Title | Size | Downloads |
V7-IPS-1.0.360.dat | 16.27 MB |
Version number
V7-IPS-1.0.360
MD5 number
89dfc32227f0e30f0d6e6694591444e6
Update time
2025-07-09
Update attack list
Key new rules:
55759 CVE-2025-32023_Redis_HyperLogLog_Remote_Code_Execution_Vulnerability[2]
---- Category: Vulnerability
---- Description: Redis is an open-source database written in ANSI C, supported by the network, based on memory and persistent logs,
---- key-value storage databases, and provides APIs in multiple languages. When Redis processes hyperloglog operations, because the input is not strictly validated,
---- an attacker can construct malicious data to cause an integer overflow during index accumulation, bypassing bounds checking,
---- and eventually triggering out-of-bounds writes to heap memory, which may lead to remote code execution.
55789 CVE-2025-32813_Infoblox_NETMRI_saml_id_Command_Injection_Vulnerability[2]
---- Description: Infoblox NetMRI is an enterprise-level solution for network automation and management.
---- A command injection vulnerability has been reported in Infoblox NETMRI. The vulnerability is due to insufficient validation of the saml_id parameter.
---- Remote unauthenticated attackers can exploit this vulnerability by sending a specific HTTP request.
---- Successful exploitation would allow an attacker to execute remote code and gain control of the server.
55806 CVE-2025-7081_Belkin_F9K1122_formSetWanStatic_Command_Injection_Vulnerability[2]
---- Description: A command injection vulnerability has been reported in Belkin F9K1122. The vulnerability is due to improper validation of requests send by users to the formSetWanStatic interface.
---- A remote attacker could exploit this vulnerability by sending a crafted request to the target server. Successful exploitation could allow attackers to execute arbitrary command in the context of system.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 25451 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
