Title | Size | Downloads |
V7-IPS-1.0.346.dat | 15.78 MB |
Version number
V7-IPS-1.0.346
MD5 number
cf1caa658f2a6ad37b7bb40fdbc21bff
Update time
2025-04-10
Update attack list
Key new rules:
54861 CVE-2025-29635_D-Link_DIR-823X_AX3000_Series_Router_Command_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: The D-Link DIR-823X is a wireless router from the Chinese company D-Link.
---- D-Link DIR-823X versions 240126 and 240802 have a security vulnerability that stems from an authorized attacker
---- triggering remote command execution by sending a POST request to /goform/set_prohibiting.
54865 CVE-2025-1648_WordPress_Yawave_Plugin_Unauthorized_SQL_Injection_Vulnerability[2]
---- Description: Both WordPress and WordPress plugin are products of the WordPress Foundation.
---- WordPress is a blogging platform developed using the PHP language. The platform supports hosting personal blog sites
---- on PHP and MySQL servers. The WordPress plugin is an application plugin. The WordPress plugin Yawave 2.9.1 and earlier
---- has an SQL injection vulnerability that stems from potentially allowing unauthenticated users to extract sensitive information.
54824 CVE-2025-2945_pgAdmin4_Command_Injection_Vulnerability[2]
---- Description: PgAdmin is an open-source management and development platform for the PostgreSQL database.
---- There is a security vulnerability in pgAdmin 4 before 9.2, which arises from the unsafe passing of parameters
---- to the eval function, which may result in remote code execution.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 24635 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
