| Title | Size | Downloads |
| V7-IPS-1.0.392.dat | 17.51 MB |
Version number
V7-IPS-1.0.392
MD5 number
a37d3f4c746fd019165d23c3e8a9fdb4
Update time
2026-01-22
Update attack list
Key new rules:
57060 CVE-2025-68493_Apache_Struts2_XXE_Vulnerability[2]
---- Category: Vulnerability
---- Description: Apache Struts is an open-source project of the Apache Foundation in the United States. It is an open-source
---- MVC framework used for creating enterprise-level Java Web applications, mainly offering two framework versions, Struts 1
---- and Struts 2. Versions of Apache Struts 2 from 2.0.0 to 2.3.37, 2.5.0 to 2.5.33, and 6.0.0 to 6.1.0 have security vulnerabilities.
---- These vulnerabilities are due to the lack of XML validation, making them susceptible to XML External Entity (XXE) injection
---- attacks.
57069 CVE-2025-68613_N8n_Remote_Code_Execution_Vulnerability[2]
---- Description: n8n is an open-source, scalable workflow automation tool. Versions of n8n from 0.211.0 to 1.120.4, 1.121.1,
---- and versions prior to 1.122.0 contain a security vulnerability stemming from insufficient isolation in the workflow expression
---- evaluation system, which could lead to remote code execution.
57056 CVE-2025-63387_Dify_Unauthorized_Access_Vulnerability[2]
---- Description: Dify is an open-source LLM application development platform developed by LangGenius. Dify version 1.9.1 contains
---- a security vulnerability stemming from improper permissions, which could lead to unauthorized access to system configuration
---- data.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 4GB. After loading the IPS rules library file of this version, 26420 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is equal to 4GB. After loading the IPS rules library file of this version, 15365 predefined rules can be generated in "Intrusion Prevention System"
[5] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3296 predefined rules can be generated in "Intrusion Prevention System"
