H3C S3600 Command Manual-Release 1602(V1.02)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Command Manual-Release 1602(V1.02)
13-MAC Address Table Management Command
13-MAC Address Table Management Command 51.06 KB
l          This chapter describes the management of static, dynamic, and blackhole MAC address entries. For information about the management of multicast MAC address entries, refer to the “Multicast Protocol” part of the manual.
l          The function of destination MAC address triggered update was introduced. For detailed description, refer to the description of the command mac-address aging destination-hit enable.
l          The function of assigning MAC addresses for Ethernet ports was introduced. For detailed description, refer to the description of the commands display port-mac and port-mac.
MAC Address Table Management Configuration Commands
display mac-address aging-time
View
None
Use the display mac-address aging-time command to display the aging time of the dynamic MAC address entries in the MAC address table.
Related commands: mac-address, mac-address timer, display mac-address.
# Display the aging time of the dynamic MAC address entries.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The output information indicates that the aging time of the dynamic MAC address entries is 300 seconds.
Mac address aging time: no-aging
The output information indicates that dynamic MAC address entries do not age out.
display mac-address
display mac-address [ display-option ]
View
display-option: Option used to display specific MAC address table information, as described in Table 1-1.
Table 1-1 Description on the display-option argument
Value
mac-address [ vlan vlan-id ]
Displays information about a specified MAC address entry.
{ static | dynamic | blackhole } [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Displays information about dynamic, static, or blackhole MAC address entries.
interface interface-type interface-number [ vlan vlan-id ] [ count ]
Displays information about the MAC address entries concerning a specified port.
vlan vlan-id [ count ]
Displays information about the MAC address entries concerning a specified VLAN.
count
Displays the total number of the MAC address entries maintained by the switch.
statistics
Displays statistics of the MAC address entries maintained by the switch.
mac-address: Specifies a MAC address, in the form of H-H-H.
static: Displays static MAC address entries.
dynamic: Displays dynamic MAC address entries.
blackhole: Displays blackhole MAC address entries.
interface-type interface-number: Specify a port by its interface type and number, of which the MAC address entries are displayed.
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094, in which the MAC address entries are displayed.
count: Displays only the total number of the MAC address entries.
statistics: Displays statistics of the MAC address entries maintained by the switch.
Use the display mac-address command to display information about MAC address entries in the MAC address table, including: MAC address, VLAN and port corresponding to the MAC address, the type (static or dynamic) of a MAC address entry, whether a MAC address is within the aging time and so on.
# Display information about MAC address 000f-e20f-0101.
<Sysname> display mac-address 000f-e20f-0101
MAC ADDR          VLAN ID   STATE          PORT INDEX       AGING TIME(s)
000f-e20f-0101    1         Learned        Ethernet1/0/1    AGING
# Display the MAC address entries for the port Ethernet 1/0/4.
<Sysname> display mac-address interface Ethernet 1/0/4
000d-88f6-44ba  1           Learned       Ethernet1/0/4           AGING
000d-88f7-9f7d  1       Learned       Ethernet1/0/4           AGING
000d-88f7-b094  1       Learned       Ethernet1/0/4           AGING
000f-e200-00cc  1       Learned       Ethernet1/0/4           AGING
000f-e200-2201  1       Learned       Ethernet1/0/4           AGING
000f-e207-f2e0  1       Learned       Ethernet1/0/4           AGING
000f-e209-ecf9  1       Learned       Ethernet1/0/4           AGING
---  7 mac address(es) found on port Ethernet1/0/4 ---
# Display the total number of MAC address entries for VLAN 2.
<Sysname> display mac-address vlan 2 count
9 mac address(es) found in vlan 2
Table 1-2 Description on the fields of the display mac-address command
MAC ADDR
MAC address
VLAN ID
ID of the VLAN to which the network device identified by the MAC address belongs
STATE
The state of the MAC address entry, which can be one of the following:
l      Config static: Indicates a manually configured static address entry.
l      Learned: Indicates a dynamically learnt address entry.
l      Config dynamic: Indicates a manually configured dynamic address entry.
l      Blackhole: Indicates a blackhole entry.
PORT INDEX
Outgoing port out of which the traffic destined for the MAC address should be sent.
AGING TIME(s)
Indicates whether the MAC address entry is aging. AGING indicates that the entry is aging; NOAGED indicates that the entry will never age out.
display port-mac
display port-mac
View
None
Use the display port-mac command to display the configured start port MAC address for the Ethernet ports on the switch, that is, the MAC address of Ethernet 1/0/1.
Related commands: port-mac.
# Display the start port MAC address.
<Sysname> display port-mac
Port MAC start address : 000f-e200-0001
mac-address
l          In system view:
mac-address { static | dynamic | blackhole } mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ mac-address-attribute ]
l          In Ethernet port view:
mac-address { static | dynamic | blackhole } mac-address vlan vlan-id
undo mac-address { static | dynamic | blackhole } mac-address vlan vlan-id
View
System view, Ethernet port view
static: Specifies a static MAC address entry.
dynamic: Specifies a dynamic MAC address entry.
blackhole: Specifies a blackhole MAC address entry.
mac-address: Specifies a MAC address, in the form of H-H-H. When entering the MAC address, you can omit the leading 0s in each segment. For example, you can input f-e2-1 for 000f-00e2-0001.
interface-type interface-number: Specifies the outgoing port by its type and number for the MAC address. All traffic destined for the MAC address will be sent out the port.
vlan-id: Specifies a VLAN ID, in the range of 1 to 4094. The VLAN must already exist.
mac-address-attribute: Specifies the criteria for removing MAC address entries. Available syntax options for the argument are described in Table 1-3.
Table 1-3 Available syntax options for the mac-address-attribute argument
{ static | dynamic | blackhole } interface interface-type interface-number
Removes the static, dynamic, or blackhole MAC address entries concerning a specified port.
{ static | dynamic | blackhole } vlan vlan-id
Removes the static, dynamic, or blackhole MAC address entries concerning a specified VLAN.
{ static | dynamic | blackhole } mac-address [ interface interface-type interface-number ] vlan vlan-id
Removes a specified static, dynamic, or blackhole MAC address entry.
Removes all the MAC address entries concerning a specified port.
vlan vlan-id
Removes all the MAC address entries concerning a specified VLAN.
Removes a specified MAC address entry.
Use the mac-address command to add or modify a MAC address entry.
Use the undo mac-address command to remove one or more MAC address entries.
In Ethernet port view, the MAC address entry configured with the mac-address command in Ethernet port view takes the current Ethernet port as the outgoing port.
If the MAC address you input in the mac-address command already exists in the MAC address table, the system will modify the attributes of the corresponding MAC address entry according to your settings in the command.
You can remove all unicast MAC address entries on a port, or remove a specific type of MAC address entries, such as the addresses learnt by the system, dynamic or static MAC address entries configured, or blackhole addresses.
# Configure a static MAC address entry with the following settings:
l          MAC address: 000f-e20f-0101
l          Outbound port: Ethernet 1/0/1 port
l          Ethernet 1/0/1 port belongs to VLAN 2.
[Sysname] mac-address static 000f-e20f-0101 interface Ethernet 1/0/1 vlan 2
undo mac-address aging destination-hit enable
View
None
Use the mac-address aging destination-hit enable command to enable the destination MAC address triggered update function.
Use the undo mac-address aging destination-hit enable command to disable the function.
With the destination MAC address triggered update function, the switch, when forwarding packets, updates the MAC address entries for the destination MAC addresses. This increases the MAC address table update frequency, improves the usability of the MAC address table, and reduces broadcasts.
By default, the destination MAC address triggered update function is disabled.
# Enable destination MAC address triggered update.
[Sysname] mac-address aging destination-hit enable
mac-address max-mac-count
undo mac-address max-mac-count
View
Ethernet port view
count: Maximum number of MAC addresses a port can learn. This argument ranges from 0 to 4096. A value of 0 disables the port from learning MAC addresses.
Use the mac-address max-mac-count command to set the maximum number of MAC addresses an Ethernet port can learn.
Use the undo mac-address max-mac-count command to cancel the limitation on the number of MAC addresses an Ethernet port can learn.
By default, the number of MAC addresses an Ethernet port can learn is unlimited.
When you use the mac-address max-mac-count command, the port stops learning MAC addresses after the number of MAC addresses it learned reaches the value of the count argument you provided. You can use the undo command to cancel this limit so that the port can learn MAC addresses without the number limitation. By default, no number limitation is set to the port for MAC address learning.
To prevent illegal devices from accessing the network through a port, you can configure static MAC addresses and disable MAC address learning for the port. Thus, only the packets destined for the configured MAC addresses can be forwarded out the port.
Related commands: mac-address, mac-address timer.
# Set the maximum number of MAC addresses Ethernet 1/0/3 port can learn to 600.
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] mac-address max-mac-count 600
mac-address timer
mac-address timer { aging age | no-aging }
undo mac-address timer aging
View
aging age: Specifies the aging time (in seconds) for dynamic MAC address entries. The age argument ranges from 10 to 1000000.
no-aging: Specifies not to age dynamic MAC address entries.
Use the mac-address timer command to set the MAC address aging timer.
Use the undo mac-address timer command to restore the default.
The default MAC address aging timer is 300 seconds.
The timer applies only to dynamic address entries, including both entries learnt and configured.
Setting an appropriate MAC address aging timer is important for the switch to run efficiently.
l          If the aging timer is set too short, the MAC address entries that are still valid may be removed. Upon receiving a packet destined for a MAC address that is already removed, the switch broadcasts the packet through all its ports in the VLAN which the packet belongs to. This decreases the operating performance of the switch.
l          If the aging timer is set too long, MAC address entries may still exist even if they turn invalid. This causes the switch to be unable to update its MAC address table in time. In this case, the MAC address table cannot reflect the position changes of network devices in time.
# Set the aging time of MAC address entries to 500 seconds.
port-mac
port-mac start-mac-address
undo port-mac
View
start-mac-address: Start MAC address for the Ethernet ports on the switch, in the format of H-H-H. It must be a valid unicast address.
Use the port-mac command to configure the start MAC address for the Ethernet ports on the device. This MAC address is assigned to port Ethernet 1/0/1, and is called the start port MAC address.
Use the undo port-mac command to remove the configuration.
# Set the start port MAC address to 000f-e200-0001.
[Sysname] port-mac 000f-e200-0001
