Title | Size | Downloads |
V7-WAF-1.0.40.dat | 2.20 MB |
Version number
V7-WAF-1.0.40
MD5 number
0c6fb986ba7dac3c95e155a2d7251f68
Update time
2025-05-22
Update attack list
Key new rules:
49620 CVE-2025-22214_Landray_EIS_Intelligent_Collaboration_Platform_Fi_Message_Receiver.Aspx_SQL_Injection_Vulnerability
---- Category: Vulnerability
---- Description:
---- Landray EIS is a comprehensive intelligent collaboration platform from China's Landray company. Landray EIS 2001 to 2006 has a security vulnerability due to the vulnerability to SQL injection attacks.
49623 Ant-Sword_Webshell_Trojan_Upload_(php_create_function_script)
---- Description:
---- This feature detects the upload of the Antsword webshell Trojan (php_create_function_script).
49632 CVE-2025-2030_Seeyon_Internet_FE_Collaborative_Office_Platform_SQL_Injection_Vulnerability
---- Description:
---- Seeyon Internet FE Collaborative Office Platform is a collaborative office platform software of BeiJing Seeyon Internet in Beijing, China, which is used for collaborative office and information sharing within enterprises. There is a security vulnerability in Seeyon Internet FE Collaborative Office Platform 20250224 and earlier versions, which is caused by SQL injection due to incorrect operation of the parameter groupId.
49645 CVE-2025-27636_Apache_Camel_Arbitrary_Command_Execution_Vulnerability
---- Description:
---- Apache Camel is an open source Integration framework based on Enterprise Integration Pattern(Enterprise Integration Pattern, referred to as EIP) from the Apache Foundation. The framework provides an implementation of Java objects (POJOs) in the enterprise integration pattern, and the rules for routing and mediation are configured through application program interfaces. Apache Camel has a security vulnerability that stems from an error in the default filtering mechanism that resulted in a bypass or injection attack.
