H3C S9500 Series Routing Switches SecBlade FW VPN Cards Command Manual(V1.03)
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Series Routing Switches SecBlade FW VPN Cards Command Manual(V1.03)
05-Appendix
05-Appendix 206 KB
Appendix A  Command Index
The command index includes all the commands in the H3C Secblade FW/VPN Cards Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
Security
1-1
accounting
Security
1-2
accounting optional
Security
1-3
accounting optional
Security
1-21
acl
Security
2-1
acl number
Security
5-1
add interface
Security
4-35
aging-time
Security
4-8
ah authentication-algorithm
VPN
3-1
algorithm-suite
VPN
6-1
allow l2tp
VPN
1-1
aspf session limit
Security
4-28
aspf-policy
Security
4-9
authentication
Security
1-3
authentication super hwtacacs-scheme
Security
1-4
VPN
4-1
authentication-client method
VPN
6-2
authentication-method
VPN
4-1
authentication-server method
VPN
6-2
authorization
Security
1-5
B
bridge vlanid-transparent-transmit enable
Security
5-1
C
ca identifier
VPN
5-1
certificate request entity
VPN
5-1
certificate request from
VPN
5-2
certificate request mode
VPN
5-3
certificate request polling
VPN
5-4
certificate request url
VPN
5-4
common-name
VPN
5-10
connection-limit default
Security
3-1
connection-limit default amount
Security
3-1
connection-limit enable
Security
3-2
connection-limit policy
Security
3-3
country
VPN
5-10
crl check disable
VPN
5-5
crl update-period
VPN
5-6
crl url
VPN
5-6
D
data algorithm-suite
VPN
6-3
data ipsec-sa duration
VPN
6-4
data-flow-format
Security
1-22
data-flow-format
Security
1-50
debugging aspf
Security
4-9
debugging aspf http
Security
4-10
debugging connection-limit
Security
3-3
debugging dnsc
Security
9-18
debugging dvpn
VPN
6-5
debugging encrypt-card host
VPN
3-41
debugging firewall blacklist
Security
4-29
debugging firewall defend
Security
7-1
debugging firewall eff
Security
5-3
debugging firewall mac-binding
Security
4-31
debugging firewall packet-filter
Security
4-1
debugging firewall packet-filter fragments-inspect events
Security
4-2
debugging firewall smtp-filter
Security
6-20
debugging firewall transparent-mode eth-forwarding
Security
5-4
debugging firewall transparent-mode ip-forwarding
Security
5-6
debugging firewall url-filter host
Security
6-1
debugging firewall url-filter parameter
Security
6-1
debugging firewall webdata-filter
Security
6-2
debugging hwtacacs
Security
1-51
debugging ids
Security
8-3
debugging ike
VPN
4-3
debugging ike dpd
VPN
3-2
debugging ipsec
VPN
3-2
debugging l2tp
VPN
1-2
debugging local-server
Security
1-22
debugging nat
Security
3-4
debugging pki
VPN
5-18
debugging radius
Security
1-23
debugging smtpc
Security
9-16
debugging Tunnel
VPN
2-1
debugging vrrp
Reliability
1-1
default-login-user
Overview
1-1
description
Security
2-2
destination
VPN
2-1
detect
Security
4-11
detect http
Security
4-12
dh
VPN
4-3
display acl
Security
2-2
display aspf all
Security
4-13
display aspf interface
Security
4-14
display aspf policy
Security
4-15
display aspf session
Security
4-16
display aspf statistics
Security
4-17
display connection
Security
1-6
display connection-limit policy
Security
3-4
display connection-limit statistics
Security
3-5
display dnsc
Security
9-19
display domain
Security
1-7
display dvpn info
VPN
6-8
display dvpn ipsec-sa
VPN
6-5
display dvpn map
VPN
6-6
display dvpn online-user
VPN
6-9
display dvpn session
VPN
6-7
display encrypt-card fast-switch
VPN
3-41
display firewall blacklist
Security
4-29
display firewall defend flag
Security
7-2
display firewall ethernet-frame-filter
Security
5-7
display firewall fragment
Security
4-2
Security
4-18
display firewall mac-binding
Security
4-32
display firewall mode
Security
5-8
display firewall packet-filter statistics
Security
4-3
display firewall session aging-time
Security
4-18
display firewall session table
Security
4-19
display firewall smtp-filter
Security
6-21
display firewall statistic
Security
9-1
display firewall statistic system defend
Security
9-3
display firewall statistic system flow-percent
Security
9-4
display firewall tcp-proxy session
Security
7-2
display firewall transparent-mode address-table
Security
5-9
display firewall transparent-mode config
Security
5-10
display firewall transparent-mode traffic
Security
5-10
display firewall url-filter host
Security
6-3
display firewall url-filter parameter
Security
6-4
display firewall url-filter parameter counter detail
Security
6-4
display firewall webdata-filter
Security
6-5
display hwtacacs scheme
Security
1-52
display ids
Security
8-1
display ids-acl
Security
8-3
display ike dpd
VPN
3-3
display ike peer
VPN
4-4
display ike proposal
VPN
4-5
display ike sa
VPN
4-5
display interface encrypt
VPN
3-42
display interface Tunnel
VPN
2-2
display interzone
Security
4-35
display ipsec policy
VPN
3-4
display ipsec policy-template
VPN
3-7
display ipsec proposal
VPN
3-8
display ipsec sa
VPN
3-9
display ipsec statistics
VPN
3-13
display ipsec Tunnel
VPN
3-14
display l2tp session
VPN
1-3
display l2tp Tunnel
VPN
1-4
display l2tp user
VPN
1-5
display local-server statistics
Security
1-24
display local-user
Security
1-8
display nat
Security
3-6
display nat connection-limit
Security
3-8
display pki certificate
VPN
5-22
display pki crl
VPN
5-24
display port-mapping
Security
4-21
display radius scheme
Security
1-24
display radius statistics
Security
1-26
display secblade module
Overview
1-1
display smtpc
Security
9-16
display stop-accounting-buffer
Security
1-31
Security
1-54
display time-range
Security
2-8
display vrrp
Reliability
1-1
display zone
Security
4-36
dnsc cache
Security
9-20
dnsc server
Security
9-19
domain
Security
1-10
dpd
VPN
3-15
dvpn class
VPN
6-10
dvpn client register-dumb
VPN
6-10
dvpn client register-interval
VPN
6-11
dvpn client register-retry
VPN
6-12
dvpn dvpn-id
VPN
6-12
dvpn interface-type
VPN
6-13
dvpn policy
VPN
6-13
dvpn policy
VPN
6-14
dvpn register-type
VPN
6-15
dvpn security
VPN
6-16
dvpn server
VPN
6-16
dvpn server authentication-client method
VPN
6-17
dvpn server map age-time
VPN
6-18
dvpn server pre-shared-key
VPN
6-18
dvpn service enable
VPN
6-19
E
encapsulation-mode
VPN
3-15
encrypt-card backuped
VPN
3-43
VPN
3-44
encryption-algorithm
VPN
4-7
esp authentication-algorithm
VPN
3-17
esp encryption-algorithm
VPN
3-18
exchange-mode
VPN
4-8
F
firewall arp-learning enable
Security
5-13
firewall aspf
Security
4-21
firewall blacklist
Security
4-30
firewall defend all
Security
7-4
firewall defend arp-flood
Security
7-5
firewall defend arp-spoofing
Security
7-5
firewall defend frag-flood
Security
7-7
firewall defend fraggle
Security
7-6
firewall defend icmp-flood
Security
7-7
firewall defend icmp-flood enable
Security
7-9
firewall defend icmp-redirect
Security
7-9
firewall defend icmp-unreachable
Security
7-10
firewall defend ip-fragment
Security
7-10
firewall defend ip-spoofing
Security
7-11
firewall defend ip-sweep
Security
7-12
firewall defend land
Security
7-12
firewall defend large-icmp
Security
7-13
firewall defend ping-of-death
Security
7-14
firewall defend port-scan
Security
7-14
firewall defend route-record
Security
7-15
firewall defend smurf
Security
7-16
firewall defend source-route
Security
7-16
firewall defend syn-flood
Security
7-17
firewall defend syn-flood enable
Security
7-18
firewall defend tcp-flag
Security
7-19
firewall defend teardrop
Security
7-19
firewall defend tracert
Security
7-20
firewall defend udp-flood
Security
7-20
firewall defend udp-flood enable
Security
7-21
firewall defend winnuke
Security
7-22
Security
5-13
firewall fragment limit
Security
4-27
firewall interzone
Security
4-37
firewall log-time
Security
9-21
Security
4-33
firewall mac-binding enable
Security
4-33
firewall mode
Security
5-14
Security
4-6
firewall packet-filter default
Security
4-3
firewall packet-filter enable
Security
4-4
Security
4-4
firewall packet-filter fragments-inspect { high | low }
Security
4-5
Security
4-22
firewall session aging-time default
Security
4-23
firewall session limit
Security
4-27
firewall session log-type
Security
9-21
firewall smtp-filter attach add
Security
6-22
firewall smtp-filter attach clear
Security
6-23
firewall smtp-filter attach delete
Security
6-23
firewall smtp-filter attach enable
Security
6-24
firewall smtp-filter attach load-file
Security
6-24
firewall smtp-filter attach save-file
Security
6-25
firewall smtp-filter content add
Security
6-26
firewall smtp-filter content clear
Security
6-26
firewall smtp-filter content delete
Security
6-27
firewall smtp-filter content enable
Security
6-27
firewall smtp-filter content load-file
Security
6-28
firewall smtp-filter content save-file
Security
6-28
firewall smtp-filter rcptto add
Security
6-29
firewall smtp-filter rcptto clear
Security
6-30
firewall smtp-filter rcptto default
Security
6-30
firewall smtp-filter rcptto delete
Security
6-31
firewall smtp-filter rcptto enable
Security
6-31
firewall smtp-filter rcptto load-file
Security
6-32
firewall smtp-filter rcptto save-file
Security
6-33
firewall smtp-filter subject add
Security
6-33
firewall smtp-filter subject clear
Security
6-34
firewall smtp-filter subject delete
Security
6-34
firewall smtp-filter subject enable
Security
6-35
firewall smtp-filter subject load-file
Security
6-35
firewall smtp-filter subject save-file
Security
6-36
firewall statistic system connect-number
Security
9-5
firewall statistic system enable
Security
9-6
Security
9-7
firewall statistic warning-level drop
Security
9-8
firewall system-ip
Security
5-15
firewall tcp-proxy
Security
7-23
firewall transparent-mode aging-time
Security
5-16
firewall transparent-mode transmit
Security
5-16
firewall unknown-mac
Security
5-17
firewall unknown-mac broadcast
Security
5-18
firewall unknown-mac multicast
Security
5-18
firewall unknown-mac unicast
Security
5-19
firewall url-filter host acl-number
Security
6-6
firewall url-filter host add
Security
6-6
firewall url-filter host clear
Security
6-7
firewall url-filter host default
Security
6-8
firewall url-filter host delete
Security
6-8
firewall url-filter host enable
Security
6-9
firewall url-filter host ip-address
Security
6-9
firewall url-filter host save-file
Security
6-10
firewall url-filter load-file
Security
6-10
firewall url-filter parameter add
Security
6-11
firewall url-filter parameter add-default
Security
6-12
firewall url-filter parameter clear
Security
6-13
firewall url-filter parameter delete
Security
6-13
firewall url-filter parameter enable
Security
6-13
firewall url-filter parameter load-file
Security
6-14
firewall url-filter parameter save-file
Security
6-15
firewall webdata-filter add
Security
6-15
firewall webdata-filter clear
Security
6-16
firewall webdata-filter delete
Security
6-17
firewall webdata-filter enable
Security
6-17
firewall webdata-filter load-file
Security
6-18
firewall webdata-filter save-file
Security
6-19
firewall zone
Security
4-38
firewall zone name
Security
4-38
fqdn
VPN
5-9
G
gre checksum
VPN
2-4
gre key
VPN
2-5
H
hwtacacs nas-ip
Security
1-55
hwtacacs scheme
Security
1-56
I
ids-acl enable
Security
8-1
id-type
VPN
4-9
ike dpd
VPN
3-19
ike encrypt-card dh-computation disabled
VPN
4-9
ike local-name
VPN
4-10
ike next-payload check disabled
VPN
4-11
ike peer
VPN
4-11
ike proposal
VPN
4-12
ike sa keepalive-timer interval
VPN
4-14
ike sa keepalive-timer timeout
VPN
4-15
ike sa nat-keepalive-timer interval
VPN
4-16
ike-peer
VPN
4-12
interface encrypt
VPN
3-45
interface Tunnel
VPN
2-5
interface virtual-template
VPN
1-6
interval-time
VPN
3-19
ip
VPN
5-11
ip pool
Security
1-11
ipsec card-proposal
VPN
3-46
ipsec policy
VPN
3-20
ipsec policy
VPN
3-21
VPN
3-22
ipsec proposal
VPN
3-23
ipsec sa global-duration
VPN
3-24
J
K
keepalive
VPN
2-6
key
Security
1-32
key
Security
1-57
L
l2tp enable
VPN
1-6
l2tp-auto-client enable
VPN
1-7
l2tp-group
VPN
1-7
l2tpmoreexam enable
VPN
1-8
ldap-server
VPN
5-7
level
Security
1-12
limit
Security
3-9
local
VPN
4-16
local-address
VPN
4-17
locality
VPN
5-11
local-server
Security
1-33
local-user
VPN
6-20
local-user
Security
1-13
local-user password-display-mode
Security
1-14
log enable
Security
4-24
M
mandatory-chap
VPN
1-9
mandatory-lcp
VPN
1-10
map to slot
Overview
1-2
N
nas-ip
Security
1-34
nas-ip
Security
1-57
nat address-group
Security
3-11
nat aging-time
Security
3-11
nat alg
Security
3-12
nat connection-limit-policy
Security
3-13
nat dns-map
Security
3-14
nat outbound
Security
3-15
nat outbound interface
Security
3-16
nat outbound static
Security
3-17
nat overlapaddress
Security
3-18
nat server
Security
3-19
nat static
Security
3-22
nat static inside
Security
3-22
nat traversal
VPN
4-17
O
organization
VPN
5-12
organization-unit
VPN
5-12
P
password
Security
1-15
peer
VPN
4-18
pfs
VPN
3-25
pki delete-certificate
VPN
5-14
pki domain
VPN
5-7
pki entity
VPN
5-13
pki import-certificate
VPN
5-15
pki request-certificate
VPN
5-15
pki retrieval-certificate
VPN
5-16
pki retrieval-crl
VPN
5-17
pki validate-certificate
VPN
5-17
port-mapping
Security
4-24
pre-shared-key
VPN
4-19
pre-shared-key
VPN
6-21
primary accounting
Security
1-34
primary accounting
Security
1-58
primary authentication
Security
1-35
Security
1-59
primary authorization
Security
1-60
private-ip
VPN
6-21
proposal
VPN
3-26
public-ip
VPN
6-20
Q
R
radius nas-ip
Security
1-37
radius scheme
Security
1-36
radius trap
Security
1-38
remote-address
VPN
4-19
remote-name
VPN
4-20
reset acl counter
Security
2-3
reset aspf session
Security
4-25
reset aspf statistic http
Security
4-26
reset counters interface encrypt
VPN
3-47
reset dvpn all
VPN
6-22
reset dvpn map
VPN
6-22
reset dvpn session
VPN
6-23
reset dvpn statistics
VPN
6-23
reset encrypt-card fast-switch
VPN
3-47
reset encrypt-card sa
VPN
3-48
reset encrypt-card statistics
VPN
3-48
reset encrypt-card syslog
VPN
3-49
reset firewall ethernet-frame-filter
Security
5-20
reset firewall log-buf
Security
9-22
reset firewall mac-binding
Security
4-34
reset firewall packet-filter statistics
Security
4-7
reset firewall session table
Security
4-26
reset firewall smtp-filter counter
Security
6-36
reset firewall statistic ip
Security
9-9
reset firewall statistic system
Security
9-9
reset firewall statistic zone
Security
9-10
reset firewall transparent-mode address-table
Security
5-20
reset firewall transparent-mode traffic
Security
5-21
reset firewall url-filter host counter
Security
6-19
reset firewall url-filter parameter counter
Security
6-19
reset firewall webdata-filter counter
Security
6-20
reset hwtacacs statistics
Security
1-61
reset ike sa
VPN
4-21
reset ipsec sa
VPN
3-27
reset ipsec statistics
VPN
3-29
reset l2tp session
VPN
1-10
reset l2tp Tunnel
VPN
1-11
reset l2tp user
VPN
1-11
reset nat
Security
3-23
reset radius statistics
Security
1-39
reset stop-accounting-buffer
Security
1-39
Security
1-61
retry
Security
1-40
retry realtime-accounting
Security
1-41
retry stop-accounting
Security
1-42
Security
1-62
root-certificate fingerprint
VPN
5-8
rule
Security
2-3
rule
Security
5-21
rule comment
Security
2-7
S
sa authentication-hex
VPN
3-29
sa duration
VPN
3-31
sa duration
VPN
4-22
sa encryption-hex
VPN
3-32
sa spi
VPN
3-33
sa string-key
VPN
3-35
scheme
Security
1-16
secblade aggregation slot
Overview
1-3
secblade module
Overview
1-3
secblade slot
Overview
1-4
secblade-interface
Overview
1-4
secondary accounting
Security
1-43
Security
1-63
secondary authentication
Security
1-44
Security
1-64
secondary authorization
Security
1-64
security acl
VPN
3-36
security-vlan
Overview
1-5
server-type
Security
1-44
service-type
Security
1-17
service-type dvpn
Security
1-18
service-type ftp
Security
1-18
service-type ppp
Security
1-19
session algorithm-suite
VPN
6-24
session idle-time
VPN
1-12
session idle-time
VPN
6-25
session keepalive-interval
VPN
6-26
session setup-interval
VPN
6-26
set priority
Security
4-37
smtpc administrator mail
Security
9-17
smtpc trigger time
Security
9-17
snmp-agent trap enable encrypt-card
VPN
3-50
source
VPN
2-7
start l2tp
VPN
1-13
start l2tp Tunnel
VPN
1-14
state
VPN
5-13
state
Security
1-19
state
Security
1-45
statistic connect-number ip
Security
9-10
statistic connect-number zone
Security
9-12
statistic connect-speed ip
Security
9-13
statistic connect-speed zone
Security
9-14
statistic enable
Security
9-15
stop-accounting-buffer enable
Security
1-46
Security
1-65
super authentication-mode
Security
1-20
T
time-out
VPN
3-37
timer quiet
Security
1-47
timer quiet
Security
1-66
timer realtime-accounting
Security
1-48
Security
1-67
timer response-timeout
Security
1-49
Security
1-68
time-range
Security
2-9
transform
VPN
3-38
Tunnel authentication
VPN
1-14
Tunnel avp-hidden
VPN
1-15
Tunnel flow-control
VPN
1-16
Tunnel keepstanding
VPN
1-16
Tunnel local
VPN
3-39
Tunnel name
VPN
1-17
Tunnel password
VPN
1-18
Tunnel remote
VPN
3-40
Tunnel timer hello
VPN
1-18
Tunnel-protocol gre
VPN
2-8
Tunnel-protocol udp dvpn
VPN
6-27
U
use encrypt-card
VPN
3-51
user-name-format
Security
1-49
user-name-format
Security
1-68
V
vrrp authentication-mode
Reliability
1-3
vrrp ping-enable
Reliability
1-3
vrrp un-check ttl
Reliability
1-4
vrrp vrid preempt-mode
Reliability
1-5
vrrp vrid priority
Reliability
1-6
vrrp vrid timer advertise
Reliability
1-6
vrrp vrid track
Reliability
1-7
vrrp vrid virtual-ip
Reliability
1-8
W
X
Y
Z
