H3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
HomeSupportSwitchesH3C S5120 Switch SeriesReference GuidesCommand ReferencesH3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
Preface
The H3C S5120-SI Series Ethernet Switches Command Reference, Release 1101 describes the commands available in the H3C S5120-SI series software release 1101.
This preface includes:
1)        About This Document
l          Audience
l          Organization
l          Conventions
2)        Documentation Guide
l          Related Documentation
l          Obtaining Documentation
l          Technical Support
l          Documentation Feedback
About This Document
Audience
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the S5120-SI series
Organization
The H3C S5120-SI Series Ethernet Switches Command Reference, Release 1101 comprises these chapters:
Chapter
Content
01-CLI
CLI Configuration Commands
02-Login
l      Commands for Logging into an Ethernet Switch
l      Commands for Controlling Login Users
03-Ethernet Port
Ethernet Port Configuration Commands
04-Loopback Interface and Null Interface
Loopback Interface and Null Interface Configuration Commands
05-Ethernet Link Aggregation
Ethernet Link Aggregation Configuration Commands
06-Port Isolation
Port Isolation Configuration Commands
07-Port Mirroring
Port Mirroring Configuration Commands
08-LLDP
LLDP Configuration Commands
09-VLAN
l      VLAN Configuration Commands
l      Port-Based VLAN Configuration Commands
l      Voice VLAN Configuration Commands
10-MSTP
MSTP Configuration Commands
11-IP Addressing
IP Addressing Configuration Commands
12-IP Performance Optimization
IP Performance Optimization Configuration Commands
13-ARP
l      ARP Configuration Commands
l      ARP Active Acknowledgement Configuration Commands
14-DHCP
l      DHCP Relay Agent Configuration Commands
l      DHCP Client Configuration Commands
l      DHCP Snooping Configuration Commands
l      BOOTP Client Configuration Commands
15-FTP and TFTP
l      FTP Server Configuration Commands
l      FTP Client Configuration Commands
l      TFTP Client Configuration Commands
16-IP Routing Basics Configuration
Routing-table Display and Reset Commands
17-Static Routing
Static Routing Configuration Commands
18-Mulitcast
l      IGMP Snooping Configuration Commands
l      Multicast VLAN Configuration Commands
19-QoS
l      Class Configuration Commands
l      Traffic Behavior Configuration Commands
l      QoS Policy Configuration and Application Commands
l      Priority Mapping Configuration Commands
l      Line Rate Configuration Commands
l      Congestion Management Configuration Commands
20-802.1X
802.1X Configuration Commands
21-AAA
l      AAA Configuration Commands
l      RADIUS Configuration Commands
22-PKI
PKI Configuration Commands
23-SSL
SSL Configuration Commands
24-SSH2.0
SSH2.0 Configuration Commands
25-Public Key
Public Key Configuration Commands
26-HABP
HABP Configuration Commands
27-ACL
ACL Configuration Commands
28-Device Management
Device Management Commands
29-NTP
NTP Configuration Commands
30-SNMP
SNMP Configuration Commands
31-RMON
RMON Configuration Commands
32-File System Management
l      File System Management Commands
l      Configuration File Management Commands
33-System Maintaining and Debugging
l      System Maintaining Commands
l      System Debugging Commands
34-Basic System Configuration
Basic Configuration Commands
35-Information Center
Information Center Configuration Commands
36-MAC Address Table
MAC Address Table Configuration Commands
37-Cluster Management
l      NDP Configuration Commands
l      NTDP Configuration Commands
l      Cluster Configuration Commands
38-HTTP
l      HTTP Configuration Commands
l      HTTPS Configuration Commands
39-Stack Management
l      Stack Management Configuration Commands
40-PoE
PoE Configuration Commands
41-IP Source Guard
IP Source Guard Configuration Commands
42-Appendix
Command Index
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
The H3C S5120-SI documentation set also includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Installation guide
l      Provides a complete guide to hardware installation and hardware specifications.
l      Provides a complete guide to software and hardware troubleshooting.
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
Power configuration
RPS ordering guide
Provides the RPS and switch compatibility matrix and RPS cable specifications.
Software configuration
Configuration guide
Describes software features and configuration procedures.
Command reference
Provides a quick reference to all available commands.
Operations and maintenance
Login password recovery manual
Tells how to find the lost password or recover the password when the login password is lost.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
l          [Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
l          [Products & Solutions] Provides information about products and technologies, as well as solutions.
l          [Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical Support
service@h3c.com
http://www.h3c.com
We appreciate your comments.
