Title | Size | Downloads |
V7-IPS-1.0.359.dat | 16.24 MB |
Version number
V7-IPS-1.0.359
MD5 number
cfb91f6dea10870046cd770714eeb1da
Update time
2025-07-07
Update attack list
Key new rules:
55755 Yonyou_Chanjet_T+_AccountClearControler_SQL_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: Chanjet Tplus is a financial and business integration application mainly targeting small and medium-sized industrial and commercial enterprises.
---- Changjietong T+ has a SQL injection vulnerability, through which an attacker can obtain sensitive information and even cause the system to be completely controlled.
55722 EasySite_replication_Template_Injection_Vulnerability[2]
---- Description: EasySite Content Management System is a professional portal content management system developed by ZKHUILIAN.
---- There is a template injection vulnerability in the EasySite replicatione interface, which originates from the failure of the replication interface to adequately filter the submitted data,
---- and can be exploited by an attacker to execute arbitrary code.
55750 Yonyou_Chanjet_GetisInitBCRetail_SQL_Injection_Vulnerability[2]
---- Description: Changjie Tong T+ is a cloud-based ERP management software for small and medium-sized enterprises.
---- An SQL Injection vulnerability has been reported in Yonyou Chanjet. This vulnerability is due to insufficient validation of the accNum parameter by the application.
---- A remote attacker could exploit this vulnerability by sending a specific HTTP request. Successful exploitation of this vulnerability would allow
---- an attacker to append additional SQL queries to existing queries, which could be used to extract sensitive information from the database.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 25383 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
