RPS1000-A3 User Manual(V1.04)
HomeSupportSwitchesH3C S3100 Switch SeriesInstall & UpgradePower Supply ManualsRPS1000-A3 User Manual(V1.04)
Table of Contents
Related Documents
01-Text
01-Text 824.51 KB
Packing List
Check the contents against the following packing list. In case of shortage or breakage of any of these items, contact your local dealer immediately.
Table 1  Packing list
Item
Quantity
RPS1000-A3
1
Output power cable (0404A053)
1
Output power cables (0404A054)
3
Output power cable (0404A055)
1
Front mounting ears
2
Front mounting ear screws
4
Rear mounting ears
2
Rear mounting ear weight-bearing screws
2
Foot pads
5
Quality certificate
1
Spare fuses 10A/DC125V
6
Grounding cable
1
Screwdriver (for removing the power modules)
1
User manual
1
Product Overview
2.1  Introduction
The RPS1000-A3 is an external power supply unit that uses AC inputs and provides eight lines of DC output, with a maximum output power of 2900 W. It can provide DC power supply simultaneously for multiple powered devices (such as switches and routers). The RPS1000-A3 can serve as:
l       A heavy-duty external PoE power supply unit
l       A redundant backup power supply unit for the powered devices
When serving as a redundant backup power supply unit, the RPS1000-A3 has the following functions:
l       If using the same AC power source with the powered device, when the internal power supply system of the powered device fails, the RPS1000-A3 can provide DC supply to the powered device, thus ensuring uninterrupted operation of the powered device;
l       If using the different AC power source from the powered device, when the AC power source to the powered device fails, the RPS1000-A3 can provide DC supply to the powered device, thus ensuring uninterrupted operation of the powered device.
Note:
The RPS1000-A3 supports hot backup of power supply. Namely, when the power supply system of the powered device operates normally, the RPS1000-A3 also provides part of the power supply to the device; when the power supply system of the powered device fails, the RPS1000-A3 becomes an independent power supply system.
2.2  Front Panel
(1) Power module slot 1 (default)
(2) Power module slot 2 (optional)
Figure 1  Front panel of the RPS1000-A3
The RPS1000-A3 has two power module slots, allowing two Flatpack 1500 power modules to work in parallel, one of which is provided as the default feature and the other is optional. For details about the Flatpack 1500, refer to section 2.5  Flatpack 1500 Power Module on page 8.
2.3  Rear Panel
(1) AC input for power module 2
(2) AC input for power module 1
(3) 25-A output reset buttons
(4) DC 25-A outputs
(5) DC 8-A outputs
(6) Grounding screw
(7) Fuses for the 8-A outputs
Figure 2  Rear panel of the RPS1000-A3
Note:
l      Each of the two AC inputs is for one power module;
l      One reset button is provided for each of the two 25-A outputs. The left reset button controls the left 25-A output, while the right reset button controls the right 25-A output. For the usage of the reset buttons, refer to Table 3  on page 6;
l      One replaceable fuse is provided for each 8-A output immediately below it. For the usage of the six fuses, refer to Table 3  on page 6 and 3.5   Replacing Fuses on page 26.
2.4  Technical Specifications and Performance
Table 2  Technical specifications of the RPS1000-A3
Item
Specifications
Dimensions (H × W × D)
44.45 × 440 × 393 mm (1.75 × 17.32 × 15.47 in.)
Weight
< 8 kg (< 17.64 lb.)
Power module slots
2 slots for Flatpack 1500 power modules
AC inputs
2 AC inputs:
100 to 240 VAC, 47 to 63 Hz
DC outputs
l    2 DC outputs: –54 V/ 25 A
l    6 DC outputs: –54 V/8 A
Maximum output power
l    With one power module: 1450 W
l    With two power modules: 2900 W
(For details, refer to section 2.6.1  Output Power Distribution on page 10)
Operating temperature
–5 to +45 (+23 to +113)
Operating relative humidity
5% to 90% (non-condensing)
Note:
The design of this product complies with environmental protection requirements. Be sure to observe the relevant local laws and regulations when storing, using or disposing of this product.
The RPS1000-A3 supports a variety of protection features, as shown in Table 3  on page 6.
Table 3  Protection features of the RPS1000-A3
Item
Input over-voltage protection
When the input voltage exceeds 312 ± 5 VAC, the unit comes into an over-voltage protection shutdown and generates an alarm.
When the input voltage comes down to 310 ± 5 VAC, the unit automatically recovers and clears the alarm.
Input under-voltage protection
When the input voltage comes down to 85 ± 5 VAC, the unit comes into an under-voltage protection shutdown and generates an alarm.
When the input voltage rises to 89 ± 5 VAC, the unit automatically recovers and clears the alarm.
Output over-voltage protection
When the output voltage exceeds –59.5 VDC, the power module comes into an over-voltage protection shutdown and generates an alarm.
To clear the alarm, remove the fault, and then pull out the power module and insert it again or turn off the AC input and turn it on again.
Output over-current protection
When the output current of a Flatpack 1500 power module exceeds 26 A, the power module comes into an over-current protection shutdown and generates an alarm.
When the over-current condition is eliminated, the power module automatically recovers and clears the alarm.
Per-output over-current protection and short-circuit protection
A protection action of one output does not affect any other.
l    For a 25-A output, press the reset button to clear the condition;
l    For an 8-A output, check the corresponding fuse, and replace the fuse if it was blown to clear the condition.
High-temperature protection
At temperatures higher than 70 (158), the unit operates with reduced output power.
At temperatures higher than 90 (194), the unit comes into a high-temperature protection shutdown and generates an alarm.
When the temperature comes down to 90 (194), the unit automatically recovers and clears the alarm.
The Flatpack 1500 is a hot-swappable internal AC-DC power module for standalone use or for working in parallel. When working in parallel, the Flatpack 1500 power modules automatically share the current in the power supply system.
Each Flatpack 1500 delivers a maximum of 1450 W output power.
2.5.1  Front Panel of the Flatpack 1500
(1) Output current LEDs
(2) Alarm LED
(3) No-faults LED
Figure 3  Front panel of the Flatpack 1500
2.5.2  LEDs Description
Table 4  Flatpack 1500 LEDs description
LEDs
Mark on panel
Status
Meaning
Output current LEDs
0 current 100%
Green LED bargraph
Output current indication: 0 to 30 A
The higher output current, the more LEDs on.
Alarm LED
alarm
Red LED on
Power module failure
No-faults LED
on
Green LED on
No faults
Caution:
When the alarm LED lights up, check for AC mains failure, output over-voltage condition, input over-voltage condition, input under-voltage condition, output over-current condition or high-temperature condition. For more information, refer to Table 3  on page 6.
2.6  Output Specifications
Table 5  Output power distribution
Number of modules
Input voltage
Max. output power per 8-A output
Max. output power per 25-A output
Total max. output power of 8 outputs
1
220 VAC
440 W
1375 W
1450 W
110 VAC
440 W
600 W
600 W
2
220 VAC
440 W
1375 W
2900 W
110 VAC
440 W
1200 W
1200 W
Caution:
The RPS1000-A3 can provide power supply to multiple devices at the same time. Use one or two power modules depending on the power consumption of the powered devices. Make sure that:
l      The system power consumption of each powered device does not exceed the maximum output power of the corresponding DC output;
l      The total power consumption contributed by all the powered devices does not exceed the total maximum output power of the RPS1000-A3.
2.6.2  DC Output Cables
Table 6  RPS1000-A3 DC output cables
DC cable number
Powered device type
Power output port type
Max. current of power output port
0404A053
PoE
A-direction/ B-direction: JD5
25A
0404A054
Non-PoE
A-direction/ B-direction: JD5-A
8A
0404A055
A-direction: JD5-A
B-direction: JD5
8A
Note:
l    An A-direction plug connects with the DC power supply receptacle of a powered device, while a B-direction plug connects with a DC output of the RPS1000-A3.
l      A JD5-A and a JD5 look alike except that a JD5 is a little bigger.
Installation
3.1  Precautions
To avoid any device impairment or bodily injury because of improper use, follow the precautions listed below.
l       Do not place the RPS unit on an unstable case or tabletop, and ensure that the cabinet and the workbench are firm enough to support the RPS unit and its accessories.
l       Make sure that the ventilation and heat dissipation systems of the cabinet and the table-top are good. Make sure that enough room is left around the air intake and outlet of the RPS unit to allow good heat dissipation. Never block the air intake and outlet of the RPS unit.
l       Keep the RPS unit away from any heavy-duty radio transmitter, radar transmitter, and high-frequency devices working in high current. Take electromagnetic shielding measures if necessary.
l       Make sure that the operating voltage of the power source matches the voltage required by the device.
l       Interface cables must be routed indoors. Otherwise, over-voltage and over-current may damage the device. As for power cables from the outside of the building, you may add a dedicated lightening arrester at the input end of the cable.
l       To enhance lightening protection, you may need to add a power lightening arrester at the input end.
l       Wear an ESD-preventive wrist strap when installing the RPS unit, and make sure that the wrist strap has good skin contact.
l       To avoid electric shock, NEVER open the chassis of the RPS unit while it is in operation; try not to open the RPS unit even if it is not electrified.
l       Unplug the power cord before cleaning the RPS unit.
l       Keep the equipment room clean. The limits on the concentrations of dust and harmful gases in the equipment room are shown in the following tables:
Table 7  Limit on dust concentration
Mechanical active material
Limit (particles/m³)
Dust particles
≤ 3 × 104 (No visible dust on tabletop over three days)
Note: Dust particle size ≥ 5µm
Table 8  Limits on harmful gas concentration
Gas
Limit (mg/m3)
SO2
0.2
H2S
0.006
NH3
0.05
Cl2
0.01
3.2  Installing the RPS Unit
The RPS1000-A3 can be installed either in a 19-inch standard rack or directly on a tabletop.
3.2.1  Installing the RPS Unit to a 19-inch Rack
Caution:
The front mounting ears are used only for fixing the RPS unit to the rack; they cannot bear the weight of the RPS unit. When installing the RPS1000-A3 to a 19-inch rack, be sure to use a supporting tray or rear mounting ears to support the weight of the unit.
I. Installing the unit using front and rear mounting ears and a supporting tray
Step 1: Put on an ESD-preventive wrist strap and check the grounding and stableness of the rack.
Step 2: Take out the supplied front ear screws and attach the front ears to the front end of the RPS unit using the screws, as shown in Figure 4 .
Step 3: Take out the supplied rear ear weight bearing screws and install them into the appropriate screw holes at both side of the RPS unit, as shown in Figure 4 .
Figure 4  Attach the front mounting ears and weight-bearing screws to the RPS unit
Step 4: In accordance with the RPS unit installation position in the rack, fix the rear mounting rears to the rear square-holed brackets of the rack using M6 screws and cage nuts (user supplied), as shown in Figure 5 .
Step 5: With one hand supporting the bottom and the other hand holding the front end of the RPS unit, gently push the RPS unit into the rack, as shown in Figure 5 .
Figure 5  Install the rear mounting ears
After pushing the RPS unit into the rack, make sure of the close contact between the upper edges of the rear mounting ears on the rack and the weight-bearing screws on the RPS unit, as shown in Figure 6 .
Figure 6  Install the RPS unit to the rack using front and rear mounting ears (1)
Step 6: Fix the front mounting ears to the front square-holed brackets of the rack using M6 screws and cage nuts (user supplied), and make sure that the RPS unit is securely fixed with the front and rear mounting ears on the rack, as shown in Figure 7 .
Figure 7  Install the RPS unit to the rack using front and rear mounting ears (2)
II. Installing the unit using front mounting ears and a supporting tray
Step 2: Fix the supporting tray supplied with the rack horizontally at the appropriate position of the rack.
Step 3: Take out the supplied front ear screws and attach the front ears to the front end of the RPS unit using the screws, as shown in Figure 4 on page 16.
Figure 8  Install the RPS unit to the rack using front mounting ears and a supporting tray
Step 4: Place the RPS unit horizontally on the supporting tray, gently push the unit into the rack along the supporting tray, and fix the mounting ears to the front square-holed brackets of the rack with M6 screws and cage nuts (user supplied), as shown in Figure 8 .
3.2.2  Installing the RPS Unit on a Tabletop
If a 19-inch standard rack is not available, you can place the RPS unit directly on a clean, stable tabletop.
Follow these steps to install the RPS unit on a tabletop:
Step 1: Cautiously turn the RPS unit upside down. Then, use a piece of dry, soft cloth to remove any oil stain or dust from the dents on the bottom of the chassis.
Step 2: Peel off the stickers on the supplied foot pads and paste the foot pads into the dents on the chassis bottom.
Step 3: Turn over the RPS unit and place it on the tabletop. Verify the stableness and good grounding of the table.
3.3  Installation and Removal of the Flatpack 1500
3.3.1  Handles of the Flatpack 1500
The Flatpack 1500 has two handles, which serve two purposes:
l       For locking the RPS unit in place.
After the power module is inserted into the chassis, it is locked in place by the handles at both sides of the front panel. The handles must be turned to the right position and firmly pushed into their slots.
l       For pulling out the power module.
With both handles released, you can use them to pull the power module part way out to detach it from the power module connector.
Each handle has a locking mechanism that locks the handle in its slots. To release a handle, you need to insert a screwdriver (supplied with the RPS unit) into the hole at the corresponding upper corner of the front panel. The handle will project from its slot, as shown in Figure 9 .
Figure 9  Release a handle
Caution:
l      Never move the power module by its handles.
l      When releasing the handles, do not use excessive force.
l      When inserting the power module into the RPS chassis, make sure that the handles are unlocked.
l      Upon inserting the power module into the chassis, push the handles into their slots to secure the power module in place.
3.3.2  Installing the Flatpack 1500
Follow these steps to install a power module:
Step 1: Release both handles of the power module with the supplied screwdriver, and make sure that the handles have completely projected from their slots, as shown in Figure 9 .
Step 2: With both hands holding the handles, gently push the power module into the chassis.
Step 3: Press the handles into their slots to lock the power module in place.
3.3.3  Removing the Flatpack 1500
Follow these steps to remove a power module:
Step 1: Release both handles of the power module with the supplied screwdriver, as shown in Figure 9 .
Step 2: With both hands holding the handles, gently pull the power module part way out so that it is detached from the connector, as shown in Figure 10 .
Step 3: With one hand supporting the bottom and the other hand holding the power module, gently pull it out of the chassis. Note that the power module may be quite hot when it is just pulled out.
Figure 10  Remove a power module
Caution:
The Flatpack 1500 power modules are hot swappable. Before hot-swapping a power module, however, make sure that the current load does not exceed the total output power of the one that will remain in operation.
3.4  Connecting the RPS Unit to the Powered Devices
3.4.1  Connecting the cables
Follow these steps to connect the RPS unit to a powered device:
Step 1: Check that the power source to the RPS unit is disconnected and the powered device is powered off.
Step 2: Connect the supplied grounding cable to the grounding screw on the chassis of the RPS unit, which is located at the lower right corner of the rear panel, as shown in Figure 2  on page 4. Check that the powered device is well grounded.
Step 3: Plug one end of an RPS DC output power cable into the DC input socket of the powered device and the other end into the DC output socket of the RPS unit. Make sure the correct DC output interface and output cable are selected. For details, refer to section 2.6  Output Specifications on page 10.
Step 4: Connect the power source to the RPS unit and power on the powered device.
Caution:
Check that the AC input cable and the DC output cable are firmly connected to eliminate poor or loose contact.
3.4.2  Commissioning the RPS Unit
l       Before powering on the RPS unit, check the AC input with a multimeter set to the resistance measurement function to eliminate any short circuit.
l       Upon powering on the RPS unit, check that output current LEDs on the front panel indicate the normal output condition.
l       If the alarm LED on the front panel lights up after the RPS unit is powered on, you are encountering a power module failure or AC mains problem. Check the power input.
3.5  Replacing Fuses
Follow these steps to replace a blown fuse:
Step 1: Check that the RPS unit is powered off.
Step 2: Press down the fuse cover (refer to Figure 2  on page 4) appropriately with a flat-blade screwdriver, turn the fuse cover approximately 90° anticlockwise, and then release the screwdriver so that the fuse is ejected together with the fuse cover.
Step 3: Remove the blown fuse and insert a spare fuse into the fuse cover. Verify that the fuse is in good contact with the spring at the bottom of the fuse cover.
Step 4: Insert the new fuse together with the fuse cover into the fuse receptacle on the chassis, press down the fuse cover appropriately with a flat-blade screwdriver, and turn the fuse cover approximately 90° clockwise to lock it in place.
Caution:
To prevent fire hazards, always use fuses of the correct type and rating: FX 10A/DC125V.
