IPS Signature V7-IPS-1.0.368
Release time:2025-07-29
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-IPS-1.0.368.dat 16.44 MB
Version number
V7-IPS-1.0.368
MD5 number
055e960dcf9963b01538b0fa85f1e4e9
Update time
2025-07-28
Update attack list
Key new rules:
56056  Yonyou_U8Cloud_LoginVideoServlet_Remote_Code_Execution_Vulnerability[2]
---- Category: Vulnerability
---- Description: Yonyou U8Cloud is a new generation cloud ERP solution launched by
---- Yonyou Network Technology Co., Ltd. Yonyou U8Cloud has a code execution vulnerability
---- in the/LoginVideoServlet interface, which can be exploited by unauthenticated
---- attackers to deserialize and execute arbitrary code.
56062  CVE-2025-32429_XWiki_Platform_getdeleteddocuments.vm_SQL_Injection_Vulnerability[2]
---- Description: XWiki Platform is an enterprise level open-source Wiki and knowledg
---- e management platform based on Java. There is an SQL injection vulnerability
---- (CVE-225-32429) in the XWiki getdeleteddocuments-vm interface, which allows attackers
---- to manipulate database queries by injecting SQL statements through the sort parameter
---- of getdeleteddocuments-vm, resulting in serious consequences such as data leakage,
---- data tampering, or denial of service.
56054  Dahua_Smart_Park_Integrated_Management_Platform_Xstream_cascade_modifyLinkedDev_deserialization_code_execution_vulnerability[2]
---- Description: Dahua Smart Park Comprehensive Management Platform is a comprehensive
---- management platform that has functions such as park operation, resource allocation,
---- and intelligent services. Dahua DSS has a code execution vulnerability in the
---- access_madifyOrg.action interface, which can be exploited by unauthenticated attackers
---- to execute arbitrary code.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 25710 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3326 predefined rules can be generated in "Intrusion Prevention System"
