE 802.1ag draft 5.2 version of CFD is used.
[Sysname] cfd version draft5
Linktrace to MEP 2001 with the sequence number 1101-43361 :
MAC Address TTL Forwarded Relay Action
0010-FC00-6512 63 No None
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1 when the IEEE 802.1ag draft 5.2 interim version of CFD is used.
[Sysname] cfd version draft5-plus
Table 2 Output description
Linktrace to MEP 2001 with the sequence number 1101-43361 |
Linktrace to target MEP 2001 with the sequence number 1101-43361 |
MAC Address |
Source MAC address in the LTR messages |
TTL |
Hop count when the LTM passes the device |
Last MAC |
MAC address of the last-hop device the LTM passes |
Forwarded |
Indicates whether the device forwards LTMs: · Yes means that the current device forwards LTMs. · No means that the current device does not forward LTMs. |
Relay Action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—Indicates that the current device is the destination device. · FDB—Indicates that the forwarding device found the destination MAC address. · MPDB—Indicates that the destination MAC address is not found, or that the destination MAC address is found in the MEP or MIP database. When the IEEE 802.1ag draft5.2 version or the IEEE 802.1ag draft 5.2 interim version of CFD is used: · Found—Indicates that the forwarding device found the destination MAC address. · Unknown—Indicates that the forwarding device failed to find the destination MAC address. · None—Indicates that it is a MEP that responded to the LTM message. A MEP does not need to find the destination MAC address. |
cfd linktrace auto-detection [ size size-value ]
undo cfd linktrace auto-detection
View
Default level
2: System level
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of sending times).
This value defaults to 5, which means the buffer stores the results of the recent five auto-detections.
Use the cfd linktrace auto-detection command to enable the auto sending of linktrace messages.
Use the undo cfd linktrace auto-detection command to disable this function.
By default, this function is disabled.
After LT messages automatic sending is enabled, if the source MEP fails to receive the CCMs from the target MEP within 3.5 times the sending interval, the link between the two is regarded as faulty and LTMs will be sent out. (The destination of the LTMs is the target MEP, and the TTL field value is 255.) Based on the LTRs that echo back, the fault source can be located.
Once you disable LT messages automatic sending, the content stored in the buffer will be removed.
Related commands: cfd linktrace.
# Enable automatic LT messages sending, and specify the size of the buffer used to store the auto-detection result to 100 (in terms of sending times).
[Sysname] cfd linktrace auto-detection size 100
cfd loopback
cfd loopback service-instance instance-id mep mep-id { target-mep target-mep-id | target-mac mac-address } [ number number ]
View
Default level
0: Visit level
target-mep target-mep-id: Specifies the ID of the target MEP, in the range of 1 to 8191.
target-mac mac-address: Specifies the destination MAC address of the MP, in the format of H-H-H.
number number: Specifies the number of the LBMs packets sent, in the range of 1 to 10 and defaulting to 5.
Use the cfd loopback command to enable LB function so that LBMs can be sent from the source MEP to the target MP, and LBR messages can be received.
By default, LB is not enabled.
# Enable LB to check the status of the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to 0010-FC00-6512 with the sequence number start from 1101-43404:
Reply from 0010-FC00-6512: sequence number=1101-43404 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43405 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43406 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43407 time=5ms
Reply from 0010-FC00-6512: sequence number=1101-43408 time=5ms
Send:5 Received:5 Lost:0
# Enable LB to check the status of the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sequence number=1101-43404: Request timed out
Send:5 Received:0 Lost:5
Table 3 Output description
Loopback to 0010-FC00-6512 with the sequence number start from 1101-43404 |
Sends LBMs to 0010-FC00-6512 with the sequence number starting with 1101-43404. |
sequence number |
Sequence number in the LBR messages. |
time=5ms |
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds. |
Request timed out |
The request is timed out because no LBR is received within 5 milliseconds. |
Send |
Number of LBMs sent. |
Received |
Number of LBR messages received. |
Lost |
Number of lost LBRs. |
cfd ma
cfd ma ma-name md md-name vlan vlan-id
undo cfd ma ma-name md md-name
View
Default level
2: System level
ma ma-name: Specifies the name of the MA, which is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
md md-name: Specifies the name of an MD, a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
vlan vlan-id: Specifies the ID of the VLAN where MA is in service, in the range of 1 to 4094.
Use the cfd ma command to create MAs in an MD.
Use the undo cfd ma command to delete MAs in an MD.
By default, no MA is created.
Before creating an MA, you must create an MD first.
The total length of the MA and MD names should not exceed 44 characters.
When deleting an MA, you will also delete the configurations related to that MA.
Related commands: cfd md.
# Create an MA named test_ma in an MD named test_md, and configure the MA to serve VLAN 100.
[Sysname] cfd md test_md level 3
[Sysname] cfd ma test_ma md test_md vlan 100
cfd md
cfd md md-name level level-value
undo cfd md md-name
View
Default level
2: System level
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
level level-value: Specifies an MD level, in the range of 0 to 7.
Use the cfd md command to create an MD.
Use the undo cfd md command to delete an MD.
By default, no MD is created.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md, with its level being 3.
cfd mep
cfd mep mep-id service-instance instance-id { inbound | outbound }
undo cfd mep mep-id service-instance instance-id
View
Default level
2: System level
inbound: Creates an inward-facing MEP.
outbound: Creates an outward-facing MEP.
Use the cfd mep command to create a MEP on a port.
Use the undo cfd mep command to delete the specified MEP.
By default, no MEP exists on a port.
In creating a MEP, the service instance you specified defines the MD and MA that the MEP belongs to.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
Related commands: cfd meplist.
# Configure a MEP list in service instance 5, and create and enable inward-facing MEP 3 in service instance 5 on GigabitEthernet 3/0/1.
[Sysname] cfd service-instance 5 md test_md ma test_ma
[Sysname] cfd meplist 3 service-instance 5
[Sysname-GigabitEthernet3/0/1] cfd mep 3 service-instance 5 inbound
cfd mep enable
cfd mep service-instance instance-id mep mep-id enable
undo cfd mep service-instance instance-id mep mep-id enable
View
Default level
2: System level
Use the cfd mep enable command to enable the MEP configured on a port.
Use the undo cfd mep enable command to disable the MEP.
By default, MEP is disabled on a port and cannot respond to various CFD frames (such as LTM frames, LBM frames, 1DM frames, DMM frames, and TST frames) unless you enable it.
Related commands: cfd mep.
# Enable MEP 3 in service instance 5 on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] cfd mep service-instance 5 mep 3 enable
cfd meplist
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
View
Default level
2: System level
meplist mep-list: Specifies a list of MEP IDs, indicating multiple MEPs, in the format of mep-list = { mep-id [ to mep-id ] }&<1-10>, in which mep-id represents the MEP ID and is in the range of 1 to 8191. &<1-10> indicates you can specify up to 10 MEP ID ranges.
Use the cfd meplist command to create a MEP list, which is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Use the undo cfd meplist command to delete existing MEP lists.
By default, no MEP list is created.
Before creating a MEP list, create the relevant MD, MA, and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
Related commands: cfd ma, cfd md, and cfd service-instance.
# Create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd mip-rule
cfd mip-rule { explicit | default } service-instance instance-id
undo cfd mip-rule service-instance instance-id
View
Default level
2: System level
explicit: This rule means that if the lower level MA is not configured with MIPs, whether the current MA will create MIPs depends on whether the lower level MA is configured with MEPs.
default: This rule means that if the lower level MA is not configured with MIPs, the current MA will create MIPs.
Use the cfd mip-rule command to configure the rules for generating MIPs. MIPs are generated on each port automatically according to the rules configured.
Use the undo cfd mip-rule command to delete the rule for generating MIPs.
By default, no rules for generating MIPs are configured and no MIPs exist.
# Configure the MIP generation rule as default in service instance 5.
[Sysname] cfd mip-rule default service-instance 5
cfd service-instance instance-id md md-name ma ma-name
undo cfd service-instance instance-id
View
Default level
2: System level
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
ma ma-name: Specifies the name of an MA. The ma-name argument is a string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
Use the cfd service-instance command to create a service instance with the MD name.
Use the undo cfd service-instance command to delete a service instance.
By default, no service instance is created.
You must create the relevant MD and MA prior to creating a service instance with the MD name.
The service instance ID uniquely identifies an MA in an MD.
When deleting a service instance, you are deleting the configurations related to that service instance as well.
Deleting a service instance simply breaks up the connection between the service instance and the relevant MA, the MA itself is not deleted.
A service instance with the MD name takes effect in all versions of CFD.
Related commands: cfd md, cfd ma, and cfd version.
# Create a level-3 MD named test_md, create an MA named test_ma, which serves VLAN 100, in test_md, and then create service instance 5 with the MD name for test_md and test_ma.
cfd service-instance maid format
cfd service-instance instance-id maid format { icc-based ma-name | string ma-name } level level-value vlan vlan-id
Default level
2: System level
icc-based ma-name: MA name in the Y.1731 format. The ma-name argument is a string of 1 to 13 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
string ma-name: MA name in the IEEE 802.1ag format. The ma-name argument is a string of 1 to 45 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
level level-value: Specifies the MD level for the service instance, which is in the range of 0 to 7.
vlan vlan-id: Specifies the VLAN for the service instance. The vlan-id argument is in the range of 1 to 4094.
Use the cfd service-instance maid format command to create a service instance without the MD name.
Use the undo cfd service-instance command to remove the specified service instance.
When you create a service instance without the MD name, the system automatically creates the MA and MD for the service instance.
The service instance ID, MA name, and MD level uniquely identify a MA.
Deleting a service instance also deletes all configurations based on the service instance.
Deleting a service instance removes not only the service instance ID-MA association, but also the MA.
A MD with no MAs will be deleted.
A service instance without the MD name takes effect only in the IEEE 802.1ag standard version of CFD.
Related commands: cfd version.
# Create service instance 5 without the MD name in CFD IEEE 802.1ag, and configure the MA named test_ma1 in the Y.1731 format, MD level 3, and VLAN 100 for the service instance.
[Sysname] cfd service-instance 5 maid format icc-based test_ma1 level 3 vlan 100
# Create service instance 6 without the MD name in CFD IEEE 802.1ag, and configure the MA named test_ma2 in the IEEE 802.1ag format, MD level 4, and VLAN 200 for the service instance.
[Sysname] cfd service-instance 6 maid format string test_ma2 level 4 vlan 200
cfd tst
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
View
Default level
2: System level
mep mep-id: Specifies the source MEP by its ID, which is in the range of 1 to 8191.
target-mac mac-address: Specifies the target MEP by its MAC address, which is in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID, which is in the range of 1 to 8191.
number number: Specifies the number of TST frames sent. The number argument is in the range of 1 to 10, and defaults to 5.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The length argument is in the range of 4 to 1400 and defaults to 64.
pattern-of-test { all-zero | prbs } [ with-crc ]: Specifies the pattern of the Test TLV in the TST frame, which can be all-zero (all-zero value without CRC-32), prbs (pseudo random bit sequence without CRC-32), all-zero with-crc (all-zero value with CRC-32), and prbs with-crc (pseudo random bit sequence with CRC-32). The default mode is all-zero.
Use the cfd tst command to enable the TST function. The TST function detects the bit errors between two MEPs by sending TST frames from the source MEP to the target MEP.
By default, the TST function is disabled.
The TST function takes effect only in CFD IEEE 802.1ag.
To view the TST test result, use the display cfd tst command on the target MEP.
Related commands: cfd version and display cfd tst.
# Enable the TST function in CFD IEEE 802.1ag to test the bit errors between source MEP 1101 and destination MEP 1003 in service instance 1.
[Sysname] cfd tst service-instance 1 mep 1101 target-mep 1003
Info: TST process is done. Please check the result on the remote device.
Table 4 Output description
TST process is done |
The TST test has been performed |
cfd version
cfd version { draft5 | draft5-plus | standard }
undo cfd version
View
Default level
2: System level
draft5: Specifies that IEEE 802.1ag draft5.2 be used.
draft5-plus: Specifies that the IEEE 802.1ag draft5.2 interim version be used.
standard: Specifies that the standard version of IEEE 802.1ag be used.
Use the cfd version command to configure the CFD protocol version.
Use the undo cfd version command to restore the default.
By default, CFD uses the standard version of IEEE 802.1ag.
If an MD is created by using the cfd md command or automatically generated by using the cfd service-instance maid format command on a device, you cannot switch between the standard version and draft5.2 version (or draft5.2 interim version); however, you can switch between the draft5.2 version and draft5.2 interim version. This restriction does not apply to the device without an MD configured.
Related commands: cfd md and cfd service-instance maid format.
# Configure the CFD protocol version as IEEE 802.1ag draft5.2.
display cfd ais
display cfd ais [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies the MEP by its ID, which is in the range of 1 to 8191.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display cfd ais command to display the AIS configuration and information on the specified MEP.
If no MEP is specified, the display cfd ais command displays the AIS configuration and information of all MEPs in the specified service instance.
If no service instance is specified, the display cfd ais command displays the AIS configuration and information of all MEPs in all service instances.
Related commands: cfd ais enable, cfd ais level, and cfd ais period.
# Display the AIS configuration and information of all the MEPs in all service instances.
<Sysname> display cfd ais
Service instance: 5
AIS level: 4 AIS period: 1s
MEP ID: 1
AIS condition: yes Time to enter the condition: 2009/05/22 10:43:57
AIS state machine: Prestate: NO_RECEIVE
Curstate: RECEIVE
MEP ID: 2
Curstate: RECEIVE
Service instance: 20
AIS level: 3 AIS period: 60s
MEP ID: 10
Curstate: RECEIVE
Service instance: 100
AIS level: 6 AIS period: 1s
MEP ID: 20
AIS condition: no Time to enter the condition: 2009/05/22 11:40:01
AIS state machine: Prestate: IDLE
Curstate: NO_RECEIVE
Table 5 Output description
Service instance |
Service instance of the MEP |
AIS level |
AIS frame transmission level |
AIS period |
AIS frame transmission period |
AIS condition |
AIS status: · yes—AIS is running · no—AIS is not running |
Time to enter the condition |
The time when the AIS status began |
AIS state machine |
AIS packet receiving state machine |
Prestate |
Previous state: · IDLE—Not activated · NO_RECEIVE—Activated · RECEIVE—AIS frames are received |
Curstate |
Current state: · IDLE—Not activated · NO_RECEIVE—Activated · RECEIVE—AIS frames are received |
display cfd linktrace-reply
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd linktrace-reply command to display the LTR information received by a MEP.
If this command is used without specifying MEP, the information of LTRs of all MEPs in the current service instance is displayed.
If this command is used without specifying any service instance, the information of LTRs of all MEPs is displayed.
# Display the LTR information saved on all the MEPs in every service instance when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] display cfd linktrace-reply
Service instance: 1 MEP ID: 1003
0000-FC00-6505 63 0000-FC00-6504 MPDB
000F-E269-A852 62 0000-FC00-6505 FDB
0000-FC00-6508 61 000F-E269-A852 Hit
Service instance: 2 MEP ID: 1023
# Display the LTR information saved on all the MEPs in every service instance when the IEEE 802.1ag draft5.2 version of CFD is used.
00E0-FC27-6502 63 Yes Found
00E0-FC00-6510 62 Yes Found
00E0-FC52-BAA0 61 No None
00E0-FC27-6502 63 No None
# Display the LTR information saved on all the MEPs in every service instance when the IEEE 802.1ag draft5.2 interim version of CFD is used.
Table 6 Output description
Service instance |
Service instance to which the MEPs that send LTMs belong |
MEP ID |
ID of the MEP that sends LTMs |
MAC Address |
Source MAC address in the LTR message |
TTL |
Hop count when LTM passes the device |
Last MAC |
Forwarded |
Indicates whether the device forwards LTMs: · Yes means that the device has forwarded the LTMs. · No means that the device did not forward the LTMs. |
Relay Action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—Indicates that the current device is the destination device. · FDB—Indicates that the forwarding device found the destination MAC address. · MPDB—Indicates that the destination MAC address is not found, or that the destination MAC address is found in the MEP or MIP database. When the IEEE 802.1ag draft5.2 version or the IEEE 802.1ag draft5.2 interim version of CFD is used: · Found—Indicates that the forwarding device found the destination MAC address in its MAC address table. · Unknown—Indicates that the forwarding device failed to find the destination MAC address in its MAC address table. · None—Indicates that it is a MEP that responded to the LTM message. A MEP does not need to find the destination MAC address. |
display cfd linktrace-reply auto-detection
display cfd linktrace-reply auto-detection [ size size-value ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100.
Use the display cfd linktrace-reply auto-detection command to display the content of the LTR messages received as responses to the automatically sent LTMs.
These LTR messages received as responses to automatically sent LTMs are stored in the buffer after you executed the cfd linktrace auto-detection command.
With the size keyword not specified, this command displays the information of all LTRs stored in the buffer.
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the standard version (IEEE 802.1ag) of CFD is used.
[Sysname] display cfd linktrace-reply auto-detection
Service instance: 1 MEP ID: 1003 Time: 2006/05/22 10:43:57
Target MEP ID: 2005 TTL: 64
Service instance: 2 MEP ID: 1023 Time: 2006/05/22 10:44:06
Target MEP ID: 2025 TTL: 64
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the IEEE 802.1ag draft5.2 version of CFD is used.
# Display the contents of the LTRs received as responses to the LTMs automatically sent when the IEEE 802.1ag draft5.2 interim version of CFD is used.
Table 7 Output description
Service instance |
Service instance to which the MEPs that sent LTM messages belong. |
MEP ID |
ID of the MEP that sends LTMs. |
Time |
Time of the LTMs automatically sent. |
Target MEP ID |
ID of the target MEP. |
TTL |
Initial hop count of the automatically sent LTMs. |
MAC Address |
Source MAC address in the LTR messages. |
TTL |
Hop count when LTM passes the device. |
Last MAC |
MAC address of the last-hop device the LTM passes. |
Forwarded |
Relay Action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—Indicates that the current device is the destination device. · FDB—Indicates that the forwarding device found the destination MAC address. · MPDB—Indicates that the destination MAC address is not found, or that the destination MAC address is found in the MEP or MIP database. When the IEEE 802.1ag draft5.2 version or the IEEE 802.1ag draft5.2 interim version of CFD is used: · Found—Indicates that the forwarding device found the destination MAC address. · Unknown—Indicates that the forwarding device failed to find the destination MAC address. · None—Indicates that it is a MEP that responded to the LTM message. A MEP does not need to find the destination MAC address. |
display cfd ma
display cfd ma [ [ ma-name ] md { md-name | level level-value } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ma-name: Name of MA, a character string of 1 to 43 characters. IEEE 802.1ag standard version allows an MA name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MA name to contain letters, numbers, and special characters (including – and _), but do not allow an MA name to start or end with a special character.
md-name: Name of an MD, a character string of 1 to 43 characters. IEEE 802.1ag standard version allows an MD name to contain letters, numbers, and special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /). IEEE 802.1ag draft5.2 version and IEEE 802.1ag draft5.2 interim version allow an MD name to contain letters, numbers, and special characters (including – and _), but do not allow an MD name to start or end with a special character.
level level-value: MD level, which is in the range of 0 to 7.
Use the display cfd ma command to display the configuration of a specified MA.
If MD is not specified, this command will display the MA configurations of all MDs on the device.
If both MD and MA are specified, this command will display the specified MA configuration.
If only MD is specified, this command will display the configurations of all MAs in that MD.
If a MD does not have a name, you can specify it only by the MD level.
# Display the MA configuration information in all MDs.
<Sysname> display cfd ma
3 maintenance domain(s) configured.
Maintenance domain: mdtest_5
1 maintenance association(s) belong(s) to this maintenance domain:
Maintenance association: matest_5
Service instance: 5 VLAN: 5 Level: 5
Maintenance domain: mdtest_6
Maintenance association: matest_6
Service instance: 6 VLAN: 6 Level: 6
Maintenance domain: (Without Name)
Maintenance association: matest_7
Service instance: 7 VLAN: 7 Level: 7
Table 8 Output description
3 maintenance domain(s) configured. |
Number of MDs configured |
Maintenance domain |
Name of the MD (if the MD does not have a name, this field is displayed as Without Name) |
Level |
MD level |
1 maintenance association(s) belong(s) to this maintenance domain |
Number of MAs configured in the MD |
Maintenance association |
Name of the MA |
Service instance |
Service instance of the MA |
VLAN |
VLAN to which the service instance belongs |
Level |
Level of the MD to which the MA belongs |
display cfd md
display cfd md [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd md command to display the MD configuration information.
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
8 maintenance domain(s) configured:
Level: 0 Maintenance domain: mdtest_0
Level: 1 Maintenance domain: mdtest_1
Level: 2 Maintenance domain: mdtest_2
Level: 3 Maintenance domain: mdtest_3
Level: 4 Maintenance domain: mdtest_4
Level: 5 Maintenance domain: mdtest_5
Level: 6 Maintenance domain: mdtest_6
Level: 7 Maintenance domain: (Without Name)
Table 9 Output description
8 maintenance domain(s) configured |
Level |
Level of MD, each level allows only one MD. |
Name of MD (if the MD does not have a name, this field is displayed as Without Name) |
display cfd mep
display cfd mep mep-id service-instance instance-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies a MEP by its ID, in the range of 1 to 8191.
service-instance instance-id: Specifies a service instance by its ID, in the range of 1 to 32767.
Use the display cfd mep command to display the attribute and operating information of a MEP.
# Display the attribute and operating information of MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: GigabitEthernet3/0/2
Maintenance association: matest_1
Level: 1 VLAN: 1 Direction: Outbound
Administrative state: Active CCM send: Enable
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s SendCCM: 12018
Loopback:
NextSeqNumber: 8877
SendLBR: 0 ReceiveInOrderLBR: 0 ReceiveOutOrderLBR: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0 ReceiveLTM: 0
No CCM from some remote MEPs is received.
One or more streams of error CCMs is received. The last-received CCM:
Maintenance association:matest1
MEP:5 Sequence Number:0x50A
Received Time: 02/3/6 13:01:34
One or more streams of cross-connect CCMs is received. The last-received CCM:
Maintenance domain:mdtest1
MEP:6 Sequence Number:0x63A
Some other MEPs are transmitting the RDI bit.
Table 10 Output description
Interface that an MD belongs to. |
MD that a MEP belongs to (if the MD does not have a name, this field is displayed as Without Name). |
MA that a MEP belongs to. |
Level |
Level of the MD. |
VLAN |
VLAN that the MA belongs to. |
Direction |
Direction of the MEPs. |
Administrative state |
State of MEP, either Active or Inactive. |
CCM send |
Whether the MEP sends CCM. |
FNG state |
State of FNG (Fault Notification Generator): · FNG_RESET · FNG_DEFECT · FNG_REPORT_DEFECT · FNG_DEFECT_REPORTED · FNG_DEFECT_CLEARING If this field is not supported, a hyphen (-) is displayed. |
CCM |
Information related to CCM. |
Current state |
State of CCMs sent: · CCI_IDLE · CCI_WAITING If this field is not supported, a hyphen (-) is displayed. |
Interval |
Interval to send CCM. |
SendCCM |
Number of CCMs that have been sent by the MEPs. If this field is not supported, a hyphen (-) is displayed. |
Loopback |
Information related to Loopback. |
NextSeqNumber |
Sequence number of the next LBM to be sent. |
SendLBR |
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted. |
ReceiveInOrderLBR |
Number of LBR messages received in correct sequence. |
ReceiveOutOrderLBR |
Number of LBR messages received out of order. |
Linktrace |
Information related to linktrace |
NextSeqNumber |
Sequence number of the next LTM to be sent. |
SendLTR |
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted. |
ReceiveLTM |
Number of LTMs received. |
No CCM from some remote MEPs is received. |
Failure to receive CCMs from some remote MEPs (This information is displayed only when some CCMs are lost.) |
One or more streams of error CCMs is received. The last-received CCM: |
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCM(s) is/are received.) |
MD of the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
MA of the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
MEP |
ID of the MEP that sent the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
Sequence Number |
Sequence number of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Received Time |
Time when the last error CCM is received. |
One or more streams of cross-connect CCMs is received. The last-received CCM: |
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCM(s) is/are received.) |
Some other MEPs are transmitting the RDI bit. |
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCM(s) is/are received.) |
display cfd meplist
display cfd meplist [ service-instance instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd meplist command to display the MEP list in a service instance.
If the service instance ID is not specified, this command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
display cfd mp [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the MP information on a port specified by its port type and port number.
Use the display cfd mp command to display the MP information.
If no port is specified, this command displays the MP information on all ports.
The output is arranged by port name, then in the ascending VLAN ID order on the same port, and in the order of outward-facing MEPs (from low to high level), MIPs, and inward-facing MEPs (from high to low level) within the same VLAN.
# Display the MP information on all ports.
<Sysname> display cfd mp
Interface GigabitEthernet3/0/1 VLAN 100
MEP ID: 100 Level: 0 Service instance: 100 Direction: Outbound
Maintenance domain: mdtest0
Maintenance association: mainmd0
MEP ID: 105 Level: 5 Service instance: 105 Direction: Outbound
Maintenance domain: mdtest5
Maintenance association: mainmd5
MIP Level: 6 Service instance: 106
Maintenance domain: mdtest6
Maintenance association: mainmd6
MEP ID: 104 Level: 4 Service instance: 104 Direction: Inbound
Maintenance domain: mdtest4
Maintenance association: mainmd4
MEP ID: 102 Level: 2 Service instance: 102 Direction: Inbound
Maintenance domain: mdtest2
Maintenance association: mainmd2
Interface GigabitEthernet3/0/4 VLAN 1
MEP ID: 9 Level: 6 Service instance: 6 Direction: Outbound
Maintenance association: matest6
Table 11 Output description
Interface GigabitEthernet3/0/1 VLAN 100 |
MP configuration of the specified VLAN on the specified port |
MEP ID |
ID of the MEP |
MIP |
A MIP in the MP |
Level |
MD level that an MP belongs to |
Service instance |
Service instance to which the MP belongs |
Direction |
Direction of the MEP |
MD to which an MP belongs |
MA to which an MP belongs |
display cfd remote-mep
display cfd remote-mep service-instance instance-id mep mep-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mep mep-id: Specifies the ID of a remote MEP, in the range of 1 to 8191.
Use the display cfd remote-mep command to display the information of a remote MEP.
# Display the information of remote MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID MAC Address State Time MAC Status
20 00E0-FC00-6565 OK 2006/03/06 02:36:38 UP
30 00E0-FC27-6502 OK 2006/03/06 02:36:38 DOWN
40 00E0-FC00-6510 FAILED 2006/03/06 02:36:39 DOWN
50 00E0-FC52-BAA0 OK 2006/03/06 02:36:44 DOWN
60 0010-FC00-6502 OK 2006/03/06 02:36:42 DOWN
Table 12 Output description
MEP ID |
ID of the remote MED |
MAC Address |
MAC address of the remote MEP device. If this field is not supported, a hyphen (-) is displayed. |
State |
Running state of the remote MEP, which can be OK or FAILED |
Time |
Time when the remote MEP entered the FAILED or OK state for the last time. |
MAC Status |
State of the port indicated by the last CCM received from the remote MEP, which can be UP or DOWN. If this field is not supported, a hyphen (-) is displayed. |
display cfd service-instance
display cfd service-instance [ instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
instance-id: Service instance ID, in the range of 1 to 32767.
Use the display cfd service-instance command to display the configuration information of service instance.
Without specifying the service instance ID, the command will display the configuration information of all service instances.
# Display the configuration information of all service instances.
<Sysname> display cfd service-instance
2 service instance(s) configured:
Service instance 5:
Level: 5 VLAN: 5 MIP rule: None CCM interval: 1s
Service instance 6:
Level: 6 VLAN: 6 MIP rule: None CCM interval: 1s
MEP ID: 730 Interface: GigabitEthernet3/0/1 Direction: Inbound
Service instance 6:
MEP ID: 731 Interface: GigabitEthernet3/0/2 Direction: Outbound
Table 13 Output description
2 service instance(s) are configured. |
Number of service instance configured. |
Service instance 5 |
Service instance ID |
MD of the service instance (if the MD does not have a name, this field is displayed as Without Name) |
Maintenance association: |
MA of the service instances |
Level |
MD level |
VLAN |
VLAN that the MA belongs to |
MIP rule |
MIP generation rules configured on service instance |
CCM interval |
Interval to send CCMs |
MEP ID |
ID of MEPs configured on the service instance |
Interface of the MEP configured on the service instance |
Direction |
Direction of the MEPs configured on the service instance |
display cfd status
display cfd status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd status command to display the status of CFD and AIS (enabled or disabled).
# Display the status of CFD and AIS.
<Sysname> display cfd status
CFD is enabled.
display cfd tst
display cfd tst [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd tst command to display the TST result on the specified MEP.
If no MEP is specified, the display cfd tst command displays the TST results of all MEPs in the specified service instance.
If no service instance is specified, the display cfd tst command displays the TST results of all MEPs in all service instances.
Related commands: cfd tst.
# Display the TST results of all the MEPs in all service instances.
<Sysname> display cfd tst
Service instance: 1
MEP ID: 1003
Send TST total number: 0
Received TST total number: 5
Received from 0010-FC00-6510, sequence number 1: Bit True
Received from 0010-FC00-6510, sequence number 2: Bit True
Received from 0010-FC00-6510, sequence number 3: Bit True
Received from 0010-FC00-6510, sequence number 4: Bit True
Received from 0010-FC00-6510, sequence number 5: Bit True
MEP ID: 1004
Send TST total number: 5
Received TST total number: 0
Service instance: 2
No mep exists in the service instance.
Service instance: 3
MEP ID: 1023
Table 14 Output description
Service instance |
Send TST total number |
Number of TST frames sent |
Received TST total number |
Number of TST frames received |
Received from 0010-FC00-6510, sequence number 01 |
TST frame with sequence number 01 received from the MEP with MAC address 0010-FC00-6510: · Bit True—No bit error occurred · Bit False—Bit errors occurred |
display cfd version
display cfd version [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display cfd version command to display the CFD protocol version.
# Display the CFD protocol version.
<Sysname> display cfd version
The current CFD version is standard.
Table 15 Output description
The current CFD version is draft5 |
Indicates that the current CFD protocol is IEEE 802.1ag draft5.2 |
The current CFD version is draft5-plus |
Indicates that the current CFD protocol is the IEEE 802.1ag draft5.2 interim version |
The current CFD version is standard |
Indicates that the current CFD protocol is the standard version of IEEE 802.1ag |
reset cfd tst
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
View
Default level
1: Monitor level
Use the reset cfd tst command to clear the TST result on the specified MEP.
If no MEP is specified, the reset cfd tst command clear the TST results of all MEPs in the specified service instance.
If no service instance is specified, the reset cfd tst command clears the TST results of all MEPs in all service instances.
Related commands: display cfd tst.
# Clear the TST results of all the MEPs in all service instances.
<Sysname> reset cfd tst
