H3C SecPath L5000-AD540-G L5000-AD520-G L5000-AD190-G Series
Release time:2026-02-07
HomeSupportSecurityH3C SecPath L5000Software DownloadL5000-AD920 L5000-AD830 L5000-AD540-G L5000-AD520-G L5000-AD190-G Series
H3C SECPATHL5000AD540G-SECPATHL5000AD190G-CMW710-R9900P34 Release Notes
Version information· 1
Version number 1
Supported browsers· 1
Version compatibility matrix· 1
Upgrade restrictions and guidelines· 3
Hardware feature updates· 3
Software feature and command updates· 3
MIB updates· 3
Operation changes· 4
Restrictions and cautions· 4
Restrictions· 4
Cautions· 4
Licensing· 4
About licensing· 4
Registering and installing licenses· 4
Open problems and workarounds· 5
List of resolved problems· 5
Resolved problems in R9900P34· 5
Resolved problems in R9900P31· 5
Resolved problems in R9900P30· 5
Resolved problems in R9900P2701· 6
Resolved problems in R9900P24· 6
Related documentation· 6
Documentation set 6
Obtaining documentation· 6
Technical support 6
Appendix A Feature list 7
Appendix B Fixed vulnerabilities· 12
Appendix C Upgrading software· 13
Software images· 13
Software images types· 13
Software release forms· 13
Configuration files· 13
Upgrade methods· 14
Preparing for the upgrade· 14
Upgrading system software· 14
Upgrading system software from the CLI 14
Upgrading system software from the Web interface· 22
Upgrading the BootWare· 23
Upgrading the BootWare from the CLI 24
Upgrading the BootWare from an Ethernet interface through TFTP/FTP· 24
Performing file management from the BootWare menu· 28
Handling software upgrade failures· 32
List of tables
Table 1 Version history. 1
Table 2 Version compatibility matrix. 1
Table 3 MIB updates. 3
Table 4 Hardware features. 7
Table 5 Software features. 7
Table 6 Default login information. 22
Table 11 File control submenu. 29
This document introduces the features, usage restrictions, issues, and workarounds of version R9900P34. Before loading R9900P34, back up the configuration file and perform internal verification to avoid potential risks as a best practice.
Use this document in conjunction with H3C SECPATHL5000AD540G-SECPATHL5000AD190G-CMW710-R9900P34 Release Notes (Software Feature Changes) and the documents listed in "Related documentation."
Version information
Version number
Version number: H3C Comware Software, Version 7.1.064, Release 9900P34
You can see the version number with the display version command in any view.
Version number
Last version
Release date
Version type
Remarks
R9900P34
R9900P31
2025-12-29
Release
Annual version
R9900P31
R9900P30
2025-10-31
Release
Fixed bugs
R9900P30
R9900P2701
2025-09-23
Release
Released for Technical Support.
R9900P2701
R9900P24
2025-06-30
Release
R9900P24
N/A
2025-3-17
Release
Fixed bugs.
Supported browsers
As a best practice, use the following browsers:
·            IE 10 or higher
·            Firefox 19 or higher
·            Chrome 31 and later versions
·            Safari 5 and later versions
CAUTION:
To avoid an upgrade failure, use the following table to verify the hardware and software compatibility before performing an upgrade.
Product series
Product model
Model
L5000-AD540-G
L5000-AD520-G
L5000-AD190-G[AD170-G][AD150-G]
Memory
64 GB
32 GB
16 GB
Flash
8 GB EMMC flash
Boot ROM version
1.19
(You can see the version number with the display version command in any view.)
Software image file and MD5 checksum
SECPATHL5000AD540G-CMW710-R9900P34.ipe:17731793fea7d0969b31b8b4857b4c00
l5000cn3ade-cmw710-boot-R9900P34.bin:8369df2f03dfe01e49686a13ca4c5eba
l5000cn3ade-cmw710-system-R9900P34.bin:790e3d42a0fa9c3996da26e01ad4c334
l5000cn3ade-cmw710-system-R9900P34.xsd.tar.bz2:699b77da9a7438643c9083035df8a4c9
IMC version
iMC-ACLM 7.3 (E0710P06)
iMC-DM 7.3 (E0710P06)
iMC EIA 7.3 (TAM) (E0633H03)
iMC-iCC 7.3 (E0710P06)
iMC PLAT 7.3 (E0710P06)
iMC SHM 7.3 (E0707L06)
iMC SSM 7.3 (LBM) (E0505P03)
iMC SSM 7.3 (SSM) (E0506H01)
iMC-VLAN 7.3 (E0710P06)
iNode version
iNode PC 7.3 (E0644)
ADDC version
ADDC 7.1
ADNET-FCAPS version
E0709
AOM version
E0706P01
Remarks
N/A
Example: To display the host software and BootWare version of L5000-AD540-G, perform the following:
<H3C>dis version
Copyright (c) 2004-2024 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath L5000-AD540-G uptime is 0 weeks, 0 days, 0 hours, 3 minutes
Last reboot reason: UserReboot
Boot image: flash:/l5000cn3ade-cmw710-boot-R9900P34.bin
Boot image version: 7.1.064, Release 9900P34
  Compiled Aug 15 2024 15:00:00
System image: flash:/l5000cn3ade-cmw710-system-R9900P34.bin
System image version: 7.1.064, Release 9900P34
SLOT 1 CPU 0
CPU type           : Multi-core CPU
DDR4 SDRAM Memory  : 65536M bytes
FLASH              : 7312M bytes
Board PCB       Version: Ver. A
CPLD            Version:   5.0
Basic  BootWare Version:  1.14
Extend BootWare Version:  1.14
[SubSlot 0] (Hardware)Ver.A, (Driver)1.0, (Cpld)5.0
[SUBCARD 1] NS-HPIM-TG4A (Hardware)Ver.A, (Driver)1.0, (Cpld)3.0
[SUBCARD 2] NS-HPIM-TG4A (Hardware)Ver.A, (Driver)1.0, (Cpld)4.0
[SUBCARD 3] NS-HPIM-TG4A (Hardware)Ver.A, (Driver)1.0, (Cpld)4.0
[SUBCARD 4] NS-HPIM-TG4A (Hardware)Ver.A, (Driver)1.0, (Cpld)4.0
N/A
N/A
For more information about the software feature and command update history, see H3C SECPATHL5000AD540G-SECPATHL5000AD190G-CMW710-R9900P34 Release Notes (Software Feature Changes).
MIB updates
Table 3 MIB updates
Version number
Item
MIB file
Module name
Remarks
R9900P34
New
N/A
Modified
N/A
R9900P31
New
N/A
Modified
N/A
R9900P30
New
N/A
Modified
N/A
R9900P2701
New
N/A
Modified
N/A
R9900P24
New
N/A
Modified
N/A
Operation changes
N/A
Before performing an upgrade, see H3C SECPATHL5000AD540G-SECPATHL5000AD190G-CMW710-R9900P34 Release Notes (Software Feature Changes) and related documentation to see the software feature changes and evaluate the influence on the service.
Restrictions
·            You cannot configure the same feature module both at the CLI and in the Web interface.
·            The number of contexts used must strictly follow the specifications.
·            The 4SFP+/8SFP+/8SFP/8GE network cards do not support per-packet processing.
·            The 4SFP+/8SFP+ interface cards do not support Gigabit autosensing or 1G fiber-to-copper modules. 10G fiber-to-copper modules are supported.
·            Interface cards do not support hot swapping.
Cautions
·            As a best practice, do not perform operations such as restarting, starting, or stopping contexts when memory is insufficient.
·            If multiple virtual servers use the same LB policy, the different real server groups corresponding to the load balancing actions of each virtual server must either all perform source address translation or all not perform source address translation.
·            SNAT addresses must not overlap with health check source addresses. You can use an interface secondary address as the SNAT address, or bind the health check to a local IP different from the SNAT address.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses.
H3C License Management Platform provides product licensing services for H3C customers. You can access this system to obtain an activation file or transfer licenses.
H3C License Management Platform is accessible at http://www.h3c.com/en/License/.
For more information about license registration, activation file installation, and license transfer, see H3C Security Products Licensing Configuration Demonstration Video, H3C Security Products Licensing Configuration Demonstration, H3C Security Products Licensing Configuration Examples, and H3C Security Products Licensing Guide.
H3C provides license-related FAQ. For more information, see H3C Security Products Licensing FAQ.
On the virtual server page, when both iShell script and VRF need to be configured simultaneously, configure the VRF after the IP address of the virtual server.
In an N+M cluster scenario, virtual servers of different traffic groups must use different SNAT address pools.
202504221214
·            Symptom: When there is traffic on the VS, editing the IP or VRF of the VS will cause VS flag change, leading to VS packet loss.
·            Condition: This symptom might occur if you edit the IP or VRF of the VS while traffic is present.
·            Workaround: Do not edit the IP or VRF of the VS while traffic is present.
202512090999
·            Symptom: When you construct IPv6 packets of mixed lengths and protocol value of 60 and send them to the device ingress interface for link service processing, all service ports of the device cannot be pinged, and all services fail.
·            Condition: This symptom might occur when IPv6 packets of mixed lengths and protocol value of 60 are sent.
202509120457
·            Symptom: In SSL bidirectional or load traffic scenarios, when you enable per-request load sharing, the first two requests or the last two requests do not fail when traffic is sent. However, when all four requests are sent together and distributed to two SFs, failures occur. The client captures a packet where one request does not receive a 200 OK, and the server discards this request. This is related to asynchronous encryption.
·            Condition: This symptom might occur in SSL bidirectional or load traffic scenarios when per-request load sharing is enabled and one connection has multiple requests.
202508210656
·            Symptom: The card reboots if you execute the undo loadbalance ssl performance-optimize cache-value command use the AES128-SHA cipher suite when SSL traffic is present.
·            Condition: This symptom occurs if you execute the undo loadbalance ssl performance-optimize cache-value command use the AES128-SHA cipher suite when SSL traffic is present.
202503040268
·            Symptom: The returned values are null when a MIB browser is used to read nodes of the virtual server name, server farm name, and real server name through SNMP.
·            Condition: This symptom occurs if nodes of the virtual server name, server farm name, and real server name are read through SNMP
N/A
Documentation set
·            H3C SecPath L5000-AD5X0[AD1X0] Series Configuration Guides(V7)(R9900)
·            H3C SecPath L5000-AD5X0[AD1X0] Series Command Reference(V7)(R9900)
To obtain the latest documents, go to the H3C website at www.h3c.com/en
·            To obtain the most recent drive and firmware, access http://www.h3c.com/en/Technical_Documents
·            Select the product category and product model. Then, you can search for and download documents related to the product.
Technical support
Email: [email protected]
Website: http://www.h3c.com/en
Hardware features
Item
Specifications
Product model
L5000-AD540-G
L5000-AD520-G
Ports
1 × console port
1 × management Ethernet port
2 × USB 2.0 ports
Memory
64 GB
32 GB
16 GB
Flash
8 GB
Expansion slots
4 expansion slots that support the following interface modules:
·          8-port SFP interface module
·          4-port SFP+ interface module
·          8-port GE interface module
·          NS-FPIM-CQG4TG16GT16AL high-density interface module
Hard disk slots
2 × M.2 hard disk slots
Power modules
2 power expansion slots, supporting AC or DC power supply modules. In dual power mode, the power supply modules must have the same specifications. Supported power supply specifications are 250W AC, 450W AC, 450W DC, and 450W HVDC.
Dimensions (H × W × D)
44 × 560 × 440 mm (1.73 × 22.05 ×17.32 in)
Temperature
·          Operating:
¡  Without disks: 0°C to 40°C (32°F to 104°F)
¡  With disks: 5°C to 40°C (41°F to 104°F)
·          Storage: –40°C to 70°C (–40°F to 158°F)
Humidity
·          Operating:
¡  Without disks: 5% RH to 95% RH
¡  With disks: 10% RH to 90% RH
·          Storage: 5% RH to 95% RH
Software features
Category
Features
Server load balancing
Scheduling algorithms
Weighted round-robin algorithm
Random
Real server-based weighted least connections
Dynamic feedback
Minimum time
Bandwidth
Maximum bandwidth
Source IP address hash
Source IP address CARP hash
Source IP address and port hash
Source IP address and port CARP hash
Destination IP address hash
Destination IP address CARP hash
HTTP hash
HTTP CARP hash
Member-based weighted least connections
Priority-based scheduling algorithm
URL-based hash
Session persistence
Source IP address-based session persistence
Destination IP address-based session persistence
Source IP and source port-based session persistence
Destination IP and destination port-based session persistence
Source IP, source port, destination IP, destination port-based session persistence
Source IP and destination IP-based session persistence
HTTP packet header-based session persistence
HTTP cookie-based session persistence
HTTP content-based session persistence
HTTP URL-based session persistence
SIP-based session persistence
RADIUS attribute-based session persistence
DHCP attribute-based session persistence
SSL ID-based session persistence
Health check
ICMP
TCP
TcpHalfOpen
FTP
HTTP
HTTPS
SSL
DNS
Radius
UDP
POP3
RTSP
IMAP4
SNMP
SIP
ARP
SMTP
snmp-dca
WAP
Custom
Combined health check algorithm
HTTP policy
Policy matching elements:
·          HTTP cookie
·          HTTP header
·          HTTP URL
·          HTTP content
·          HTTP method
·          HTTP class: Nested invocation of HTTP classes
·          generic-class: Using generic classes as matching conditions
Actions:
·          HTTP Header insert
·          HTTP Header rewrite
·          HTTP Header delete
·          SSL URL location rewrite
·          SSL Client policy set
·          Real server farm selection
Generic policy
·          Source IP
·          generic-class: Nested invocation of generic classes
Actions:
·          SSL client policy setting
·          IP ToS setting
Protection policy
HTTP protection policy
WebSocket
WebSocket
HTTP parameter profile
Case sensitivity
Maximum HTTP header resolve length
Maximum HTTP content resolve length
Server connection multiplexing
HTTP message modification per request
HTTP request distribution
Secondary cookie separator
Secondary cookie start bit character
Handling method for URL or cookie exceeding maximum length
TCP parameter profile
Setting the processing method for data segments exceeding MSS: allow or discard
Setting the size of the send and receive buffers
IP parameter profile
Setting the ToS field of IP packets responded by the real server through the device
SSL offloading
SSL offloading: offload SSL-based traffic
All SSL server features, including certificate management, and authentication
SSL client features, SSL encrypted transmission with backend servers
Inbound link load balancing
DNS listener
DNS query type
Bandwidth busy protection
Link health inspection
Load sharing algorithms, including least connections, random, and round-robin.
Outbound link load balancing
Load sharing algorithms, including least connections, random, round-robin, address HASH, bandwidth, and link quality.
Traffic classification based on source IP, ISP, and ACL.
Dynamic proximity
ALG
Management
Management mode
CLI (Telnet/SSH)
Serial port
SNMPv3, compatible with SNMP v2c and SNMP v1
IMC
Networking
Networking schemes
L4/L7 server load balancing
Bypass mode
Fixed vulnerabilities in R9900P34 and earlier versions
N/A
CAUTION:
Do not power off or reboot the device during the upgrade process.
The software upgrade procedure is the same for all security devices. This chapter describes how to upgrade software from the CLI and Web interface. The default storage medium varies by device model. This chapter uses the flash memory as the default storage medium.
Software images
The following software types are available:
·            BootWare image—A .btw file that contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the device cannot start up correctly.
·            System software image—Includes the following image subcategories:
¡  Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡  Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
You can assign the following attributes to a system software image:
¡  Main—The image is the primary image. The system always attempts to load the main image at startup in preference to the backup image.
¡  Backup—The image is the backup image. It is used only if the primary image is corrupt or not available.
Software images are released in one of the following forms:
·            Separate .bin files. You must verify compatibility between software images.
·            As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Configuration files
You can save settings you made to a configuration file so they can survive a reboot.
The device supports .cfg configuration files. The default .cfg configuration file is named startup.cfg.
Upgrade methods
To upgrade system software, use one of the following methods:
·            Upgrading system software from the CLI
·            Upgrading system software from the Web interface
To upgrade the BootWare, use either of the following methods:
·            Upgrading the BootWare from the CLI
·            Upgrading the BootWare from an Ethernet interface through TFTP/FTP
You must reboot the device after a system software or BootWare upgrade. A device reboot interrupts services.
Before a software upgrade, read the release notes to identify the command changes. Some commands in the configuration file might not be supported after a software upgrade.
The device can function as the TFTP client, FTP client, or FTP server. In the following examples that use TFTP or FTP, the device functions as the TFTP or FTP client.
To use a PC as the TFTP or FTP server, prepare the TFTP or FTP server software by yourself. The device is not shipped with the software.
Before you upgrade system software, complete the following tasks:
·            Run a TFTP or FTP server on the file server. (Skip this task if you upgrade software from the Web interface.)
·            Assign an IP address to the file server. Make sure the management Ethernet port on the device and the file server can reach each other.
By default, the IP address of the management Ethernet port GigabitEthernet 1/0/0 is 186.23.0.15/16 and the management Ethernet port belongs to the Management security zone. The Management security zone and the Local security zone can communicate with each other.
You can also change the IP address of the management Ethernet port from its default and add it to a security zone other than Management. Then, you configure a zone pair to make sure the security zone and the Local security zone can communicate with each other. For more information about security zones and zone pairs, see the security zone configuration in the fundamentals configuration guide.
·            Transfer the software upgrade file to the file server and set the working directory on the TFTP or FTP server.
·            Log in to the CLI of the device through the console port. (Skip this task if you upgrade software from the Web interface.)
·            Make sure the upgrade has minimal impact on the network services. During the upgrade, the device cannot provide any services.
You can use TFTP or FTP on the device to access the TFTP or FTP server to back up or download software files.
Using TFTP to upgrade system software
2.      Back up the running system software image and configuration file:
a.    Display current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  cfa0:/main-cmw710-boot-R8513.bin
  cfa0:/main-cmw710-system-R8513.bin
Main startup software images:
Backup startup software images:
  None
b.    Back up the current software images.
<Sysname> copy main-cmw710-boot-R8513.bin boot_backup.bin
<Sysname> copy main-cmw710-system-R8513.bin system_backup.bin
c.    Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin backup
d.    Execute the save command in any view to save the running configuration.
<Sysname> save
<Sysname>
e.    Execute the dir command in user view to identify the system software image and configuration file names and verify that the flash memory has sufficient space for the new system software image.
<Sysname> dir
Directory of flash: (VFAT)
   0 drw-           - Nov 15 2022 10:35:02   WEB
   1 -rw-         855 Nov 14 2022 17:56:08   cacert.crt
   2 drw-           - Nov 15 2022 15:06:50   context
   3 -rw-      512539 Oct 25 2022 20:11:38   defaultfile.zip
   4 drw-           - Nov 15 2022 15:12:58   diagfile
   5 drw-           - Mar 29 2022 09:28:26   dpi
   6 -rw-    10394091 Nov 10 2022 13:52:00   dq1.mdb
   7 -rw-         735 Nov 07 2022 11:17:40   hostkey
   8 -rw-   207949824 Nov 18 2022 14:14:20   l5000cn.ipe
   9 -rw-    34035712 Nov 16 2022 11:29:46   l5000cnade-cmw710-boot-E1160P29.bin
  10 -rw-   173906944 Nov 16 2022 11:29:48   l5000cnade-cmw710-system-E1160P29.bin
  11 drw-           - Mar 29 2022 19:48:06   lb
  12 -rw-      111720 Nov 18 2022 14:26:45   lbispinfo_v1.5.tp
  13 drw-           - Nov 14 2022 11:30:20   license
  14 -rw-        1645 Nov 14 2022 17:56:30   local.pfx
  15 drw-           - Mar 29 2022 09:41:20   logfile
  16 drw-           - Apr 02 2022 09:02:36   pcap
  17 drw-           - Apr 01 2022 16:11:10   pkey
  18 drw-           - Nov 14 2022 17:56:30   pki
  19 -rw-         800 Nov 18 2022 14:26:39   rbmSwitchInfoFile.dat
  20 drw-           - Sep 30 2021 03:57:36   seclog
  21 -rw-         591 Nov 07 2022 11:17:40   serverkey
  22 -rw-      271151 Nov 14 2022 15:45:16   startup.cfg
  23 -rw-     2144097 Nov 14 2022 15:45:16   startup.mdb
  24 -rw-      587148 Nov 09 2022 10:58:44   test.mdb
  25 drw-           - Nov 07 2022 11:37:44   versionInfo
  26 drw-           - Jun 30 2022 17:42:08   webtmp
  27 -rw-        8202 Nov 18 2022 14:17:42   zhu.cfg
  28 -rw-      557271 Nov 18 2022 14:17:42   zhu.mdb
7455012 KB total (6224148 KB free)
<Sysname>
f.     Execute the tftp put command in user view to upload the startup.cfg file to the TFTP server.
<Sysname> tftp 186.23.0.15 put startup.cfg vpn-instance management
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  3950    0     0  100  3950      0   204k --:--:-- --:--:-- --:--:--  642k
<Sysname>
3.      Upgrade the system software:
a.    Execute the tftp get command in user view to download the system software image file to the flash memory on the device.
<Sysname>tftp 186.23.0.15 get l5000cn.ipe
100  198M  100  198M    0     0  2231k      0  0:01:30  0:01:30 --:--:-- 2395k
Writing file...Done.
<Sysname>
b.    Execute the boot-loader file command in user view to load the l5000cn.ipe file and specify it as the main image file at the next reboot.
<Sysname> boot-loader file flash:/l5000cn.ipe all main
Verifying the file flash:/l5000cn.ipe on slot 1...Done.
H3C SecPath L5060-G images in IPE:
This command will set the main startup software images. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Add images to slot 1.
File flash:/l5000cnade-cmw710-boot-E1160P29.bin already exists on slot 1.
File flash:/l5000cnade-cmw710-system-E1160P29.bin already exists on slot 1.
Overwrite the existing files?[Y/N]:y
Decompressing file l5000cnade-cmw710-boot-E1160P29.bin to flash:/l5000cnade-cmw710-boot-E1160P29.bin...Done.
Decompressing file l5000cnade-cmw710-system-E1160P29.bin to flash:/l5000cnade-cmw710-system-E1160P29.bin...Done.
Verifying the file flash:/l5000cnade-cmw710-boot-E1160P29.bin on slot 1...Done.
Verifying the file flash:/l5000cnade-cmw710-system-E1160P29.bin on slot 1...Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
Decompression completed.
Do you want to delete flash:/l5000cn.ipe now? [Y/N]:n
<Sysname>
c.    Execute the display boot-loader command in user view to verify that the file has been loaded.
<Sysname>display boot-loader
<Sysname>
d.    Execute the reboot command in user view to reboot the device.
<Sysname>reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Start to check configuration with next startup configuration file in Context con
text1, please wait.........DONE!
Now rebooting, please wait...
…omitted…
e.    After the reboot is complete, execute the display version command to verify that the system software image is correct.
<Sysname> dis version
H3C Comware Software, Version 7.1.064, Ess 1160P29
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath L5060-G uptime is 0 weeks, 0 days, 21 hours, 35 minutes
Last reboot reason: User reboot
Boot image: flash:/l5000cnade-cmw710-boot-E1160P29.bin
Boot image version: 7.1.064, Ess 1160P29
  Compiled Oct 31 2022 14:00:00
System image: flash:/l5000cnade-cmw710-system-E1160P29.bin
System image version: 7.1.064, Ess 1160P29
SLOT 1
CPU type: Multi-core CPU
DDR4 SDRAM Memory      32768M bytes
NSQ1F5MSPUFTA(CPU)   PCB  Version:Ver.A
NSQ1F5ASPUA10A(Base) PCB  Version:Ver.A
NSQ1F5SWUCTCA(Front) PCB  Version:Ver.B
NSQ1F5MSPUFTA(CPU)   CPLD Version:  3.0
NSQ1F5ASPUA10A(Base) CPLD Version:  3.0
NSQ1F5SWUCTCA(Front) CPLD Version:  2.0
PowChip          Version:2.0
Basic  BootWare  Version: 1.04
Extend BootWare  Version: 1.04
HD PCB           Version:Ver.A
[SubSlot 0]12GE+4FGE+16XGE  (Hardware)Ver.A, (Driver)1.0, (Cpld)3.0
<Sysname>
Using FTP to upgrade system software
4.      Back up the running system software image and configuration file:
  None
<Sysname>
<Sysname> save
<Sysname>
<Sysname> dir
<Sysname>
f.     Execute the ftp command in user view to access the FTP server.
<Sysname> ftp 186.23.0.15
Connected to 186.23.0.15 (186.23.0.15).
220 3Com 3CDaemon FTP Server Version 2.0
User (186.23.0.15:(none)): admin
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
ftp>
g.    Execute the put command in FTP client view to upload the startup.cfg file to the FTP server.
ftp> put startup.cfg
227 Entering passive mode (186,23,0,15,26,3)
125 Using existing data connection
226 Closing data connection; File transfer successful.
3950 bytes sent in 0.001 seconds (4.13 Mbytes/s)
ftp>
5.      Upgrade the system software:
a.    Execute the get command in FTP client view to download the system software image file to the flash memory on the device.
ftp> get l5000cn.ipe
l5000cn.ipe already exists. Overwrite it? [Y/N]:y
227 Entering passive mode (186,23,0,15,220,177)
................................................................................................................................................................................................................................................................................................................................................................226 Closing data connection; File transfer successful.
207949824 bytes received in 22.808 seconds (8.69 Mbytes/s)
ftp>
b.    Execute the quit command in FTP client view to return to user view.
ftp> quit
221 Service closing control connection
<Sysname>
c.    Execute the boot-loader file command in user view to load the l5000cn.ipe file and specify it as the main image file at the next reboot.
<Sysname>
d.    Execute the display boot-loader command in user view to verify that the file has been loaded.
S Software images on slot 1:
<Sysname>
e.    Execute the reboot command in user view to reboot the device.
<Sysname>reboot
.......DONE!
…omitted…
f.     After the reboot is complete, execute the display version command to verify that the system software image is correct.
SLOT 1
PowChip          Version:2.0
<Sysname>
CAUTION:
·       You can use the default account settings or create a new account to log in to the Web interface for the first time. This section uses the default account settings. For security purposes, if you use the default account settings, modify the default password or create a new account and delete the default account after the first login.
·       Do not perform any operation on the Web interface while the system is upgrading software.
Table 6 describes the default settings for you to log in to the Web interface.
Login information
Default setting
Username
admin
Password
admin
IP address of GigabitEthernet 1/0/0
186.23. 0.15/16
The default management Ethernet port varies by device model. In this example, the default management Ethernet port is GigabitEthernet 1/0/0.
To upgrade the system software from the Web interface:
6.      Use an Ethernet cable to connect the PC to an Ethernet port on the device. As a best practice, connect the PC to the management Ethernet port on the device.
7.      Assign an IP address on the same subnet as the management port GigabitEthernet 1/0/0 to the PC.
In this example, assign 186.23.0.15 to the PC.
8.      Launch the Web browser, and enter 186.23.0.15 in the address bar.
The Web login page appears.
9.      Type the default username and password, and click Login.
10.    Select System > Upgrade Center > Software Upgrade from the navigation tree.
Figure 1 Software upgrade page
11.    Click Upgrade immediately on the Software Upgrade page.
12.    Select the startup file to be used, and click OK.
Figure 2 Upgrade Immediately page
You can upgrade the BootWare from the CLI or BootWare menus.
Whether a .btw file is compressed together with an .ipe file depends on the device model and software release. Please check it with H3C technical support. This section describes only how to upgrade the BootWare from the CLI.
To upgrade the BootWare from the CLI:
13.    Use FTP or TFTP to download or upload the new BootWare image file to the root directory of the storage medium on the device.
14.    Execute the bootrom update command to upgrade the BootWare.
<System> bootrom update flash:/ 8042f109039122_v1.01.btw slot 1
  This command will update bootrom file, Continue? [Y/N]:y
  Now updating bootrom, please wait...
 Updating basic bootrom!
 Update basic bootrom success!
 Updating extended bootrom!
 Update extended bootrom success!
 Update bootrom success!
<System>
15.    Execute the reboot command to reboot the device.
·       To upgrade the BootWare from an Ethernet interface through TFTP/FTP, make sure the password recovery capability is enabled.
·       To enable the password recovery capability, execute the password-recovery enable command. To disable the password recovery capability, execute the undo password-recovery enable command.
16.    Access the BootWare menu.
When the device starts up or reboots, the configuration terminal displays the following information:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing................................
Done.
*                   H3C SecPath BootWare, Version 1.04                     *
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd.
Compiled Date       : Mar  4 2021
Memory Type         : DDR4 SDRAM
Memory Size         : 32768MB
Flash Size          : 16MB
flash Size          : 7296MB
CPLD0 Version       : 3.0
CPLD1 Version       : 3.0
CPLD2 Version       : 2.0
PCB0 Version        : Ver.A
PCB1 Version        : Ver.A
PCB2 Version        : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Press Ctrl + B immediately when the Press Ctrl+B to access EXTENDED-BOOTWARE MENU... message is displayed.
You can identify whether the password recovery capability is enabled in the output information.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
The menu description is as follows:
Table 7 BootWare main menu
Option
<1> Boot System
Access the boot file.
Access the serial port submenu.
Access the Ethernet interface submenu.
<4> File Control
Access the file control submenu.
Restore factory defaults.
 CAUTION:
·          For this operation to take effect, make sure the password recovery capability is disabled.
·          After you restore factory defaults, the system will delete the current configuration file and start with initial configuration. Use this feature with caution.
Start the system with the current configuration skipped. This is a one-off operation and is typically used when a user forgets the password.
For this operation to take effect, make sure the password recovery capability is enabled.
Access the BootWare operations submenu.
Start the system without console port authentication. This is a one-off operation and is typically used when a user forgets the console password.
Access the storage control menu.
<0> Reboot
Reboot the device.
17.    Press 7 in the BootWare menu to access the BootWare operations menu.
=========================<BootWare Operation Menu>==========================
|Note:the operating device is flash                                        |
|<1> Backup Full BootWare                                                  |
|<2> Restore Full BootWare                                                 |
|<3> Update BootWare By Serial                                             |
|<4> Update BootWare By Ethernet                                           |
|<0> Exit To Main Menu                                                     |
Enter your choice(0-4):
Table 8 BootWare operations menu
Option
Back up complete BootWare.
Restore complete BootWare.
Upgrade BootWare through the serial port.
Upgrade BootWare through the Ethernet port.
Return to the BootWare main menu.
18.    Press 4 to access the BootWare operations Ethernet interface submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare                                                  |
|<2> Update Extend BootWare                                                |
|<3> Update Basic BootWare                                                 |
|<4> Modify Ethernet Parameter                                             |
Table 9 BootWare operations Ethernet submenu
Option
Upgrade complete BootWare.
Upgrade extended BootWare.
Upgrade basic BootWare.
Edit Ethernet interface parameters.
19.    Press 4 to enter the Ethernet interface configuration menu.
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :ftp
Load File Name         :l5000cn.ipe
Target File Name       :l5000cn.ipe
Server IP Address      :186.23.0.15
Local IP Address       :186.23.15.116
Subnet Mask            :255.255.0.0
Gateway IP Address     :186.23.0.1
FTP User Name          :admin
FTP User Password      :******
Table 10 Ethernet parameters
'.' = Clear field
Press the dot (.) to clear the setting for a field.
Press the hyphen (-) to return to the previous field.
Ctrl+D = Quit
Press Ctrl and D to exit the parameter configuration interface.
Transfer protocol, which can be FTP or TFTP.
Load File Name
Name of the file to be downloaded.
Target File Name
Name of the software image file. By default, the name is consistent with the downloaded file name.
Server IP Address
IP address of the TFTP or FTP server.
Local IP Address
Local IP address, which is the IP address of the Ethernet interface used for upgrade.
Gateway IP Address
Gateway IP address. Configure the gateway IP address if the device and the FTP server do not belong to the same subnet.
For example, to upgrade complete BootWare, press 1 in the BootWare operations Ethernet submenu.
Enter your choice(0-4): 1
Loading............Done!
418156 bytes downloaded!
Updating Basic BootWare? [Y/N]Y
Updating Basic BootWare...........Done!
Updating Extend BootWare? [Y/N]Y
Updating Extend BootWare...........Done!
After the upgrade completes, return to the BootWare main menu, and then press 0 to reboot the system.
Press 4 in the BootWare main menu to access the file control submenu. From this submenu, you can view all files in the flash memory, configure the startup file type, and delete files.
===============================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Image File type                                                   |
|<3> Set Bin File type                                                     |
|<4> Set Configuration File type                                           |
|<5> Delete File                                                           |
|<6> Copy File                                                             |
Enter your choice(0-6):
Option
Displaying all files
Configure the .ipe file type
Configure the .bin file type
The .bin file is decompressed from the .ipe file.
Configure the configuration file type
<5> Delete File
Delete files
<6> Copy File
Copy file
Press 1 in the file control submenu to display all files
Display all file(s) in flash:
 'M' = MAIN      'B' = BACKUP      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   642       Nov/18/2022 14:28:38 N/A    flash:/.trash/.trashinfo        |
|2   267       Apr/02/2022 09:48:26 N/A    flash:/.trash/lb.lua_0001       |
|3   248       Apr/02/2022 09:50:54 N/A    flash:/.trash/lb1.lua_0001      |
|4   207534080 Nov/09/2022 10:56:56 N/A    flash:/.trash/l1000gcn.ipe_0001 |
|5   179872768 Oct/26/2022 11:13:38 N/A    flash:/.trash/l1000gcn_ade.ipe_0|
|001        |
|6   17787904  Oct/26/2022 13:51:32 N/A    flash:/.trash/l1000gcnade-unw710|
|-boot-f1160p1615.bin_0001                                                 |
|7   162077696 Oct/26/2022 13:52:08 N/A    flash:/.trash/l1000gcnade-unw710|
|-system-f1160p1615.bin_0001                                               |
|8   207145984 Oct/26/2022 14:05:28 N/A    flash:/.trash/l5000gcn.ipe_0001 |
|9   747665    Nov/10/2022 13:52:00 N/A    flash:/.trash/dq1.cfg_0001      |
|10  11851     Nov/09/2022 10:58:44 N/A    flash:/.trash/test.cfg_0001     |
|11  120346    Nov/15/2022 15:21:26 N/A    flash:/.trash/diag_sysname_20221|
|115-152025.tar.gz_0001                                                    |
|12  800       Nov/18/2022 14:29:16 N/A    flash:/rbmswitchinfofile.dat    |
|13  111720    Nov/18/2022 14:26:44 N/A    flash:/lbispinfo_v1.5.tp        |
|14  271151    Nov/14/2022 15:45:16 N/A    flash:/startup.cfg              |
|15  2144097   Nov/14/2022 15:45:16 N/A    flash:/startup.mdb              |
|16  941       Jun/30/2022 17:41:56 N/A    flash:/license/history/deviceid_|
|20220630174157.did                                                        |
|17  978       Oct/25/2022 20:11:54 N/A    flash:/license/history/deviceid_|
|20221025201155.did                                                        |
|18  941       Sep/30/2021 03:57:36 N/A    flash:/license/210235a2jnb20c000|
|008.did        |
|19  941       Oct/25/2022 20:11:54 N/A    flash:/license/210235a43rb20c000|
|008.did        |
|20  965       Oct/27/2022 16:28:06 N/A    flash:/license/210235a4g5b20c000|
…omitted…
|<5> Delete File                                                           |
|<6> Copy File                                                             |
Configuring the .ipe startup file type
20.    Press 2 in the file control submenu to configure the startup file type:
|1   207949824 Nov/18/2022 14:14:20 N/A    flash:/l5000cn.ipe              |
|0   Exit        |
21.    Enter the number of the file to be edited, and then press Enter. Then, you can edit the file type.
Modify the file attribute:
|<1> +Main        |
|<2> +Backup                                                               |
|<0> Exit        |
Enter your choice(0-2):
22.    Enter the number of the target file type. For example, to set the file type to main, enter 1.
Enter your choice(0-2):1
This operation may take several minutes. Please wait....
The file is exist,will you overwrite it? [Y/N]Y
Image file l5000cnade-cmw710-boot-E1160P29.bin is self-decompressing...
Saving file flash:/l5000cnade-cmw710-boot-E1160P29.bin .....................
......Done.
Image file l5000cnade-cmw710-system-E1160P29.bin is self-decompressing...
Saving file flash:/l5000cnade-cmw710-system-E1160P29.bin ...................
.........................................Done.
Set the file attribute success!
Configuring the .bin startup file type
Press 3 in the file control submenu to configure the startup file type:
|1   34035712  Nov/18/2022 14:35:02 M+B    flash:/l5000cnade-cmw710-boot-e1|
|160p29.bin        |
|2   173906944 Nov/18/2022 14:35:10 M+B    flash:/l5000cnade-cmw710-system-|
|e1160p29.bin                                                              |
|0   Exit        |
Note:Select .bin files. One but only one boot image and system image must
be included.
Enter file No.(Allows multiple selection):1
Enter another file No.(0-Finish choice):2
Enter another file No.(0-Finish choice):0    //0 indicates stopping file selection
You have selected:
flash:/l5000cnade-cmw710-boot-e1160p29.bin
flash:/l5000cnade-cmw710-system-e1160p29.bin
|<1>+Main        |
|<2>+Backup        |
|<0> Exit        |
Deleting files
23.    Press 5 in the file control submenu to delete file:
Deleting the file in flash:
|001        |
|008.did        |
|008.did        |
|008.did        |
…omitted…
|0   Exit        |
Enter file No.:
24.    Enter the number of the file to be deleted, and then press Enter. The system displays the following information if the file is deleted successfully:
Enter file No.:3
The file you selected is flash:/.trash/lb1.lua_0001,Delete it? [Y/N]Y
Deleting...Done.
If a software upgrade fails, the system runs the old software version. To handle a software failure:
1.      Check the physical ports for a loose or incorrect connection, and verify that the LEDs are reflecting the correct port status.
2.      If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
3.      Check the file transfer settings:
¡  If Xmodem is used, make sure the HyperTerminal and the console port are consistent in baud rate.
¡  If TFTP is used, you must enter the same TFTP server IP address, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, file name, working directory, and FTP username and password as set on the FTP server.
4.      Check the FTP or TFTP server for incorrect settings.
5.      Check that the flash memory has sufficient space for the upgrade file.
6.      If the message "Something is wrong with the file" appears, check the file for file corruption.
