07-Inter-VLAN Communication on Downlink Switches Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR Routers Commonly Used Feature Configuration Examples(Web)-R9141-6W10007-Inter-VLAN Communication on Downlink Switches Configuration Examples
01-Inter-VLAN Configuration Examples
Introduction
This document describes a typical configuration example for implementing inter-VLAN communication on downlink switches.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of VLAN.
Software versions used
This configuration example was created and verified on R9141 of the MSR router series.
Example: Configuring inter-VLAN communication on downlink switches
As shown in Figure 1, Switch 1 and Switch 2 are attached to Router, and Host A and Host B are connected to Switch 1 and Switch 2, respectively. Configure the network to meet the following requirements:
·     Host A and Host B obtain IP addresses from the subnets of VLAN 10 and VLAN 20, respectively.
·     The gateways for VLAN 10 and VLAN 20 are located on Router, which also acts as the DHCP server to allocate IP addresses to the hosts.
Figure 1 Network diagram
Data plan
Table 1 Subnet plan
Subnet
Detailed data plan
VLAN 10
·     Subnet: 192.168.10.0/24
·     Gateway: Router
·     Gateway interface IP address: 192.168.10.1/24
VLAN 20
·     Subnet: 192.168.20.0/24
·     Gateway: Router
·     Gateway interface IP address: 192.168.20.1/24
VLAN 1 (interconnect address between Router and Switch)
·     Subnet: 192.168.1.0/0
·     Router interconnect interface IP address: 192.168.1.1/24
·     Switch 1 interconnect interface IP address: 192.168.1.2/24
·     Switch 2 interconnect interface IP address: 192.168.1.3/24.
Table 2 VLAN assignment plan for interfaces
Device
Router
·     Connect interface GE 0/0/4 to Switch 1. Configure the link type as trunk and PVID as 1, and assign the interface to VLAN 1 and VLAN 10.
·     Connect interface GE 0/0/5 to Switch 2. Configure the link type as trunk and PVID as 1, and assign the interface to VLAN 1 and VLAN 20.
Switch 1
·     Connect interface GE 1/0/1 to Router. Configure the link type as trunk and PVID as 1, and assign the interface to VLAN 1 and VLAN 10.
·     Connect interface GE1/0/2 to Host A. Configure the link type as access, and assign the interface to VLAN 10.
Switch 2
·     Connect interface GE 1/0/1 to Router. Configure the link type as trunk and PVID as 1, and assign the interface to VLAN 1 and VLAN 20.
·     Connect interface GE1/0/2 to Host B. Configure the link type as access, and assign the interface to VLAN 20.
Analysis
·     Log in to the Web management interface of Router through a browser, and connect to the switches through the Console ports for configuration.
·     Configure subnets on Router and switches as planned, and configure the DHCP server on Router to assign IP addresses to endpoints.
·     The default IP address of VLAN-interface 1 on Router is 192.168.0.1/23. Edit the default IP address of VLAN-interface 1 on Router and switches as required.
·     After editing the default IP address of VLAN-interface 1 on Router, use the new IP address to log in to the Web management interface.
·     Connect the PC to the LAN interface of Router by using an Ethernet cable. Configure the PC with a fixed IP address of 192.168.0.X/23. Then, open a browser and enter the management IP address of Router (https://192.168.0.1) to access the Web management interface.
·     Verify that the PC has installed terminal software and is connected to a switch's Console port through a serial cable. Start the terminal software and configure the relevant parameters to connect to the backend interface of the switch.
Procedures
Configuring Router
1.     Change the IP address of VLAN-interface 1 to 192.168.1.1/24 as required:
a.     From the left navigation pane, select Network > LAN Settings.
b.     Click the Edit icon in the Actions column for VLAN-interface 1 to access the page for editing the LAN settings.
c.     In the Interface IP address field, change the IP address of the interface to 192.168.1.1.
d.     In the Subnet Mask field, change the subnet mask to 255.255.255.0.
e.     Clear the Enable DHCP option to disable DHCP.
f.     Use the default settings for the other parameters, and then click Apply.
Figure 2 Editing the LAN
2.     Create VLAN 10, configure an IP address for the VLAN interface, and enable DHCP on the interface:
b.     Click Add.
c.     In the LAN interface type field, select VLAN interface.
d.     In the VLAN ID field, enter 10.
e.     In the Interface IP address field, enter 192.168.10.1.
f.     In the Subnet Mask field, enter 255.255.255.0.
g.     Select the Enable DHCP option to enable DHCP.
h.     Use the default settings for the other parameters, and then click Apply.
Figure 3 Configuring VLAN 10
3.     Create VLAN 20, configure an IP address for the VLAN interface, and enable DHCP on the interface:
b.     Click Add.
d.     In the VLAN ID field, enter 20.
e.     In the Interface IP address field, enter 192.168.20.1.
Figure 4 Configuring VLAN 20
4.     Assign interface GE 0/0/4 to VLAN 1 and VLAN 10:
b.     Click the VLAN Division tab.
c.     Click the Edit icon in the Actions column for interface GE 0/0/4.
The detailed port configuration page opens.
d.     Click VLAN 10 in the Available VLANs area to add VLAN 10 to the Selected VLANs area.
e.     Use the default settings for the other parameters, and then click Apply.
Figure 5 Configuring interface GE 0/0/4
5.     Assign interface GE 0/0/5 to VLAN 1 and VLAN 20:
c.     Click the Edit icon in the Actions column for interface GE 0/0/5.
d.     Click VLAN 20 in the Available VLANs area to add VLAN 20 to the Selected VLANs area.
Figure 6 Configuring interface GE 0/0/5
Configuring Switch 1
1.     Configure the IP address for VLAN-interface 1 and configure VLAN 10.
<L2 switch 1> system-view
[L2 switch 1] interface vlan 1
[L2 switch 1-interface1] ip address 192.168.1.2 24
[L2 switch 1-interface1] quit
[L2 switch 1] VLAN 10
[L2 switch 1-VLAN10] quit
2.     Set the link type of GigabitEthernet 1/0/1 to trunk and assign it to VLANs 1 and 10.
[L2 switch 1] interface gigabitethernet 1/0/1
[L2 switch 1-GigabitEthernet1/0/1] port link-type trunk
[L2 switch 1-GigabitEthernet1/0/1] port trunk permit VLAN 1 10
[L2 switch 1-GigabitEthernet1/0/1] quit
3.     Set the link type of interface GigabitEthernet 1/0/2 to access and assign it to VLAN 10.
[L2 switch 1] interface gigabitethernet 1/0/2
[L2 switch 1-GigabitEthernet1/0/2] port link-type access
[L2 switch 1-GigabitEthernet1/0/2] port access vlan 10
[L2 switch 1-GigabitEthernet1/0/2] quit
[L2 switch 1]
Configuring Switch 2
1.     Configure the IP address for VLAN-interface 1 and configure VLAN 20.
<L2 switch 2> system-view
[L2 switch 2] interface vlan 1
[L2 switch 2-interface1] ip address 192.168.1.3 24
[L2 switch 2-interface1] quit
[L2 switch 2] VLAN 20
[L2 switch 2-VLAN20] quit
2.     Set the link type of GigabitEthernet 1/0/1 to trunk and assign it to VLANs 1 and 20.
[L2 switch 2] interface gigabitethernet 1/0/1
[L2 switch 2-GigabitEthernet1/0/1] port link-type trunk
[L2 switch 2-GigabitEthernet1/0/1] port trunk permit VLAN 1 20
[L2 switch 2-GigabitEthernet1/0/1] quit
3.     Set the link type to access for interface GigabitEthernet 1/0/2 and assign it to VLAN 20.
[L2 switch 2] interface gigabitethernet 1/0/2
[L2 switch 2-GigabitEthernet1/0/2] port link-type access
[L2 switch 2-GigabitEthernet1/0/2] port access vlan 20
[L2 switch 2-GigabitEthernet1/0/2] quit
Host A can obtain an IP address from the subnet of VLAN 10, and Host B can obtain an IP address from the subnet of VLAN 20. Verify that the configuration is successful.
