Title | Size | Downloads |
V7-IPS-1.0.369.dat | 16.46 MB |
Version number
V7-IPS-1.0.369
MD5 number
11b724ec5dd0c3daf31974a7f9080906
Update time
2025-07-30
Update attack list
Key new rules:
56096 JeeWMS_commonController.do_XXE_Vulnerability[2]
---- Category: Vulnerability
---- Description: JeeWMS is a JAVA based warehouse management system developed by JeeWMS, a Chinese company. The JeeWMS system
---- interface commonController. do has an XXE injection vulnerability, which can be exploited by attackers to perform high-risk
---- and sensitive operations.
56092 CVE-2025-7824_Jinher_OA_C6_XmlHttp.aspx_XXE_Vulnerability[2]
---- Description: Jinher OA is a collaborative management software developed by Jinher Corporation in China. Jinher OA version
---- 1.1 has a code issue vulnerability, which arises from an erroneous operation on the file XmlHttp.xml, resulting in an XML
---- external entity reference.
56093 CVE-2025-7823_Jinher_OA_C6_ProjectScheduleDelete.aspx_XXE_Vulnerability[2]
---- 1.2 has a code issue vulnerability, which arises from an erroneous operation on the file ProjectScheduleDelete.xml, resulting
---- in an XML external entity reference.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 25734 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3326 predefined rules can be generated in "Intrusion Prevention System"
