IPS Signature V7-IPS-1.0.393
Release time:2026-02-02
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-IPS-1.0.393.dat 17.53 MB
Version number
V7-IPS-1.0.393
MD5 number
71a106f2625a3ef8e848527bf711c8a3
Update time
2026-01-29
Update attack list
Key new rules:
57076  CVE-2025-59718_Fortinet_FortiOS_and_FortiProxy_Authentication_Bypass_Vulnerability[2]
---- Category: Vulnerability
---- Description: Multiple Fortinet products have a data forgery vulnerability, which originates from improper encrypted signature
---- verification and could potentially allow bypassing FortiCloud SSO authentication.
57094  CVE-2025-55523_Agent_Zero_Arbitrary_File_Download_Vulnerability[2]
---- Description: Agent Zero is an artificial intelligence framework developed by Jan, an individual developer. Agent Zero v0.8
---- contains a security vulnerability stemming from a directory traversal flaw in the /api/download_work_dir_file.py component.
57092  CVE-2026-24061_GNU_Inetutils_Telnetd_Authentication_Bypass_Vulnerability[2]
---- Description: GNU Inetutils is a set of open-source tools for network communication, among which telnetd is the Telnet service
---- daemon it provides, used for remote login functionality. GNU Inetutils has an authentication bypass vulnerability that allows
---- unauthenticated users to log in to the server with root privileges and execute arbitrary commands in the background.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 4GB. After loading the IPS rules library file of this version, 26428 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is equal to 4GB. After loading the IPS rules library file of this version, 15399 predefined rules can be generated in "Intrusion Prevention System"
[5] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3296 predefined rules can be generated in "Intrusion Prevention System"
