Title | Size | Downloads |
V7-IPS-1.0.358.dat | 16.21 MB |
Version number
V7-IPS-1.0.358
MD5 number
fe3f74dc7f4d884f86ed1d204030a448
Update time
2025-07-04
Update attack list
Key new rules:
55706 Kingdee_EAS_AutoLogin_Code_Execution_Vulnerability[2]
---- Category: Vulnerability
---- Description: Kingdee EAS autoLogin has a code execution vulnerability. Attackers can exploit this vulnerability to execute arbitrary code and obtain server privileges.
55710 DCME-320_black_list.php_Aribitary_File_Read_Vulnerability[2]
---- Description: he DCME-320 is a new-generation high-performance Internet egress gateway.An aribitary file read vulnerability has been reported in DCME-320. The vulnerability
---- is due to insufficient validation of the proxy_request parameter entered by the user by the application. Remote unauthenticated attackers can exploit this vulnerability by sending
---- specific HTTP requests. Successful exploitation would allow an attacker to read important system files to obtain sensitive information.
55694 Glodon_OA_linkworks_Sensitive_Information_Disclosure_Vulnerability[2]
---- Description: Guanglianda Linkworks Office Automation is a comprehensive office automation solution aimed at improving work efficiency and collaboration capabilities within
---- an organization. It provides a series of functions and tools to help enterprises manage and handle daily office tasks, processes, and documents. Due to sensitive information leakage
---- in its GetOrgUserList and other interfaces, attackers exploit this vulnerability to obtain account and password hashes and enter the backend.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 25338 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
