H3C S9500 Command Manual-Release1648[v1.24]-04 IP Multicast Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-04 IP Multicast Volume
02-IGMP Snooping Configuration Commands
02-IGMP Snooping Configuration Commands 91.89 KB
Chapter 1  IGMP Snooping Configuration Commands
&  Note:
The term "router" in this document refers to a router in a generic sense or a Layer 3 switch running an IP routing protocol.
1.1  IGMP Snooping Configuration Commands
1.1.1  debugging igmp-snooping
debugging igmp-snooping { abnormal | all | events | forward | groups | packets | timers }
undo debugging igmp-snooping { abnormal | all | events | forward | groups | packets | timers }
View
abnormal: Enables IGMP Snooping abnormal debugging
all: Turns on all IGMP Snooping debugging switches
events: Enables IGMP Snooping events debugging
forward: Enables IGMP Snooping forwarding debugging
groups: Enables IGMP Snooping multicast groups debugging
packets: Enables IGMP Snooping packets debugging
timers: Enables IGMP Snooping timers debugging
Use the debugging igmp-snooping command to enable IGMP Snooping debugging.
Use the undo debugging igmp-snooping to disable IGMP Snooping debugging.
By default, IGMP Snooping debugging is disabled.
# Enable IGMP Snooping timers debugging.
<H3C> debugging igmp-snooping timers
IGMP snooping timers debugging switch is on.
1.1.2  display igmp-snooping configuration
View
None
Use the display igmp-snooping configuration command to view the IGMP Snooping configuration information.
Related commands: igmp-snooping.
# Display the IGMP Snooping configuration information of the switch.
<H3C> display igmp-snooping configuration
Enable IGMP-Snooping.
The router port timeout  is 260 second(s).
The max response timeout is 1 second(s).
The host port timeout is 260 second(s).
Enable IGMP-Snooping Non-Flooding.
Table 1-1 display igmp-snooping configuration command output description
IGMP Snooping is enabled
Aging time of the router port
Maximum response time
Aging time of the multicast group member
IGMP Snooping non-flooding is enabled.
1.1.3  display igmp-snooping group
display igmp-snooping group [ vlan vlan-id [ group-address] ]
View
vlan vlan-id: Specifies the VLAN where the multicast group to be viewed is located. When the parameter is not provided, the command will display the information about all the multicast groups on the VLAN.
group-address: Address of the multicast group, the information of which is to be displayed. If this argument is not provided, the command displays information of all the multicast groups in the specified VLAN.
Use the display igmp-snooping group command to view the IP multicast group and MAC multicast group information of a VLAN or all the VLANs on the Ethernet switch.
# Display the multicast group information of VLAN 10.
<H3C> display igmp-snooping group vlan 10
  Total 1 IP Group(s).
  Total 1 MAC Group(s).
  Vlan(id):10.
    Router port(s):
    IP group(s):the following ip group(s) match to one mac group.
        IP group address:230.45.45.1
        Host port(s):Ethernet4/1/1
    MAC group(s):
        MAC group address:0100-5e2d-2d01
Table 1-2 display igmp-snooping group command output description
Vlan(id)
Specified VLAN ID
Router port(s)
Router port
IP group(s)
IP multicast group
IP group address
IP address of the IP multicast group
Host port(s)
Host port of the IP multicast group
MAC group(s)
MAC multicast group
MAC group address
MAC address of the MAC multicast group
Host port(s)
Host port of the MAC multicast group
1.1.4  display igmp-snooping statistics
View
None
Use the display igmp-snooping statistics command to view the statistics information on IGMP Snooping.
# Display statistics information about IGMP Snooping.
<H3C> display igmp-snooping statistics
Received IGMP general query packet(s) number:1.
Received IGMP specific query packet(s) number:2.
Received IGMP V1 report packet(s) number:2.
Received IGMP V2 report packet(s) number:0.
Received IGMP leave packet(s) number:3.
Received error IGMP packet(s) number:0.
Sent IGMP specific query packet(s) number:5.
Table 1-3 display igmp-snooping statistics command output description
Number of received IGMP general queries
Number of received IGMP group-specific queries
Number of received IGMPv1 reports
Number of received IGMPv2 reports
Number of received IGMP leave messages
Number of received error IGMP messages
Number of sent IGMP group-specific queries
1.1.5  igmp-snooping
igmp-snooping { enable | disable }
View
System view, VLAN view
enable: Enables IGMP Snooping.
disable: Disables IGMP Snooping;
Use the igmp-snooping enable command to enable IGMP Snooping globally or in a VLAN.
Use the igmp-snooping disable command to disable IGMP Snooping.
By default, the switch disables IGMP Snooping.
  Caution:
l      When configuring IGMP Snooping, first enable global IGMP Snooping in system view, and then enable IGMP Snooping in VLAN view. Otherwise the IGMP Snooping function will not take effect.
l      If the VLAN VPN is enabled on a port, the IGMP Snooping feature cannot be enabled on the VLAN for the port or the IGMP feature cannot be enabled on the corresponding VLAN interface.
l      If IGMP Snooping feature is enabled in a VLAN, or IGMP is enabled on the VLAN interface, you cannot add the member port on which VLAN VPN is enabled into the VLAN.
l      Isolate-user-VLAN supports the IGMP-Snooping function. After IGMP-Snooping is enabled under isolate-user-VLAN, all secondary VLANs are IGMP-Snooping enabled.
l      In a secondary VLAN, IGMP packets will be directly converted and processed in isolate-user-VLAN, namely all the multicast services are implemented within isolate-user-VLAN.
l      Ports in secondary VLANs cannot be used as source addresses of multicast.
l      If the undo igmp-snooping command is executed in system view, all IGMP Snooping configurations previously made are removed.
# Enable IGMP Snooping in system view.
<H3C> system-view
[H3C] igmp-snooping enable
# Enable IGMP Snooping on VLAN 10
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] igmp-snooping enable
1.1.6  igmp-snooping 10ge-non-flooding enable slot
igmp-snooping 10ge-non-flooding enable slot slot-num
undo igmp-snooping 10ge-non-flooding enable slot slot-num
View
slot-num: Slot number of the interface board.
Use the igmp-snooping 10ge-non-flooding enable slot command to suppress the ports on the specified interface board from flooding unknown multicast packets at Layer 2.
Use the undo igmp-snooping 10ge-non-flooding enable slot command to remove the configuration.
By default, a port floods unknown multicast traffic at Layer 2.
&  Note:
Currently, this command is not supported.
# Suppress the interface board at Slot 5 from flooding unknown multicast traffic at Layer 2.
<H3C> system-view
[H3C] igmp-snooping 10ge-non-flooding enable slot 5
1.1.7  igmp-snooping fast-leave
igmp-snooping fast-leave [ vlan { vlan-id [ to vlan-id ] }&<1-10> ]
undo igmp-snooping fast-leave [ vlan { vlan-id [ to vlan-id ] } &<1-10> ]
View
System view, Ethernet port view
vlan { vlan-id [ to vlan-id ] }&<1-10>: Specifies any VLAN or VLAN scope for port you want to enable/disable the IGMP Snooping fast leave feature on. The vlan-id argument ranges from 1 to 4094.
Use the igmp-snooping fast-leave command to enable IGMP Snooping fast leave.
Use the undo igmp-snooping fast-leave command to disable IGMP Snooping fast leave.
You can optionally specify multiple VLANs in the igmp-snooping fast-leave command, through which you can enable IGMP Snooping fast leave in the corresponding VLANs. If you do not specify any VLAN, IGMP Snooping fast leave is enabled in all VLANs.
&  Note:
l      Fast leaves that are configured in system view and Ethernet port view operate separately.
l      Fast leave works on all ports of the specified VLANs if you configure it in system view. However, it only works on the current port (e.g., a port operates as a trunk of multiple VLANs) in the specified VLANs if you configure it in Ethernet port view.
  Caution:
l      Fast leave configured for a port takes effect only when the VLAN it belongs to is IGMP Snooping-enabled.
l      Fast leave does not work if the corresponding specified VLANs do not exist, the port does not belongs to any of the specified VLANs, or the VLANs do not have IGMP Snooping enabled.
l      A newly configured IGMP Snooping clears all existing fast leave configurations.
l      The igmp-snooping fast-leave command is useless if you do not enable IGMP Snooping globally. (You can enable IGMP Snooping globally by executing the igmp-snooping enable command in system view.)
l      When you configure IGMP Snooping fast leave on aggregation ports, the configuration takes effect only on primary aggregation ports.
l      If you add an IGMP V1 host of the same multicast group to the port, the switch does not remove the port when the port receives an IGMP Leave packet of the multicast group even you enable IGMP Snooping fast leave for the port.
Fast leave is disabled by default.
# Enable IGMP Snooping fast leave on Ethernet2/1/1 for VLAN 5, VLAN 7, VLAN 8, VLAN 30 through VLAN 40, and VLAN 50.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] igmp-snooping fast-leave vlan 5 7 to 8 30 to 40 50
# Enable IGMP Snooping fast leave for all Ethernet ports except those in VLAN 5.
<H3C> system-view
[H3C] igmp-snooping fast-leave
[H3C] undo igmp-snooping fast-leave vlan 5
1.1.8  igmp-snooping group-policy
igmp-snooping group-policy acl-number
undo igmp-snooping group-policy
View
VLAN view
acl-number: Number of basic ACL, in the range of 2,000 to 2,999.
Use the igmp-snooping group-policy command to configure the filtering rule of multicast groups on a specified VLAN so as to control the access to IP multicast groups. You can configure only one ACL rule for each VLAN, and the new configured rule will replace the old one.
Use the undo igmp-snooping group-policy command to remove the configuration.
By default, no filtering rule is set in a VLAN. In this case, a host can join any multicast group.
If an ACL is configured in a VLAN to filter multicast groups, hosts can join only those multicast groups that are permitted to join.
# Create ACL2001 and configure the rule for basic ACL, using the source IP address as the destination multicast address.
<H3C> system-view
[H3C]acl number 2001
[H3C-acl-basic-2001]rule 0 permit source 224.1.1.1 0
[H3C-acl-basic-2001]quit
# Create VLAN 2.
<H3C> system-view
[H3C] vlan 2
# Configure the filtering rule of multicast groups in VLAN 2.
[H3C-vlan2] igmp-snooping group-policy 2001
1.1.9  igmp-snooping host-aging-time
igmp-snooping host-aging-time seconds
undo igmp-snooping host-aging-time
View
seconds: Port aging time for the multicast group member, ranging from 200 to 1000 seconds. By default, it is 260 seconds.
Use the igmp-snooping host-aging-time command to configure the port aging time of the multicast group members.
Use the undo igmp-snooping host-aging-time command to restore the default value.
This command is used to set the aging time of the multicast group member so that the refresh frequency can be controlled. When the group members change frequently, the aging time should be comparatively short, and vice versa.
# Set the aging time to 300 seconds.
<H3C> system-view
[H3C] igmp-snooping host-aging-time 300
1.1.10  igmp-snooping host-port vlan
igmp-snooping host-port vlan { all | vlan-id }
undo igmp-snooping host-port vlan { all | vlan-id }
View
Ethernet port view
all: Specifies all VLANs.
vlan-id: Specifies the ID of a VLAN in the range of 1 to 4094.
Use the igmp-snooping host-port vlan command to enable the host port function on the port.
Use the undo igmp-snooping host-port vlan command to disable the function on the port.
By default, the host port function is disabled.
# Enable the host port function on Ethernet 5/1/1 for all VLANs.
<H3C> system-view
[H3C] interface ethernet 5/1/1
[H3C-Ethernet5/1/1] igmp-snooping host-port vlan all
1.1.11  igmp-snooping max-response-time
igmp-snooping max-response-time seconds
undo igmp-snooping max-response-time
View
seconds: Maximum response time for a query, ranging from 1 to 25 seconds. By default, it is 1 second.
Use the igmp-snooping max-response-time command to configure the maximum response time for a query.
Use the undo igmp-snooping max-response-time command to restore the default value.
The set maximum response time decides the time limit for the switch to respond to IGMP Snooping query packets.
Related commands: igmp-snooping, igmp-snooping router-aging-time.
# Set the maximum response time for the IGMP Snooping packet to 15s.
<H3C> system-view
[H3C] igmp-snooping max-response-time 15
1.1.12  igmp-snooping nonflooding-enable
undo igmp-snooping nonflooding-enable
View
None
Use the igmp-snooping nonflooding-enable command to suppress flooding of unknown multicast data packets within their respective VLANs.
Use the undo igmp-snooping nonflooding-enable command to restore the default.
Note that if IGMP Snooping is not enabled on the VLAN (nor Layer 3 multicast), unknown multicast packets are flooded within their respective VLANs no matter whether this function is enabled or not. To suppress flooding of unknown multicast data packets within their respective VLANs, you need to enable IGMP Snooping in the VLANs and enable igmp-snooping nonflooding-enable globally.
By default, unknown multicast data packets are flooded within their respective VLANs.
# Enable the device to suppress flooding of unknown multicast packets within their respective VLANs.
<H3C> system-view
[H3C] igmp-snooping nonflooding-enable
1.1.13  igmp-snooping router-aging-time
igmp-snooping router-aging-time seconds
undo igmp-snooping router-aging-time
View
seconds: Router port aging time, ranging from 1 to 1000 measured in seconds; By default, it is 260.
Use the igmp-snooping router-aging-time command to configure the router port aging time of IGMP Snooping.
Use the undo igmp-snooping router-aging-time command to restore the default value.
The port here refers to the Ethernet switch port connected to the multicast router. The Layer-2 Ethernet switch receives general query packets from the router via this port. The timer should be set to about 3.5 times of the general query period of the router.
Related commands: igmp-snooping, igmp-snooping max-response-time.
# Set the aging time of the IGMP Snooping router port to 500 seconds.
<H3C> system-view
[H3C] igmp-snooping router-aging-time 500
1.1.14  reset igmp-snooping statistics
View
None
Use the reset igmp-snooping statistics command to reset the IGMP Snooping statistic information.
# Clear IGMP Snooping statistic information.
<H3C> reset igmp-snooping statistics
1.2  Multicast Static Routing Port Configuration Commands
1.2.1  multicast static-router-port
In VLAN view:
multicast static-router-port port-number
undo multicast static-router-port port-number
In Ethernet port view:
multicast static-router-port vlan vlan-id
undo multicast static-router-port vlan vlan-id
View
VLAN view, Ethernet port view
port-number: Port number of the port to be configured as a static routing port. Provide this argument in the format of interface-type interface-number, where the interface-type argument can only be Ethernet port type.
vlan-id: ID of the VLAN where the port belongs.
Use the multicast static-router-port command to configure a port in a VLAN as a static routing port, through which IGMP packets can be transparently transmitted, so as to meet the requirements of specific networks.
Use the undo multicast static-router-port command to remove static routing port configuration.
By default, no static routing port is configured.
# Configure GigabitEthernet 5/1/1 in VLAN 10 to be a static routing port.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] multicast static-router-port GigabitEthernet 5/1/1
1.3  IGMP Snooping Load Balancing Configuration Commands
1.3.1  display igmp-snooping configuration
View
None
Use the display igmp-snooping configuration command to view the configuration information related to IGMP Snooping.
# Display the IGMP Snooping configuration information.
The IGMP-Snooping Non-Flooding entry age time is 16:36:59.
Table 1-4 display igmp-snooping configuration command output description
IGMP Snooping is enabled.
Maximum response time in query messages
host port timeout
Aging time of member ports
Unknown-multicast flooding suppression is enabled.
Aging time of IGMP Snooping non-flooding entries
1.3.2  Igmp-snooping non-flooding entry-age-time
igmp-snooping non-flooding entry-age-time hh:mm:ss
undo igmp-snooping non-flooding entry-age-time
View
hh:mm:ss: Point of time at which IGMP Snooping non-flooding entries age out every day.
Use the igmp-snooping non-flooding entry-age-time command to configure the aging time of IGMP Snooping non-flooding entries.
Use the undo igmp-snooping non-flooding entry-age-time command to restore the default.
By default, the aging time is 3:00:00.
Related commands: display igmp-snooping configuration.
# Set the aging time of IGMP Snooping non-flooding entries to 16:36:59.
<H3C> system-view
[H3C] igmp-snooping non-flooding entry-age-time 16:36:59
1.4  IGMP Snooping Querier Configuration Commands
1.4.1  display igmp-snooping configuration vlan
display igmp-snooping configuration [ vlan vlan-id ]
View
vlan vlan-id: Displays the IGMP Snooping configuration information in the specified VLAN.
Use the display igmp-snooping configuration command to view IGMP Snooping configuration information.
# Display the global IGMP Snooping configuration information on the switch.
The IGMP-Snooping Non-Flooding entry age time is 03:00:00.
Enable IGMP-Snooping report-aggregation
The output information shows that IGMP Snooping is enabled; the aging time of router ports is 260 seconds; the max response time of group-specific query messages is 1 second; the aging time of member ports is 260 seconds; IGMP Snooping non-flooding is enabled; and IGMP report transparent transmission suppression is enabled.
# Display the IGMP Snooping configuration information in VLAN 66.
<H3C> display igmp-snooping configuration vlan 66
IGMP-snooping querier is enabled.
IGMP-snooping general query interval is 60 second(s).
IGMP-snooping max-response-time in general query is 10 second(s).
IGMP-snooping source address in general query is 0.0.0.0.
1.4.2  igmp-snooping general-query source-ip
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
View
VLAN view
current-interface: Configures the source IP address to be carried in the IGMP queries sent by the device to be the primary IP address of the current VLAN interface.
ip-address: Specified an IP address as the source IP address to be carried in the IGMP queries sent by the device.
Use the igmp-snooping general-query source-ip current-interface command to configure the querier to use the primary IP address of the current VLAN interface as the source IP address. If no VLAN interface is available or the VLAN interface has no primary IP address, 0.0.0.0 will be used.
Use the igmp-snooping general-query source-ip ip-address command to specify an IP address as the source IP address of IGMP queries..
Use the undo igmp-snooping general-query source-ip command to restore the source IP address of IGMP queries to the default.
By default, the source IP address is 0.0.0.0.
# Enable IGMP Snooping globally.
<H3C> system-view
Enable IGMP-Snooping ok.
# Create VLAN 2.
[H3C] vlan 2
# Enable IGMP Snooping in VLAN 2.
[H3C-vlan2] igmp-snooping enable
# Set the source IP address of IGMP queries to 100.100.100.100 in VLAN 2.
[H3C-vlan2] igmp-snooping general-query source-ip 100.100.100.100
1.4.3  igmp-snooping leave-aggregation
undo igmp-snooping leave-aggregation
View
None
Use the igmp-snooping leave-aggregation command to enable the function of suppressing transparent relaying of IGMP leave messages.
Use the undo igmp-snooping leave-aggregation command to disable the function of suppressing transparent relaying of IGMP leave messages.
By default, this function is disabled.
Before enabling the function of suppressing transparent relaying of IGMP leave messages, you must enable IGMP Snooping globally.
# Enable the function of suppressing transparent relaying of IGMP leave messages.
<H3C> system-view
[H3C] igmp-snooping leave-aggregation
1.4.4  igmp-snooping max-response-time
igmp-snooping max-response-time max-response-time
View
VLAN view
max-response-time: Maximum response time of query messages, ranging from 1 to 25, in seconds.
Use the igmp-snooping max-response-time command to configure the maximum response time of IGMP queries in the VLAN.
Use the undo igmp-snooping max-response-time command to restore the maximum response time of IGMP queries to the default value.
By default, the maximum response time of IGMP queries is 10 seconds.
<H3C> system-view
# Create VLAN 2.
[H3C] vlan 2
# Set the maximum response time of IGMP queries to 20 seconds in VLAN 2.
[H3C-vlan2] igmp-snooping max-response-time 20
1.4.5  igmp-snooping querier
undo igmp-snooping querier
View
VLAN view
None
Use the igmp-snooping querier command to enable the IGMP Snooping querier in the current VLAN.
Use the undo igmp-snooping querier command to disable the IGMP Snooping querier in the current VLAN.
By default, the IGMP Snooping querier is not enabled in a VLAN.
<H3C> system-view
# Create VLAN 2.
[H3C] vlan 2
# Enable the IGMP Snooping querier in VLAN 2.
[H3C-vlan2] igmp-snooping querier
1.4.6  igmp-snooping query-interval
igmp-snooping query-interval time-interval
undo igmp-snooping query-interval
View
VLAN view
time-interval: Interval between IGMP general queries, ranging from 1 to 300, in seconds.
Use the igmp-snooping query-interval command to configure the interval at which the IGMP Snooping querier sends queries in a VLAN.
Use the undo igmp-snooping query-interval command to restore the interval between IGMP general queries to the default value.
By default, the interval between IGMP general queries is 60 seconds.
<H3C> system-view
# Create VLAN 2.
[H3C] vlan 2
# Set the interval between IGMP general queries to 28 seconds in VLAN 2.
[H3C-vlan2] igmp-snooping query-interval 28
1.4.7  igmp-snooping report-aggregation
undo igmp-snooping report-aggregation
View
None
Use the igmp-snooping report-aggregation command to enable the function of suppressing transparent relaying of IGMP report messages.
Use the undo igmp-snooping report-aggregation command to disable the function of suppressing transparent relaying of IGMP report messages.
# Enable the function of suppressing transparent relaying of IGMP report messages globally.
<H3C> system-view
[H3C] igmp-snooping report-aggregation
1.5  Multicast Forwarding on Demand Configuration Commands
1.5.1  multicast forward according-to-need
undo multicast forward according-to-need
View
VLAN view
None
Use the multicast forward according-to-need command to enable the multicast forwarding on demand function in a VLAN.
Use the undo multicast forward according-to-need command to disable the multicast forwarding on demand function in a VLAN.
Note that:
l           Globally enable IGMP Snooping before configuring this function.
l           After configuring this function, you need to use the reset command to clear all IGMP and Layer 3 multicast group entries to bring the configuration into effect.
# Enable the multicast forwarding on demand function in VLAN 2.
<sysname> system-view
[sysname] igmp-snooping enable
[sysname] igmp-snooping non-flooding
[sysname] vlan 2
[sysname-vlan2] multicast forward according-to-need
